Why does Captivate 5 Crash when I open PS CS5 or Flash CS5?
May 26, 2011 6:49 AM
Every time we have Captivate 5 open, and we open Flash CS5 or Photoshop CS5, Captivate crashes. We don't own any other products to test this with, or I would've already. I have uninstalled all 3, rebooting between each uninstall, then reinstalled each application, again, restarting between installs.
The system specs that is running these apps is -
3.13GHz Dual-Core
4GB of Memory
256GB SSD
ATI Radeon Graphics Card w/ Dual Monitors
Windows XP SP3 32-Bit (Full Windows Updates)
They work fine seperately, but if we open either Flash or Photoshop w/ Captivate open it crashes.
It works fine if we open PS w/ Flash open, and vice versa.
The Flash/PS are installed from CS5 Disk, the Captivate is an internet download, with the key added at install... could this be the issue?
Why does this happen? Are these applications too resource intensive? We are considering trying to upgrade to 8GB of memory, but if there is a known compatibility issue, we'd rather know now, and save the money.
    May 26, 2011 8:18 AM   in reply to ToadLauncher
    How many RAM on the video card? You didn't specify that one.
    I have been using 4GB on laptop and opened Flash / PS CS5 / Captivate together without issues, but have a 1GB Nvidia graphics card and use WIN7. But then everything was sometimes slowing up. Upgraded to 12GB, no issues anymore. And what about the SSD: enough free space?
    Lilybiri
    May 26, 2011 2:30 PM   in reply to ToadLauncher
    Hello
    Try to recreate the prefernces of Captivate 5.
    Adobe Captivate 5:
    1. Close Adobe Captivate.
    2. Locate the preference folder:
      • Windows Vista and Windows 7: C:\Users\[user name]\AppData\Local\Adobe\Adobe Captivate 5 folder
      • Windows XP:  C:\Documents and Settings\[user name]\Local Settings\Application Data\Adobe\Adobe Captivate 5 folder
      • Mac:  /Users/[user name]/Library/Preferences/Adobe Captivate 5 folder
    3. Rename the preference folder.
    4. Restart Adobe Captivate. A new configuration folder is automatically created.
    Then observe that you are still facing the same issue or not?
    Also if this workaround didn't resolve your issue, try to uninstall Captivate 5 and install it once again.
    Hope it helps
    Vishal
    May 26, 2011 11:28 PM   in reply to Vishal Jaswal
    Hi Vishal,
    Why do you offer mostly the same advice for almost all issues? This question is clearly about Captivate having issues when one or both of two other graphic intensive applications are launched. Why do you think that the Preferences in Captivate have being corrupted to cause that, could you explain?
    Clearing the cache could perhaps free space, but not even sure that this would help if the hardware is not capable of handling...
    Lilybiri
    May 27, 2011 12:59 PM   in reply to Lilybiri
    Hello Lilybiri
    This is the exact issue that i was able to reproduce at my end.
    I tried this workaround and that resolves my issue. So that is why i suggested this workaround.
    I believe, you are alos aware of the fact that by recreating the prefernces does not harm Captivate at all.
    Unless you are using your own Customized workspace.
    I hope you will understand as you are much more experienced and knowledgable than me on Captivate.
    Regarding the issue, if this still doesn't solve the issue. There is one more workaround.
    - Deactivate Captive 5 (Launch Cp 5> Help> Deactivate)
    - Uninstall Captivate 5 completely
    - Create a new user account (if admin account thats well n perfect)
    - Install Captivate 5 on a new admin account
    - Launch Captivate 5, it will work perfectly
    - Now switch user and switch to the original account
    - Launch Captivate 5 and see that you were able to resolve the issue or not
    Hope it helps
    Vishal
    May 31, 2011 5:59 AM   in reply to ToadLauncher
    I'm checking with the team to see if anyone has seen this before. Can you
    describe your system configuration on the current system for me?
    I gather you're on Windows. Do you have admin perms for the machine on which
    Cp is running? Does it happen in reverse - eg. If you open flash and
    photoshop and then Cp does Cp still crash?
    Are you running PS in 32 bit mode or 64 bit mode?
    Does Cp crash the instant one of the others load, or does it take some time
    or other trigger?
    --Allen
    Jun 1, 2011 7:20 AM   in reply to Allen_Partridge
    For what it's worth, I'm on a Mac (OS 10.6.7) and have repeatedly experienced the PS-related CP (v5.0.1.624) crash effect, despite having renamed and regenerated the CP preference file.
    Jun 12, 2011 9:43 PM   in reply to Mr. Zogg
    Shall we have a connect session so that it may help us to find the cause for the issue?
    Let me know when you would be available, you can e-mail to my address vikranth@adobe.com for further info.
    Vikranth
    Jun 15, 2011 3:00 PM   in reply to ToadLauncher
    I have a user that is having this exact issue. The user has the eLearning Suite 2 and is running windows 7 Pro 64 bit. Is their a fix for this?
    Justin
    Jun 24, 2011 1:04 AM   in reply to JustinGSEIWI2
    I am experiencing the exact same problem. I'm on a windows machine running windows 7, 4 gm memory and 32-bit operating system.
    I also have it very regularly that when captivate is still running and i'm working with it, want to save the file, it crashes while saving, and I've lost all my latest edits. Very annoying when you've just done voice recording I can tell you...
    Is there a fix or patch for this?
    Jun 25, 2011 11:09 AM   in reply to cvdleest
    This would be a heck of a lot more exciting if it was actually a roundtrip and not a one-way ride to Captivate freeze-and-crash-city! You kids at Adobe talk to each other now and then don't you? Maybe you could make these apps play nice?
    Jun 27, 2011 5:02 AM   in reply to ToadLauncher
    I have Captivate 5 and PS CS5 as part of the Technical Communication Suite 2, and I have yet to see any Captivate crashes when opening PS. And this is on a 2.33GHz Dual Core machine running XP Pro SP3 with 3GB RAM
    Jul 10, 2011 11:56 PM   in reply to Mr. Zogg
    I have this exact same issue.
    Last week I reinstalled the whole eLearning suite, and now it happens again.
    I only use PS 64-bit.
    System:
    Win 7 64 Bit, 8GB RAM
    nVidia Quadro 2800M Graphics card 1 GB
    eLearning Suite 2.0 (latest version)
    Jul 11, 2011 8:08 AM   in reply to ToadLauncher
    I'm having the same issue and so is one of my co-workers. Typically I launch Captivate 1st, then I launch Photoshop or Flash. Then Captivate crashes. It seems to only happen on the first launch of the day. I've tried the "Preferences" thing, no help. Still crashes.
    I have a HP 6730b:
    • Win XP Pro SP3 (all updates)
    • Intel Core 2 Duo CPU P8600 @ 2.4 GHz 2.39 GHz
    • 2.90 GB RAM
    It would be nice to find a solution. It is a daily annoyance. =)
    Jul 11, 2011 8:12 AM   in reply to ToadLauncher
    I know this won't help most people but I figured I would post anyway. I have updated my Adobe eLearning Suite to 2.5, which updated Captivate and other software, and the user has not reported the problem since.
    Justin
    Jul 12, 2011 4:41 AM   in reply to ToadLauncher
    Here is the Error Report I get since it just happened again:
    <?xml version="1.0" encoding="UTF-16"?>
    <DATABASE>
    <EXE NAME="AdobeCaptivate.exe" FILTER="GRABMI_FILTER_PRIVACY">
        <MATCHING_FILE NAME="ACE.dll" SIZE="1005024" CHECKSUM="0x6DF234DC" BIN_FILE_VERSION="2.16.29.7272" BIN_PRODUCT_VERSION="2.16.0.1" PRODUCT_VERSION="61.418258" FILE_DESCRIPTION="Adobe Color Engine" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="ACE 2010/01/26-18:07:03" FILE_VERSION="2.16.29.7272" ORIGINAL_FILENAME="ACE.dll" INTERNAL_NAME="ACE" LEGAL_COPYRIGHT="© 1999-2009 Adobe Systems Incorporated" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xF8BDF" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="2.16.29.7272" UPTO_BIN_PRODUCT_VERSION="2.16.0.1" LINK_DATE="01/27/2010 04:04:42" UPTO_LINK_DATE="01/27/2010 04:04:42" VER_LANGUAGE="English (United States) [0x800]" />
        <MATCHING_FILE NAME="adbeape.dll" SIZE="30176" CHECKSUM="0xD5D23E45" BIN_FILE_VERSION="3.1.65.7508" BIN_PRODUCT_VERSION="3.1.65.7508" PRODUCT_VERSION="61.421986" FILE_DESCRIPTION="Adobe APE(32 bit)" COMPANY_NAME="Adobe Systems, Incorporated " PRODUCT_NAME="Adobe APE 2010/02/23-12:40:58" FILE_VERSION="3.1.65.7508" ORIGINAL_FILENAME="adbeape.dll" INTERNAL_NAME="Adobe APE" LEGAL_COPYRIGHT="© 2006-2010 Adobe Systems Incorporated. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1557B" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="3.1.65.7508" UPTO_BIN_PRODUCT_VERSION="3.1.65.7508" LINK_DATE="02/23/2010 21:25:25" UPTO_LINK_DATE="02/23/2010 21:25:25" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="AdobeCaptivate.exe" SIZE="331632" CHECKSUM="0x2E33A960" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="AdobeCaptivate.exe" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x0" MODULE_TYPE="WIN32" PE_CHECKSUM="0x5196D" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 07:33:13" UPTO_LINK_DATE="06/07/2011 07:33:13" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="AdobeLinguistic.dll" SIZE="4174800" CHECKSUM="0x2559F9A9" BIN_FILE_VERSION="5.0.0.9556" BIN_PRODUCT_VERSION="5.0.32.1" PRODUCT_VERSION="5.0.0" FILE_DESCRIPTION="Linguistic Library" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe Linguisitc Library" FILE_VERSION="5.0.0.9556" ORIGINAL_FILENAME="AdobeLinguistic.dll" INTERNAL_NAME="Lilo" LEGAL_COPYRIGHT="Copyright 1999-2009 Adobe Systems Incorporated. All Rights Reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x3FDAAE" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.9556" UPTO_BIN_PRODUCT_VERSION="5.0.32.1" LINK_DATE="04/17/2009 13:25:34" UPTO_LINK_DATE="04/17/2009 13:25:34" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="AdobeOwl.dll" SIZE="1371536" CHECKSUM="0x7FA78468" BIN_FILE_VERSION="3.0.71.0" BIN_PRODUCT_VERSION="3.0.71.0" PRODUCT_VERSION="3.0.71" FILE_DESCRIPTION="Adobe Owl(32 bit)" COMPANY_NAME="Adobe Systems, Incorporated " PRODUCT_NAME="Adobe Owl 2009/11/12-18:06:30" FILE_VERSION="3.0.71" ORIGINAL_FILENAME="AdobeOwl.dll" INTERNAL_NAME="Adobe Owl" LEGAL_COPYRIGHT="Copyright © 2006-2009 Adobe Systems Incorporated. All Rights Reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x14EF55" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="3.0.71.0" UPTO_BIN_PRODUCT_VERSION="3.0.71.0" LINK_DATE="11/13/2009 03:06:58" UPTO_LINK_DATE="11/13/2009 03:06:58" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="AdobePDFL.dll" SIZE="6229984" CHECKSUM="0xA728F253" BIN_FILE_VERSION="9.9.0.7272" BIN_PRODUCT_VERSION="9.9.0.7272" PRODUCT_VERSION="61.276366" FILE_DESCRIPTION="Adobe PDF Library" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="PDFL 2010/01/26-18:07:03" FILE_VERSION="9.9.0.7272" ORIGINAL_FILENAME="AdobePDFL.dll" INTERNAL_NAME="PDFL" LEGAL_COPYRIGHT="© 1987-2009 Adobe Systems Incorporated.
     All Rights Reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x5F70CD" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="9.9.0.7272" UPTO_BIN_PRODUCT_VERSION="9.9.0.7272" LINK_DATE="01/27/2010 04:55:58" UPTO_LINK_DATE="01/27/2010 04:55:58" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="AdobePIP.dll" SIZE="581488" CHECKSUM="0x3048A14F" BIN_FILE_VERSION="5.0.0.559" BIN_PRODUCT_VERSION="5.0.0.559" PRODUCT_VERSION="5.0.0.559" FILE_DESCRIPTION="Adobe Product Improvement Program" COMPANY_NAME="Adobe Systems, Incorporated" PRODUCT_NAME="Adobe Product Improvement Program" FILE_VERSION="5.0.0.559" ORIGINAL_FILENAME="AdobePIP.dll" INTERNAL_NAME="AdobePIP" LEGAL_COPYRIGHT="Copyright (C) 2008 Adobe Systems, Inc. All rights reserved" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x9D43A" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.559" UPTO_BIN_PRODUCT_VERSION="5.0.0.559" LINK_DATE="11/26/2009 11:07:31" UPTO_LINK_DATE="11/26/2009 11:07:31" VER_LANGUAGE="Language Neutral [0x0]" />
        <MATCHING_FILE NAME="AdobePSL.dll" SIZE="12304848" CHECKSUM="0x79C0F6E" BIN_FILE_VERSION="12.0.0.7524" BIN_PRODUCT_VERSION="12.0.0.7524" PRODUCT_VERSION="61.654535_12.654498" FILE_DESCRIPTION="AdobePSL" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="AdobePSL" FILE_VERSION="12.0.0.7524" ORIGINAL_FILENAME="AdobePSL.dll" INTERNAL_NAME="AdobePSL" LEGAL_COPYRIGHT="© 1984-2009 Adobe Systems Incorporated" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xBCB243" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="12.0.0.7524" UPTO_BIN_PRODUCT_VERSION="12.0.0.7524" LINK_DATE="02/26/2010 23:06:49" UPTO_LINK_DATE="02/26/2010 23:06:49" VER_LANGUAGE="English (United States) [0x800]" />
        <MATCHING_FILE NAME="AdobeSWFL.dll" SIZE="8555488" CHECKSUM="0x488254CE" BIN_FILE_VERSION="2.0.0.7489" BIN_PRODUCT_VERSION="2.0.0.7489" PRODUCT_VERSION="2.0.0.7489" FILE_DESCRIPTION="Adobe SWFL library" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="AdobeSWFL" FILE_VERSION="2.0.0.7489" ORIGINAL_FILENAME="AdobeSWFL.dll" INTERNAL_NAME="AdobeSWFL.dll" LEGAL_COPYRIGHT="© 2007-2010 Adobe Systems Incorporated. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x0" MODULE_TYPE="WIN32" PE_CHECKSUM="0x833F30" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="2.0.0.7489" UPTO_BIN_PRODUCT_VERSION="2.0.0.7489" LINK_DATE="02/19/2010 23:07:42" UPTO_LINK_DATE="02/19/2010 23:07:42" VER_LANGUAGE="English (United States) [0x800]" />
        <MATCHING_FILE NAME="AdobeXMP.dll" SIZE="303072" CHECKSUM="0x79A3DBCF" BIN_FILE_VERSION="5.0.0.60" BIN_PRODUCT_VERSION="5.0.0.0" PRODUCT_VERSION="5.0" FILE_DESCRIPTION="Adobe XMP Core, 5.0-c060" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe XMP Core" FILE_VERSION="5.0-c060, 61.134503, 2010/01/24-18:06:58" ORIGINAL_FILENAME="AdobeXMP.dll" INTERNAL_NAME="AdobeXMPCore" LEGAL_COPYRIGHT="Copyright 2002-2009, Adobe Systems Incorporated. All Rights Reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x514EB" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.60" UPTO_BIN_PRODUCT_VERSION="5.0.0.0" LINK_DATE="01/25/2010 05:36:55" UPTO_LINK_DATE="01/25/2010 05:36:55" VER_LANGUAGE="English (United States) [0x800]" />
        <MATCHING_FILE NAME="adobe_caps.dll" SIZE="423872" CHECKSUM="0xBC827D51" BIN_FILE_VERSION="3.0.116.0" BIN_PRODUCT_VERSION="3.0.116.0" PRODUCT_VERSION="3,0,116,0" FILE_DESCRIPTION="Adobe CAPS DLL" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe CAPS" FILE_VERSION="3,0,116,0" ORIGINAL_FILENAME="adobe_caps.dll" INTERNAL_NAME="adobe_caps.dll" LEGAL_COPYRIGHT="© 2005-2010 Adobe Systems Incorporated. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x75805" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="3.0.116.0" UPTO_BIN_PRODUCT_VERSION="3.0.116.0" LINK_DATE="01/22/2010 19:34:22" UPTO_LINK_DATE="01/22/2010 19:34:22" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="Adobe_OOBE_Launcher.dll" SIZE="233400" CHECKSUM="0xCDF69285" BIN_FILE_VERSION="1.0.0.64" BIN_PRODUCT_VERSION="1.0.0.64" PRODUCT_VERSION="1.0.0.64 (BuildVersion: 1.0; BuildDate: Mon Jan 26 2010 21:49:00)" FILE_DESCRIPTION="Adobe OOBE launcher Utility" COMPANY_NAME="Adobe Systems, Incorporated" PRODUCT_NAME="Adobe OOBE Launcher" FILE_VERSION="1.0.0.64" ORIGINAL_FILENAME="Adobe_OOBE_Launcher.dll" INTERNAL_NAME="Adobe OOBE Launcher" LEGAL_COPYRIGHT="Copyright 2009 Adobe Systems Incorporated. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x47FA8" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.0.64" UPTO_BIN_PRODUCT_VERSION="1.0.0.64" LINK_DATE="01/27/2010 09:27:15" UPTO_LINK_DATE="01/27/2010 09:27:15" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="AFL.dll" SIZE="153040" CHECKSUM="0xCF6329B3" BIN_FILE_VERSION="1.0.0.0" BIN_PRODUCT_VERSION="1.0.0.0" PRODUCT_VERSION="1.0" FILE_DESCRIPTION="Adobe File Library" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME=" AFL" FILE_VERSION="1.0.0" ORIGINAL_FILENAME="AFL.dll" INTERNAL_NAME="AFL" LEGAL_COPYRIGHT="Copyright 2000-2006 Adobe Systems Incorporated." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x2C9B5" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.0.0" UPTO_BIN_PRODUCT_VERSION="1.0.0.0" LINK_DATE="11/22/2008 04:23:30" UPTO_LINK_DATE="11/22/2008 04:23:30" VER_LANGUAGE="Language Neutral [0x0]" />
        <MATCHING_FILE NAME="aflamingo.dll" SIZE="2047456" CHECKSUM="0xDD03E2DC" BIN_FILE_VERSION="2.0.402.7511" BIN_PRODUCT_VERSION="2.0.0.1" PRODUCT_VERSION="61.421978" FILE_DESCRIPTION="Adobe Flamingo" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="AFlamingo 2010/02/23-17:27:33" FILE_VERSION="2.0.402.7511" ORIGINAL_FILENAME="AFlamingo.dll" INTERNAL_NAME="AFlamingo" LEGAL_COPYRIGHT="© 2009-2010 Adobe Systems Incorporated" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1FB29B" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="2.0.402.7511" UPTO_BIN_PRODUCT_VERSION="2.0.0.1" LINK_DATE="02/24/2010 04:55:32" UPTO_LINK_DATE="02/24/2010 04:55:32" VER_LANGUAGE="English (United States) [0x800]" />
        <MATCHING_FILE NAME="Aggregator.exe" SIZE="104816" CHECKSUM="0x725EDCA5" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="Aggregator.exe" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x0" MODULE_TYPE="WIN32" PE_CHECKSUM="0x23336" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 07:33:08" UPTO_LINK_DATE="06/07/2011 07:33:08" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="aggregatorUI.dll" SIZE="753008" CHECKSUM="0xCE708DF0" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="aggregatorUI.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xC7804" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 07:32:04" UPTO_LINK_DATE="06/07/2011 07:32:04" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="AGM.dll" SIZE="5670880" CHECKSUM="0xB5438B02" BIN_FILE_VERSION="4.20.67.7272" BIN_PRODUCT_VERSION="4.20.0.1" PRODUCT_VERSION="61.418258" FILE_DESCRIPTION="Adobe Graphics Manager" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="AGM 2010/01/26-18:07:03" FILE_VERSION="4.20.67.7272" ORIGINAL_FILENAME="AGM.dll" INTERNAL_NAME="AGM" LEGAL_COPYRIGHT="© 1984-2009 Adobe Systems Incorporated" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x56E547" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="4.20.67.7272" UPTO_BIN_PRODUCT_VERSION="4.20.0.1" LINK_DATE="01/27/2010 04:09:10" UPTO_LINK_DATE="01/27/2010 04:09:10" VER_LANGUAGE="English (United States) [0x800]" />
        <MATCHING_FILE NAME="ahclient.dll" SIZE="112072" CHECKSUM="0x1FCA9C64" BIN_FILE_VERSION="1.5.0.30" BIN_PRODUCT_VERSION="1.5.0.30" PRODUCT_VERSION="1,5,0,30" FILE_DESCRIPTION="Adobe Help Client Library" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME=" AdobeHelp Dynamic Link Library" FILE_VERSION="1,5,0,30" ORIGINAL_FILENAME="ahclient.dll" INTERNAL_NAME="AdobeHelp" LEGAL_COPYRIGHT="Copyright (C) 2008 Adobe Systems Inc." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x24282" LINKER_VERSION="0x10000" UPTO_BIN_FILE_VERSION="1.5.0.30" UPTO_BIN_PRODUCT_VERSION="1.5.0.30" LINK_DATE="12/10/2009 08:23:45" UPTO_LINK_DATE="12/10/2009 08:23:45" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="AIDE.dll" SIZE="673248" CHECKSUM="0x8D4AFD96" BIN_FILE_VERSION="1.0.0.7631" BIN_PRODUCT_VERSION="1.0.0.7631" PRODUCT_VERSION="61.424422" FILE_DESCRIPTION="Adobe Image Decode Encode Library" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="AIDE 2010/03/17-08:41:20" FILE_VERSION="1.0.0.7631" ORIGINAL_FILENAME="AIDE.dll" INTERNAL_NAME="AIDE" LEGAL_COPYRIGHT="Copyright 2009 Adobe Systems Incorporated. All Rights Reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xA7561" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.0.7631" UPTO_BIN_PRODUCT_VERSION="1.0.0.7631" LINK_DATE="03/17/2010 16:33:21" UPTO_LINK_DATE="03/17/2010 16:33:21" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="AlcidDLL.dll" SIZE="86992" CHECKSUM="0xFE260FAC" MODULE_TYPE="WIN32" PE_CHECKSUM="0x21846" LINKER_VERSION="0x0" LINK_DATE="01/20/2010 10:22:39" UPTO_LINK_DATE="01/20/2010 10:22:39" />
        <MATCHING_FILE NAME="amefoundation.dll" SIZE="255952" CHECKSUM="0xEC120AB" MODULE_TYPE="WIN32" PE_CHECKSUM="0x48C3A" LINKER_VERSION="0x0" LINK_DATE="01/22/2010 16:03:42" UPTO_LINK_DATE="01/22/2010 16:03:42" />
        <MATCHING_FILE NAME="ameproperties.dll" SIZE="206800" CHECKSUM="0x6295DF5" MODULE_TYPE="WIN32" PE_CHECKSUM="0x38B83" LINKER_VERSION="0x0" LINK_DATE="01/22/2010 16:06:51" UPTO_LINK_DATE="01/22/2010 16:06:51" />
        <MATCHING_FILE NAME="amtlib.dll" SIZE="911800" CHECKSUM="0xF0A8F93B" BIN_FILE_VERSION="3.0.0.64" BIN_PRODUCT_VERSION="3.0.0.64" PRODUCT_VERSION="3.0.0.64 (BuildVersion: 3.0; BuildDate:  Mon Jan 26 2010 21:49:00)" FILE_DESCRIPTION="AMT Licensing" COMPANY_NAME="Adobe Systems, Incorporated" PRODUCT_NAME="AMTLib" FILE_VERSION="3.0.0.64" ORIGINAL_FILENAME="amtlib.dll" INTERNAL_NAME="amtlib" LEGAL_COPYRIGHT="Copyright 2006-2010 Adobe Systems Incorporated. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xE4B09" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="3.0.0.64" UPTO_BIN_PRODUCT_VERSION="3.0.0.64" LINK_DATE="01/27/2010 09:29:37" UPTO_LINK_DATE="01/27/2010 09:29:37" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="amtservices.dll" SIZE="1101240" CHECKSUM="0xA574FA8F" BIN_FILE_VERSION="3.0.0.64" BIN_PRODUCT_VERSION="3.0.0.64" PRODUCT_VERSION="3.0.0.64 (BuildVersion: 3.0; BuildDate:  Mon Jan 26 2010 21:49:00)" FILE_DESCRIPTION="AMT Services" COMPANY_NAME="Adobe Systems, Incorporated" PRODUCT_NAME="AMTServices" FILE_VERSION="3.0.0.64" ORIGINAL_FILENAME="amtservices.dll" INTERNAL_NAME="amtservices" LEGAL_COPYRIGHT="Copyright 2006-2010 Adobe Systems Incorporated. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x10E92F" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="3.0.0.64" UPTO_BIN_PRODUCT_VERSION="3.0.0.64" LINK_DATE="01/27/2010 09:28:50" UPTO_LINK_DATE="01/27/2010 09:28:50" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="ApplicationUICore.dll" SIZE="782192" CHECKSUM="0xBF8A318E" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="ApplicationUICore.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xC0683" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 07:23:54" UPTO_LINK_DATE="06/07/2011 07:23:54" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="arh.exe" SIZE="75064" CHECKSUM="0xF8D6FB39" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1CA35" LINKER_VERSION="0x0" LINK_DATE="06/17/2009 02:51:06" UPTO_LINK_DATE="06/17/2009 02:51:06" />
        <MATCHING_FILE NAME="ASLFoundation.dll" SIZE="363984" CHECKSUM="0x1C0963FC" BIN_FILE_VERSION="5.0.0.0" BIN_PRODUCT_VERSION="5.0.0.0" PRODUCT_VERSION="5, 0, 0, 0" FILE_DESCRIPTION="Adobe Media Encoder Support Library" COMPANY_NAME="Adobe Systems, Incorporated" PRODUCT_NAME="Adobe Media Encoder CS5" FILE_VERSION="5, 0, 0, 0" ORIGINAL_FILENAME="ASLFoundation.dll" LEGAL_COPYRIGHT="Copyright © 1991-2009 Adobe Systems, Incorporated" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x62065" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.0" UPTO_BIN_PRODUCT_VERSION="5.0.0.0" LINK_DATE="01/22/2010 16:04:06" UPTO_LINK_DATE="01/22/2010 16:04:06" VER_LANGUAGE="Language Neutral [0x0]" />
        <MATCHING_FILE NAME="asneu.dll" SIZE="149944" CHECKSUM="0xAC693B3D" BIN_FILE_VERSION="1.7.0.1" BIN_PRODUCT_VERSION="1.7.0.1" PRODUCT_VERSION="1, 7, 0, 1" FILE_DESCRIPTION="AsnEndUser Dynamic Link Library" COMPANY_NAME="Adobe Systems Inc." PRODUCT_NAME=" AsnEndUser Dynamic Link Library" FILE_VERSION="1, 7, 0, 1" ORIGINAL_FILENAME="asneu.dll" INTERNAL_NAME="AsnEndUser" LEGAL_COPYRIGHT="Copyright © 2002 - 2006 Adobe Systems Inc.  All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x31027" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.7.0.1" UPTO_BIN_PRODUCT_VERSION="1.7.0.1" LINK_DATE="06/23/2009 23:32:17" UPTO_LINK_DATE="06/23/2009 23:32:17" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="authplay.dll" SIZE="4813776" CHECKSUM="0x277E34D8" BIN_FILE_VERSION="10.0.12.29" BIN_PRODUCT_VERSION="10.0.12.29" PRODUCT_VERSION="10,0,12,29" FILE_DESCRIPTION="Adobe Flash Player 10.0 r12" COMPANY_NAME="Adobe Systems, Inc." PRODUCT_NAME="Shockwave Flash" FILE_VERSION="10,0,12,29" ORIGINAL_FILENAME="authplay.dll" INTERNAL_NAME="Adobe Flash Player 10.0" LEGAL_COPYRIGHT="Adobe® Flash® Player. Copyright © 1996-2008 Adobe Systems Incorporated. All Rights Reserved. Protected by U.S. Patent 6,879,327; Patents Pending in the United States and other countries. Adobe and Flash are either trademarks or registered trademarks in the United States and/or other countries." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x49CA8B" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="10.0.12.29" UPTO_BIN_PRODUCT_VERSION="10.0.12.29" LINK_DATE="09/30/2008 02:12:27" UPTO_LINK_DATE="09/30/2008 02:12:27" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="AXE8SharedExpat.dll" SIZE="174560" CHECKSUM="0x9FF5D3E5" BIN_FILE_VERSION="3.5.101.7282" BIN_PRODUCT_VERSION="3.5.0.1" PRODUCT_VERSION="61.418555" FILE_DESCRIPTION="AXE Shared EXPAT (UTF-8 native)" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="AXE8SharedExpat 2010/01/27-18:07:17" FILE_VERSION="3.5.101.7282" ORIGINAL_FILENAME="AXE8SharedExpat.dll" INTERNAL_NAME="AXE8SharedExpat" LEGAL_COPYRIGHT="© 2003-2010 Adobe Systems Incorporated" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x3903D" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="3.5.101.7282" UPTO_BIN_PRODUCT_VERSION="3.5.0.1" LINK_DATE="01/28/2010 05:31:53" UPTO_LINK_DATE="01/28/2010 05:31:53" VER_LANGUAGE="English (United States) [0x800]" />
        <MATCHING_FILE NAME="AXEDOMCore.dll" SIZE="661984" CHECKSUM="0xB1DAE24" BIN_FILE_VERSION="3.5.101.7282" BIN_PRODUCT_VERSION="3.5.0.1" PRODUCT_VERSION="61.418555" FILE_DESCRIPTION="Adobe XML Engine: DOM Core" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="AXEDOMCore 2010/01/27-18:07:17" FILE_VERSION="3.5.101.7282" ORIGINAL_FILENAME="AXEDOMCore.dll" INTERNAL_NAME="AXEDOMCore" LEGAL_COPYRIGHT="© 2001-2010 Adobe Systems Incorporated" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xAA703" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="3.5.101.7282" UPTO_BIN_PRODUCT_VERSION="3.5.0.1" LINK_DATE="01/28/2010 05:29:13" UPTO_LINK_DATE="01/28/2010 05:29:13" VER_LANGUAGE="English (United States) [0x800]" />
        <MATCHING_FILE NAME="BIB.dll" SIZE="284640" CHECKSUM="0xA06ABDAE" BIN_FILE_VERSION="1.2.2.7272" BIN_PRODUCT_VERSION="1.2.0.1" PRODUCT_VERSION="61.418258" FILE_DESCRIPTION="Bravo Interface Binder" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="BIB 2010/01/26-18:07:03" FILE_VERSION="1.2.02.7272" ORIGINAL_FILENAME="BIB.dll" INTERNAL_NAME="BIB" LEGAL_COPYRIGHT="© 1995-2009 Adobe Systems Incorporated" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x53799" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.2.2.7272" UPTO_BIN_PRODUCT_VERSION="1.2.0.1" LINK_DATE="01/27/2010 03:59:51" UPTO_LINK_DATE="01/27/2010 03:59:51" VER_LANGUAGE="English (United States) [0x800]" />
        <MATCHING_FILE NAME="BIBUtils.dll" SIZE="248288" CHECKSUM="0xA0B71B17" BIN_FILE_VERSION="1.1.1.1" BIN_PRODUCT_VERSION="1.1.0.1" PRODUCT_VERSION="61.418258" FILE_DESCRIPTION="Bravo Interface Binder Utilities" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="BIBUtils 2010/01/26-18:07:03" FILE_VERSION="1.1.01.7272" ORIGINAL_FILENAME="BIBUtils.dll" INTERNAL_NAME="BIBUtils" LEGAL_COPYRIGHT="© 1993-2009 Adobe Systems Incorporated" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x3F2F3" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.1.1.1" UPTO_BIN_PRODUCT_VERSION="1.1.0.1" LINK_DATE="01/27/2010 04:03:37" UPTO_LINK_DATE="01/27/2010 04:03:37" VER_LANGUAGE="English (United States) [0x800]" />
        <MATCHING_FILE NAME="boost_date_time.dll" SIZE="58832" CHECKSUM="0xEFC8F9A7" BIN_FILE_VERSION="5.0.0.0" BIN_PRODUCT_VERSION="5.0.0.0" PRODUCT_VERSION="5.0.0" COMPANY_NAME="Adobe Systems, Incorporated" PRODUCT_NAME="DVA Product" FILE_VERSION="5.0.0.0" ORIGINAL_FILENAME="boost_date_time.dll" INTERNAL_NAME="boost_date_time" LEGAL_COPYRIGHT="Copyright (c) Adobe Systems, Inc.  All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x0" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1BDE0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.0" UPTO_BIN_PRODUCT_VERSION="5.0.0.0" LINK_DATE="02/03/2010 08:19:45" UPTO_LINK_DATE="02/03/2010 08:19:45" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="boost_filesystem.dll" SIZE="81360" CHECKSUM="0x8ED6D83C" BIN_FILE_VERSION="5.0.0.0" BIN_PRODUCT_VERSION="5.0.0.0" PRODUCT_VERSION="5.0.0" COMPANY_NAME="Adobe Systems, Incorporated" PRODUCT_NAME="DVA Product" FILE_VERSION="5.0.0.0" ORIGINAL_FILENAME="boost_filesystem.dll" INTERNAL_NAME="boost_filesystem" LEGAL_COPYRIGHT="Copyright (c) Adobe Systems, Inc.  All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x0" MODULE_TYPE="WIN32" PE_CHECKSUM="0x21351" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.0" UPTO_BIN_PRODUCT_VERSION="5.0.0.0" LINK_DATE="02/03/2010 08:20:39" UPTO_LINK_DATE="02/03/2010 08:20:39" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="boost_iostreams.dll" SIZE="31184" CHECKSUM="0xA1F7AC21" BIN_FILE_VERSION="5.0.0.0" BIN_PRODUCT_VERSION="5.0.0.0" PRODUCT_VERSION="5.0.0" COMPANY_NAME="Adobe Systems, Incorporated" PRODUCT_NAME="DVA Product" FILE_VERSION="5.0.0.0" ORIGINAL_FILENAME="boost_iostreams.dll" INTERNAL_NAME="boost_iostreams" LEGAL_COPYRIGHT="Copyright (c) Adobe Systems, Inc.  All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x0" MODULE_TYPE="WIN32" PE_CHECKSUM="0xA6E3" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.0" UPTO_BIN_PRODUCT_VERSION="5.0.0.0" LINK_DATE="02/03/2010 08:19:47" UPTO_LINK_DATE="02/03/2010 08:19:47" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="boost_regex.dll" SIZE="614352" CHECKSUM="0x536EFF00" BIN_FILE_VERSION="5.0.0.0" BIN_PRODUCT_VERSION="5.0.0.0" PRODUCT_VERSION="5.0.0" COMPANY_NAME="Adobe Systems, Incorporated" PRODUCT_NAME="DVA Product" FILE_VERSION="5.0.0.0" ORIGINAL_FILENAME="boost_regex.dll" INTERNAL_NAME="boost_regex" LEGAL_COPYRIGHT="Copyright (c) Adobe Systems, Inc.  All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x0" MODULE_TYPE="WIN32" PE_CHECKSUM="0xA0343" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.0" UPTO_BIN_PRODUCT_VERSION="5.0.0.0" LINK_DATE="02/03/2010 08:20:11" UPTO_LINK_DATE="02/03/2010 08:20:11" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="boost_signals.dll" SIZE="71632" CHECKSUM="0x8934DBC0" BIN_FILE_VERSION="5.0.0.0" BIN_PRODUCT_VERSION="5.0.0.0" PRODUCT_VERSION="5.0.0" COMPANY_NAME="Adobe Systems, Incorporated" PRODUCT_NAME="DVA Product" FILE_VERSION="5.0.0.0" ORIGINAL_FILENAME="boost_signals.dll" INTERNAL_NAME="boost_signals" LEGAL_COPYRIGHT="Copyright (c) Adobe Systems, Inc.  All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x0" MODULE_TYPE="WIN32" PE_CHECKSUM="0x12145" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.0" UPTO_BIN_PRODUCT_VERSION="5.0.0.0" LINK_DATE="02/03/2010 08:20:16" UPTO_LINK_DATE="02/03/2010 08:20:16" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="boost_system.dll" SIZE="20432" CHECKSUM="0xACD44439" BIN_FILE_VERSION="5.0.0.0" BIN_PRODUCT_VERSION="5.0.0.0" PRODUCT_VERSION="5.0.0" COMPANY_NAME="Adobe Systems, Incorporated" PRODUCT_NAME="DVA Product" FILE_VERSION="5.0.0.0" ORIGINAL_FILENAME="boost_system.dll" INTERNAL_NAME="boost_system" LEGAL_COPYRIGHT="Copyright (c) Adobe Systems, Inc.  All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x0" MODULE_TYPE="WIN32" PE_CHECKSUM="0xEAA4" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.0" UPTO_BIN_PRODUCT_VERSION="5.0.0.0" LINK_DATE="02/03/2010 08:19:44" UPTO_LINK_DATE="02/03/2010 08:19:44" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="boost_threads.dll" SIZE="51152" CHECKSUM="0x2FAD52BF" BIN_FILE_VERSION="5.0.0.0" BIN_PRODUCT_VERSION="5.0.0.0" PRODUCT_VERSION="5.0.0" COMPANY_NAME="Adobe Systems, Incorporated" PRODUCT_NAME="DVA Product" FILE_VERSION="5.0.0.0" ORIGINAL_FILENAME="boost_threads.dll" INTERNAL_NAME="boost_threads" LEGAL_COPYRIGHT="Copyright (c) Adobe Systems, Inc.  All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x0" MODULE_TYPE="WIN32" PE_CHECKSUM="0x125D7" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.0" UPTO_BIN_PRODUCT_VERSION="5.0.0.0" LINK_DATE="02/03/2010 08:20:16" UPTO_LINK_DATE="02/03/2010 08:20:16" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CaptivateUI.dll" SIZE="5712240" CHECKSUM="0x921786EA" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CaptivateUI.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x57B63D" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 07:27:40" UPTO_LINK_DATE="06/07/2011 07:27:40" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CaptivateUICore.dll" SIZE="2850672" CHECKSUM="0xF80E757B" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CaptivateUICore.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x2C02B3" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 06:58:21" UPTO_LINK_DATE="06/07/2011 06:58:21" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="Capture.dll" SIZE="646512" CHECKSUM="0x1DD3A09C" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="Capture.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xAD408" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 07:16:40" UPTO_LINK_DATE="06/07/2011 07:16:40" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CaptureUI.dll" SIZE="547184" CHECKSUM="0x69379BC6" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CaptureUI.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x877F6" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 07:22:54" UPTO_LINK_DATE="06/07/2011 07:22:54" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CoolType.dll" SIZE="3041248" CHECKSUM="0xE2C071D7" BIN_FILE_VERSION="5.7.82.7272" BIN_PRODUCT_VERSION="5.7.0.1" PRODUCT_VERSION="61.418258" FILE_DESCRIPTION="CoolType Typography Engine" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="CoolType 2010/01/26-18:07:03" FILE_VERSION="5.07.82.7272" ORIGINAL_FILENAME="CoolType.dll" INTERNAL_NAME="CoolType" LEGAL_COPYRIGHT="© 1984-2009 Adobe Systems Incorporated" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x2F355A" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.7.82.7272" UPTO_BIN_PRODUCT_VERSION="5.7.0.1" LINK_DATE="01/27/2010 04:24:02" UPTO_LINK_DATE="01/27/2010 04:24:02" VER_LANGUAGE="English (United States) [0x800]" />
        <MATCHING_FILE NAME="CPAdditionalUI.dll" SIZE="134000" CHECKSUM="0x5FCD2D89" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPAdditionalUI.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x29204" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 07:31:20" UPTO_LINK_DATE="06/07/2011 07:31:20" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CPAnimationUtils.dll" SIZE="209776" CHECKSUM="0xF1D76B3" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPAnimationUtils.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x35E4E" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 06:41:22" UPTO_LINK_DATE="06/07/2011 06:41:22" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CPApplicationCore.dll" SIZE="664944" CHECKSUM="0x3BC57DEC" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPApplicationCore.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xA59F4" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 06:41:36" UPTO_LINK_DATE="06/07/2011 06:41:36" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CPAS3Compile.dll" SIZE="19824" CHECKSUM="0x30A92477" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPAS3Compile.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x5424" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 06:39:43" UPTO_LINK_DATE="06/07/2011 06:39:43" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CPAudio.dll" SIZE="236912" CHECKSUM="0xDB7BD04B" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPAudio.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x49165" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 06:42:12" UPTO_LINK_DATE="06/07/2011 06:42:12" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CPAudioCore.dll" SIZE="2194800" CHECKSUM="0xA63499F2" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPAudioCore.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x21B24B" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 06:41:49" UPTO_LINK_DATE="06/07/2011 06:41:49" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CPAudioUI.dll" SIZE="1256304" CHECKSUM="0x2877ADCB" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPAudioUI.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x134679" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 07:12:28" UPTO_LINK_DATE="06/07/2011 07:12:28" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CPBranchingUI.dll" SIZE="698736" CHECKSUM="0x4ABF1F4F" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPBranchingUI.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xB7FA3" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 07:28:29" UPTO_LINK_DATE="06/07/2011 07:28:29" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CPBridge.dll" SIZE="332144" CHECKSUM="0xD02C527C" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPBridge.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x56EA1" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 07:08:31" UPTO_LINK_DATE="06/07/2011 07:08:31" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CPBridgeUI.dll" SIZE="33136" CHECKSUM="0xB0B914E2" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPBridgeUI.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xB198" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 07:32:27" UPTO_LINK_DATE="06/07/2011 07:32:27" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CPCaptionExporter.dll" SIZE="94576" CHECKSUM="0x2045D48D" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPCaptionExporter.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1DEB0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 07:28:53" UPTO_LINK_DATE="06/07/2011 07:28:53" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CPCaptionImporter.dll" SIZE="121200" CHECKSUM="0x75FFE651" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPCaptionImporter.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x22B21" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 07:05:59" UPTO_LINK_DATE="06/07/2011 07:05:59" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CPClipboard.dll" SIZE="264048" CHECKSUM="0x9A6A953F" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPClipboard.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x4D778" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 06:41:16" UPTO_LINK_DATE="06/07/2011 06:41:16" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CPCSXSUI.dll" SIZE="69488" CHECKSUM="0xFEAABCA8" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPCSXSUI.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1A5B2" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 07:31:25" UPTO_LINK_DATE="06/07/2011 07:31:25" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CPDatabase.dll" SIZE="218992" CHECKSUM="0x739DDBB1" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPDatabase.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x456AB" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 06:39:14" UPTO_LINK_DATE="06/07/2011 06:39:14" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CPExportImportUI.dll" SIZE="68464" CHECKSUM="0xD2CFEA8C" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPExportImportUI.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1A06E" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 07:31:22" UPTO_LINK_DATE="06/07/2011 07:31:22" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CPF4VFLVEncoder.dll" SIZE="66928" CHECKSUM="0x5545154C" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPF4VFLVEncoder.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x11A57" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 07:05:50" UPTO_LINK_DATE="06/07/2011 07:05:50" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CPFlashUtils.dll" SIZE="63856" CHECKSUM="0xEB3C7841" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPFlashUtils.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1492C" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 07:10:39" UPTO_LINK_DATE="06/07/2011 07:10:39" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CPFLVPublish.dll" SIZE="195952" CHECKSUM="0xE5C7B04C" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPFLVPublish.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x38FEF" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 07:06:40" UPTO_LINK_DATE="06/07/2011 07:06:40" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CPFMREdit.dll" SIZE="118128" CHECKSUM="0x2C8B6437" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPFMREdit.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x269BC" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 07:07:11" UPTO_LINK_DATE="06/07/2011 07:07:11" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CPJavaBridge.dll" SIZE="23408" CHECKSUM="0xAB221B4E" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPJavaBridge.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x14A16" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 06:39:37" UPTO_LINK_DATE="06/07/2011 06:39:37" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CPObjects.dll" SIZE="4007280" CHECKSUM="0x60B89D61" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPObjects.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x3DF275" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 06:54:29" UPTO_LINK_DATE="06/07/2011 06:54:29" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CPObjectStylesUI.dll" SIZE="722288" CHECKSUM="0x87212BDC" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPObjectStylesUI.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xB2205" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 07:18:54" UPTO_LINK_DATE="06/07/2011 07:18:54" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CPOtherUI.dll" SIZE="429424" CHECKSUM="0x30E55DEC" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPOtherUI.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x72EEF" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 07:22:23" UPTO_LINK_DATE="06/07/2011 07:22:23" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CPPainters.dll" SIZE="639344" CHECKSUM="0xC870284E" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPPainters.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xA4005" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 07:04:21" UPTO_LINK_DATE="06/07/2011 07:04:21" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CPPPTEditUI.dll" SIZE="140144" CHECKSUM="0xDECA7F8E" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPPPTEditUI.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x3080D" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 07:32:23" UPTO_LINK_DATE="06/07/2011 07:32:23" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CPPPTImport.dll" SIZE="231792" CHECKSUM="0x614A8A28" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPPPTImport.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x3B4B9" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 07:22:01" UPTO_LINK_DATE="06/07/2011 07:22:01" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CPPPTImportUI.dll" SIZE="80240" CHECKSUM="0x9A4B88C6" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPPPTImportUI.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x14ADE" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 07:28:50" UPTO_LINK_DATE="06/07/2011 07:28:50" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CPPreferencesUI.dll" SIZE="736624" CHECKSUM="0xCAF98441" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPPreferencesUI.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xBEF2E" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 07:21:38" UPTO_LINK_DATE="06/07/2011 07:21:38" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CPProjectNSlides.dll" SIZE="3767664" CHECKSUM="0xD0A38DDB" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPProjectNSlides.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x3992B1" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 06:48:48" UPTO_LINK_DATE="06/07/2011 06:48:48" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CPPSDImport.dll" SIZE="196464" CHECKSUM="0xFA843971" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPPSDImport.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x3970F" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 07:07:03" UPTO_LINK_DATE="06/07/2011 07:07:03" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CPPSDImportUI.dll" SIZE="190832" CHECKSUM="0xE0A0C6A8" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPPSDImportUI.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x35CA1" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 07:28:03" UPTO_LINK_DATE="06/07/2011 07:28:03" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CPPublic.dll" SIZE="1568112" CHECKSUM="0xD0E9910" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPPublic.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x185DD9" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 06:39:04" UPTO_LINK_DATE="06/07/2011 06:39:04" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CPPublish.dll" SIZE="1600880" CHECKSUM="0xCB369DA" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPPublish.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x187B40" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 07:07:49" UPTO_LINK_DATE="06/07/2011 07:07:49" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CPPublishUI.dll" SIZE="2628976" CHECKSUM="0x23C5772A" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPPublishUI.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x28F681" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 07:29:27" UPTO_LINK_DATE="06/07/2011 07:29:27" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CPQuizzing.dll" SIZE="3096432" CHECKSUM="0x97CEE49" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPQuizzing.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x302F46" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 07:02:52" UPTO_LINK_DATE="06/07/2011 07:02:52" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CPQuizzingPainters.dll" SIZE="303472" CHECKSUM="0x912B7EA0" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPQuizzingPainters.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x4BB4B" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 07:29:02" UPTO_LINK_DATE="06/07/2011 07:29:02" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CPQuizzingUI.dll" SIZE="1051504" CHECKSUM="0x6F14B913" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPQuizzingUI.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x106309" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 07:30:23" UPTO_LINK_DATE="06/07/2011 07:30:23" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CPSWFCommentingUI.dll" SIZE="257392" CHECKSUM="0x7A38CD1A" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPSWFCommentingUI.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x42335" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 07:31:44" UPTO_LINK_DATE="06/07/2011 07:31:44" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CPSWFGenerator.dll" SIZE="983408" CHECKSUM="0x5783FC22" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPSWFGenerator.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xFFED2" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 07:05:30" UPTO_LINK_DATE="06/07/2011 07:05:30" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CPSWFParser.dll" SIZE="523120" CHECKSUM="0xF6B4E99E" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPSWFParser.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x8B0F5" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 06:41:07" UPTO_LINK_DATE="06/07/2011 06:41:07" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CPTextModel.dll" SIZE="3054960" CHECKSUM="0x5504B0F0" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPTextModel.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x2F8FEE" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 06:40:48" UPTO_LINK_DATE="06/07/2011 06:40:48" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CPThumbnails.dll" SIZE="388976" CHECKSUM="0x16979DAD" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPThumbnails.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x69E26" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 07:20:26" UPTO_LINK_DATE="06/07/2011 07:20:26" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CPUIUtils.dll" SIZE="1613680" CHECKSUM="0x2E404BD4" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPUIUtils.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x19665B" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 07:10:23" UPTO_LINK_DATE="06/07/2011 07:10:23" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CPUnitTesting.dll" SIZE="1205616" CHECKSUM="0x9FE7054C" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPUnitTesting.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x133F8C" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 07:31:09" UPTO_LINK_DATE="06/07/2011 07:31:09" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CPVariablesNScriptingUI.dll" SIZE="306544" CHECKSUM="0x11F61B33" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPVariablesNScriptingUI.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x5861D" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 07:32:57" UPTO_LINK_DATE="06/07/2011 07:32:57" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CPVideo.dll" SIZE="373104" CHECKSUM="0xCB09952" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPVideo.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x67610" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 06:59:21" UPTO_LINK_DATE="06/07/2011 06:59:21" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CPVideoUI.dll" SIZE="882544" CHECKSUM="0xFAEF5998" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPVideoUI.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xE09E6" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 07:30:43" UPTO_LINK_DATE="06/07/2011 07:30:43" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CPWidgetUI.dll" SIZE="184176" CHECKSUM="0xD7DCBF46" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPWidgetUI.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x3677E" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 07:31:32" UPTO_LINK_DATE="06/07/2011 07:31:32" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CPWinWordUtils.dll" SIZE="349040" CHECKSUM="0x340E054A" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPWinWordUtils.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x58572" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 07:04:41" UPTO_LINK_DATE="06/07/2011 07:04:41" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CPWordPublish.dll" SIZE="250224" CHECKSUM="0x521BDA08" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPWordPublish.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x46346" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 07:06:08" UPTO_LINK_DATE="06/07/2011 07:06:08" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CPWordPublishData.dll" SIZE="37744" CHECKSUM="0x98F684D9" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPWordPublishData.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xCB49" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 06:59:28" UPTO_LINK_DATE="06/07/2011 06:59:28" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CPXFLExport.dll" SIZE="651120" CHECKSUM="0x82C427E8" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPXFLExport.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xA8774" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 07:13:29" UPTO_LINK_DATE="06/07/2011 07:13:29" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CPXFLExportUI.dll" SIZE="66416" CHECKSUM="0x78294F8" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPXFLExportUI.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x15EE2" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 07:32:15" UPTO_LINK_DATE="06/07/2011 07:32:15" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CPXMLImportExport.dll" SIZE="205168" CHECKSUM="0x4E3170FE" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPXMLImportExport.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x3C3FF" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 07:06:27" UPTO_LINK_DATE="06/07/2011 07:06:27" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CPXMLParser.dll" SIZE="54640" CHECKSUM="0x7D4843DB" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPXMLParser.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x197C2" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 06:40:58" UPTO_LINK_DATE="06/07/2011 06:40:58" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CPXMLWriter.dll" SIZE="178544" CHECKSUM="0xF6554735" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPXMLWriter.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x39492" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 06:40:13" UPTO_LINK_DATE="06/07/2011 06:40:13" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="CPZipUtils.dll" SIZE="317808" CHECKSUM="0xF695404F" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPZipUtils.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x572FC" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 06:41:13" UPTO_LINK_DATE="06/07/2011 06:41:13" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="dvaadameve.dll" SIZE="3475408" CHECKSUM="0x49F880F1" BIN_FILE_VERSION="5.0.0.0" BIN_PRODUCT_VERSION="5.0.0.0" PRODUCT_VERSION="5.0.0" COMPANY_NAME="Adobe Systems, Incorporated" PRODUCT_NAME="DVA Product" FILE_VERSION="5.0.0.0" ORIGINAL_FILENAME="dvaadameve.dll" INTERNAL_NAME="dvaadameve" LEGAL_COPYRIGHT="Copyright (c) Adobe Systems, Inc.  All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x0" MODULE_TYPE="WIN32" PE_CHECKSUM="0x35BF80" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.0" UPTO_BIN_PRODUCT_VERSION="5.0.0.0" LINK_DATE="04/15/2010 12:29:58" UPTO_LINK_DATE="04/15/2010 12:29:58" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="dvacore.dll" SIZE="1629648" CHECKSUM="0xC9F0FC3E" BIN_FILE_VERSION="5.0.0.0" BIN_PRODUCT_VERSION="5.0.0.0" PRODUCT_VERSION="5.0.0" COMPANY_NAME="Adobe Systems, Incorporated" PRODUCT_NAME="DVA Product" FILE_VERSION="5.0.0.0" ORIGINAL_FILENAME="dvacore.dll" INTERNAL_NAME="dvacore" LEGAL_COPYRIGHT="Copyright (c) Adobe Systems, Inc.  All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x0" MODULE_TYPE="WIN32" PE_CHECKSUM="0x18EDEC" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.0" UPTO_BIN_PRODUCT_VERSION="5.0.0.0" LINK_DATE="02/03/2010 08:21:26" UPTO_LINK_DATE="02/03/2010 08:21:26" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="dvamediatypes.dll" SIZE="134608" CHECKSUM="0x28082DDF" BIN_FILE_VERSION="5.0.0.15826" BIN_PRODUCT_VERSION="5.0.0.15826" PRODUCT_VERSION="5.0.0" COMPANY_NAME="Adobe Systems, Incorporated" PRODUCT_NAME="Adobe Media Encoder CS5" FILE_VERSION="5.0.0.212434" ORIGINAL_FILENAME="dvamediatypes.dll" INTERNAL_NAME="dvamediatypes" LEGAL_COPYRIGHT="Copyright (c) Adobe Systems, Inc.  All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x0" MODULE_TYPE="WIN32" PE_CHECKSUM="0x29761" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.15826" UPTO_BIN_PRODUCT_VERSION="5.0.0.15826" LINK_DATE="01/22/2010 16:03:14" UPTO_LINK_DATE="01/22/2010 16:03:14" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="dvaui.dll" SIZE="4059600" CHECKSUM="0x1D915028" BIN_FILE_VERSION="5.0.0.0" BIN_PRODUCT_VERSION="5.0.0.0" PRODUCT_VERSION="5.0.0" COMPANY_NAME="Adobe Systems, Incorporated" PRODUCT_NAME="DVA Product" FILE_VERSION="5.0.0.0" ORIGINAL_FILENAME="dvaui.dll" INTERNAL_NAME="dvaui" LEGAL_COPYRIGHT="Copyright (c) Adobe Systems, Inc.  All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x0" MODULE_TYPE="WIN32" PE_CHECKSUM="0x3E033F" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.0" UPTO_BIN_PRODUCT_VERSION="5.0.0.0" LINK_DATE="04/30/2010 08:05:12" UPTO_LINK_DATE="04/30/2010 08:05:12" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="dvaworkspace.dll" SIZE="1093072" CHECKSUM="0xDE8176D5" BIN_FILE_VERSION="5.0.0.0" BIN_PRODUCT_VERSION="5.0.0.0" PRODUCT_VERSION="5.0.0" COMPANY_NAME="Adobe Systems, Incorporated" PRODUCT_NAME="DVA Product" FILE_VERSION="5.0.0.0" ORIGINAL_FILENAME="dvaworkspace.dll" INTERNAL_NAME="dvaworkspace" LEGAL_COPYRIGHT="Copyright (c) Adobe Systems, Inc.  All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x0" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1145AA" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.0" UPTO_BIN_PRODUCT_VERSION="5.0.0.0" LINK_DATE="02/03/2010 08:33:22" UPTO_LINK_DATE="02/03/2010 08:33:22" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="Effects.dll" SIZE="533360" CHECKSUM="0xF0216540" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="Effects.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x89CE2" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 06:59:04" UPTO_LINK_DATE="06/07/2011 06:59:04" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="EffectsUI.dll" SIZE="682864" CHECKSUM="0x687A3B9A" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="EffectsUI.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xAE231" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 07:28:45" UPTO_LINK_DATE="06/07/2011 07:28:45" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="ExtendScript.dll" SIZE="669960" CHECKSUM="0x9E665D2C" BIN_FILE_VERSION="4.1.21.6863" BIN_PRODUCT_VERSION="4.1.21.6863" PRODUCT_VERSION="1.416121" FILE_DESCRIPTION="Adobe ExtendScript scripting engine (32 bit)" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="ExtendScript 2009/12/17-03:06:41" FILE_VERSION="4.1.21.6863" ORIGINAL_FILENAME="AdobeExtendScript.dll" INTERNAL_NAME="AdobeExtendScript" LEGAL_COPYRIGHT="© 1998-2009 Adobe Systems Incorporated. All Rights Reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xB365B" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="4.1.21.6863" UPTO_BIN_PRODUCT_VERSION="4.1.21.6863" LINK_DATE="12/17/2009 13:59:05" UPTO_LINK_DATE="12/17/2009 13:59:05" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="FakeFlash.exe" SIZE="15312" CHECKSUM="0xD663B678" MODULE_TYPE="WIN32" PE_CHECKSUM="0x76C8" LINKER_VERSION="0x0" LINK_DATE="08/21/2009 06:51:29" UPTO_LINK_DATE="08/21/2009 06:51:29" />
        <MATCHING_FILE NAME="Fireworks Library.dll" SIZE="7969232" CHECKSUM="0x83C487E9" BIN_FILE_VERSION="11.0.0.352" BIN_PRODUCT_VERSION="11.0.0.352" PRODUCT_VERSION="11.0.0.352" FILE_DESCRIPTION="Fireworks Resources" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Fireworks" FILE_VERSION="11.0.0.352" ORIGINAL_FILENAME="Fireworks_Library_Resources.dll" INTERNAL_NAME="Fireworks Resources" LEGAL_COPYRIGHT="Copyright © 1998-2009 Adobe Systems Incorporated. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x79D7E6" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="11.0.0.352" UPTO_BIN_PRODUCT_VERSION="11.0.0.352" LINK_DATE="03/13/2010 15:28:47" UPTO_LINK_DATE="03/13/2010 15:28:47" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="FullmotionRecorder.dll" SIZE="439664" CHECKSUM="0x1E582D91" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="FullmotionRecorder.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x7AE65" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 06:46:25" UPTO_LINK_DATE="06/07/2011 06:46:25" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="icucnv36.dll" SIZE="664576" CHECKSUM="0xC2B7B4DF" BIN_FILE_VERSION="3.6.0.0" BIN_PRODUCT_VERSION="3.6.0.0" PRODUCT_VERSION=" Build gtlib_main.9345" FILE_DESCRIPTION="IBM ICU Common DLL" COMPANY_NAME="IBM Corporation and others" PRODUCT_NAME="International Components for Unicode 2009/01/04-11:11:10" FILE_VERSION="3, 6, 0, 1004" ORIGINAL_FILENAME="icuuc36.dll" LEGAL_COPYRIGHT=" Copyright (C) 2005, International Business Machines Corporation and others. All Rights Reserved. " VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xAA5BB" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="3.6.0.0" UPTO_BIN_PRODUCT_VERSION="3.6.0.0" LINK_DATE="04/01/2009 06:00:51" UPTO_LINK_DATE="04/01/2009 06:00:51" VER_LANGUAGE="Language Neutral [0x0]" />
        <MATCHING_FILE NAME="icudt36.dll" SIZE="10159616" CHECKSUM="0xEE351ED2" BIN_FILE_VERSION="3.6.0.0" BIN_PRODUCT_VERSION="3.6.0.0" PRODUCT_VERSION=" Build gtlib_main.9345" FILE_DESCRIPTION="ICU Data DLL" COMPANY_NAME="IBM Corporation and others" PRODUCT_NAME="International Components for Unicode 2009/01/04-11:11:10" FILE_VERSION="3, 6, 0, 1004" ORIGINAL_FILENAME="icudt36.dll" LEGAL_COPYRIGHT=" Copyright (C) 2005, International Business Machines Corporation and others. All Rights Reserved. " VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="3.6.0.0" UPTO_BIN_PRODUCT_VERSION="3.6.0.0" LINK_DATE="04/01/2009 06:05:14" UPTO_LINK_DATE="04/01/2009 06:05:14" VER_LANGUAGE="Language Neutral [0x0]" />
        <MATCHING_FILE NAME="icuin36.dll" SIZE="963072" CHECKSUM="0x89B67341" BIN_FILE_VERSION="3.6.0.0" BIN_PRODUCT_VERSION="3.6.0.0" PRODUCT_VERSION=" Build gtlib_main.9345" FILE_DESCRIPTION="IBM ICU I18N DLL" COMPANY_NAME="IBM Corporation and others" PRODUCT_NAME="International Components for Unicode 2009/01/04-11:11:10" FILE_VERSION="3, 6, 0, 1004" ORIGINAL_FILENAME="icuin36.dll" LEGAL_COPYRIGHT=" Copyright (C) 2005, International Business Machines Corporation and others. All Rights Reserved. " VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xF5359" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="3.6.0.0" UPTO_BIN_PRODUCT_VERSION="3.6.0.0" LINK_DATE="04/01/2009 06:01:45" UPTO_LINK_DATE="04/01/2009 06:01:45" VER_LANGUAGE="Language Neutral [0x0]" />
        <MATCHING_FILE NAME="icuuc36.dll" SIZE="1053136" CHECKSUM="0x30302752" BIN_FILE_VERSION="3.6.0.0" BIN_PRODUCT_VERSION="3.6.0.0" PRODUCT_VERSION=" Build gtlib_main.9345" FILE_DESCRIPTION="IBM ICU Common DLL" COMPANY_NAME="IBM Corporation and others" PRODUCT_NAME="International Components for Unicode 2009/01/04-11:11:10" FILE_VERSION="3, 6, 0, 1004" ORIGINAL_FILENAME="icuuc36.dll" LEGAL_COPYRIGHT=" Copyright (C) 2005, International Business Machines Corporation and others. All Rights Reserved. " VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1052FE" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="3.6.0.0" UPTO_BIN_PRODUCT_VERSION="3.6.0.0" LINK_DATE="04/01/2009 06:00:51" UPTO_LINK_DATE="04/01/2009 06:00:51" VER_LANGUAGE="Language Neutral [0x0]" />
        <MATCHING_FILE NAME="IESpy.dll" SIZE="31232" CHECKSUM="0x6DA35061" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="IESpy.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x12D26" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 06:47:00" UPTO_LINK_DATE="06/07/2011 06:47:00" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="ImageRenderer.dll" SIZE="934864" CHECKSUM="0x61679DF" BIN_FILE_VERSION="5.0.0.0" BIN_PRODUCT_VERSION="5.0.0.0" PRODUCT_VERSION="5, 0, 0, 0" FILE_DESCRIPTION="Adobe Media Encoder Support Library" COMPANY_NAME="Adobe Systems, Incorporated" PRODUCT_NAME="Adobe Media Encoder CS5" FILE_VERSION="5, 0, 0, 0" ORIGINAL_FILENAME="ImageRenderer.dll" LEGAL_COPYRIGHT="Copyright © 1991-2009 Adobe Systems, Incorporated" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xF2F60" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.0" UPTO_BIN_PRODUCT_VERSION="5.0.0.0" LINK_DATE="01/22/2010 16:06:15" UPTO_LINK_DATE="01/22/2010 16:06:15" VER_LANGUAGE="Language Neutral [0x0]" />
        <MATCHING_FILE NAME="ImageUtils.dll" SIZE="308080" CHECKSUM="0xCDADC94F" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="ImageUtils.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x572FD" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 06:39:19" UPTO_LINK_DATE="06/07/2011 06:39:19" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="JP2KLib.dll" SIZE="675808" CHECKSUM="0x58BF0636" BIN_FILE_VERSION="2.0.0.7282" BIN_PRODUCT_VERSION="2.0.0.7282" PRODUCT_VERSION="61.129282" FILE_DESCRIPTION="Adobe JPEG2000 Core Library" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="JP2KLib 2010/01/27-18:07:17" FILE_VERSION="2.0.0.7282" ORIGINAL_FILENAME="JP2KLib.dll" INTERNAL_NAME="JP2KLib" LEGAL_COPYRIGHT="© 2009 Adobe Systems Incorporated.
     All Rights Reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xABD07" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="2.0.0.7282" UPTO_BIN_PRODUCT_VERSION="2.0.0.7282" LINK_DATE="01/28/2010 05:34:15" UPTO_LINK_DATE="01/28/2010 05:34:15" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="libguide40.dll" SIZE="200704" CHECKSUM="0xD90AF7DF" BIN_FILE_VERSION="4.0.2006.1212" BIN_PRODUCT_VERSION="4.0.2006.1212" PRODUCT_VERSION="4, 0, 2006, 1212" FILE_DESCRIPTION="Guide Runtime Library" COMPANY_NAME="Intel Corporation" PRODUCT_NAME="Guide Run-time Library" FILE_VERSION="4, 0, 2006, 1212" ORIGINAL_FILENAME="Windows_NT.rc" INTERNAL_NAME="libguide40" LEGAL_COPYRIGHT="Copyright © 2006" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x40000" UPTO_BIN_FILE_VERSION="4.0.2006.1212" UPTO_BIN_PRODUCT_VERSION="4.0.2006.1212" LINK_DATE="12/12/2006 17:52:15" UPTO_LINK_DATE="12/12/2006 17:52:15" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="libmmd.dll" SIZE="2887680" CHECKSUM="0x913067B3" BIN_FILE_VERSION="10.1.10.2" BIN_PRODUCT_VERSION="0.0.0.0" PRODUCT_VERSION="10.1" FILE_DESCRIPTION="Math Library for Intel(r) Compilers (thread-safe)" COMPANY_NAME="Intel Corporation" PRODUCT_NAME="Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler" FILE_VERSION="10.1.10.2" ORIGINAL_FILENAME="libmmd.dll" INTERNAL_NAME="libmmd.dll" LEGAL_COPYRIGHT="Copyright (c) 1985-2007 Intel Corporation. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x0" VERFILETYPE="0x0" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="10.1.10.2" UPTO_BIN_PRODUCT_VERSION="0.0.0.0" LINK_DATE="02/13/2008 03:26:53" UPTO_LINK_DATE="02/13/2008 03:26:53" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="LogSession.dll" SIZE="341808" CHECKSUM="0xBA28E0C9" BIN_FILE_VERSION="2.0.1.8" BIN_PRODUCT_VERSION="2.0.1.8" PRODUCT_VERSION="2, 0, 1, 8" FILE_DESCRIPTION="LogSession" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="LogSession" FILE_VERSION="2, 0, 1, 8" ORIGINAL_FILENAME="LogSession.dll" INTERNAL_NAME="LogSession" LEGAL_COPYRIGHT="Copyright 2007 Adobe Systems Incorporated and its licensors. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x62571" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="2.0.1.8" UPTO_BIN_PRODUCT_VERSION="2.0.1.8" LINK_DATE="09/08/2009 02:02:09" UPTO_LINK_DATE="09/08/2009 02:02:09" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="LogTransport2.exe" SIZE="268592" CHECKSUM="0x7DF7A2FF" BIN_FILE_VERSION="2.0.1.8" BIN_PRODUCT_VERSION="2.0.1.8" PRODUCT_VERSION="2, 0, 1, 8" FILE_DESCRIPTION="LogTransport Application" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME=" LogTransport Application" FILE_VERSION="2, 0, 1, 8" ORIGINAL_FILENAME="LogTransport.exe" INTERNAL_NAME="LogTransport" LEGAL_COPYRIGHT="Copyright 2007 Adobe Systems Incorporated and its licensors. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x45BF2" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="2.0.1.8" UPTO_BIN_PRODUCT_VERSION="2.0.1.8" LINK_DATE="09/09/2009 06:54:37" UPTO_LINK_DATE="09/09/2009 06:54:37" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="mc_dec_dv.dll" SIZE="270336" CHECKSUM="0x1748C67" BIN_FILE_VERSION="8.5.0.12323" BIN_PRODUCT_VERSION="8.5.0.12323" PRODUCT_VERSION="8.5.0.12323" FILE_DESCRIPTION="MainConcept DV+ Codec (b)" COMPANY_NAME="MainConcept GmbH" PRODUCT_NAME="MainConcept DV Codec (+) v.8.5.0.12323" FILE_VERSION="8.5.0.12323" ORIGINAL_FILENAME="mc_dvd_32.dll" INTERNAL_NAME="mc_dvd_32" LEGAL_COPYRIGHT="Copyright© MainConcept GmbH 2001-2009" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x3" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="8.5.0.12323" UPTO_BIN_PRODUCT_VERSION="8.5.0.12323" LINK_DATE="01/07/2010 08:42:30" UPTO_LINK_DATE="01/07/2010 08:42:30" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="mc_enc_avc.dll" SIZE="1286144" CHECKSUM="0x5EE41B62" BIN_FILE_VERSION="8.5.0.12323" BIN_PRODUCT_VERSION="8.5.0.12323" PRODUCT_VERSION="8.5.0" FILE_DESCRIPTION="AVC/H.264 Encoder" COMPANY_NAME="MainConcept GmbH" PRODUCT_NAME="MainConcept® AVC/H.264 Encoder" FILE_VERSION="8.5.0.12323 2009/11/09" ORIGINAL_FILENAME="mc_enc_avc.dll" INTERNAL_NAME="mc_enc_avc" LEGAL_COPYRIGHT="Copyright© 2009 MainConcept GmbH" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x10004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="8.5.0.12323" UPTO_BIN_PRODUCT_VERSION="8.5.0.12323" LINK_DATE="01/07/2010 08:30:13" UPTO_LINK_DATE="01/07/2010 08:30:13" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="mc_enc_dv.dll" SIZE="262144" CHECKSUM="0x4807AC1F" BIN_FILE_VERSION="8.5.0.12323" BIN_PRODUCT_VERSION="8.5.0.12323" PRODUCT_VERSION="8.5.0.12323" FILE_DESCRIPTION="MainConcept DV+ Codec (b)" COMPANY_NAME="MainConcept GmbH" PRODUCT_NAME="MainConcept DV Codec (+) v.8.5.0.12323" FILE_VERSION="8.5.0.12323" ORIGINAL_FILENAME="mc_dvd_32.dll" INTERNAL_NAME="mc_dvd_32" LEGAL_COPYRIGHT="Copyright© MainConcept GmbH 2001-2009" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x3" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="8.5.0.12323" UPTO_BIN_PRODUCT_VERSION="8.5.0.12323" LINK_DATE="01/07/2010 08:43:05" UPTO_LINK_DATE="01/07/2010 08:43:05" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="MPS.dll" SIZE="4704208" CHECKSUM="0xC7831428" BIN_FILE_VERSION="5.5.0.1" BIN_PRODUCT_VERSION="5.5.0.1" PRODUCT_VERSION="61.421463" FILE_DESCRIPTION="Modular Parsing System" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="MPS 2010/02/19-13:50:10" FILE_VERSION="5.5.0.1" ORIGINAL_FILENAME="MPS.dll" INTERNAL_NAME="MPS" LEGAL_COPYRIGHT="© 1996-2009 Adobe Systems Incorporated. All Rights Reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x48B119" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.5.0.1" UPTO_BIN_PRODUCT_VERSION="5.5.0.1" LINK_DATE="03/20/2010 08:44:11" UPTO_LINK_DATE="03/20/2010 08:44:11" VER_LANGUAGE="English (United States) [0x800]" />
        <MATCHING_FILE NAME="MultiSCOPackager.exe" SIZE="103280" CHECKSUM="0xE4713AAE" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="MultiSCOPackager.exe" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x0" MODULE_TYPE="WIN32" PE_CHECKSUM="0x29245" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 07:33:05" UPTO_LINK_DATE="06/07/2011 07:33:05" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="multiscoUI.dll" SIZE="436080" CHECKSUM="0xE9ECBD22" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="multiscoUI.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x7957B" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 07:29:45" UPTO_LINK_DATE="06/07/2011 07:29:45" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="NPSWF32.dll" SIZE="5541344" CHECKSUM="0x97FA11D3" BIN_FILE_VERSION="10.1.51.87" BIN_PRODUCT_VERSION="10.1.51.87" PRODUCT_VERSION="10,1,51,87" FILE_DESCRIPTION="Shockwave Flash 10.1 d51" COMPANY_NAME="Adobe Systems, Inc." PRODUCT_NAME="Shockwave Flash" FILE_VERSION="10,1,51,87" ORIGINAL_FILENAME="npswf32.dll" INTERNAL_NAME="Adobe Flash Player 10.1" LEGAL_COPYRIGHT="Adobe® Flash® Player. Copyright © 1996-2010 Adobe Systems Incorporated. All Rights Reserved. Adobe and Flash are either trademarks or registered trademarks in the United States and/or other countries." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x54B829" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="10.1.51.87" UPTO_BIN_PRODUCT_VERSION="10.1.51.87" LINK_DATE="02/13/2010 05:32:56" UPTO_LINK_DATE="02/13/2010 05:32:56" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="Plugin.dll" SIZE="49104" CHECKSUM="0xC28C4A23" BIN_FILE_VERSION="12.0.0.0" BIN_PRODUCT_VERSION="12.0.0.0" PRODUCT_VERSION="CS5" FILE_DESCRIPTION="Photoshop Plugin Utilities" COMPANY_NAME="Adobe Systems, Incorporated" PRODUCT_NAME="Adobe Photoshop CS5" FILE_VERSION="12.0 (12.0x001)" ORIGINAL_FILENAME="Plugin.dll" INTERNAL_NAME="Plugin" LEGAL_COPYRIGHT="Copyright 2008 Adobe Systems Inc." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xF2D5" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="12.0.0.0" UPTO_BIN_PRODUCT_VERSION="12.0.0.0" LINK_DATE="12/08/2009 18:23:40" UPTO_LINK_DATE="12/08/2009 18:23:40" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="PlugPlug.dll" SIZE="1118152" CHECKSUM="0x49FEFFE9" BIN_FILE_VERSION="2.0.0.746" BIN_PRODUCT_VERSION="2.0.0.746" PRODUCT_VERSION="2.0.0.746" FILE_DESCRIPTION="PlugPlug Standard Dll (32 bit)" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe(R) CSXS PlugPlug Standard Dll (32 bit)" FILE_VERSION="2.0.0.746" ORIGINAL_FILENAME="PlugPlug Standard Dll (32 bit)" INTERNAL_NAME="PlugPlug" LEGAL_COPYRIGHT="(C) 2009 Adobe Systems, Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x0" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1207A1" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="2.0.0.746" UPTO_BIN_PRODUCT_VERSION="2.0.0.746" LINK_DATE="03/25/2010 17:50:22" UPTO_LINK_DATE="03/25/2010 17:50:22" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="PotluckStd.dll" SIZE="230864" CHECKSUM="0xFF5743C3" BIN_FILE_VERSION="2.4.7.0" BIN_PRODUCT_VERSION="2.4.7.0" PRODUCT_VERSION="2.4.7" FILE_DESCRIPTION="Potluck2" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Potluck2" FILE_VERSION="2.4.7" INTERNAL_NAME="Potluck2" LEGAL_COPYRIGHT="Copyright 2008" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x3B444" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="2.4.7.0" UPTO_BIN_PRODUCT_VERSION="2.4.7.0" LINK_DATE="01/21/2009 02:52:05" UPTO_LINK_DATE="01/21/2009 02:52:05" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="ppt2swf.dll" SIZE="6229360" CHECKSUM="0x9F0CE0CF" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="ppt2swf.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x5FD7AD" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 07:16:08" UPTO_LINK_DATE="06/07/2011 07:16:08" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="PRM.dll" SIZE="15312" CHECKSUM="0xA0A8B175" BIN_FILE_VERSION="5.0.0.0" BIN_PRODUCT_VERSION="5.0.0.0" PRODUCT_VERSION="5, 0, 0, 0" FILE_DESCRIPTION="Adobe Media Encoder Support Library" COMPANY_NAME="Adobe Systems, Incorporated" PRODUCT_NAME="Adobe Media Encoder CS5" FILE_VERSION="5, 0, 0, 0" ORIGINAL_FILENAME="PRM.dll" LEGAL_COPYRIGHT="Copyright © 1991-2009 Adobe Systems, Incorporated" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x9825" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.0" UPTO_BIN_PRODUCT_VERSION="5.0.0.0" LINK_DATE="01/22/2010 16:01:18" UPTO_LINK_DATE="01/22/2010 16:01:18" VER_LANGUAGE="Language Neutral [0x0]" />
        <MATCHING_FILE NAME="PropertyInspector.dll" SIZE="2585600" CHECKSUM="0xD1517DB0" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="PropertyInspector.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x27BDAD" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 07:15:56" UPTO_LINK_DATE="06/07/2011 07:15:56" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="QuickTimeGlue.dll" SIZE="35840" CHECKSUM="0x160AABDB" MODULE_TYPE="WIN32" PE_CHECKSUM="0xCDBB" LINKER_VERSION="0x0" LINK_DATE="01/29/2010 04:28:46" UPTO_LINK_DATE="01/29/2010 04:28:46" />
        <MATCHING_FILE NAME="ScCore.dll" SIZE="585992" CHECKSUM="0x41CDA730" BIN_FILE_VERSION="4.1.21.6863" BIN_PRODUCT_VERSION="4.1.21.6863" PRODUCT_VERSION="1.416121" FILE_DESCRIPTION="Scripting Components Core (32 bit)" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="ScCore 2009/12/17-03:06:41" FILE_VERSION="4.1.21.6863" ORIGINAL_FILENAME="AdobeScCore.dll" INTERNAL_NAME="AdobeScCore" LEGAL_COPYRIGHT="© 1998-2009 Adobe Systems Incorporated. All Rights Reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x929C8" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="4.1.21.6863" UPTO_BIN_PRODUCT_VERSION="4.1.21.6863" LINK_DATE="12/17/2009 13:58:55" UPTO_LINK_DATE="12/17/2009 13:58:55" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="updaternotifications.dll" SIZE="585200" CHECKSUM="0x1492B5CD" BIN_FILE_VERSION="1.0.0.64" BIN_PRODUCT_VERSION="1.0.0.64" PRODUCT_VERSION="1.0.0.64 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)" FILE_DESCRIPTION="Adobe Updater Notifications Library" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe Updater Notifications Library" FILE_VERSION="1\,0\,0\,64" ORIGINAL_FILENAME="Updaternotifications.dll" INTERNAL_NAME="UpdaterNotifications.dll" LEGAL_COPYRIGHT="Copyright 2009-10 Adobe Systems Incorporated. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x910D4" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.0.64" UPTO_BIN_PRODUCT_VERSION="1.0.0.64" LINK_DATE="01/22/2010 13:54:52" UPTO_LINK_DATE="01/22/2010 13:54:52" VER_LANGUAGE="Language Neutral [0x4009]" />
        <MATCHING_FILE NAME="VeelaUpgrader.dll" SIZE="840560" CHECKSUM="0xBA68BFD8" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="VeelaUpgrader.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xD8BB8" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 07:32:41" UPTO_LINK_DATE="06/07/2011 07:32:41" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="vt_eng.dll" SIZE="643072" CHECKSUM="0xFFFCE209" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" LINK_DATE="07/09/2009 06:44:58" UPTO_LINK_DATE="07/09/2009 06:44:58" />
        <MATCHING_FILE NAME="WebKit.dll" SIZE="4284896" CHECKSUM="0xF1C44C7C" MODULE_TYPE="WIN32" PE_CHECKSUM="0x425ABF" LINKER_VERSION="0x0" LINK_DATE="02/19/2010 23:48:25" UPTO_LINK_DATE="02/19/2010 23:48:25" />
        <MATCHING_FILE NAME="WHook.dll" SIZE="14336" CHECKSUM="0xB62CC1A1" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="WHook.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xA64A" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 06:50:30" UPTO_LINK_DATE="06/07/2011 06:50:30" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="WRServices.dll" SIZE="1202896" CHECKSUM="0x799DF95" BIN_FILE_VERSION="4.0.0.1" BIN_PRODUCT_VERSION="4.0.0.1" PRODUCT_VERSION="Build 0.11423" FILE_DESCRIPTION="WRServices Engine" COMPANY_NAME="WinSoft S.A." PRODUCT_NAME="WRServices Thursday January 21 2010 12:13:3" FILE_VERSION="4.0.0.1000" ORIGINAL_FILENAME="WRServices.dll" INTERNAL_NAME="WRServices" LEGAL_COPYRIGHT="(c) 1993 - 2008 WinSoft S.A., (c) 2007 Adobe Systems, Inc." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1264A2" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="4.0.0.1" UPTO_BIN_PRODUCT_VERSION="4.0.0.1" LINK_DATE="01/21/2010 20:16:26" UPTO_LINK_DATE="01/21/2010 20:16:26" VER_LANGUAGE="English (United States) [0x800]" />
        <MATCHING_FILE NAME="xerces-c_2_6.dll" SIZE="1818064" CHECKSUM="0x6F5794F8" BIN_FILE_VERSION="2.5.0.0" BIN_PRODUCT_VERSION="2.5.0.0" PRODUCT_VERSION="2, 6, 0" FILE_DESCRIPTION="Shared Library for Xerces-C Version 2.6.0" COMPANY_NAME="Apache Software Foundation" PRODUCT_NAME="Xerces-C Version 2.6.0" FILE_VERSION="2, 6, 0" ORIGINAL_FILENAME="xerces-c_2_6.dll" INTERNAL_NAME="xerces-c_2_6.dll" LEGAL_COPYRIGHT="Copyright © Apache Software Foundation 2000 subject to licensing terms" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1BBE49" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="2.5.0.0" UPTO_BIN_PRODUCT_VERSION="2.5.0.0" LINK_DATE="01/21/2009 02:51:41" UPTO_LINK_DATE="01/21/2009 02:51:41" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="AirApps\AdobeAIRInstaller.exe" SIZE="15849560" CHECKSUM="0xA241A2B4" BIN_FILE_VERSION="1.5.3.9130" BIN_PRODUCT_VERSION="1.5.3.9130" PRODUCT_VERSION="1.5.3" FILE_DESCRIPTION="Adobe AIR Installer" COMPANY_NAME="Adobe Systems Inc." PRODUCT_NAME="Adobe AIR 1.5.3" FILE_VERSION="1.5.3.9130" ORIGINAL_FILENAME="Adobe AIR Installer.exe" INTERNAL_NAME="Adobe AIR Installer.exe" LEGAL_COPYRIGHT="Copyright 2009, Adobe Systems Inc." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0xF2385D" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.5.3.9130" UPTO_BIN_PRODUCT_VERSION="1.5.3.9130" LINK_DATE="02/01/2010 10:45:30" UPTO_LINK_DATE="02/01/2010 10:45:30" />
        <MATCHING_FILE NAME="as_templates\CPAS3Template.dll" SIZE="94576" CHECKSUM="0xFFC29619" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPAS3Template.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1B288" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 07:33:17" UPTO_LINK_DATE="06/07/2011 07:33:17" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="ExecutablePublish\FakeFlash.exe" SIZE="6168432" CHECKSUM="0x8CE12845" BIN_FILE_VERSION="1.0.0.1" BIN_PRODUCT_VERSION="1.0.0.1" PRODUCT_VERSION="5.0.0.0" FILE_DESCRIPTION="Flash Player" PRODUCT_NAME="Adobe Captivate" FILE_VERSION="1.0.0.1" ORIGINAL_FILENAME="FlashPlayer.exe" INTERNAL_NAME="FlashPlayer" LEGAL_COPYRIGHT="Copyright (C) 2002-2008 Adobe Systems Incorporated" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x5E7773" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.0.1" UPTO_BIN_PRODUCT_VERSION="1.0.0.1" LINK_DATE="08/05/2010 15:39:37" UPTO_LINK_DATE="08/05/2010 15:39:37" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="HLC\HLC.dll" SIZE="168816" CHECKSUM="0x476C1D9" BIN_FILE_VERSION="5.0.0.1" BIN_PRODUCT_VERSION="5.0.0.1" PRODUCT_VERSION="5, 0, 0, 1" FILE_DESCRIPTION="Adobe Captivate HLC Library" PRODUCT_NAME="HLC Dynamic Link Library" FILE_VERSION="5, 0, 0, 1" ORIGINAL_FILENAME="HLC.dll" INTERNAL_NAME="HLC" LEGAL_COPYRIGHT="© 2010 Adobe Systems Incorporated.
     All Rights Reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x349BD" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.1" UPTO_BIN_PRODUCT_VERSION="5.0.0.1" LINK_DATE="03/01/2010 10:18:29" UPTO_LINK_DATE="03/01/2010 10:18:29" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="JVM\bin\awt.dll" SIZE="1339493" CHECKSUM="0xDF21B5B5" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="awt.dll" INTERNAL_NAME="awt" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1510C4" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:05" UPTO_LINK_DATE="09/07/2006 23:06:05" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="JVM\bin\axbridge.dll" SIZE="94321" CHECKSUM="0x5BC35DFB" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="ActiveX Bridge for JavaBeans(TM)" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="axbridge.dll" INTERNAL_NAME="ActiveX Bridge for JavaBeans(TM)" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x17B82" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 22:51:18" UPTO_LINK_DATE="09/07/2006 22:51:18" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="JVM\bin\cmm.dll" SIZE="192613" CHECKSUM="0x7A13C65F" BIN_FILE_VERSION="1.1.0.0" BIN_PRODUCT_VERSION="1.1.0.0" PRODUCT_VERSION="1.1.0" FILE_DESCRIPTION="KODAK DIGITAL SCIENCE Java CMM" COMPANY_NAME="Eastman Kodak Company" PRODUCT_NAME="KODAK DIGITAL SCIENCE Java CMM" FILE_VERSION="1.1.0" ORIGINAL_FILENAME="cmm.dll" INTERNAL_NAME="cmm" LEGAL_COPYRIGHT="Eastman Kodak Company 1997" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x2F829" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.1.0.0" UPTO_BIN_PRODUCT_VERSION="1.1.0.0" LINK_DATE="09/07/2006 23:06:06" UPTO_LINK_DATE="09/07/2006 23:06:06" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="JVM\bin\dcpr.dll" SIZE="143462" CHECKSUM="0x246E1B98" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="dcpr.dll" INTERNAL_NAME="dcpr" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x2D191" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:06" UPTO_LINK_DATE="09/07/2006 23:06:06" VER_LANGUAGE="Language Neutral [0x0]" />
        <MATCHING_FILE NAME="JVM\bin\deploy.dll" SIZE="69632" CHECKSUM="0x700186B3" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) Deployment Library" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="deploy.dll" INTERNAL_NAME="Java(TM) Deployment Library" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1492B" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:06" UPTO_LINK_DATE="09/07/2006 23:06:06" VER_LANGUAGE="Language Neutral [0x0]" />
        <MATCHING_FILE NAME="JVM\bin\dt_shmem.dll" SIZE="32872" CHECKSUM="0x6968A64D" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="dt_shmem.dll" INTERNAL_NAME="dt_shmem" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x176C0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:06" UPTO_LINK_DATE="09/07/2006 23:06:06" VER_LANGUAGE="Language Neutral [0x0]" />
        <MATCHING_FILE NAME="JVM\bin\dt_socket.dll" SIZE="28778" CHECKSUM="0x84D180D4" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="dt_socket.dll" INTERNAL_NAME="dt_socket" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xF117" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:06" UPTO_LINK_DATE="09/07/2006 23:06:06" VER_LANGUAGE="Language Neutral [0x0]" />
        <MATCHING_FILE NAME="JVM\bin\eula.dll" SIZE="61545" CHECKSUM="0xE9927472" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="EULA" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="eula.dll" INTERNAL_NAME="EULA" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x172DF" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:06" UPTO_LINK_DATE="09/07/2006 23:06:06" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="JVM\bin\fontmanager.dll" SIZE="258166" CHECKSUM="0x1274DBF3" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="fontmanager.dll" INTERNAL_NAME="fontmanager" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x442A1" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:06" UPTO_LINK_DATE="09/07/2006 23:06:06" VER_LANGUAGE="Language Neutral [0x0]" />
        <MATCHING_FILE NAME="JVM\bin\hpi.dll" SIZE="32878" CHECKSUM="0x73C1312C" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="hpi.dll" INTERNAL_NAME="hpi" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x107EE" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:06" UPTO_LINK_DATE="09/07/2006 23:06:06" VER_LANGUAGE="Language Neutral [0x0]" />
        <MATCHING_FILE NAME="JVM\bin\hprof.dll" SIZE="122983" CHECKSUM="0xEC39C0B" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="hprof.dll" INTERNAL_NAME="hprof" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x23DAB" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:06" UPTO_LINK_DATE="09/07/2006 23:06:06" VER_LANGUAGE="Language Neutral [0x0]" />
        <MATCHING_FILE NAME="JVM\bin\instrument.dll" SIZE="57466" CHECKSUM="0x883CA566" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="instrument.dll" INTERNAL_NAME="instrument" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x10CB1" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:06" UPTO_LINK_DATE="09/07/2006 23:06:06" VER_LANGUAGE="Language Neutral [0x0]" />
        <MATCHING_FILE NAME="JVM\bin\ioser12.dll" SIZE="28802" CHECKSUM="0xAD2EB248" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="ioser12.dll" INTERNAL_NAME="ioser12" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xEE33" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:06" UPTO_LINK_DATE="09/07/2006 23:06:06" VER_LANGUAGE="Language Neutral [0x0]" />
        <MATCHING_FILE NAME="JVM\bin\j2pkcs11.dll" SIZE="69768" CHECKSUM="0xC85E5932" BIN_FILE_VERSION="1.5.0.0" BIN_PRODUCT_VERSION="1.5.0.0" PRODUCT_VERSION="1.5.0.0" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0" FILE_VERSION="1.5.0.0" ORIGINAL_FILENAME="j2pkcs11.dll" INTERNAL_NAME="j2pkcs11" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1AD81" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.5.0.0" UPTO_BIN_PRODUCT_VERSION="1.5.0.0" LINK_DATE="09/07/2006 23:06:06" UPTO_LINK_DATE="09/07/2006 23:06:06" VER_LANGUAGE="Language Neutral [0x0]" />
        <MATCHING_FILE NAME="JVM\bin\jaas_nt.dll" SIZE="24698" CHECKSUM="0xCD7A90E" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="jaas_nt.dll" INTERNAL_NAME="jaas_nt" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x13B3A" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:07" UPTO_LINK_DATE="09/07/2006 23:06:07" VER_LANGUAGE="Language Neutral [0x0]" />
        <MATCHING_FILE NAME="JVM\bin\java.dll" SIZE="118890" CHECKSUM="0x3C339B6F" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="java.dll" INTERNAL_NAME="java" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x24C53" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:07" UPTO_LINK_DATE="09/07/2006 23:06:07" VER_LANGUAGE="Language Neutral [0x0]" />
        <MATCHING_FILE NAME="JVM\bin\java.exe" SIZE="49248" CHECKSUM="0xFA61D8B4" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="java.exe" INTERNAL_NAME="java" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 21:14:36" UPTO_LINK_DATE="09/07/2006 21:14:36" VER_LANGUAGE="Language Neutral [0x0]" />
        <MATCHING_FILE NAME="JVM\bin\javacpl.exe" SIZE="45171" CHECKSUM="0xFEDD854D" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) Control Panel" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="javacpl.exe" INTERNAL_NAME="Java(TM) Control Panel" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 22:48:06" UPTO_LINK_DATE="09/07/2006 22:48:06" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="JVM\bin\javaw.exe" SIZE="53346" CHECKSUM="0x42775B6F" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="javaw.exe" INTERNAL_NAME="javaw" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 21:14:46" UPTO_LINK_DATE="09/07/2006 21:14:46" VER_LANGUAGE="Language Neutral [0x0]" />
        <MATCHING_FILE NAME="JVM\bin\JavaWebStart.dll" SIZE="147456" CHECKSUM="0xB7413D6C" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="1.5.0.0" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) Web Start ActiveX Control" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="JavaWebStart.dll" INTERNAL_NAME="Java(TM) Web Start ActiveX Control" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x27D0C" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="1.5.0.0" LINK_DATE="09/07/2006 23:06:07" UPTO_LINK_DATE="09/07/2006 23:06:07" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="JVM\bin\javaws.exe" SIZE="127078" CHECKSUM="0x1A417F05" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) Web Start Launcher" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="javaws.exe" INTERNAL_NAME="Java(TM) Web Start Launcher" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 22:38:23" UPTO_LINK_DATE="09/07/2006 22:38:23" VER_LANGUAGE="Language Neutral [0x0]" />
        <MATCHING_FILE NAME="JVM\bin\java_crw_demo.dll" SIZE="32881" CHECKSUM="0x10146607" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="java_crw_demo.dll" INTERNAL_NAME="java_crw_demo" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x15121" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:07" UPTO_LINK_DATE="09/07/2006 23:06:07" VER_LANGUAGE="Language Neutral [0x0]" />
        <MATCHING_FILE NAME="JVM\bin\jawt.dll" SIZE="24679" CHECKSUM="0x4B519BEC" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="jawt.dll" INTERNAL_NAME="jawt" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x130DD" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:07" UPTO_LINK_DATE="09/07/2006 23:06:07" VER_LANGUAGE="Language Neutral [0x0]" />
        <MATCHING_FILE NAME="JVM\bin\JdbcOdbc.dll" SIZE="53365" CHECKSUM="0x995B7807" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="JdbcOdbc.dll" INTERNAL_NAME="JdbcOdbc" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x14329" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:07" UPTO_LINK_DATE="09/07/2006 23:06:07" VER_LANGUAGE="Language Neutral [0x0]" />
        <MATCHING_FILE NAME="JVM\bin\jdwp.dll" SIZE="200800" CHECKSUM="0xB11149FD" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="jdwp.dll" INTERNAL_NAME="jdwp" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x3225A" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:07" UPTO_LINK_DATE="09/07/2006 23:06:07" VER_LANGUAGE="Language Neutral [0x0]" />
        <MATCHING_FILE NAME="JVM\bin\jpeg.dll" SIZE="127079" CHECKSUM="0xA4D3E4C3" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="jpeg.dll" INTERNAL_NAME="jpeg" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x2D9F1" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:07" UPTO_LINK_DATE="09/07/2006 23:06:07" VER_LANGUAGE="Language Neutral [0x0]" />
        <MATCHING_FILE NAME="JVM\bin\jpicom32.dll" SIZE="86129" CHECKSUM="0xD3430683" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) Plug-in COM Library" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="jpicom32.dll" INTERNAL_NAME="Java(TM) Plug-in COM Library" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x22034" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:07" UPTO_LINK_DATE="09/07/2006 23:06:07" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="JVM\bin\jpiexp32.dll" SIZE="98417" CHECKSUM="0xFC4D755B" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) Plug-in for Internet Explorer" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="jpiexpl32.dll" INTERNAL_NAME="Java(TM) Plug-in for Internet Explorer" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1CE73" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:07" UPTO_LINK_DATE="09/07/2006 23:06:07" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="JVM\bin\jpinscp.dll" SIZE="86127" CHECKSUM="0x632553BF" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="jpinscp.dll" INTERNAL_NAME="Java(TM) Plug-in Netscape Core Library" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1C495" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:07" UPTO_LINK_DATE="09/07/2006 23:06:07" VER_LANGUAGE="Language Neutral [0x0]" />
        <MATCHING_FILE NAME="JVM\bin\jpioji.dll" SIZE="49266" CHECKSUM="0x98611FD" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="jpioji.dll" INTERNAL_NAME="Java(TM) Plug-in OJI Library" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x186E4" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:07" UPTO_LINK_DATE="09/07/2006 23:06:07" VER_LANGUAGE="Language Neutral [0x0]" />
        <MATCHING_FILE NAME="JVM\bin\jpishare.dll" SIZE="77937" CHECKSUM="0x21BE2B69" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) Plug-in Share Library" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="jpishare.dll" INTERNAL_NAME="Java(TM) Plug-in Share Library" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1D8BE" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:07" UPTO_LINK_DATE="09/07/2006 23:06:07" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="JVM\bin\jsound.dll" SIZE="147567" CHECKSUM="0x6C869F2A" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="jsound.dll" INTERNAL_NAME="jsound" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x32A0A" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:07" UPTO_LINK_DATE="09/07/2006 23:06:07" VER_LANGUAGE="Language Neutral [0x0]" />
        <MATCHING_FILE NAME="JVM\bin\jsoundds.dll" SIZE="32883" CHECKSUM="0x5978B3DB" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="jsoundds.dll" INTERNAL_NAME="jsoundds" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x84FF" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:07" UPTO_LINK_DATE="09/07/2006 23:06:07" VER_LANGUAGE="Language Neutral [0x0]" />
        <MATCHING_FILE NAME="JVM\bin\jucheck.exe" SIZE="241775" CHECKSUM="0x1953E4D8" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) Update Checker" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="jucheck.exe" INTERNAL_NAME="Java(TM) Update Checker" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 22:42:59" UPTO_LINK_DATE="09/07/2006 22:42:59" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="JVM\bin\jusched.exe" SIZE="49263" CHECKSUM="0x9F95B06C" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="jusched.exe" INTERNAL_NAME="Java(TM) Update Scheduler" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 22:43:16" UPTO_LINK_DATE="09/07/2006 22:43:16" VER_LANGUAGE="Language Neutral [0x0]" />
        <MATCHING_FILE NAME="JVM\bin\keytool.exe" SIZE="53368" CHECKSUM="0xF122C1BE" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="keytool.exe" INTERNAL_NAME="keytool" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 21:33:06" UPTO_LINK_DATE="09/07/2006 21:33:06" VER_LANGUAGE="Language Neutral [0x0]" />
        <MATCHING_FILE NAME="JVM\bin\kinit.exe" SIZE="53364" CHECKSUM="0x62518154" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="kinit.exe" INTERNAL_NAME="kinit" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 21:33:54" UPTO_LINK_DATE="09/07/2006 21:33:54" VER_LANGUAGE="Language Neutral [0x0]" />
        <MATCHING_FILE NAME="JVM\bin\klist.exe" SIZE="53364" CHECKSUM="0x62518154" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="klist.exe" INTERNAL_NAME="klist" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 21:34:03" UPTO_LINK_DATE="09/07/2006 21:34:03" VER_LANGUAGE="Language Neutral [0x0]" />
        <MATCHING_FILE NAME="JVM\bin\ktab.exe" SIZE="53362" CHECKSUM="0x62518154" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="ktab.exe" INTERNAL_NAME="ktab" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 21:34:12" UPTO_LINK_DATE="09/07/2006 21:34:12" VER_LANGUAGE="Language Neutral [0x0]" />
        <MATCHING_FILE NAME="JVM\bin\management.dll" SIZE="32897" CHECKSUM="0x2329125A" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="management.dll" INTERNAL_NAME="management" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1233F" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:08" UPTO_LINK_DATE="09/07/2006 23:06:08" VER_LANGUAGE="Language Neutral [0x0]" />
        <MATCHING_FILE NAME="JVM\bin\net.dll" SIZE="77926" CHECKSUM="0x92D4172C" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="net.dll" INTERNAL_NAME="net" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1AD93" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:08" UPTO_LINK_DATE="09/07/2006 23:06:08" VER_LANGUAGE="Language Neutral [0x0]" />
        <MATCHING_FILE NAME="JVM\bin\nio.dll" SIZE="36967" CHECKSUM="0xD210D466" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="nio.dll" INTERNAL_NAME="nio" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x16F21" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:08" UPTO_LINK_DATE="09/07/2006 23:06:08" VER_LANGUAGE="Language Neutral [0x0]" />
        <MATCHING_FILE NAME="JVM\bin\NPJava11.dll" SIZE="69743" CHECKSUM="0x7B4C1FEA" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java Plug-in 1.5.0_09 for Netscape Navigator (DLL Helper)" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="NPJava11.dll" INTERNAL_NAME="Java(TM) Plug-in" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x133B7" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:08" UPTO_LINK_DATE="09/07/2006 23:06:08" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="JVM\bin\NPJava12.dll" SIZE="69743" CHECKSUM="0x234CA07C" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java Plug-in 1.5.0_09 for Netscape Navigator (DLL Helper)" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="NPJava12.dll" INTERNAL_NAME="Java(TM) Plug-in" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x166EF" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:08" UPTO_LINK_DATE="09/07/2006 23:06:08" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="JVM\bin\NPJava13.dll" SIZE="69743" CHECKSUM="0xE4D2025" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java Plug-in 1.5.0_09 for Netscape Navigator (DLL Helper)" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="NPJava13.dll" INTERNAL_NAME="Java(TM) Plug-in" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1490B" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:08" UPTO_LINK_DATE="09/07/2006 23:06:08" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="JVM\bin\NPJava14.dll" SIZE="69743" CHECKSUM="0x74CC59B1" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java Plug-in 1.5.0_09 for Netscape Navigator (DLL Helper)" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="NPJava14.dll" INTERNAL_NAME="Java(TM) Plug-in" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1E7EB" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:08" UPTO_LINK_DATE="09/07/2006 23:06:08" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="JVM\bin\NPJava32.dll" SIZE="69743" CHECKSUM="0x624E22F8" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java Plug-in 1.5.0_09 for Netscape Navigator (DLL Helper)" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="NPJava32.dll" INTERNAL_NAME="Java(TM) Plug-in" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x206E4" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:08" UPTO_LINK_DATE="09/07/2006 23:06:08" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="JVM\bin\NPJPI150_09.dll" SIZE="69746" CHECKSUM="0x7B49F343" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java Plug-in 1.5.0_09 for Netscape Navigator (DLL Helper)" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="NPJPI&quot;150_09&quot;.dll" INTERNAL_NAME="Java(TM) Plug-in" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x20796" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:08" UPTO_LINK_DATE="09/07/2006 23:06:08" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="JVM\bin\NPOJI610.dll" SIZE="69743" CHECKSUM="0xF64F2987" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java Plug-in 1.5.0_09 for Netscape Navigator (DLL Helper)" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="NPOJI610.dll" INTERNAL_NAME="Java(TM) Virtual Machine for Netscape and Mozilla" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1BB6B" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:08" UPTO_LINK_DATE="09/07/2006 23:06:08" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="JVM\bin\orbd.exe" SIZE="53383" CHECKSUM="0x55E23BA1" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="orbd.exe" INTERNAL_NAME="orbd" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 22:03:31" UPTO_LINK_DATE="09/07/2006 22:03:31" VER_LANGUAGE="Language Neutral [0x0]" />
        <MATCHING_FILE NAME="JVM\bin\pack200.exe" SIZE="53376" CHECKSUM="0xC7AC3BDE" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="pack200.exe" INTERNAL_NAME="pack200" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 22:04:46" UPTO_LINK_DATE="09/07/2006 22:04:46" VER_LANGUAGE="Language Neutral [0x0]" />
        <MATCHING_FILE NAME="JVM\bin\policytool.exe" SIZE="53374" CHECKSUM="0xC8E041BF" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="policytool.exe" INTERNAL_NAME="policytool" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 21:33:44" UPTO_LINK_DATE="09/07/2006 21:33:44" VER_LANGUAGE="Language Neutral [0x0]" />
        <MATCHING_FILE NAME="JVM\bin\RegUtils.dll" SIZE="143473" CHECKSUM="0x7148B389" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="RegUtils.dll" INTERNAL_NAME="RegUtils" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x325C1" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:08" UPTO_LINK_DATE="09/07/2006 23:06:08" VER_LANGUAGE="Language Neutral [0x0]" />
        <MATCHING_FILE NAME="JVM\bin\rmi.dll" SIZE="24677" CHECKSUM="0x82CE3442" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="rmi.dll" INTERNAL_NAME="rmi" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x14389" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:08" UPTO_LINK_DATE="09/07/2006 23:06:08" VER_LANGUAGE="Language Neutral [0x0]" />
        <MATCHING_FILE NAME="JVM\bin\rmid.exe" SIZE="53362" CHECKSUM="0xC922C1BE" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="rmid.exe" INTERNAL_NAME="rmid" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 21:56:12" UPTO_LINK_DATE="09/07/2006 21:56:12" VER_LANGUAGE="Language Neutral [0x0]" />
        <MATCHING_FILE NAME="JVM\bin\rmiregistry.exe" SIZE="53374" CHECKSUM="0xC8E041BF" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="rmiregistry.exe" INTERNAL_NAME="rmiregistry" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 21:55:53" UPTO_LINK_DATE="09/07/2006 21:55:53" VER_LANGUAGE="Language Neutral [0x0]" />
        <MATCHING_FILE NAME="JVM\bin\servertool.exe" SIZE="53395" CHECKSUM="0x8CC0CFD8" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="servertool.exe" INTERNAL_NAME="servertool" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 22:03:40" UPTO_LINK_DATE="09/07/2006 22:03:40" VER_LANGUAGE="Language Neutral [0x0]" />
        <MATCHING_FILE NAME="JVM\bin\ssv.dll" SIZE="434279" CHECKSUM="0x4E83B310" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="ssv.dll" INTERNAL_NAME="ssv" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x7191B" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:08" UPTO_LINK_DATE="09/07/2006 23:06:08" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="JVM\bin\tnameserv.exe" SIZE="53392" CHECKSUM="0x3B8540BB" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="tnameserv.exe" INTERNAL_NAME="tnameserv" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 22:03:12" UPTO_LINK_DATE="09/07/2006 22:03:12" VER_LANGUAGE="Language Neutral [0x0]" />
        <MATCHING_FILE NAME="JVM\bin\unicows.dll" SIZE="245400" CHECKSUM="0x226D997F" BIN_FILE_VERSION="1.0.4011.0" BIN_PRODUCT_VERSION="1.0.4011.0" PRODUCT_VERSION="1.0.4011.0" FILE_DESCRIPTION="Microsoft Layer for Unicode on Win9x Systems (MSLU)" COMPANY_NAME="Microsoft Corporation" PRODUCT_NAME="Microsoft (R) Windows (R) 95, Windows (R) 98, and Windows (R) Millennium Operating Systems" FILE_VERSION="1.0.4011.0" ORIGINAL_FILENAME="UnicoWS.dll" INTERNAL_NAME="Godot.dll" LEGAL_COPYRIGHT="© Microsoft Corporation. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x41644" LINKER_VERSION="0x60000" UPTO_BIN_FILE_VERSION="1.0.4011.0" UPTO_BIN_PRODUCT_VERSION="1.0.4011.0" LINK_DATE="03/10/2003 22:59:25" UPTO_LINK_DATE="03/10/2003 22:59:25" VER_LANGUAGE="Language Neutral [0x0]" />
        <MATCHING_FILE NAME="JVM\bin\unpack.dll" SIZE="61566" CHECKSUM="0x536847B7" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="unpack.dll" INTERNAL_NAME="unpack" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x16FBE" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:09" UPTO_LINK_DATE="09/07/2006 23:06:09" VER_LANGUAGE="Language Neutral [0x0]" />
        <MATCHING_FILE NAME="JVM\bin\unpack200.exe" SIZE="127101" CHECKSUM="0x2D7B0B" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="unpack.dll" INTERNAL_NAME="unpack" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 22:04:20" UPTO_LINK_DATE="09/07/2006 22:04:20" VER_LANGUAGE="Language Neutral [0x0]" />
        <MATCHING_FILE NAME="JVM\bin\verify.dll" SIZE="49252" CHECKSUM="0x7A01B3FB" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="verify.dll" INTERNAL_NAME="verify" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1072C" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:09" UPTO_LINK_DATE="09/07/2006 23:06:09" VER_LANGUAGE="Language Neutral [0x0]" />
        <MATCHING_FILE NAME="JVM\bin\w2k_lsa_auth.dll" SIZE="24692" CHECKSUM="0x874B9E58" BIN_FILE_VERSION="1.5.0.0" BIN_PRODUCT_VERSION="1.5.0.0" PRODUCT_VERSION="1.5.0_07.0" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0_07" FILE_VERSION="1.5.0_07.0" ORIGINAL_FILENAME="w2k_lsa_auth.dll" INTERNAL_NAME="w2k_lsa_auth" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x12A25" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.5.0.0" UPTO_BIN_PRODUCT_VERSION="1.5.0.0" LINK_DATE="09/07/2006 23:06:09" UPTO_LINK_DATE="09/07/2006 23:06:09" VER_LANGUAGE="Language Neutral [0x0]" />
        <MATCHING_FILE NAME="JVM\bin\zip.dll" SIZE="61547" CHECKSUM="0xA4FB5883" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java(TM) 2 Platform Standard Edition binary" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition 5.0 Update 9" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="zip.dll" INTERNAL_NAME="zip" LEGAL_COPYRIGHT="Copyright © 2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x15878" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:09" UPTO_LINK_DATE="09/07/2006 23:06:09" VER_LANGUAGE="Language Neutral [0x0]" />
        <MATCHING_FILE NAME="JVM\bin\client\jvm.dll" SIZE="1613945" CHECKSUM="0x69A9A0B2" BIN_FILE_VERSION="5.0.90.1" BIN_PRODUCT_VERSION="5.0.90.1" PRODUCT_VERSION="5.0.90.1" FILE_DESCRIPTION="Java HotSpot(TM) Client VM" COMPANY_NAME="Sun Microsystems, Inc." PRODUCT_NAME="Java(TM) 2 Platform Standard Edition" FILE_VERSION="5.0.90.1" ORIGINAL_FILENAME="jvm.dll" INTERNAL_NAME="jvm" LEGAL_COPYRIGHT="Copyright © 2005" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1974E1" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.90.1" UPTO_BIN_PRODUCT_VERSION="5.0.90.1" LINK_DATE="09/07/2006 23:06:09" UPTO_LINK_DATE="09/07/2006 23:06:09" VER_LANGUAGE="Language Neutral [0x0]" />
        <MATCHING_FILE NAME="Microsoft.VC80.DebugCRT\msvcm80d.dll" SIZE="1015808" CHECKSUM="0x4753EC37" BIN_FILE_VERSION="8.0.50727.762" BIN_PRODUCT_VERSION="8.0.50727.762" PRODUCT_VERSION="8.00.50727.762" FILE_DESCRIPTION="Microsoft® C Runtime Library" COMPANY_NAME="Microsoft Corporation" PRODUCT_NAME="Microsoft® Visual Studio® 2005" FILE_VERSION="8.00.50727.762" ORIGINAL_FILENAME="MSVCM80D.DLL" INTERNAL_NAME="MSVCM80D.DLL" LEGAL_COPYRIGHT="© Microsoft Corporation.  All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xFEFD5" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="8.0.50727.762" UPTO_BIN_PRODUCT_VERSION="8.0.50727.762" LINK_DATE="12/02/2006 06:52:14" UPTO_LINK_DATE="12/02/2006 06:52:14" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="Microsoft.VC80.DebugCRT\msvcp80d.dll" SIZE="1036288" CHECKSUM="0x4FB8414E" BIN_FILE_VERSION="8.0.50727.762" BIN_PRODUCT_VERSION="8.0.50727.762" PRODUCT_VERSION="8.00.50727.762" FILE_DESCRIPTION="Microsoft® C++ Runtime Library" COMPANY_NAME="Microsoft Corporation" PRODUCT_NAME="Microsoft® Visual Studio® 2005" FILE_VERSION="8.00.50727.762" ORIGINAL_FILENAME="MSVCP80D.DLL" INTERNAL_NAME="MSVCP80D.DLL" LEGAL_COPYRIGHT="© Microsoft Corporation.  All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x104491" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="8.0.50727.762" UPTO_BIN_PRODUCT_VERSION="8.0.50727.762" LINK_DATE="12/02/2006 06:52:51" UPTO_LINK_DATE="12/02/2006 06:52:51" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="Microsoft.VC80.DebugCRT\msvcr80d.dll" SIZE="1175552" CHECKSUM="0xADEB8523" BIN_FILE_VERSION="8.0.50727.762" BIN_PRODUCT_VERSION="8.0.50727.762" PRODUCT_VERSION="8.00.50727.762" FILE_DESCRIPTION="Microsoft® C Runtime Library" COMPANY_NAME="Microsoft Corporation" PRODUCT_NAME="Microsoft® Visual Studio® 2005" FILE_VERSION="8.00.50727.762" ORIGINAL_FILENAME="MSVCR80D.DLL" INTERNAL_NAME="MSVCR80D.DLL" LEGAL_COPYRIGHT="© Microsoft Corporation.  All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x12E0C9" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="8.0.50727.762" UPTO_BIN_PRODUCT_VERSION="8.0.50727.762" LINK_DATE="12/02/2006 06:50:26" UPTO_LINK_DATE="12/02/2006 06:50:26" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="Microsoft.VC80.DebugMFC\mfc80d.dll" SIZE="2404352" CHECKSUM="0xB5D5C1F5" BIN_FILE_VERSION="8.0.50727.762" BIN_PRODUCT_VERSION="8.0.50727.762" PRODUCT_VERSION="8.00.50727.762" FILE_DESCRIPTION="MFCDLL Shared Library - Debug Version" COMPANY_NAME="Microsoft Corporation" PRODUCT_NAME="Microsoft® Visual Studio® 2005" FILE_VERSION="8.00.50727.762" ORIGINAL_FILENAME="MFC80D.DLL" INTERNAL_NAME="MFC80D.DLL" LEGAL_COPYRIGHT="© Microsoft Corporation.  All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x2598F1" LINKER_VERSION="0x80000" UPTO_BIN_FILE_VERSION="8.0.50727.762" UPTO_BIN_PRODUCT_VERSION="8.0.50727.762" LINK_DATE="12/02/2006 08:05:12" UPTO_LINK_DATE="12/02/2006 08:05:12" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="Microsoft.VC80.DebugMFC\mfc80ud.dll" SIZE="2406912" CHECKSUM="0x563BF969" BIN_FILE_VERSION="8.0.50727.762" BIN_PRODUCT_VERSION="8.0.50727.762" PRODUCT_VERSION="8.00.50727.762" FILE_DESCRIPTION="MFCDLL Shared Library - Debug Version" COMPANY_NAME="Microsoft Corporation" PRODUCT_NAME="Microsoft® Visual Studio® 2005" FILE_VERSION="8.00.50727.762" ORIGINAL_FILENAME="MFC80UD.DLL" INTERNAL_NAME="MFC80UD.DLL" LEGAL_COPYRIGHT="© Microsoft Corporation.  All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x2569E5" LINKER_VERSION="0x80000" UPTO_BIN_FILE_VERSION="8.0.50727.762" UPTO_BIN_PRODUCT_VERSION="8.0.50727.762" LINK_DATE="12/02/2006 08:06:49" UPTO_LINK_DATE="12/02/2006 08:06:49" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="Microsoft.VC80.DebugMFC\mfcm80d.dll" SIZE="114688" CHECKSUM="0x7BEBE154" BIN_FILE_VERSION="8.0.50727.762" BIN_PRODUCT_VERSION="8.0.50727.762" PRODUCT_VERSION="8.00.50727.762" FILE_DESCRIPTION="MFC Managed Library - Debug Version" COMPANY_NAME="Microsoft Corporation" PRODUCT_NAME="Microsoft® Visual Studio® 2005" FILE_VERSION="8.00.50727.762" ORIGINAL_FILENAME="MFCM80D.DLL" INTERNAL_NAME="MFCM80D.DLL" LEGAL_COPYRIGHT="© Microsoft Corporation.  All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1C80B" LINKER_VERSION="0x80000" UPTO_BIN_FILE_VERSION="8.0.50727.762" UPTO_BIN_PRODUCT_VERSION="8.0.50727.762" LINK_DATE="12/02/2006 08:09:11" UPTO_LINK_DATE="12/02/2006 08:09:11" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="Microsoft.VC80.DebugMFC\mfcm80ud.dll" SIZE="102400" CHECKSUM="0xF65DA344" BIN_FILE_VERSION="8.0.50727.762" BIN_PRODUCT_VERSION="8.0.50727.762" PRODUCT_VERSION="8.00.50727.762" FILE_DESCRIPTION="MFC Managed Library - Debug Version" COMPANY_NAME="Microsoft Corporation" PRODUCT_NAME="Microsoft® Visual Studio® 2005" FILE_VERSION="8.00.50727.762" ORIGINAL_FILENAME="MFCM80UD.DLL" INTERNAL_NAME="MFCM80UD.DLL" LEGAL_COPYRIGHT="© Microsoft Corporation.  All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1F6DE" LINKER_VERSION="0x80000" UPTO_BIN_FILE_VERSION="8.0.50727.762" UPTO_BIN_PRODUCT_VERSION="8.0.50727.762" LINK_DATE="12/02/2006 08:09:27" UPTO_LINK_DATE="12/02/2006 08:09:27" VER_LANGUAGE="English (United States) [0x409]" />
        <MATCHING_FILE NAME="SWF_Components\AlternateReporting\AlternateReporting.exe" SIZE="12288" CHECKSUM="0x2D610552" MODULE_TYPE="WIN32" PE_CHECKSUM="0x7B28" LINKER_VERSION="0x0" LINK_DATE="07/21/2009 19:22:14" UPTO_LINK_DATE="07/21/2009 19:22:14" />
        <MATCHING_FILE NAME="swf_templates\CPSwf9Template.dll" SIZE="3820912" CHECKSUM="0xA39EE160" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPSwf9Template.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x3A989E" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 07:33:01" UPTO_LINK_DATE="06/07/2011 07:33:01" VER_LANGUAGE="English (United States) [0x409]" />
    </EXE>
    <EXE NAME="CPCSXSUI.dll" FILTER="GRABMI_FILTER_THISFILEONLY">
        <MATCHING_FILE NAME="CPCSXSUI.dll" SIZE="69488" CHECKSUM="0xFEAABCA8" BIN_FILE_VERSION="5.0.2.630" BIN_PRODUCT_VERSION="5.0.2.630" PRODUCT_VERSION="5.0.2.630" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe® Captivate®" FILE_VERSION="5.0.2.630" ORIGINAL_FILENAME="CPCSXSUI.dll" LEGAL_COPYRIGHT=" 2002-2010 Adobe Systems Incorporated. All rights reserved. See the legal notices in the about box." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1A5B2" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.2.630" UPTO_BIN_PRODUCT_VERSION="5.0.2.630" LINK_DATE="06/07/2011 07:31:25" UPTO_LINK_DATE="06/07/2011 07:31:25" VER_LANGUAGE="English (United States) [0x409]" />
    </EXE>
    <EXE NAME="kernel32.dll" FILTER="GRABMI_FILTER_THISFILEONLY">
        <MATCHING_FILE NAME="kernel32.dll" SIZE="989696" CHECKSUM="0x2D998938" BIN_FILE_VERSION="5.1.2600.5781" BIN_PRODUCT_VERSION="5.1.2600.5781" PRODUCT_VERSION="5.1.2600.5781" FILE_DESCRIPTION="Windows NT BASE API Client DLL" COMPANY_NAME="Microsoft Corporation" PRODUCT_NAME="Microsoft® Windows® Operating System" FILE_VERSION="5.1.2600.5781 (xpsp_sp3_gdr.090321-1317)" ORIGINAL_FILENAME="kernel32" INTERNAL_NAME="kernel32" LEGAL_COPYRIGHT="© Microsoft Corporation. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xFE572" LINKER_VERSION="0x50001" UPTO_BIN_FILE_VERSION="5.1.2600.5781" UPTO_BIN_PRODUCT_VERSION="5.1.2600.5781" LINK_DATE="03/21/2009 14:06:58" UPTO_LINK_DATE="03/21/2009 14:06:58" VER_LANGUAGE="English (United States) [0x409]" />
    </EXE>
    </DATABASE>
    Sep 8, 2011 9:19 AM   in reply to Allen_Partridge
    Hi Allen,
    I'm getting the same thing happening here. Captivate 5 stops working if you open a Photoshop or Flash file. I'm not even all that good yet, so my files are relatively small for the most part. Let me know if you can't see the info pasted below.
    I have the eLearning Suite 5 pack.
    Apr 24, 2012 9:52 AM   in reply to ToadLauncher
    No anwers yet, and the issue is still happening? It's been almost 3 years since the last post here!
    It looks like it's common across many different types of systems, but just in case:
    Win7 x64
    Core2 Duo E8500 3.16 GHz
    4GB RAM
    1GB Video RAM
    I frequently have Captivate 5 open
    Every time I open PS CS5 while Captivate is already open, Captivate crashes. It happens when I open Dreamweaver also. I haven't tried any others, but these are the ones I use most.
    Any help would be greatly apreciated.
    Feb 13, 2013 2:06 PM   in reply to mnealonjr
    This same issue has recently arisen for me. After quite a while working successfully with eLearning Suite 2 round-tripping and having other Apps open such as Photoshop or Illustrator, Cp5 is now crashing during round-tripping, and also when opening PS or AI while Cp5 is open.
    A reinstall of the suite did not help. It seemed OK in testing right after the reinstall, but after working with Captivate for an hour or so, it crashed when I opened Photoshop.
    This gets very awkward and frustrating to try to work with images and screen captures independently of having Captivate open! Of course it's worse when you open Photoshop without thinking and crash an hour's worth of work.
