Exit Code 7
May 25, 2011 9:01 PM
ARG! My computer can run Starcraft 2 at full graphics but cannot install Illistrator or Flash because of Display Requirements?... Is there some way I can get around this? What should I do? I tried the whole "Exit Code 7 Solutions" such as the whole command prompt thing. I tried booting in safe mode and installing but sitll no luck. Any suggestions?
Exit Code: 7
-------------------------------------- Summary --------------------------------------
- 1 fatal error(s), 12 error(s), 4 warning(s)
WARNING: DW065: Display requirements not met for {60E59A6C-7399-495A-B85C-C829F4E59602}
WARNING: DW065: Display requirements not met for {23767F5D-A80C-4264-B8EA-ED4085FC332A}
WARNING: DW065: Display requirements not met for {DDBDE7B0-6FC4-40B1-B673-66EEE8CB60CF}
WARNING: DW031: Payload:{2EBE92C3-F9D8-48B5-A32B-04FA5D1709FA} Adobe XMP Panels CS5 3.0.0.0 has been updated and has been selected for repair. The patch {42774483-D33C-46F7-8B20-FD0B1A3DAC25} Adobe XMP Panels CS5_3.1_AdobeXMPPanelsAll 3.1.0.0 will be uninstalled now.
ERROR: DW020: Found payload conflicts and errors:
ERROR: DW020:  - Adobe Dreamweaver CS5.5 depends on Adobe Dreamweaver Widget Browser to be installed.
ERROR: DW020:  - Adobe Photoshop CS5.1 Core depends on AdobeColorPhotoshop CS5.5 to be installed.
ERROR: DW020:  - Adobe Photoshop CS5.1 Core_x64 depends on AdobeColorPhotoshop CS5.5 to be installed.
ERROR: DW020:  - Adobe Photoshop CS5.1 Core_x64 depends on Adobe Player for Embedding x64 3.1 to be installed.
ERROR: DW020:  - Adobe Photoshop CS5.1 Core_x64 depends on Photoshop Camera Raw (64 bit) to be installed.
ERROR: DW020:  - Adobe Photoshop CS5.1 Core_x64 depends on AdobeCMaps x64 CS5 to be installed.
ERROR: DW020:  - Adobe Flash CS5.5 depends on Adobe Player for Embedding x64 3.1 to be installed.
ERROR: DW020:  - Adobe Flash CS5.5 depends on Photoshop Camera Raw (64 bit) to be installed.
ERROR: DW020:  - Adobe Flash CS5.5 depends on AdobeCMaps x64 CS5 to be installed.
ERROR: DW020:  - Adobe Flash CS5.5 depends on Adobe Flash Player 10 ActiveX to be installed.
ERROR: DW020:  - Adobe Flash CS5.5 depends on Adobe Flash Player 10 Plugin to be installed.
FATAL: DW020: Conflicts were found in the selected payloads. Halting installation.
  • Sharad Saxena
    Apr 30, 2010
    May 25, 2011 11:41 PM   in reply to Howdy_McGee
    In case you have any pre-release build installed on your machine, try uninstalling it first and then run the installer again.
  • Sharad Saxena
    Apr 30, 2010
    May 26, 2011 11:17 PM   in reply to Howdy_McGee
    Good to hear that it's fixed. Sorry I could not reply to you so promptly.
