I am following the procedure outlined in Trent’s Blog:
http://www.trentmueller.com/blog/search-and-replace-wildcard-character s-in-dreamweaver.html
This is fantastic stuff and will really help me.
I have a few (but only a few) times had success.
It says to “Use regular expression.” What does that mean? What is an “irregular expression?” I have tried with the box checked and unchecked. Usually with the box checked it will not Find my string. I uncheck the box and it sometimes does.
Example:
Link to www.schembs.com/TEST_jds_1.html
At the moment all the Cases are identical. I have not uploaded the .css to the site so the right-most formating is not properly displaying. It does work when the .css is available.
In the source code I literally copy the line of code:
<p class="type_X"><u>Joh. Heinrich Schöm (1713-1785) <span class="right-most">1.</span></u></p>
and paste it into the Find box of F&R. I then put my cursor above the line and it does not Find it, giving me the “Done. Not found in current document.” response. I uncheck the “Use regular expression” box and it will find it.
THEN,
I try using a wildcard (with the box checked), Finding:
<p class="type_X">([^<]*)< p>
or
<p class="type_X">[^”]*< p>
and it will find the misc. lines, e.g. where the text is “Case #1”, but not the lines of interest, with Heinrich’s name. With the box unchecked it Finds nothing.
Really would appreciate help. Thanks.
jds
http://www.regular-expressions.info/
Mylenium
A regular expression is a pattern for matching text. It uses a combination of literal characters and special symbols or sequences of characters (technically called metacharacters or metasequences) to represent such things as the beginning and end of a line or any alphanumeric character. For example, \d represents any number (single digit), \d* represents zero or more numbers in sequence.
I have written a tutorial series on using regular expressions in Dreamweaver here: http://www.adobe.com/devnet/dreamweaver/articles/regular_expressions_p t1.html.
or
They're not wildcards, but regular expressions. The first part matches the literal characters <p class="type_X">. The next sections use metacharacters.
([^<]*) matches zero or more characters (and as many as possible) that don't include an opening angle bracket (<). The parentheses "capture" the value that's matched so it can be used in a replace sequence.
[^"]* matches zero or more characters (and as many as possible) that don't include a double quote. There are no parentheses, so the value is not captured for reuse.
The closing <p> matches those literal characters.
Regular expressions are not easy, but they're extremely powerful, and a good skill to acquire.
Your reply was very helpful. Unfortunately I concluded that I could only use the Wildcard capability in some of the cases. There are too many permutations of the raw callouts that the scripts get too complicated -- one had fourteen wildcards. I am guessing that if one were more expert, there are ways of writing more advanced scripts and solving it that way. But only using it as a novice it will be very helpful. The rest of my work will be brute force. Thanks.
jds
