Hi everyone,
I've made a LC short-lived process, that I'll call using SOAP (as a WebService) :
It's a simple process which accepts a username to look for (string) as input and returns two strings (user ID and username found).
I've created another application with a form in which i linked this corresponding wsdl file.
My problem is when I try to invoke the service (using a button in my form), I got an error approximately 30 seconds after, because the request timed out.
Is there a way to extend the timeout for a soap request inside a pdf form ?
Kind regards,
Thomas
Yes the form is reader extended to allow web services call ... But i've found a "solution"
I changed my webservice to make a direct query in the LiveCycle database, this way it is faster.
Then i made the call programatically in JavaScript. Now everything's working.
I've got a question though :
When I use the findUser operation, it took like 90 seconds to retrieve the corresponding users as an xml list.
When I use a direct Query multiple row (I wrote the sql request myself), it took like 5 secondes to retrieve the corresponding users as an xml list (with the same informations)
Why is the findUser operation so slow ? What does it do behind ?
Thomas
