There's a new Nvidia 580gtx graphics card with displayport output available on Newegg.
This is the only gtx 580 with displayport in the USA. Gainward has one available in Europe:
http://www.gainward.com/main/vgapro.php?id=452
There are also finally GTX 570 cards with displayport as well.
All of these should allow good Cuda acceleration in Adobe Premiere and also (eventually) allow for 10bit color support for Photoshop.
Soon, the NEC PA301w 30" monitor with 10bit color support will be available.
It would be really great if the Nvidia driver supports 10bit color from the Geforce display driver. I'm sure this may take some time to work out for the lowly geforce but at least theoretically - the hardware support is finally there. Photoshop supports 10bit, the monitor supports 10bit, Displayport allows 10bit color, but the Nvidia driver is now the only limiation!
Please Adobe, look into this combination and ask Nvidia to release working Geforce drivers for the GTX 580 and 10bit Photoshop support.
Thanks.
@Orbidia,
Would you happen to know if the Quadro 2000 supports 10bit color? Given that it is less expensive than the GTX 580 and also has dual DisplayPorts.
The NVidia site is lacking and the forums do not help
This document
http://www.nvidia.com/docs/IO/40049/NV_DS_QUADRO_2000_US_LR.pdf
Says it does, but with NVidia what the PDF says and what the driver does seems to be two different things.
I was planning on getting the Quadro and the PA241W
Well, I don't have the 10bit monitor. But I can tell that the Geforce drivers don't support 10bit yet.
I went to the Nvidia Control Panel and according to the Nvidia Geforce driver manual, there should be a "Deep Color" option under:
3D Settings - Manage 3D Settings
Either the Global Settings or Propram Settings Tab should show "Deep Color" option directly under the "CUDA - GPUs" option
But its not there even with the 580gtx card installed and the latest beta 266.35 driver. I suppose MAYBE if I plug in a deep color TV through HDMI or a true 10bit panel through displayport, the option could suddenly appear... But I seriously doubt it.
Luckily I mostly bought this card for CUDA support in Premiere.
Hopefully, this Photoshop 10bit issue gets resolved eventually since Nvidia manual claims it should work in the manual!
Hopefully you will be able to see the image, I am told, the drivers for the Quadros have the following. Under Manage 3D Settings, you should have a Force 10 bits per component. That preset must be selected. This is from PNY tech support. I have purchased a Quadro 2000 which I found cheaper than most GTX cards. It was temporary out of stock, but once it comes in, I will see what happens. Otherwise, I am going to switch to the FirePro cards and be done with it. it seems in all cases, it is not exactly perfect so I am not sure that 10bit is exactly cooked yet. I believe in regards to 10bit, if you go that path, you are an early adopter and you have to decide if it is worth the trouble. In the meantime, I love my PA241W
I'm here to furthur muddy the waters!
I have been looking into using a 10bbp workflow. After reading this thread I emailed nVidia and Palit about the gtx470, and its potential for using 'deep color'.
Here are the responses I got, both from Palit:
Hello !. I work with Photoshop CS5 x64, Windows 7 x64, ATI FirePro V3800, Nec monitor PA271W (Display Port).
I didn't have any problem about 10 bit support in the past. Now (I just installed Service Pack 1 and update to ACR 6.4) I can't see more 10 bit when I open 10 bit test ramp image in CS5. ATI driver is the last. Settings in CS5 about Open GL are correct.
When I restart Windows after enable 10 bit in ATI Panel, I can see 10 bit activated because Windows bar is not more trasparent but coloured. I open CS5 and 10 bit test ramp image but I see image in 8 bit. Why I can't more view correctly 10 bit test ramp image in CS5?
ATI's latest drivers (Catalyst 11.3 and 11.4) don't allow Photoshop to use OpenGL operations in Normal and Advanced modes. ATI knows about it, but they're taking their time to fix it. Revert to Catalyst 11.2 to regain this functionality, which will involve uninstalling ATI Catalyst entirely first, then installing 11.2.
-Noel
Which driver do you mean to reinstall?
The last is 8.773.1.1
http://support.amd.com/us/gpudownload/fire/Pages/fire_win7-64.aspx
Previous are these:
http://support.amd.com/us/gpudownload/fire/previous/Pages/fire_win7-64 .aspx
I reinstalled 8.773
I have everything updated. Nec PA271W has 10 bit panel. Video card is ATI FirePro V3800, and it supports 10 bit with its driver. Ati driver is the last version 8.773.1.1000. So the issue is an update (ATI or CS5) since I saw 10 bit test ramp without banding. I rolled back to previous driver ATI, but the bunding still is visible. So the issue is a CS5 update after 12.0
I can confirm that 10 bit color works fine in PS 12.0.4, just like it did in 12.0.3, so "NEC271" the problem is on your end. I have an ATI FirePro V4800 with the driver info below:
Note that if any 'element' of the taskbar (pop up, jump list, whatever) appears over the Photoshop window, the banding will appear until that element is no longer over the PS window. Also, if you hold down the left mouse button in certain areas within PS (the top bar of any of Photoshop's child windows {e.g. the Navigator window} qualify) the banding will appear. I assume it is possible for other scenarios to also break the 10 bit color pipeline.
Since you said you had 10 bit working before, I assume you already have this set:
I have Win 7 64 bit, in the event that makes any difference.
I don't know what else to check. I just updated ATI driver to 8.773.1.2 version, but I also rolled back to previous 8.773. and 8.773.1. and 8.773.1.1. CS5 version is 12.0.4. Windows 7 x64 is daily updated. I'm sure that no element of taskbar appears over the PS windows. What else should I check? I know a few people in the same situation.
Are you using the display port connection? (because DVI and VGA aren't going to do 10 bits)
Beyond that, you need to check with ATI and the display manufacturer - for some reason the driver thinks that you can't support 10 bit/channel, and Photoshop relies on the information it gets from the driver.
I just wanted to repeat this here on the second page of the thread, since (partly because of my miscue) the original conditions of your problem may not be well known by the respondents.
Just to be clear, with Photoshop 12.0.3, before installing Windows 7 service pack 1 you were seeing 10 bit operation, right? Was the transition from 10 bit working to not working exactly at that point?
You've been trying various driver versions... Are you doing a complete uninstall / reboot before installing a new copy of the driver?
-Noel
I bought Nec PA271W and ATI FirePro V3800 in October 2010. ATI driver was 8.773 and CS5 was 12.0 or 12.0.1 I think.
I installed monitor and Ati card for the first time and i could see 10 bit color. I use 10 bit operation for about a month without any problem. Then I didn't use it. So a few weeks ago I liked to use 10 bit again. In the meantime ATI driver was 8.773.1.1, CS5 was 12.0.2 or 12.0.3 and Windows 7 x64 was SP1. I opened CS5 and it appears banding.
Yes, when I tried ATI old drivers, I complete unistall previous by Control Panel.
I have almost the same setup like you (ATI FirePro V5800, Current AMD/ATI driver, NEC PA241W, Connected via DisplayPort)
I also use the latest patches for: ATI driver, Windows 7 (64 Bit) and Adobe PS5 (12.0.4) at my office
--> and my "ramp.psd" - as well as all other 16 Bit Images is rendered smoothly (you can well differ between the 2 setting 8 Bit and 10 Bit).
So in general the setup should still work fine - I personally deactivated the process before, that stops Win7 from using the Aero-Profile
--> that indeed stopped the 10 Bit feature from working ...(?)
Still some annoyances here ...
Best regards
Roland
Hi again,
here: http://support.amd.com/us/gpudownload/fire/Pages/fire_win7-64.aspx#2
you can download the latest (non WHQL certified) driver from AMD/ATI ... (this - latest - driver is version 8.83.5.4)
... maybe you can correct the issue that way - has to be something with you specific machine!
There are some people out there using the configuration you mention with successful 10 Bit color rendition.
... maybe you have some "driver mix" or anything like that ... and the "newer" version could clean it up(?)
Maybe it's worth a try - can't imagine many other errors (for you said, you already got that to work earlier).
CU
Roland
Message was edited by: Blendax74 P.S. ... I just DID that update to version 8.83.5.4 ... and 10 Bit still works (but the Aero-block etc. ist still as annoying as it always has been...)
Message was edited by: Blendax74 P.P.S.: This driver version was released on 05/24/2011 ... so this should definitely be the latest one available to the public ...
Thanks for the answer Chris.
For VGA I meant graphic card in general, I am sorry, this is how we call them here where I work
My question is: is there any nVidia graphic card that I can use with PhotoShop CS5 (Windows 7, DisplayPort) that will work in 10bit mode?
At the moment the only machine that I use that runs 10bit has a V4800 (ATI) graphic card.
aa no .... no news for a long time...
my expirience till now is.... sometimes work and sometimes not....
PS required multiple restarts to get accurate results ...dont know the reason.....
but system can because if I launch Nec 10 bit aplication it works...
download here... http://www.necdisplay.com/faq/additional-topics/color-critical-display s/14
and click on 3. row (how can I check......... )
so I think something is in PS......
cheers..........
