Have Alerts been moved from mx.controls?
May 7, 2011 4:49 PM
I copy and pasted this import mx.controls.Alert; from: http://help.adobe.com/en_US/flex/using/WS2db454920e96a9e51e63e3d11c0bf 69084-7da0.html
Why? because everytime I typed inimport mx.controls.Alert give me the error: The import Alert could not be found.
And in fact even copying and pasting that peice of code from the web site I still get the same error....
So I ask, its it not apart of the mx.controls package?
    May 7, 2011 11:16 PM   in reply to Adrien.
    Why?  Because it is Saturday and fewer people work on Saturday.
    What version of Flex?  If it is a recent version, is the mx.swc in the
    library path?
    May 8, 2011 10:48 PM   in reply to Adrien.
    Do you have a 20-line test case that fails for you?
    May 23, 2011 2:57 AM   in reply to Flex harUI
    as said in this post i externally add mx.swc in my project .my project .swc is deleted and i can't able to run the project.
    so how to achive this ?
    i want to dispaly alert in my project and i am using Spark
    Thanks & Regrads
    Megha
    May 23, 2011 3:00 PM   in reply to Megha31
    Post  a 20-line test case that fails.
    May 23, 2011 10:26 PM   in reply to Flex harUI
    i am new to flex so sorry for asking this  where i find 20-line test case ?
    May 24, 2011 7:46 AM   in reply to Megha31
    You create one yourself.
    May 25, 2011 9:44 PM   in reply to Flex harUI
    <?xml version="1.0" encoding="utf-8"?>
    <s:View xmlns:fx="http://ns.adobe.com/mxml/2009"
            xmlns:s="library://ns.adobe.com/flex/spark"
            xmlns:mx="library://ns.adobe.com/flex/mx"
            title="AlertDialog">
        <fx:Declarations>
            <!-- Place non-visual elements (e.g., services, value objects) here -->
        </fx:Declarations>
        <fx:Script>
            <![CDATA[
                protected function btn2_clickHandler(event:MouseEvent):void
                    var ale:Alert = Alert.show("This is a ALert");
        </fx:Script>
        <s:Button label="Show alert (with moduleFactory)" id="btn2" click="btn2_clickHandler(event)" />
    </s:View>
    this is my code but it not working.i add explicitly mx.swc but my project.swc file is deleted so now i have to do to  display alert in my project.
    May 26, 2011 11:49 AM   in reply to Megha31
    You are using s:View which implies you are building a Mobile app and Alert
    is not recommended for mobile apps.  Try using SkinnablePopUpContainer.
    May 26, 2011 9:27 PM   in reply to Flex harUI
    hi
    ya i am devloping mobile application.
    i want to dispaly alert and pop-up on my application.
    in my application i have to display alert and pop-up so give me any solution for that.
    can you give example of SkinnablePopUpContainer?
    Thanks & Regards
    Megha
    May 26, 2011 10:46 PM   in reply to Megha31
    A google search of SkinnablePopUpContainer promises some examples.
    May 27, 2011 3:58 AM   in reply to Adrien.
    I am using flash builder 4.5 and i am unable to call alert from an action script file?
    I am not building mobile application but compiler is still unable to find it in mx.controls package.
    May 27, 2011 9:59 AM   in reply to harissarwar
    Make sure mx.swc is one of the libraries in the project, and make sure you
    import the class.
    May 30, 2011 9:49 AM   in reply to Flex harUI
    My project settings were to use only spark components. when i switch the settings to mx+spark then alert was found.
    May 30, 2011 9:46 PM   in reply to harissarwar
    i import the import mx.alerts then also it give error on page
    May 30, 2011 11:24 PM   in reply to Megha31
    If you are having trouble getting Flash Builder to configure propertly, try
    asking on the Flash Builder forum.  If you have a 20-line project with
    mx.swc in it and you can't get it to recognize Alert after importing
    mx.control.Alert, then post the project.
    Jun 17, 2011 12:07 PM   in reply to Adrien.
    I have the same problem :(
    I don't know why it doesn't work...
    Error 1172: Definition mx.controls:Alert could not be found.
    I have Flash Builder 4.5
    I solved the problem. I just checked the settings I changed the MX Spark + Spark
    Oct 10, 2011 5:25 PM   in reply to Flex harUI
    Wow, really? It's "recommended" that, if we're working on a mobile app, we replace two lines of code (an important statement and an event handler) with what's written here  SkinnablePopUpLayer? I just want basic error output without having to attach a debugger; do you have a more elegant alternative?
