Sql version of CF
May 6, 2011 5:20 AM
Hello,
The SQL commands one would execute in CF would be considered proprietary?  Are they T-SQL? ANSI SQL?
Another words if you had to define the syntax of a SQL statements inside a cquery tag, what what you call that SQL?
Jim
    May 6, 2011 5:24 AM   in reply to jimfid45
    They're just passed, unmolested, to the DB driver, which passes them to the DB.  CF itself doesn't execute the SQL.
    Adam
    May 26, 2011 7:02 PM   in reply to jimfid45
    @Jim
    The syntax of the query you have within a cfquery tag really depends on the type of database that you're querying.  So inside the cfquery tag, you're identifying the datasource="db_name".  Over in the CF Administrator, you're setting up the type of database (Access, MS SQL), defining the correct driver, and naming the db, e.g. "db_name".
    e.g. If you're writing a query for Access, you would use syntax appropriate for Access.  SQL
    e.g. If you're writing a query for MS SQL 2008, would use syntax appropriate for MS SQL 2008. T-SQL
    <cfwild />
