1
Media Encoder Stops Encoding with the New CS5.5
May 24, 2011 May 24, 2011
I just upgraded to CS5.5 a yesterday and having some issues encoding an 1 1/2 program for a DVD. The program doesn't seem to crash per se, just stops encoding. The task manager says it's running. I tried to encode the same sequence, but shorter and have the in and out points go through the part where it always stops and it worked fine. It's just when I try the entire sequence it stops. Anyone have any experience like this with CS5.5 just coming out?
Thank you,
Doug
74.0K
replies 259 Replies 259
I have the exactly same problem here. The AME stops while encoding arbitrarily without announcing an error message. I hope, that adobe or anyone can help to solve this problem.
With CS 5, I never had problems like this.
Marco
Win7 64 Bit
I7 CPU 940 @ 2.93 GHz 3.06 GHz
RAM 12 GB
NVidia Quadro FX 4800
Blackmagic Decklink Studio 2
May 25, 2011 May 25, 2011
I've was on the phone with them most of the day yesterday (5/24/2011) and after several hours they ended up turning off the Mercury Playback Engine and rendering my sequence just with the software and it made it all the way through. They reinstalled the nVidia Quadra 5800 drivers and I ran a test last night with MPE back on. This morning the problem is still here. Every time I quit the Media Encoder I would have to use the Task Manager to kill the process as the ME would not actually quit on its own.
Adobe Employee ,
Please provide more information about the nature of the encoding job:
  • Is it from a Premiere Sequence, an After Effects comp, a single clip imported directly into AME?
  • Does AME hang at exactly the same point every time? If so, what's happening at that point in the sequence?
  • What type of content is involved? Video clips, still images, image sequences...? What format(s), codec(s), resolution(s), etc.?
  • What effects are applied?
  • What is resource usage, especially CPU usage when the hang occurs?
If you're exporting from Premiere, does the hang also occur when you go down the Export Now path rather than sending it out through AME ("Queue")?
If you still have CS5.0 installed, does AME hang while encoding the same job?
May 27, 2011 May 27, 2011
Hello Mark
I've tested again and here are my results (I excuse my knowledge of English)
- its from a Premiere Pro CS5.5 Sequence. The sequence is "Blackmagic Design DVCPROHD 720p50"
- the footage was captured with the Decklink Studio 2 in DVCPROHD 720p50 (avi), and slowed down in the time-line to 72% speed (I capture 8mm-films in 25fps and change the speed to 18 fps)
- AME hangs never at the same point, it stops always at different points, somewhere in the timeline. If I export directly from Premiere Pro (not with AME), the encoding hangs too, but never at the same point.
- I use the following FXs: "RGB-Kurven" (RGB-curves?) and "Scharfzeichner" (in english sharpener?)
- the resource report shows 0% CPU usage!
And here a picture from AME and PPro with the timeline, so that you can see, that there is nothing in the timeline that could apply the "crash".
I also have CS5.0 installed again, and in CS5, there are absolutely no problems in PPro and in AME, everything works fine without errors.
I hope that everything is clear.
Thanks for your help and greetings from switzerland
Marco
My issues seem to be resolved as us yesterday, but today..... we are back to the drawing board. Nvidia released an update to my graphics card, the Nvidia Quadro FX 5800 to 270.73. Rendering via software only was terrible slow!! Now on to my continued problems with my Drobo Pro's performance.
Jun 14, 2015 Jun 14, 2015
I am using Premiere Pro CS5.5, and I had a similar problem when I upgraded my NVIDIA graphics card to a legacy Quadro 2000 in new condition. Rendering would just stop arbitrarily at some point an hour or more into a render. Rending worked when Mercury engine turned off, but of course was slow.
To begin with, I didn't have the correct driver. Then got a version of the driver (276.14) that matched the vintage of my system (circa 2011-12) from the NVIDIA support people (very helpful chat service). Did a clean install of the driver but that didn't work either.
Finally did a clean install of Windows 7, and installed the NVIDIA 276.14 driver immediately after the system install. Did not include the NVIDIA WMI option. I did not include Windows updates. I have since had two consecutive successful overnight renders.
PS: When I get my system and software working as it was before the clean system install, I will make a system image back-up, and make restore point. Then I will update Windows.
May 31, 2011 May 31, 2011
Please read my post from a little over a week ago: "F4V File Loses 30 Minutes of 1 Hour Presentation" After conferencing with an Adobe AME specialist and a young fellow at work who works in both PC and Mac, it is possible my problems stem from the original f4v file being encoded on a Mac, possibly Final Cut Pro. This young guy understands codecs and claims that I needed to have the Quick Time codecs installed on the ssd 64x computer where CS5 is installed in order for AME to do a proper encoding.This is despite the fact that the file I was given was a high quality f4v!
In the end the only way I was able to use the 202mb f4v file was to purchase QT Pro and encode it in there for web use. However, the movie quality was unacceptable at anything less than 200mb so I pulled the audio files off (also poor quality) and married them with the Powerpoint presentation and turned that into a stunning flash movie that was a respectable 33mb, so no buffering on the website. The client then did an unofficial "Monday Morning Quarterbacking" poll in the office to see what I did wrong. They all said I didn't have the correct software. Hmm. I would have never guessed in a million years that I needed anything to do with Quicktime to encode an f4v file in Adobe Media Encoder for use in a Flash player?
This may not be related to your problem but the inability to encode a large file without destroying the end of it seems to be the same issue? I am back using CS4 on my other machine until there is a resolution. The only thing I am using in CS5 is photoshop.
Guest
Aug 03, 2011 Aug 03, 2011
Hi, I'm having the same problem you seemed to be having. If you have resolved it, could you please post your solution since I can't really find a way to fix this. It's happening on two different computers. I can export the problem areas just fine but not the whole thing.
I've cleaned cache. Deleted render files. Rendered everything again. Removed effects and Nothing.
-Omar
Adobe Employee ,
Hi Omar, Do you have GPU acceleration enabled in Premiere Pro? If so, does switching to Software Only resolve the issue?
Aug 13, 2011 Aug 13, 2011
I am having exactly the same problem. AME just quits encoding at seemingly random points in my 1 hour 720p 29.97 fps Premiere Pro 5.5 timeline, with the entire timeline rendered successfully showing green. Just like you, it doesn't crash or report through Windows as not responding. It just hangs, with the time elapsed continuing to count up but the time remaining frozen. I had even let it go overnight to see if it would eventually complete--nope, just frozen at exactly the same spot where it previously stopped. The point at which it freezes is different each time I re-try the encoding. I've cleaned the cache, re-rendered footage, etc. and nothing helps. I've switched between Memory and Performance in the memory settings. I've queued it in AME and tried exporting directly out of PP 5.5, with identical results. I've re-tried over a dozen times, rebooting the computer each time and trying different encodings and settings each time. I was able to get it to successfully complete H.264 29.97fps SD encoding once out of over a dozen tries. The fact that it CAN complete is an interesting bit of information and implies that there is nothing wrong with the timeline or elements in it (although you would expect that anything that renders with a green line successfully in PP would also be able to be exported, right?). But I've never been able to get it to finish again since.
Win 7 64, i7 980x, 3.3Ghz, 24 GB ram, Quadro FX4800, only Windows and Adobe software installed. OS, all software and drivers updated to most current versions. Adobe Production Premium 5.0 had its issues, but never as severe as this.
Obviously given the other posts, the issue is not an isolated one. This one can't be blamed on Microsoft or inadequate system specs. This is a serious, serious flaw that makes the entire 5.5 upgrade essentially unusable.
Has anyone figured out a sensible work-around?
Guest
Hi, Actually I fixed mine on two different computers by simply turning the machine off for a while (just a couple of minutes) and then starting back up. restart didn't work. It had to be shut off. I've no idea why.
In the mean time I was exporting by sending the entire sequence to after effects and using the after effects render queue. It worked flawlessly but has it's limitations. For one, it will essentially consume your premiere timeline turning it into a single AE comp, so no re editing (Of course if you hit undo in premiere after the linked comp is made, the comp remains in ae but is undone in premiere giving you back your timeline but this unlinks your sequence from after effects so you must create a new AE sequence everytime you modify the premiere sequence - not to mention it's an extra step and who likes extra steps). It won't work if you already have after effects linked comps in the sequence. (They will appear off line and again, you can relink them but it's a pain and yet another extra step)
To answer Mark Mapes question. I had one computer running gpu accelerated and another running software only. Switching to software only- and in and of itself this would be a limited solution if it worked- didn't work at all.
Thanks so much. I will try these and let everyone know how it goes. Very much appreciated!
Well, my problem happened with CS5, not 5.5. I don't encode enough to be able to say that it continues to be a problem. However, I would still pull up my CS4 AME if I needed to encode something again. But honestly, it sounds like the same problem as I had. My problem may have been further complicated by running CS5 as 64 bit.
For the record, I was never able to fully encode the f4v file I was given. AME behaved as though it was corrupt at the same point each time, shaving off about a half hour of the presentation. For several days I thought it was only a half hour presentation! I was given this file by an a/v company that caters corporate meetings. It was a video that combined a Powerpoint presentation and the audio from the podium. I asked for a file that I could use for Flash because their world is all Quicktime.
As I said, in the end the only way I could salvage this project was to extract the audio by encoding the f4v with Quicktime Pro and then use a third party software to marry it to the PPT presentation for a flash movie. That is a whole other issue I wish Adobe would look into, being able to encode PPT for flash. Corporations are doing some really cool presentations for business but MS just doesn't play well with Adobe Flash. It would really help me to be able to take my client's stuff and put it up on the web easily.
The young guy I work with said it was the lack of Quicktime codecs on my computer that was the hangup because in all likelihood they encoded the f4v with Final Cut Pro.
I work in a broadcast HD tv station. We are attempting to transition our clients commercial material to database for use on-air using computer files they provide (to get away from video tape). I can't tell you how much trouble missing codecs has been with this. Clients make their stuff in all kinds of environments and it can be professional or amateur. Sometimes the video is there but the audio is missing or vice versa. Sometimes one 30 sec spot will be fine, but the next one in the same file will take a 30 sec spot and stretch it into a 5 min timeline, losing the audio and playing the video slo mo. Our editing system is Grass Valley's Edius so that adds a whole new problem with codecs. It took us a long time just to figure out how to open a .mov on a timeline. So in the end we replaced one headache with muliple tape formats to a bigger headache with multiple codecs and proprietary software programs.
Sep 03, 2011 Sep 03, 2011
AME will randomly stop encoding, without warning, without errors in any log I can find.  The GUI is still active but it won't successfully stop the encoding that it's stuck on.  After killing the process and deleting the partially completed output file I have to reset the status on the one it failed on and press start again.  That job will complete just fine when it's restarted again – so there’s nothing wrong with the input - some hours later it'll inevitably stop again.
The frequency of AME failures seems to be higher if Windows Explorer goes anywhere near the AME output location.
Turning off SEP (real time anti virus) doesn’t seem to reduce the problem.  Starting a long queue of AME after a restart doesn’t seem to help – some hours later it’ll fail.
Difficult to figure out which Adobe component is failing – a map would help.  I mean to use process explorer to look for leaks next time.
Is there any sort of Adobe logging that can be turned on can we turn on to find out what or why it stopped?
Real pain when you have 100 or more jobs queued up to run all day or all night and Adobe consistently falls down on the job
...and when you restart the "saved queue" it'll end up re-encoding things it had already encoded prior to the crash.  So, in a production environment, using AME not only costs you the lost time from when it stops functioning and sits there doing absolutely nothing, but it also increases the wear and tear on your equipment by unnecessarily burning CPU/GPU/storage and electricity generating heat repeating things.  Add to that the time required to sort out what it has or hasn’t duplicated.  I’m guessing it’s using a text file to keep track of what it did – C:\Users\imaUser\AppData\Roaming\Adobe\Adobe Media Encoder\5.5\batch.xml - and when it is forced to crash (even after you manually command it to Save Queue (?) the queue was not actually saved and is not accurate on re-boot  e.g., Anyone know the schema of the AME queue?
Basically you can’t trust the queue if a light volume environment – say 50 things at a time – you’ll need a control system to check what you asked it to do, what it did and what it didn’t.  You have to police it.  “production bundle”…
So, if I can’t trust Adobe to provide the work flow in its production bundle is there an API I can call rather [relying on] AME?  I think that Sony product supports scripting…
Guest
Sep 04, 2011 Sep 04, 2011
Interesting that people keep running into this problem. I thought I solved mine a while ago by shutting down the computer. In fact, sadly, it only works every other time. I've also managed to get this to encode by removing certain effects from the timeline. Those clips with questionable effects will encode fine if the work area is small enough but will fail if the sequence is longer. I've also encountered the problem with timelines that have no effects.
I've been sending my projects to after effects to export using the render queue.  I'm onm a mac so I don't think it's a windows specific problem
Sep 05, 2011 Sep 05, 2011
Adobe tech support sent me a list of things to try, such as removing all 3rd party plugins and killing all processes other than those by MS. I did everything on the list, including uninstalling all software and utiltities except the Win 7 operating system and Adobe CS5.5, and the problem persists. I, like others, have found that turning off GPU hardware acceleration makes is much more likely to finish encoding, although it takes much longer. One of the big selling points for CS5 and 5.5 is that it uses Mercury playback engine. Another is the 3rd party plugins on the Adobe website, which apparently cannot be used with CS5.5. Adobe tech support tried to set up a phone consultation, but I've been too busy lately to schedule a time where I could spend hours on the phone. The problem can only be checked to see if it is solved by rendering a long timeline, which could take several hours. I can't imagine how that could be possible while staying on the phone. It seems like when AME quits processing, it typically does so near the end of rendering anyway. The fact that AME will sometimes finish using software acceleration only, makes it the most practical workaround for now until they find the problem and fix it. I just have to plan to do outputs several days in advance, knowing that it might take several overnight render tries before one finally succeeds. I can't imagine how anyone could possibly run a professional media company using this product. I also cannot understand how Adobe couldn't replicate the problem. My system is an Intel i7 980x, 24 GB RAM, Quadro FX 4800, plenty of fast, clean hard drive space, and clean install of Win 7 and Adobe Production Premium CS5.5. Off the network except briefly only to do an Adobe software and Win 7 update, then immediately back off. That's it, nothing exotic, no bizarre hardware of software configurations, nothing strange installed, no shareware or weird applications or net browsing malware. Project is just video, AE compositions, and still photographs that render in the timeline (green line) just fine. Again, nothing unusual or exotic.
By the way, ifI try to export from Premiere to After Effects it just crashes.
I skimmed quickly over the posts in this topic and I didn't see any mention of checking the usual hardware suspects:
  1. Video card drivers.  Update directly from the nVidia/AMD web site and don't rely on what came with the computer or the card.
  2. Heat.  Make sure you have plenty of fans in the case and that they're all doing their job.  If a component has its own fan, make sure it's running and that it's not blocked by other things inside the case.
  3. Power supply. Make sure your power supply can handle all the stuff in your case.
  4. UPS. Make sure the UPS can handle the load that the power supply pulls.
The comment about letting the computer sit while shut off for a while resulting in better chances of the encode finishing is a big red flag to me that heat is at least playing a part in this.
-Jeff
EDIT: I'll add "remove dust inside the case" and "update your audio card drivers" to that list as well.
Thanks for the great suggestions, Jeff. I can't speak for anyone else, but in my case all drivers are up to date, and the hardware is new, clean, has twice the needed wattage, and a good UPS. AME in CS 5.0 didn't have this problem and it only started upon upgrade to CS 5.5. But now that I've upgraded to 5.5 the projects aren't backwards compatible.
You mentioned AE Compositions being part of your Pr timeline.  Are those instances intermediate video files or are the comps dynamically linked?  If you're using dynamic link, check your system memory usage during the render.  If it keeps increasing until all 24 GBs is used up, try eliminating the AE comps or replacing them with rendered video files from AE.
Also check that you have enough room on your system drive to handle any temp files that the AME creates during the encode.  Folks have had space problems even if there's plenty of room on the media/project drives.  Checking permissions wouldn't hurt, either (but I don't think it's likely).
Have you checked the encoding logs to see if there's a clue there?
-Jeff
I have had an open case open with Adobe ever since I purchased the upgrade and have spent countless hours on the phone. The problem is somewhere between Adobe and NVidia’s video card driver. The problem still continues… and very frustrated!!
Post the case number for your open case, and I will see what I can find out about why it's still open.
182349424
Thanks, Doug. I'll see what I can find out.
