I use FAP.
My assumption has always been that this was due to the temporary naming via Photoshop of "Vector Smart Objectx.ai". I believe that the file once it is placed into PS is then reopened for the first time in AI and possibly the reuse of the naming is at issue?
FAP auto-activation works with AI/PS quite well and I don't see this notice unless it comes from an SO, and then it's not consistent and/or repeatable.
We're still not entirely sure what the Illustrator team means by that message.
Photoshop has removed pages and unused parts of the file, but we can't trim or modify the Illustrator custom information and it detects that the file has been modified.
What part are they keeping or discarding? We don't know.
Have "sort of" been following this thread and I just saw something interesting on a Peach Pit TV video.
Check it out at 3:05:
http://www.youtube.com/watch?v=7Rv4f554C6s&feature=player_embedded#at= 10
I looks like Matt gets the same dialog box that we do and it LOOKS like he ignores it. What do you all think?
Elaine
Marian Driscoll wrote:
What does it matter if it is more common?
That video shows the alert displayed out of context. We cannot tell if Matt already had the file open in Photoshop. We cannot tell if the screencast was unedited.
If the issue is more common than Adobe currently believes, than maybe Adobe will devote some resources to investigating it. I wouldn't care about getting an annoying message about the disk copy being changed if I knew that the changes were just the wrong time date stamp, but I would like to know what the actual changes are since none are visible to my eye. Having lived with this issue for over two months I feel like there is some poltergeist that lives in my computer making unknown changes to my files. Neither Apple or Adobe seems to know what is modifying my files.
If the file was already open in photoshop and then opened and modified in camera raw, it shouldn't trigger a message about the disk copy being changed, right?
There does not seem to be an unwillingness from Adobe to look at the problem. Adobe cannot investigate something it cannot see. Those in this discussion that see this problem have been unable to report what process is tweaking their file. Unless you want to send your system to Adobe, there is not much that they can do.
This topic is not new. There have been many others like it that are unfortunately hidden with this forum's malfunctioning search. Try Google for much more explanation on the topic.
I agree, but there are bugs that Adobe can reproduce that have been overlooked for the past couple releases, so it's reasonable to think that they do need to allocate resources to bigger bugs, new features and new releases. This would be true of any business. It would be great to think that any bug that can be reproduced is going to be fixed but that hasn't been the case.
Fixing bugs doesn't generate as much money as maintaining a constant release schedule. But generating new dollars keeps the guys/gals around to fix the old bugs.
I have not accused Adobe of being unwilling to look at the problem. I would be willing to have Adobe look at my system if they are interested.
We have investigated, and found that the file was modified by applications outside of Photoshop just like the message says.
When we test it on our systems without those other applications, we never get the warning because nothing else is modifying the files.
That depends on your settings in ACR. Yes, it could change the file on disk with the right settings.
Hi Mugge
> It only happen when working over network. Not on the local disk.
If you cleaned off your working drive and have the same problems, what are the specs for this network drive that you are saving to?
On a clean install why are you reinstalling CS4?
Do you have the problem if Bridge is not running?
Hi there.
It is not a network drive. We have 3 computers (Mac Pro) connected in a network and the internal drives in one of the computers are the storage drive.
Lets call them. Computer 1,2 and 3 and computer 1 is the main computer with all the files on a internal drive (2TB SATA II HD)
So we work on the files from all 3 computers and when i sometimes work on computer 2 or 3 with a images. I get this error message when saveing.
Ofcause no one else is touching the file i work on (Then that would be why it comes) so thats not the reason.
Then some days ago i bought a external Firewire 800 Raid 0,1,5 case and moved the storage drives in to that case for safety (Raid mirror now) and
it works great but we still have the same error message. So both on the old internal system and also now with external drives.
I just installed both CS4 and CS5 so i could keep on working if something happen or CS5 woulden work right.
Actually i never tried working with out Bridge running also. Photoshop and Bridge is always running together when i work because it is so much easier
to located the image i need in Bridge instead of in photoshop (Open file) and before we upgraded the computers to 10.6.x from 10.5.x i never saw this
error. It all started after 10.6 Snow Leo. I dont think its because of Snow Leo because others also have the problem on 10.5.x Leopard.
Specs.
3 Mac Pro 8-Core 2008 with internal drives. 16GB of ram. Mac OS X 10.6.7 in 2 and 10.5.8 in the third.
All 3 computers are attached to a 10/100/1000 switch so everyone have access to the files/images.
Before last week the files was stored on the internal drive on Computer 1 but now the files are stored on a external firewire 800 case (Raid Mirror)
No matter what i do i get this message ones in a wile. The funny thing is. It is not every day. Yesterday i was working all day and it never came.
Today it did ??? Really weird.
>then some days ago i bought a external Firewire 800 Raid 0,1,5 case and moved the storage drives in to that case for safety
this new RAID is directly connected to your computer via Firewire, or attached to the networked computer?
you may have already mentioned this... does the save error occur on the other computers too?
thanks
Apple engineering had me track a PSB file in terminal that was open in photoshop. During the time period that the file was being tracked, I did not open the file in any other applications. When I received the message about the disk copy being modified, I sent Apple the Terminal Saved Output as well as Capture. Engineering has come back to me and told me that the only process to set attributes on the file being tracked was setattrlist and that process occurred about 10 times during the seven hour time period that the file was open.
Attached are selections of the logs from around 15:34:36 when setattrlist first starts appearing. Also attached is a selection from the log from around the time that I received the message that the disk copy was changed.
The setattrlist calls only happen when Photoshop is saving the file. Setattrlist is not a process, but a function in the OS that sets files attributes.
That's how the file system sets things like the file name, file type, etc.
You were using fs_usage, and the format of the report is:
time_stamp file_operation file path time_taken Flags Process_Name
It sounds like your apple technician confused the file operation with the process name.
Yes, the Dropbox calls are disturbing -- it is getting info on files that are nowhere near it's directories.
dbfseventsd also appears to be a Dropbox related service, and also getting info on files nowhere near the Dropbox directory. (are you sure you didn't set Dropbox to use the whole disk by mistake?)
The MacOS spotlight (mds) code is also getting info on the temporary file.
Dropbox and spotlight should be ignoring all files in the /tmp and /TemporaryItems directories. Those are bugs, but probably not causing this issue.
And Bridge opens the file to create a thumbnail after it has been closed by Photoshop, but does not write to the file.
Unfortunately, what you show here is just the time around the Photoshop save (between open and rename), and not much of what happens AFTER Photoshop saves the file when changes are being made. In the second log, we can see backupd open the file, but we don't see everything it did with the file.
Also, it would be much easier to read if we had the text version instead of downsampled screen captures.
Thanks for your help, Chris. I tried attaching the entire log in both docx. and txt. formats and both times got a message about the content type not being allowed and the attachment exceeding 2.0 MG so I have done a copy and paste of the entire document below.
Password:
14:59:40 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000011 Adobe Photos
14:59:40 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000007 Adobe Photos
15:01:09 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000041 Adobe Photos
15:01:09 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000035 Adobe Photos
15:01:09 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000006 Adobe Photos
15:01:09 open /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>> 0.000022 Adobe Photos
15:34:00 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000037 Adobe Photos
15:34:00 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000006 Adobe Photos
15:34:00 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000008 Adobe Photos
15:34:00 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000005 Adobe Photos
15:34:00 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000010 Adobe Photos
15:34:11 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000021 Adobe Photos
15:34:11 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000008 Adobe Photos
15:34:11 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000007 Adobe Photos
15:34:11 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000006 Adobe Photos
15:34:11 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000005 Adobe Photos
15:34:11 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 29907 0.000012 Adobe Photos
15:34:25 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 29907 14.345821 W Adobe Photos
15:34:25 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 29907 0.000026 Adobe Photos
15:34:25 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 29907 0.000010 Adobe Photos
15:34:25 setattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 29907 0.000111 W Adobe Photos
15:34:25 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 29907 0.000008 Adobe Photos
15:34:25 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 29907 0.000012 Adobe Photos
15:34:25 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 29907 0.000007 Adobe Photos
15:34:25 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 29907 0.000045 Adobe Photos
15:34:25 stat64 HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 29907 0.008609 W mds
15:34:25 stat HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 29907 0.008352 W Dropbox
15:34:25 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 29907 0.000013 Adobe Photos
15:34:25 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 29907 0.000011 Adobe Photos
15:34:25 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 29907 0.000028 Adobe Photos
15:34:25 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 29907 0.000006 Adobe Photos
15:34:25 setattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 29907 0.000022 Adobe Photos
15:41:36 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 29907 0.000030 Adobe Photos
15:41:36 access_extended /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000014 Adobe Photos
15:41:36 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000012 Adobe Photos
15:41:36 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 29907 0.000009 Adobe Photos
15:41:36 listxattr HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 29907 0.000009 Adobe Photos
15:41:36 listxattr /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000007 Adobe Photos
15:41:36 stat64 HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 29907 0.000015 mds
15:41:36 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000035 Adobe Photos
15:41:36 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000008 Adobe Photos
15:41:36 open /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>> 0.000017 Adobe Photos
15:41:36 stat HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 29907 0.000021 dbfseventsd
15:41:36 stat HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 29907 0.000064 Dropbox
15:41:36 setattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 29907 0.005649 W Adobe Photos
15:41:36 rename HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 29907 0.030882 W Adobe Photos
15:41:36 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000038 Adobe Photos
15:41:36 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000009 Adobe Photos
15:41:36 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000011 Adobe Photos
15:41:36 setattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000014 Adobe Photos
15:41:36 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000007 Adobe Photos
15:41:36 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000010 Adobe Photos
15:41:36 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000021 Adobe Photos
15:41:39 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000009 Adobe Bridge
15:41:39 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000010 Adobe Bridge
15:41:39 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000007 Adobe Bridge
15:41:39 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000008 Adobe Bridge
15:41:39 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000011 Adobe Bridge
15:41:39 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000014 Adobe Bridge
15:41:39 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000013 Adobe Bridge
15:41:39 open /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>> 0.000020 Adobe Bridge
15:41:39 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000020 Adobe Bridge
15:41:39 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000012 Adobe Bridge
15:41:39 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000030 Adobe Bridge
15:41:39 open /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>> 0.000024 Adobe Bridge
15:51:09 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000036 Adobe Photos
15:51:09 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000006 Adobe Photos
15:51:09 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000009 Adobe Photos
15:51:09 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000014 Adobe Photos
15:51:09 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000011 Adobe Photos
15:51:09 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000007 Adobe Photos
15:51:15 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000040 Adobe Photos
15:51:15 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000009 Adobe Photos
15:51:15 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000006 Adobe Photos
15:52:05 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000010 backupd
15:53:28 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000010 backupd
15:53:28 getattrlist c Pro/2011-06-04-145544/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000100 backupd
15:53:28 listxattr /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000008 backupd
15:53:28 getxattr /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000005 backupd
15:53:28 getxattr /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000004 backupd
15:53:28 getxattr /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000057 backupd
15:53:28 open /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000013 backupd
15:53:28 open_extended -4779-9A78-1228D3268237/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000108 backupd
15:53:28 getattrlist -4779-9A78-1228D3268237/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000046 backupd
15:55:32 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000042 Adobe Photos
15:55:32 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000008 Adobe Photos
15:55:32 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000010 Adobe Photos
15:55:32 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000007 Adobe Photos
15:55:32 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000012 Adobe Photos
15:55:55 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000021 Adobe Photos
15:55:55 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000007 Adobe Photos
15:55:55 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000008 Adobe Photos
15:55:55 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000006 Adobe Photos
15:55:55 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 96747 0.000013 Adobe Photos
15:55:55 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 96747 0.047860 W Adobe Photos
15:55:55 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 96747 0.000015 Adobe Photos
15:55:55 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 96747 0.000007 Adobe Photos
15:55:55 setattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 96747 0.000032 Adobe Photos
15:55:55 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 96747 0.000008 Adobe Photos
15:55:55 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 96747 0.000006 Adobe Photos
15:55:55 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 96747 0.000009 Adobe Photos
15:55:55 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 96747 0.000030 Adobe Photos
15:55:55 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 96747 0.000011 Adobe Photos
15:55:55 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 96747 0.000010 Adobe Photos
15:55:55 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 96747 0.000009 Adobe Photos
15:55:55 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 96747 0.000013 Adobe Photos
15:55:55 stat64 HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 96747 0.000046 mds
15:55:55 stat HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 96747 0.000014 Dropbox
15:55:55 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 96747 0.000033 Adobe Photos
15:55:55 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 96747 0.000046 W Adobe Photos
15:55:55 setattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 96747 0.000042 Adobe Photos
15:59:07 setattrlist -4779-9A78-1228D3268237/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.111422 W backupd
15:59:07 stat -4779-9A78-1228D3268237/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.101267 W dbfseventsd
15:59:08 setattrlist -4779-9A78-1228D3268237/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.574887 W backupd
15:59:08 open -4779-9A78-1228D3268237/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000060 backupd
15:59:08 stat64 -4779-9A78-1228D3268237/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000053 mds
15:59:08 stat64 /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000011 mds
15:59:08 lstat64 /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000018 mdworker
15:59:08 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000010 mdworker
15:59:08 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000016 mdworker
15:59:08 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000011 mdworker
15:59:08 open /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>> 0.000016 mdworker
15:59:08 getattrlist c Pro/2011-06-04-145544/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.095850 W backupd
15:59:09 open /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000011 mdworker
15:59:09 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000016 mdworker
15:59:09 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000008 mdworker
15:59:09 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000020 mdworker
15:59:09 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb/.DS_Store 0.000008 mdworker
15:59:09 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000006 mdworker
15:59:09 stat64 -4779-9A78-1228D3268237/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000031 mds
15:59:21 getattrlist c Pro/2011-06-04-145544/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000081 backupd
15:59:21 open c Pro/2011-06-04-145544/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000041 backupd
15:59:21 open c Pro/2011-06-04-145544/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000080 mds
15:59:21 stat64 c Pro/2011-06-04-145544/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000026 mds
15:59:25 stat64 c Pro/2011-06-04-145544/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000053 mds
16:00:15 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 96747 0.000030 backupd
16:00:15 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 96747 0.000011 backupd
16:00:48 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 96747 0.000010 backupd
16:00:48 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 96747 0.000006 backupd
16:00:48 listxattr HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 96747 0.000006 backupd
16:00:48 getxattr HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 96747 0.000004 backupd
16:00:48 getxattr HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 96747 0.420264 W backupd
16:00:48 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 96747 0.000012 backupd
16:00:49 open_extended HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 96747 0.000087 backupd
16:00:49 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 96747 0.000036 backupd
16:03:20 setattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 96747 0.000062 backupd
16:03:20 setattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 96747 0.050056 W backupd
16:03:20 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 96747 0.000042 backupd
16:03:20 stat64 HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 96747 0.000043 mds
16:03:20 stat64 HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 96747 0.000010 mds
16:03:20 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 96747 0.000009 backupd
16:04:11 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 96747 0.000043 Adobe Photos
16:04:11 access_extended /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000015 Adobe Photos
16:04:11 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000012 Adobe Photos
16:04:11 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 96747 0.000008 Adobe Photos
16:04:11 listxattr HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 96747 0.000009 Adobe Photos
16:04:11 listxattr /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000007 Adobe Photos
16:04:11 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000013 Adobe Photos
16:04:11 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000008 Adobe Photos
16:04:11 open /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>> 0.000016 Adobe Photos
16:04:11 stat64 HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 96747 0.000028 mds
16:04:11 stat HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 96747 0.000010 dbfseventsd
16:04:11 stat HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 96747 0.000020 Dropbox
16:04:11 setattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 96747 0.016557 W Adobe Photos
16:04:11 rename HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 96747 0.064186 W Adobe Photos
16:04:11 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000049 Adobe Photos
16:04:11 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000010 Adobe Photos
16:04:11 setattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000016 Adobe Photos
16:04:11 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000014 Adobe Photos
16:04:11 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000024 Adobe Photos
16:04:11 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000009 Adobe Photos
16:04:11 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000011 Adobe Photos
16:04:11 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000007 Adobe Photos
16:04:12 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000008 Adobe Bridge
16:04:12 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000010 Adobe Bridge
16:04:12 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000006 Adobe Bridge
16:04:12 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000013 Adobe Bridge
16:04:12 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000009 Adobe Bridge
16:04:12 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000007 Adobe Bridge
16:04:12 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000011 Adobe Bridge
16:04:12 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000012 Adobe Bridge
16:04:12 open /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>> 0.000019 Adobe Bridge
16:04:12 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000014 Adobe Bridge
16:04:12 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000016 Adobe Bridge
16:04:12 open /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>> 0.000020 Adobe Bridge
16:09:50 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000035 Adobe Photos
16:09:50 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000006 Adobe Photos
16:09:50 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000008 Adobe Photos
16:09:50 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000005 Adobe Photos
16:09:50 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000009 Adobe Photos
16:10:00 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000046 Adobe Photos
16:10:00 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000008 Adobe Photos
16:10:00 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000006 Adobe Photos
16:23:13 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000039 Adobe Photos
16:23:13 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000007 Adobe Photos
16:23:13 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000010 Adobe Photos
16:23:13 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000012 Adobe Photos
16:23:13 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000008 Adobe Photos
16:23:32 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000021 Adobe Photos
16:23:32 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000009 Adobe Photos
16:23:32 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000007 Adobe Photos
16:23:32 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000006 Adobe Photos
16:23:32 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406032 63940 0.000012 Adobe Photos
16:23:32 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406032 63940 0.019134 W Adobe Photos
16:23:32 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406032 63940 0.000010 Adobe Photos
16:23:32 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406032 63940 0.000007 Adobe Photos
16:23:46 setattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406032 63940 14.357960 W Adobe Photos
16:23:46 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406032 63940 0.000021 Adobe Photos
16:23:46 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406032 63940 0.000009 Adobe Photos
16:23:46 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406032 63940 0.000017 Adobe Photos
16:23:46 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406032 63940 0.000008 Adobe Photos
16:23:46 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406032 63940 0.000010 Adobe Photos
16:23:46 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406032 63940 0.000056 Adobe Photos
16:23:46 stat HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406032 63940 0.001349 W Dropbox
16:23:46 stat64 HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406032 63940 0.001606 W mds
16:23:46 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406032 63940 0.000020 Adobe Photos
16:23:46 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406032 63940 0.000016 Adobe Photos
16:23:47 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406032 63940 0.000032 Adobe Photos
16:23:47 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406032 63940 0.000006 Adobe Photos
16:23:47 setattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406032 63940 0.000023 Adobe Photos
16:24:21 stat HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406032 63940 0.016612 W dbfseventsd
16:24:21 stat64 HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406032 63940 0.016530 W mds
16:24:21 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406032 63940 0.000038 Adobe Photos
16:24:21 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406032 63940 0.000018 Adobe Photos
16:24:21 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406032 63940 0.000010 Adobe Photos
16:24:21 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406032 63940 0.000009 Adobe Photos
16:24:21 stat HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406032 63940 0.017196 W Dropbox
16:24:21 unlink HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406032 63940 0.017284 Adobe Photos
16:24:21 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000030 Adobe Photos
16:24:21 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000008 Adobe Photos
16:24:21 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000006 Adobe Photos
16:27:50 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000008 Adobe Photos
16:27:50 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000005 Adobe Photos
16:27:50 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000006 Adobe Photos
16:32:52 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000007 Adobe Photos
16:32:52 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000006 Adobe Photos
16:32:52 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000008 Adobe Photos
16:32:52 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000007 Adobe Bridge
16:32:52 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000008 Adobe Bridge
16:32:52 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000013 Adobe Bridge
fs_usage: buffer overrun, events generated too quickly: 479232
fs_usage: buffer overrun, events generated too quickly: 472479
16:42:06 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000037 Adobe Photos
16:42:06 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000006 Adobe Photos
16:42:06 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000011 Adobe Photos
16:42:06 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000010 Adobe Photos
16:42:06 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000012 Adobe Photos
16:42:06 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000007 Adobe Photos
16:42:17 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000014 Adobe Photos
16:42:17 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000012 Adobe Photos
16:42:17 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000006 Adobe Photos
16:42:17 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406033 96137 0.000016 Adobe Photos
16:42:17 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406033 96137 0.026836 W Adobe Photos
16:42:17 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406033 96137 0.000034 Adobe Photos
16:42:17 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406033 96137 0.000007 Adobe Photos
16:42:17 setattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406033 96137 0.006057 W Adobe Photos
16:42:17 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406033 96137 0.000021 Adobe Photos
16:42:17 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406033 96137 0.000006 Adobe Photos
16:42:17 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406033 96137 0.000011 Adobe Photos
16:42:17 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406033 96137 0.000040 Adobe Photos
16:42:17 stat64 HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406033 96137 0.010571 W mds
16:42:17 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406033 96137 0.000017 Adobe Photos
16:42:17 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406033 96137 0.000017 Adobe Photos
16:42:17 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406033 96137 0.000010 Adobe Photos
16:42:17 stat HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406033 96137 0.000017 Dropbox
16:42:17 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406033 96137 0.000022 Adobe Photos
16:42:17 setattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406033 96137 0.000021 Adobe Photos
16:47:06 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406033 96137 0.000022 Adobe Photos
16:47:06 access_extended /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000014 Adobe Photos
16:47:06 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000009 Adobe Photos
16:47:06 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406033 96137 0.000008 Adobe Photos
16:47:06 listxattr HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406033 96137 0.000008 Adobe Photos
16:47:06 listxattr /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000006 Adobe Photos
16:47:06 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000010 Adobe Photos
16:47:06 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000006 Adobe Photos
16:47:06 open /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>> 0.000015 Adobe Photos
16:47:06 stat HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406033 96137 0.000021 dbfseventsd
16:47:06 setattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406033 96137 0.000867 W Adobe Photos
16:47:06 stat64 HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406033 96137 0.000237 W mds
16:47:06 stat HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406033 96137 0.000151 W Dropbox
16:47:07 rename HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406033 96137 0.127046 W Adobe Photos
16:47:07 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000050 Adobe Photos
16:47:07 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000017 Adobe Photos
16:47:07 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000009 Adobe Photos
16:47:07 setattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000019 Adobe Photos
16:47:07 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000008 Adobe Photos
16:47:07 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000007 Adobe Photos
16:47:07 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000011 Adobe Photos
16:47:07 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000014 Adobe Photos
16:47:08 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000007 Adobe Bridge
16:47:08 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000006 Adobe Bridge
16:47:08 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000005 Adobe Bridge
16:47:08 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000008 Adobe Bridge
16:47:08 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000010 Adobe Bridge
16:47:08 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000009 Adobe Bridge
16:47:08 open /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>> 0.000018 Adobe Bridge
16:47:08 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000024 Adobe Bridge
16:47:08 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000039 Adobe Bridge
16:47:08 open /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>> 0.000033 Adobe Bridge
16:50:03 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000027 Adobe Photos
16:50:03 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000008 Adobe Photos
16:50:03 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000010 Adobe Photos
16:50:03 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000007 Adobe Photos
16:50:13 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000034 Adobe Photos
16:50:13 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000006 Adobe Photos
16:50:13 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000008 Adobe Photos
16:50:13 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000005 Adobe Photos
16:50:13 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000012 Adobe Photos
16:50:39 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000021 Adobe Photos
16:50:39 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000008 Adobe Photos
16:50:39 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000007 Adobe Photos
16:50:39 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000006 Adobe Photos
16:50:39 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000005 Adobe Photos
16:50:39 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406034 62176 0.000012 Adobe Photos
16:50:39 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406034 62176 0.000219 Adobe Photos
16:50:39 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406034 62176 0.000008 Adobe Photos
16:50:39 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406034 62176 0.000006 Adobe Photos
16:50:39 setattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406034 62176 0.000027 Adobe Photos
16:50:39 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406034 62176 0.000007 Adobe Photos
16:50:39 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406034 62176 0.000008 Adobe Photos
16:50:39 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406034 62176 0.000039 Adobe Photos
16:50:39 stat64 HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406034 62176 0.005308 W mds
16:50:39 stat HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406034 62176 0.004957 W Dropbox
16:50:39 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406034 62176 0.000011 Adobe Photos
16:50:39 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406034 62176 0.000011 Adobe Photos
16:50:39 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406034 62176 0.000012 Adobe Photos
16:50:39 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406034 62176 0.000033 Adobe Photos
16:50:39 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406034 62176 0.000009 Adobe Photos
16:50:39 setattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406034 62176 0.000025 Adobe Photos
16:52:22 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406034 62176 0.000012 backupd
16:52:24 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000010 backupd
16:54:45 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406034 62176 0.000011 backupd
16:54:45 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406034 62176 0.000047 backupd
16:54:45 listxattr HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406034 62176 0.000006 backupd
16:54:45 getxattr HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406034 62176 0.000005 backupd
16:54:45 getxattr HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406034 62176 0.000003 backupd
16:54:45 getxattr HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406034 62176 0.000004 backupd
16:54:45 getxattr HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406034 62176 0.000109 backupd
16:54:45 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406034 62176 0.000006 backupd
16:54:46 open_extended HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406034 62176 0.000077 backupd
16:54:46 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406034 62176 0.000034 backupd
16:55:23 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406034 62176 0.000040 Adobe Photos
16:55:23 access_extended /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000013 Adobe Photos
16:55:23 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000010 Adobe Photos
16:55:23 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406034 62176 0.000007 Adobe Photos
16:55:23 listxattr HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406034 62176 0.000007 Adobe Photos
16:55:23 listxattr /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000006 Adobe Photos
16:55:23 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000014 Adobe Photos
16:55:23 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000006 Adobe Photos
16:55:23 open /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>> 0.000015 Adobe Photos
16:55:23 stat64 HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406034 62176 0.000018 mds
16:55:23 stat HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406034 62176 0.000020 dbfseventsd
16:55:23 stat HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406034 62176 0.000016 Dropbox
16:55:23 setattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406034 62176 0.005314 W Adobe Photos
16:55:23 rename HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406034 62176 0.026141 W Adobe Photos
16:55:23 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000063 Adobe Photos
16:55:23 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000018 Adobe Photos
16:55:23 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000008 Adobe Photos
16:55:23 setattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000033 Adobe Photos
16:55:23 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000009 Adobe Photos
16:55:23 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000005 Adobe Photos
16:55:24 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000007 Adobe Bridge
16:55:24 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000008 Adobe Bridge
16:55:24 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000013 Adobe Bridge
16:55:24 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000010 Adobe Bridge
16:55:24 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000012 Adobe Bridge
16:55:24 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000006 Adobe Bridge
16:55:24 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000011 Adobe Bridge
16:55:24 open /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>> 0.000020 Adobe Bridge
16:55:24 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000050 Adobe Bridge
16:55:24 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000014 Adobe Bridge
16:55:24 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000036 Adobe Bridge
16:55:24 open /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>> 0.000024 Adobe Bridge
16:55:26 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000018 Adobe Photos
16:55:26 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000007 Adobe Photos
16:55:26 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406035 27998 0.000011 Adobe Photos
16:55:26 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406035 27998 0.000186 Adobe Photos
16:55:26 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406035 27998 0.000008 Adobe Photos
16:55:26 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406035 27998 0.000007 Adobe Photos
16:55:26 setattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406035 27998 0.000032 Adobe Photos
16:55:26 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406035 27998 0.000006 Adobe Photos
16:55:26 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406035 27998 0.000007 Adobe Photos
16:55:26 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406035 27998 0.000034 Adobe Photos
16:55:26 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406035 27998 0.000009 Adobe Photos
16:55:26 stat64 HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406035 27998 0.000042 mds
16:55:26 stat HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406035 27998 0.000031 Dropbox
16:55:26 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406035 27998 0.000022 Adobe Photos
16:55:26 setattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406035 27998 0.000021 Adobe Photos
16:58:43 setattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406034 62176 0.531621 W backupd
16:58:43 setattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406034 62176 0.075249 W backupd
16:58:45 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406034 62176 0.000073 backupd
16:58:47 stat64 HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406034 62176 0.000053 mds
16:58:47 stat64 HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406034 62176 0.243346 W mds
16:58:47 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406034 62176 0.000013 backupd
16:58:57 getattrlist c Pro/2011-06-04-160355/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000070 backupd
16:58:57 listxattr /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000007 backupd
16:58:57 getxattr /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000004 backupd
16:58:57 getxattr /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000003 backupd
16:58:57 getxattr /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000052 backupd
16:58:57 open /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000012 backupd
16:58:57 open_extended -4EB3-97DD-C21DBB520742/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000089 backupd
16:58:57 getattrlist -4EB3-97DD-C21DBB520742/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000035 backupd
17:00:07 stat64 HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406035 27998 0.000017 mds
17:00:07 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406035 27998 0.000038 Adobe Photos
17:00:08 stat HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406035 27998 0.000019 dbfseventsd
17:00:08 stat HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406035 27998 0.000012 Dropbox
17:00:08 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406035 27998 0.000015 Adobe Photos
17:00:08 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406035 27998 0.000008 Adobe Photos
17:00:08 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406035 27998 0.000010 Adobe Photos
17:00:08 unlink HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406035 27998 0.082753 W Adobe Photos
17:00:08 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406035 27998 0.000022 Adobe Photos
17:00:08 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000018 Adobe Photos
17:00:08 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000007 Adobe Photos
17:02:47 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 96747 3.010227 W backupd
17:02:47 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 96747 0.000076 backupd
17:02:47 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 96747 0.000027 mds
17:02:47 stat64 HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 96747 0.000016 mds
17:02:48 stat64 HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406031 96747 0.000019 mds
17:03:32 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000008 Finder
17:03:32 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000010 Finder
17:03:32 open /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>> 0.000013 Finder
17:03:32 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000017 Finder
17:03:32 open /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>> 0.000017 Finder
17:03:38 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000019 Finder
17:03:38 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000052 Finder
17:03:38 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000006 Finder
17:03:38 open /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>> 0.000017 Finder
17:03:44 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000027 Finder
17:03:44 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000018 Finder
17:03:53 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000043 Finder
17:03:53 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000011 Finder
17:03:53 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000008 Finder
17:03:53 open /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>> 0.000023 Finder
17:03:53 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000007 Finder
17:03:53 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000010 Finder
17:03:55 stat64 /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000021 Finder
17:03:55 stat64 /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000003 Finder
17:03:55 open /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000013 Finder
17:03:55 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000015 Finder
17:03:55 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000012 Finder
17:03:55 open /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>> 0.000016 Finder
17:03:55 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000007 Finder
17:03:55 open /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>> 0.000008 Finder
17:03:55 stat64 /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000005 Finder
17:03:55 open /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000004 Finder
17:03:55 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000005 Finder
17:03:55 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000006 Finder
17:03:55 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000004 Finder
17:03:55 stat64 /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000004 Finder
17:03:55 open /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000020 Finder
17:03:55 open /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000030 mds
17:03:55 stat64 /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000010 mds
17:03:55 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000041 Finder
17:03:55 access_extended /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000021 Finder
17:03:55 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000016 Finder
17:03:56 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000008 Finder
17:03:56 open /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000031 Finder
17:03:56 statfs64 /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000007 Finder
17:03:56 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000021 Finder
17:03:56 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000018 Finder
17:03:56 statfs64 /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000017 Finder
17:03:56 open /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000014 Finder
17:04:06 stat -4EB3-97DD-C21DBB520742/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000023 dbfseventsd
17:04:06 setattrlist -4EB3-97DD-C21DBB520742/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 8.889458 W backupd
17:04:06 setattrlist -4EB3-97DD-C21DBB520742/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.064652 W backupd
17:04:06 open -4EB3-97DD-C21DBB520742/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000026 backupd
17:04:07 stat64 -4EB3-97DD-C21DBB520742/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000063 mds
17:04:07 stat64 /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000009 mds
17:04:07 getattrlist c Pro/2011-06-04-160355/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000059 backupd
17:04:07 lstat64 /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000031 mdworker
17:04:07 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000010 mdworker
17:04:07 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000020 mdworker
17:04:07 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000009 mdworker
17:04:07 open /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>> 0.000019 mdworker
17:04:07 open /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000007 mdworker
17:04:07 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000014 mdworker
17:04:07 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb/.DS_Store 0.000007 mdworker
17:04:07 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000005 mdworker
17:04:07 stat64 -4EB3-97DD-C21DBB520742/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000016 mds
17:07:53 getattrlist c Pro/2011-06-04-160355/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 9.461580 W backupd
17:07:57 open c Pro/2011-06-04-160355/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 4.485175 W backupd
17:07:57 open c Pro/2011-06-04-160355/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000072 mds
17:07:57 stat64 c Pro/2011-06-04-160355/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000026 mds
17:07:58 stat64 c Pro/2011-06-04-160355/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000062 mds
17:10:06 getattrlist -4EB3-97DD-C21DBB520742/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000025 backupd
17:10:06 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000008 backupd
17:10:42 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000010 backupd
17:10:43 getattrlist -4EB3-97DD-C21DBB520742/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000026 backupd
17:10:43 getattrlist -4EB3-97DD-C21DBB520742/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000027 backupd
17:10:43 listxattr /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000006 backupd
17:10:43 getxattr /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000004 backupd
17:10:43 getxattr /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000003 backupd
17:10:43 getxattr /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000052 backupd
17:10:43 link -4EB3-97DD-C21DBB520742/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000145 backupd
17:10:43 getattrlist -491D-8920-D23F278EEA40/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000032 backupd
17:10:49 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406034 62176 0.000018 backupd
17:10:49 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406034 62176 0.000013 backupd
17:10:49 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406034 62176 0.000024 mds
17:10:49 stat64 HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406034 62176 0.000012 mds
17:10:53 stat64 HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406034 62176 0.000007 mds
17:11:35 unlink HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406034 62176 0.092651 W backupd
17:11:42 unlink -4EB3-97DD-C21DBB520742/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000115 backupd
19:42:08 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000038 Adobe Photos
19:42:08 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000007 Adobe Photos
19:42:08 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000010 Adobe Photos
19:42:08 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000011 Adobe Photos
19:42:08 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000008 Adobe Photos
19:42:16 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000021 Adobe Photos
19:42:16 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000008 Adobe Photos
19:42:16 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000007 Adobe Photos
19:42:16 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000006 Adobe Photos
19:42:16 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406036 03544 0.000012 Adobe Photos
19:42:30 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406036 03544 14.363280 W Adobe Photos
19:42:30 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406036 03544 0.000023 Adobe Photos
19:42:30 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406036 03544 0.000010 Adobe Photos
19:42:30 setattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406036 03544 0.000131 W Adobe Photos
19:42:30 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406036 03544 0.000008 Adobe Photos
19:42:30 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406036 03544 0.000013 Adobe Photos
19:42:30 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406036 03544 0.000007 Adobe Photos
19:42:30 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406036 03544 0.000049 Adobe Photos
19:42:30 stat64 HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406036 03544 0.007490 W mds
19:42:30 stat HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406036 03544 0.007217 W Dropbox
19:42:30 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406036 03544 0.000013 Adobe Photos
19:42:30 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406036 03544 0.000012 Adobe Photos
19:42:30 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406036 03544 0.000009 Adobe Photos
19:42:30 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406036 03544 0.000031 Adobe Photos
19:42:30 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406036 03544 0.000006 Adobe Photos
19:42:30 setattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406036 03544 0.000021 Adobe Photos
19:47:16 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406036 03544 0.000034 Adobe Photos
19:47:16 access_extended /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000018 Adobe Photos
19:47:16 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000009 Adobe Photos
19:47:16 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406036 03544 0.000007 Adobe Photos
19:47:16 listxattr HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406036 03544 0.000007 Adobe Photos
19:47:16 listxattr /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000005 Adobe Photos
19:47:16 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000006 Adobe Photos
19:47:16 open /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>> 0.000015 Adobe Photos
19:47:16 stat HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406036 03544 0.000051 dbfseventsd
19:47:16 stat64 HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406036 03544 0.000019 mds
19:47:16 stat HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406036 03544 0.000026 Dropbox
19:47:16 setattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406036 03544 0.005669 W Adobe Photos
19:47:16 rename HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406036 03544 0.030867 W Adobe Photos
19:47:16 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000032 Adobe Photos
19:47:16 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000010 Adobe Photos
19:47:16 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000008 Adobe Photos
19:47:16 setattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000015 Adobe Photos
19:47:16 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000007 Adobe Photos
19:47:16 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000011 Adobe Photos
19:47:16 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000009 Adobe Bridge
19:47:16 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000008 Adobe Bridge
19:47:16 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000010 Adobe Bridge
19:47:16 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000011 Adobe Bridge
19:47:16 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000013 Adobe Bridge
19:47:16 open /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>> 0.000019 Adobe Bridge
19:47:16 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000015 Adobe Bridge
19:47:16 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000041 Adobe Bridge
19:47:16 open /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>> 0.000025 Adobe Bridge
19:52:38 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000010 backupd
19:55:42 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000011 backupd
19:55:43 getattrlist c Pro/2011-06-04-185319/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.020556 W backupd
19:55:43 listxattr /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000010 backupd
19:55:43 getxattr /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000006 backupd
19:55:43 getxattr /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000004 backupd
19:55:43 getxattr /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000005 backupd
19:55:43 getxattr /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000063 backupd
19:55:43 open /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000013 backupd
19:55:43 open_extended -41DD-9740-41731897E8E5/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000114 backupd
19:55:43 getattrlist -41DD-9740-41731897E8E5/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000036 backupd
20:00:37 stat -41DD-9740-41731897E8E5/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 3.276815 W dbfseventsd
20:00:37 setattrlist -41DD-9740-41731897E8E5/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 4.125817 W backupd
20:00:37 setattrlist -41DD-9740-41731897E8E5/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.030814 W backupd
20:00:37 open -41DD-9740-41731897E8E5/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000035 backupd
20:00:37 stat64 -41DD-9740-41731897E8E5/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000059 mds
20:00:37 stat64 /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000010 mds
20:00:37 getattrlist c Pro/2011-06-04-185319/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000069 backupd
20:00:37 lstat64 /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000017 mdworker
20:00:37 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000008 mdworker
20:00:37 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000018 mdworker
20:00:37 open /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>> 0.000021 mdworker
20:00:38 open /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000012 mdworker
20:00:38 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000023 mdworker
20:00:38 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000013 mdworker
20:00:38 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000015 mdworker
20:00:38 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb/.DS_Store 0.000007 mdworker
20:00:38 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000005 mdworker
20:00:42 stat64 -41DD-9740-41731897E8E5/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000015 mds
20:00:58 getattrlist c Pro/2011-06-04-185319/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000095 backupd
20:00:58 open c Pro/2011-06-04-185319/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000041 backupd
20:00:58 open c Pro/2011-06-04-185319/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000200 mds
20:00:58 stat64 c Pro/2011-06-04-185319/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000075 mds
20:00:58 stat64 c Pro/2011-06-04-185319/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000043 mds
20:02:38 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000042 Adobe Photos
20:02:39 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000037 Adobe Photos
20:02:39 open /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>> 0.000024 Adobe Photos
20:08:18 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000038 Adobe Photos
20:08:18 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000006 Adobe Photos
20:08:18 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000008 Adobe Photos
20:08:18 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000005 Adobe Photos
20:08:18 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000010 Adobe Photos
20:08:26 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000021 Adobe Photos
20:08:26 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000008 Adobe Photos
20:08:26 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000007 Adobe Photos
20:08:26 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000006 Adobe Photos
20:08:26 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000005 Adobe Photos
20:08:26 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406036 05115 0.000011 Adobe Photos
20:08:26 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406036 05115 0.013742 W Adobe Photos
20:08:26 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406036 05115 0.000009 Adobe Photos
20:08:26 setattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406036 05115 0.006348 W Adobe Photos
20:08:26 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406036 05115 0.000010 Adobe Photos
20:08:26 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406036 05115 0.000008 Adobe Photos
20:08:26 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406036 05115 0.000009 Adobe Photos
20:08:26 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406036 05115 0.000007 Adobe Photos
20:08:26 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406036 05115 0.000046 Adobe Photos
20:08:26 stat64 HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406036 05115 0.014562 W mds
20:08:26 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406036 05115 0.000014 Adobe Photos
20:08:26 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406036 05115 0.000012 Adobe Photos
20:08:26 stat HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406036 05115 0.000012 Dropbox
20:08:26 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406036 05115 0.000013 Adobe Photos
20:08:26 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406036 05115 0.000029 Adobe Photos
20:08:26 setattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406036 05115 0.000022 Adobe Photos
20:13:05 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406036 05115 0.000033 Adobe Photos
20:13:05 access_extended /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000013 Adobe Photos
20:13:05 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000011 Adobe Photos
20:13:05 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406036 05115 0.000008 Adobe Photos
20:13:05 listxattr HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406036 05115 0.000010 Adobe Photos
20:13:05 listxattr /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000007 Adobe Photos
20:13:05 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000012 Adobe Photos
20:13:05 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000008 Adobe Photos
20:13:05 open /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>> 0.000017 Adobe Photos
20:13:05 stat64 HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406036 05115 0.000017 mds
20:13:05 stat HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406036 05115 0.000036 dbfseventsd
20:13:05 stat HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406036 05115 0.000037 Dropbox
20:13:05 setattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406036 05115 0.005657 W Adobe Photos
20:13:05 rename HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406036 05115 0.022510 W Adobe Photos
20:13:05 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000029 Adobe Photos
20:13:05 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000009 Adobe Photos
20:13:05 setattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000015 Adobe Photos
20:13:05 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000007 Adobe Photos
20:13:05 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000010 Adobe Photos
20:13:05 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000006 Adobe Photos
20:13:06 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000009 Adobe Bridge
20:13:06 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000008 Adobe Bridge
20:13:06 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000010 Adobe Bridge
20:13:06 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000007 Adobe Bridge
20:13:06 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000014 Adobe Bridge
20:13:06 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000011 Adobe Bridge
20:13:06 open /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>> 0.000016 Adobe Bridge
20:13:06 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000013 Adobe Bridge
20:13:06 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000017 Adobe Bridge
20:13:06 open /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>> 0.000017 Adobe Bridge
20:21:14 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000011 Adobe Photos
20:21:14 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000005 Adobe Photos
20:21:14 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000006 Adobe Photos
20:21:14 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000009 Adobe Photos
20:21:14 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000007 Adobe Photos
20:21:14 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000008 Adobe Photos
20:21:56 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000042 Adobe Photos
20:21:56 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000043 Adobe Photos
20:21:56 open /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>> 0.000027 Adobe Photos
20:43:42 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000037 Adobe Photos
20:43:42 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000010 Adobe Photos
20:43:42 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000009 Adobe Photos
20:43:42 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000005 Adobe Photos
20:43:42 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000006 Adobe Photos
20:43:50 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000022 Adobe Photos
20:43:50 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000009 Adobe Photos
20:43:50 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000007 Adobe Photos
20:43:50 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000006 Adobe Photos
20:43:50 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406037 38311 0.000012 Adobe Photos
20:44:05 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406037 38311 14.416898 W Adobe Photos
20:44:05 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406037 38311 0.000018 Adobe Photos
20:44:05 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406037 38311 0.000009 Adobe Photos
20:44:05 setattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406037 38311 0.000152 W Adobe Photos
20:44:05 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406037 38311 0.000011 Adobe Photos
20:44:05 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406037 38311 0.000008 Adobe Photos
20:44:05 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406037 38311 0.000011 Adobe Photos
20:44:05 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406037 38311 0.000007 Adobe Photos
20:44:05 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406037 38311 0.000043 Adobe Photos
20:44:05 stat64 HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406037 38311 0.010137 W mds
20:44:05 stat HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406037 38311 0.009774 W Dropbox
20:44:05 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406037 38311 0.000026 Adobe Photos
20:44:05 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406037 38311 0.000012 Adobe Photos
20:44:05 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406037 38311 0.000032 Adobe Photos
20:44:05 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406037 38311 0.000006 Adobe Photos
20:44:05 setattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406037 38311 0.000024 Adobe Photos
20:49:09 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406037 38311 0.000032 Adobe Photos
20:49:09 access_extended /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000012 Adobe Photos
20:49:09 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000009 Adobe Photos
20:49:09 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406037 38311 0.000007 Adobe Photos
20:49:09 listxattr HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406037 38311 0.000007 Adobe Photos
20:49:09 listxattr /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000005 Adobe Photos
20:49:09 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000006 Adobe Photos
20:49:09 open /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>> 0.000015 Adobe Photos
20:49:09 stat64 HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406037 38311 0.000038 mds
20:49:09 setattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406037 38311 0.000417 W Adobe Photos
20:49:09 rename HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406037 38311 0.027795 W Adobe Photos
20:49:09 stat HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406037 38311 0.010977 W dbfseventsd
20:49:09 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000067 Adobe Photos
20:49:09 stat HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406037 38311 0.000012 Dropbox
20:49:09 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000008 Adobe Photos
20:49:09 setattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000023 Adobe Photos
20:49:09 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000007 Adobe Photos
20:49:09 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000013 Adobe Photos
20:49:09 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000023 Adobe Photos
20:49:09 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000005 Adobe Photos
20:49:10 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000007 Adobe Bridge
20:49:10 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000006 Adobe Bridge
20:49:10 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000008 Adobe Bridge
20:49:10 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000005 Adobe Bridge
20:49:10 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000012 Adobe Bridge
20:49:10 open /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>> 0.000018 Adobe Bridge
20:49:10 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000010 Adobe Bridge
20:49:10 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000037 Adobe Bridge
20:49:10 open /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>> 0.000024 Adobe Bridge
fs_usage: buffer overrun, events generated too quickly: 472843
20:52:44 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000024 backupd
20:54:45 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000010 backupd
20:54:45 getattrlist c Pro/2011-06-04-200201/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000083 backupd
20:54:45 listxattr /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000008 backupd
20:54:45 getxattr /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000005 backupd
20:54:45 getxattr /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000004 backupd
20:54:45 getxattr /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000057 backupd
20:54:45 open /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000014 backupd
20:54:45 open_extended -41FF-97AD-E9798D17E83B/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000104 backupd
20:54:45 getattrlist -41FF-97AD-E9798D17E83B/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000036 backupd
21:00:10 setattrlist -41FF-97AD-E9798D17E83B/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 8.508412 W backupd
21:00:10 stat -41FF-97AD-E9798D17E83B/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 6.887168 W dbfseventsd
21:00:10 setattrlist -41FF-97AD-E9798D17E83B/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.031328 W backupd
21:00:10 open -41FF-97AD-E9798D17E83B/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000050 backupd
21:00:10 stat64 -41FF-97AD-E9798D17E83B/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000036 mds
21:00:10 stat64 /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000007 mds
21:00:10 getattrlist c Pro/2011-06-04-200201/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000037 backupd
21:00:10 lstat64 /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000018 mdworker
21:00:10 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000012 mdworker
21:00:10 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000017 mdworker
21:00:10 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000009 mdworker
21:00:10 open /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>> 0.000020 mdworker
21:00:10 open /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000012 mdworker
21:00:10 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000022 mdworker
21:00:10 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000016 mdworker
21:00:10 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000020 mdworker
21:00:10 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb/.DS_Store 0.000007 mdworker
21:00:10 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000006 mdworker
21:00:11 stat64 -41FF-97AD-E9798D17E83B/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000029 mds
21:00:24 getattrlist c Pro/2011-06-04-200201/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000034 backupd
21:00:24 open c Pro/2011-06-04-200201/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000026 backupd
21:00:24 open c Pro/2011-06-04-200201/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000251 W mds
21:00:24 stat64 c Pro/2011-06-04-200201/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000075 mds
21:00:24 stat64 c Pro/2011-06-04-200201/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000014 mds
21:04:34 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000036 Adobe Photos
21:04:34 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000006 Adobe Photos
21:04:34 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000008 Adobe Photos
21:04:34 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000005 Adobe Photos
21:04:34 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000009 Adobe Photos
21:04:42 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000021 Adobe Photos
21:04:42 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000008 Adobe Photos
21:04:42 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000007 Adobe Photos
21:04:42 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000006 Adobe Photos
21:04:42 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000005 Adobe Photos
21:04:42 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406038 05099 0.000012 Adobe Photos
21:04:42 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406038 05099 0.015315 W Adobe Photos
21:04:42 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406038 05099 0.000011 Adobe Photos
21:04:42 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406038 05099 0.000008 Adobe Photos
21:04:42 setattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406038 05099 0.005923 W Adobe Photos
21:04:42 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406038 05099 0.000025 Adobe Photos
21:04:42 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406038 05099 0.000006 Adobe Photos
21:04:42 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406038 05099 0.000017 Adobe Photos
21:04:42 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406038 05099 0.000009 Adobe Photos
21:04:42 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406038 05099 0.000067 Adobe Photos
21:04:42 stat64 HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406038 05099 0.016454 W mds
21:04:42 stat HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406038 05099 0.016131 W Dropbox
21:04:42 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406038 05099 0.000019 Adobe Photos
21:04:42 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406038 05099 0.000013 Adobe Photos
21:04:42 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406038 05099 0.000033 Adobe Photos
21:04:42 setattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406038 05099 0.000022 Adobe Photos
21:09:54 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406038 05099 0.000030 Adobe Photos
21:09:54 access_extended /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000012 Adobe Photos
21:09:54 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000010 Adobe Photos
21:09:54 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406038 05099 0.000007 Adobe Photos
21:09:54 listxattr HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406038 05099 0.000007 Adobe Photos
21:09:54 listxattr /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000006 Adobe Photos
21:09:54 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000006 Adobe Photos
21:09:54 open /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>> 0.000015 Adobe Photos
21:09:54 stat HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406038 05099 0.000032 dbfseventsd
21:09:54 stat64 HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406038 05099 0.000013 mds
21:09:54 stat HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406038 05099 0.000033 Dropbox
21:09:54 setattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406038 05099 0.005709 W Adobe Photos
21:09:54 rename HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406038 05099 0.022476 W Adobe Photos
21:09:54 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000045 Adobe Photos
21:09:54 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000007 Adobe Photos
21:09:54 setattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000015 Adobe Photos
21:09:54 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000009 Adobe Photos
21:09:54 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000011 Adobe Photos
21:09:54 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000005 Adobe Photos
21:09:54 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000013 Adobe Bridge
21:09:54 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000007 Adobe Bridge
21:09:54 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000008 Adobe Bridge
21:09:54 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000005 Adobe Bridge
21:09:54 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000006 Adobe Bridge
21:09:54 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000010 Adobe Bridge
21:09:54 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000011 Adobe Bridge
21:09:54 open /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>> 0.000014 Adobe Bridge
21:09:54 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000039 Adobe Bridge
21:09:54 open /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>> 0.000025 Adobe Bridge
21:11:44 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000056 Adobe Photos
21:11:44 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000007 Adobe Photos
21:11:44 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000006 Adobe Photos
21:28:15 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000035 Adobe Photos
21:28:15 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000006 Adobe Photos
21:28:15 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000008 Adobe Photos
21:28:15 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000005 Adobe Photos
21:28:15 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000009 Adobe Photos
21:28:25 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000027 Adobe Photos
21:28:25 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000009 Adobe Photos
21:28:25 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000007 Adobe Photos
21:28:25 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000006 Adobe Photos
21:28:25 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000005 Adobe Photos
21:28:25 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406038 72058 0.000012 Adobe Photos
21:28:40 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406038 72058 14.382905 W Adobe Photos
21:28:40 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406038 72058 0.000028 Adobe Photos
21:28:40 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406038 72058 0.000010 Adobe Photos
21:28:40 setattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406038 72058 0.000103 W Adobe Photos
21:28:40 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406038 72058 0.000008 Adobe Photos
21:28:40 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406038 72058 0.000013 Adobe Photos
21:28:40 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406038 72058 0.000007 Adobe Photos
21:28:40 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406038 72058 0.000044 Adobe Photos
21:28:40 stat64 HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406038 72058 0.000094 W mds
21:28:40 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406038 72058 0.000014 Adobe Photos
21:28:40 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406038 72058 0.000012 Adobe Photos
21:28:40 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406038 72058 0.000009 Adobe Photos
21:28:40 stat HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406038 72058 0.000036 Dropbox
21:28:40 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406038 72058 0.000025 Adobe Photos
21:28:40 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406038 72058 0.000006 Adobe Photos
21:28:40 setattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406038 72058 0.000021 Adobe Photos
21:33:54 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406038 72058 0.000038 Adobe Photos
21:33:54 access_extended /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000015 Adobe Photos
21:33:54 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000012 Adobe Photos
21:33:54 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406038 72058 0.000009 Adobe Photos
21:33:54 listxattr HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406038 72058 0.000010 Adobe Photos
21:33:54 listxattr /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000009 Adobe Photos
21:33:54 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000008 Adobe Photos
21:33:54 open /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>> 0.000018 Adobe Photos
21:33:54 stat HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406038 72058 0.000020 dbfseventsd
21:33:54 stat64 HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406038 72058 0.000055 mds
21:33:54 stat HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406038 72058 0.000097 Dropbox
21:33:54 setattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406038 72058 0.005644 W Adobe Photos
21:33:54 rename HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406038 72058 0.014178 W Adobe Photos
21:33:54 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000046 Adobe Photos
21:33:54 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000010 Adobe Photos
21:33:54 setattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000014 Adobe Photos
21:33:54 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000009 Adobe Photos
21:33:54 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000007 Adobe Photos
21:33:54 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000011 Adobe Photos
21:33:54 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000037 Adobe Photos
21:33:54 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000025 Adobe Photos
21:33:54 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000013 Adobe Photos
21:33:56 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000007 Adobe Bridge
21:33:56 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000006 Adobe Bridge
21:33:56 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000005 Adobe Bridge
21:33:56 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000008 Adobe Bridge
21:33:56 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000011 Adobe Bridge
21:33:56 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000010 Adobe Bridge
21:33:56 open /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>> 0.000014 Adobe Bridge
21:33:56 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000012 Adobe Bridge
21:33:56 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000014 Adobe Bridge
21:33:56 open /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>> 0.000017 Adobe Bridge
21:36:00 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000019 Adobe Photos
21:36:00 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000006 Adobe Photos
21:36:00 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000008 Adobe Photos
21:36:00 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000005 Adobe Photos
21:36:05 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000037 Adobe Photos
21:36:05 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000008 Adobe Photos
21:36:05 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000006 Adobe Photos
21:37:08 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000042 Adobe Photos
21:37:08 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000007 Adobe Photos
21:37:08 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000005 Adobe Photos
21:37:08 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000006 Adobe Photos
21:48:53 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000036 Adobe Photos
21:48:53 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000006 Adobe Photos
21:48:53 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000008 Adobe Photos
21:48:53 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000010 Adobe Photos
21:49:03 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000021 Adobe Photos
21:49:03 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000008 Adobe Photos
21:49:03 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000007 Adobe Photos
21:49:03 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000006 Adobe Photos
21:49:03 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406039 38832 0.000012 Adobe Photos
21:49:17 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406039 38832 14.365392 W Adobe Photos
21:49:17 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406039 38832 0.000026 Adobe Photos
21:49:17 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406039 38832 0.000010 Adobe Photos
21:49:17 setattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406039 38832 0.000093 W Adobe Photos
21:49:17 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406039 38832 0.000008 Adobe Photos
21:49:17 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406039 38832 0.000011 Adobe Photos
21:49:17 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406039 38832 0.000007 Adobe Photos
21:49:17 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406039 38832 0.000045 Adobe Photos
21:49:17 stat64 HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406039 38832 0.025809 W mds
21:49:17 stat HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406039 38832 0.019133 W Dropbox
21:49:17 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406039 38832 0.000012 Adobe Photos
21:49:17 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406039 38832 0.000012 Adobe Photos
21:49:17 open HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406039 38832 0.000013 Adobe Photos
21:49:17 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406039 38832 0.000032 Adobe Photos
21:49:17 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406039 38832 0.000006 Adobe Photos
21:49:17 setattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406039 38832 0.000022 Adobe Photos
21:53:05 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406039 38832 0.000009 backupd
21:53:07 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000009 backupd
21:55:02 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406039 38832 0.000046 Adobe Photos
21:55:02 access_extended /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000019 Adobe Photos
21:55:02 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000011 Adobe Photos
21:55:02 getattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406039 38832 0.000008 Adobe Photos
21:55:02 listxattr HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406039 38832 0.000009 Adobe Photos
21:55:02 listxattr /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000007 Adobe Photos
21:55:02 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000007 Adobe Photos
21:55:02 open /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>> 0.000021 Adobe Photos
21:55:02 stat HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406039 38832 0.000014 dbfseventsd
21:55:02 stat64 HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406039 38832 0.000043 mds
21:55:02 stat HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406039 38832 0.000034 Dropbox
21:55:02 setattrlist HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406039 38832 0.005589 W Adobe Photos
21:55:02 rename HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb9406039 38832 0.030839 W Adobe Photos
21:55:02 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000021 Adobe Photos
21:55:02 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000009 Adobe Photos
21:55:02 setattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000014 Adobe Photos
21:55:02 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000008 Adobe Photos
21:55:02 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000012 Adobe Photos
21:55:04 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000007 Adobe Bridge
21:55:04 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000006 Adobe Bridge
21:55:04 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000008 Adobe Bridge
21:55:04 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000005 Adobe Bridge
21:55:04 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000010 Adobe Bridge
21:55:04 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000009 Adobe Bridge
21:55:04 open /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>> 0.000021 Adobe Bridge
21:55:04 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000012 Adobe Bridge
21:55:04 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000026 Adobe Bridge
21:55:04 open /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>> 0.000020 Adobe Bridge
21:55:15 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000010 backupd
21:55:15 getattrlist c Pro/2011-06-04-210127/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000088 backupd
21:55:15 listxattr /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000009 backupd
21:55:15 getxattr /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000005 backupd
21:55:15 getxattr /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000004 backupd
21:55:15 getxattr /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000173 backupd
21:55:15 open /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000010 backupd
21:55:15 open_extended -4311-B922-E59F9A3B8410/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000121 backupd
21:55:15 getattrlist -4311-B922-E59F9A3B8410/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000046 backupd
21:56:41 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000041 Adobe Photos
21:56:41 getattrlist /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb 0.000006 Adobe Photos
^C
Yes, the Dropbox calls are disturbing -- it is getting info on files that are nowhere near it's directories.
dbfseventsd also appears to be a Dropbox related service, and also getting info on files nowhere near the Dropbox directory. (are you sure you didn't set Dropbox to use the whole disk by mistake?)
According to that log, backupd (TimeMachine) is backing up and modifying the temporary files -- and it shouldn't go near /temp or /TemporaryItems.
In one case it starts reading a file *while* Photoshop is still saving that file.
In some cases, it is modifying the temporary file (setattrlist).
And there are several examples of Dropbox and dbfseventsd sniffing files that it shoudn't be (also in temp directories).
dbfseventsd also appears to be sniffing file changes on the Time Machine backup volume. I double checked - it is part of Dropbox (/Library/DropboxHelperTools/...), not part of the OS - but it's monitoring every file written, everywhere. That's really sloppy, and might be slowing down my system. Ugh, I may have to uninstall Dropbox.
The players: Photoshop, Bridge, Dropbox, Time Machine, Spotlight, Finder
Photoshop creates a temp file, writes to the temp file, and renames the temp to replace the original file, plus gets stat on the files.
Bridge only reads the file, and writes to it's database.
Finder gets attributes on the file in the normal folders.
Dropbox gets stat on the files from 2 different processes (Dropbox, dbfseventsd), even outside it's directory, even in temporary directories.
Spotlight (mdworker, mds) gets stat, and reads the files, even in temporary directories, sometimes while the file is still being written.
Time Machine (backupd) gets stats, reads the files, and sometimes sets attributes on the files, even in temporary directories.
Photoshop, Bridge and Finder are acting as expected.
While Dropbox and Spotlight are doing some excess work, they don't seem to cause file modifications.
But Time Machine is doing things wrong and causing file modifications, plus would fit with the "have the file open a long time" symptom.
Thank you Chris. I will forward a link to what you have posted to Apple.
Not quite, I wanted the location of the top level Dropbox folder.
The top level dropbox folder, the one called "files for Michael" says in file > get info > where that it is located in users> the name of the user > dropbox.
Is that what you want?
I did experience the issue when Apple had me turn off time machine entirely for about a two week period. At another time Apple had me turn off dropbox entirely although it was not uninstalled. I don't remember how they had me turn it off, but the issue still occurred. The issue also occurred before I ever installed dropbox. I am not sure however if time machine and dropbox were both disabled at the same time.
I am going to test whether the issue occurs with dropbox uninstalled, time machine turned off and spotlight disabled all at the same time.
Hi.
I also have Dropbox installed but it never runs. I only start it when needed at quits it after.
But as i remember it it happen before installing Dropbox and i never use Time Machine or Spotlight.
Both are turned completely of with Cocktail ?
But i will give it a try and uninstall Dropbox totally and see if that helps. But i dough it because as
i remember it, it also happen before un-installing Dropbox.
Alright.
Last night i uninstalled Dropbox completely on the computer where all the files are stored on.
No effect. Still the same so i guess Dropbox is out of the discussion ?
Ofcause restarted and did a total maintance with Cocktail after ![]()
I think the biggest problem with this is when the message comes if you just press "Ok" to safe anyway.
The latest stuff made on the pictures is not always saved since last saving ! Thats my problem.
Sometimes it saves everything and sometimes it doesn't and all the stuff you made since last save will be lost ![]()
Thats why i mostly do a "save as" and then saves it to another location when the message comes just to be 100%
and then after copying to the right location at the end. Lots of extra work.
Yeah, I don't think dropbox is the problem.
But I haven't been able to reproduce the pattern of file access you see from backupd on my 10.5.8 or 10.6.7 machines.
When you save, Photoshop is saving what you have in memory at that time. And unless the save fails (and gives you an error), that is what should be in the file. If something is lost, then it was most likely a problem with the file system outside of Photoshop.
Chris, I choose in system preferences to prevented spotlight from searching the internal hard drive where my files are stored and saved to. I also choose to exclude that hard drive from time machine backups. I dragged dropbox out of my applications folder and put it on my desktop. I worked for a few days in photoshop without receiving a message about the disk copy being changed, but eventually I got that message. I then checked in utilities and saw that a folder was there called dropbox helper tools. I dragged that folder to the desktop as well. Could that be the reason that the disk copy was changed?
Hi.
I really don't think its Dropbox because one week back when i saw your where talking about Dropbox i deleted everything from Dropbox and i still
have the error sometimes. Its funny because yesterday i tried to active the "auto-update open documents" i preferences an since then i haven't had
the error yet. Crossed finger, only one day have passed. But then after i activated the auto-update i out of luck saw in my history pane "updated from file"
so that means something touched my file and then PS updated it i guess ? So now i'm a little afraid of using the auto-update thing if i´m not 100% sure
of whats going on. The worst thing that could happen is stuff i make on my pictures is not saved. As i said earlier, i ones had a situation where edits i
did on pictures was not always saved ? really strange.
But i also think the hole thing is strange because i don't have a lot of extra stuff running on my working Mac. Logmein, Dropbox (not anymore) and the
free virus app "ClamXav" thats it. And yes Suitcase Fusion 3.
But as i also said earlier. Its even more strange because all this stuff started happen after i installed Snow Leopard. I had used 10.5.8 for a long time
and then one day "2 month ago" i installed SL on all our Studio computers and then it started. I never had the situation when 10.5.8 was installed.
First after 10.6.x came on. I updated the perfect running 10.5.8 to 10.6.3 from retail installer DVD and then upgraded to 10.6.6 and now all this.
Would it be safe to use the auto-update open documents. Because i don't get the warning when this is turned on ? please advice.
We're only hearing it from a few people.
And it may not be isolated, but on a clean OS install it doesn't happen, nor does it happen to most users.
There is some factor involved that hasn't been discovered yet.
But we are pretty sure that either something outside Photoshop changes the file, or that something in the OS is confused about the modification time of the file.
Chris,
I have turned off time machine. I am also not allowing spotlight to search the internal hard drive on which my files are saved. Dropbox has been thrown in the trash. I am still receiving the message about the disk copy being changed.
Do you mind looking at another terminal log for a file I tracked? I received the message about the disk copy being changed at around 20:40.
I don't see any applications on the list except photoshop and finder. (Microsoft which appears at the end of the list is probably there because I went to Microsoft word to look at my instructions for using the terminal command after getting the message about the disk copy being changed.
Thanks a lot.
17:30:38 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000037 Adobe Photos
17:30:38 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000008 Adobe Photos
17:30:38 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000007 Adobe Photos
17:30:38 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000022 Adobe Photos
17:30:38 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000016 Adobe Photos
17:30:38 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000009 Adobe Photos
17:30:38 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000006 Adobe Photos
17:30:38 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000010 Adobe Photos
17:30:38 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000005 Adobe Photos
17:30:38 open /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000007 Adobe Photos
17:30:38 open /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>> 0.000009 Adobe Photos
17:31:00 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000031 Adobe Photos
17:31:01 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000035 Adobe Photos
17:31:01 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000006 Adobe Photos
17:31:01 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000005 Adobe Photos
17:31:01 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000010 Adobe Photos
17:35:18 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000037 Adobe Photos
17:35:18 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000014 Adobe Photos
17:35:18 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000010 Adobe Photos
17:35:18 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000006 Adobe Photos
17:35:18 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000007 Adobe Photos
17:35:18 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000011 Adobe Photos
17:35:19 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000019 Adobe Photos
17:35:19 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000008 Adobe Photos
17:35:19 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000006 Adobe Photos
17:35:19 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000005 Adobe Photos
17:35:36 access_extended /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000011 Adobe Photos
17:35:36 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000009 Adobe Photos
17:35:36 listxattr /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000006 Adobe Photos
17:35:36 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000011 Adobe Photos
17:35:36 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000007 Adobe Photos
17:35:36 open /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>> 0.000015 Adobe Photos
17:35:36 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000053 Adobe Photos
17:35:36 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000012 Adobe Photos
17:35:36 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000008 Adobe Photos
17:35:36 setattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000023 Adobe Photos
17:35:36 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000006 Adobe Photos
17:35:36 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000005 Adobe Photos
17:35:38 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000013 Finder
17:35:38 open /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>> 0.000014 Finder
17:35:38 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000035 Finder
17:35:38 open /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>> 0.000023 Finder
17:35:38 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000007 Finder
17:35:38 open /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>> 0.000008 Finder
18:11:45 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000039 Adobe Photos
18:11:45 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000007 Adobe Photos
18:11:45 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000010 Adobe Photos
18:11:45 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000006 Adobe Photos
18:11:45 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000012 Adobe Photos
18:11:46 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000019 Adobe Photos
18:11:46 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000008 Adobe Photos
18:11:46 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000006 Adobe Photos
18:11:46 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000005 Adobe Photos
18:12:42 access_extended /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000013 Adobe Photos
18:12:42 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000022 Adobe Photos
18:12:42 listxattr /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000006 Adobe Photos
18:12:42 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000009 Adobe Photos
18:12:42 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000006 Adobe Photos
18:12:42 open /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>> 0.000015 Adobe Photos
18:12:42 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000033 Adobe Photos
18:12:42 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000008 Adobe Photos
18:12:42 setattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000026 Adobe Photos
18:12:42 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000007 Adobe Photos
18:12:42 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000010 Adobe Photos
18:12:42 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000011 Adobe Photos
18:12:42 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000011 Finder
18:12:42 open /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>> 0.000015 Finder
18:12:42 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000035 Finder
18:12:42 open /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>> 0.000023 Finder
18:12:42 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000007 Finder
18:12:42 open /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>> 0.000008 Finder
18:23:16 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000037 Adobe Photos
18:23:16 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000005 Adobe Photos
18:23:16 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000009 Adobe Photos
18:23:16 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000010 Adobe Photos
18:23:16 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000006 Adobe Photos
18:23:18 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000021 Adobe Photos
18:23:18 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000009 Adobe Photos
18:23:18 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000007 Adobe Photos
18:23:18 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000006 Adobe Photos
18:23:18 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000005 Adobe Photos
18:23:53 access_extended /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000013 Adobe Photos
18:23:53 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000011 Adobe Photos
18:23:53 listxattr /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000007 Adobe Photos
18:23:53 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000012 Adobe Photos
18:23:53 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000008 Adobe Photos
18:23:53 open /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>> 0.000017 Adobe Photos
18:23:53 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000043 Adobe Photos
18:23:53 setattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000021 Adobe Photos
18:23:53 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000006 Adobe Photos
18:23:53 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000005 Adobe Photos
18:23:54 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000012 Finder
18:23:54 open /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>> 0.000013 Finder
18:23:54 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000036 Finder
18:23:54 open /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>> 0.000025 Finder
18:23:54 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000010 Finder
18:23:54 open /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>> 0.000010 Finder
18:26:16 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000044 Adobe Photos
18:26:16 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000007 Adobe Photos
18:26:16 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000009 Adobe Photos
18:26:16 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000006 Adobe Photos
18:26:16 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000011 Adobe Photos
18:26:18 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000020 Adobe Photos
18:26:18 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000008 Adobe Photos
18:26:18 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000006 Adobe Photos
18:26:18 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000005 Adobe Photos
18:26:38 access_extended /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000010 Adobe Photos
18:26:38 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000014 Adobe Photos
18:26:38 listxattr /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000005 Adobe Photos
18:26:38 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000009 Adobe Photos
18:26:38 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000006 Adobe Photos
18:26:38 open /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>> 0.000014 Adobe Photos
18:26:38 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000047 Adobe Photos
18:26:38 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000012 Adobe Photos
18:26:38 setattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000021 Adobe Photos
18:26:38 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000013 Adobe Photos
18:26:38 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000008 Adobe Photos
18:26:38 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000007 Adobe Photos
18:26:38 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000005 Adobe Photos
18:26:39 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000010 Finder
18:26:39 open /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>> 0.000011 Finder
18:26:39 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000034 Finder
18:26:39 open /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>> 0.000021 Finder
18:26:39 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000007 Finder
18:26:39 open /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>> 0.000008 Finder
18:34:33 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000038 Adobe Photos
18:34:33 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000006 Adobe Photos
18:34:33 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000008 Adobe Photos
18:34:33 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000005 Adobe Photos
18:34:33 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000010 Adobe Photos
18:34:34 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000019 Adobe Photos
18:34:34 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000008 Adobe Photos
18:34:34 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000006 Adobe Photos
18:34:34 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000005 Adobe Photos
18:34:47 access_extended /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000016 Adobe Photos
18:34:47 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000012 Adobe Photos
18:34:47 listxattr /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000008 Adobe Photos
18:34:47 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000008 Adobe Photos
18:34:47 open /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>> 0.000017 Adobe Photos
18:34:47 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000046 Adobe Photos
18:34:47 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000006 Adobe Photos
18:34:47 setattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000020 Adobe Photos
18:34:47 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000009 Adobe Photos
18:34:47 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000010 Adobe Photos
18:34:47 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000005 Adobe Photos
18:34:48 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000012 Finder
18:34:48 open /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>> 0.000012 Finder
18:34:48 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000019 Finder
18:34:48 open /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>> 0.000021 Finder
18:34:48 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000007 Finder
18:34:48 open /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>> 0.000008 Finder
18:57:31 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000035 Adobe Photos
18:57:31 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000005 Adobe Photos
18:57:31 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000008 Adobe Photos
18:57:31 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000010 Adobe Photos
18:57:31 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000006 Adobe Photos
18:57:34 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000019 Adobe Photos
18:57:34 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000008 Adobe Photos
18:57:34 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000006 Adobe Photos
18:57:34 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000005 Adobe Photos
18:57:56 access_extended /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000011 Adobe Photos
18:57:56 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000009 Adobe Photos
18:57:56 listxattr /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000005 Adobe Photos
18:57:56 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000006 Adobe Photos
18:57:56 open /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>> 0.000015 Adobe Photos
18:57:56 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000044 Adobe Photos
18:57:56 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000012 Adobe Photos
18:57:56 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000008 Adobe Photos
18:57:56 setattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000016 Adobe Photos
18:57:56 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000007 Adobe Photos
18:57:56 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000011 Adobe Photos
18:57:57 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000016 Finder
18:57:57 open /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>> 0.000014 Finder
18:57:57 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000041 Finder
18:57:57 open /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>> 0.000024 Finder
18:57:57 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000007 Finder
18:57:57 open /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>> 0.000008 Finder
fs_usage: buffer overrun, events generated too quickly: 466603
fs_usage: buffer overrun, events generated too quickly: 472312
20:21:03 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000072 Adobe Photos
20:21:03 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000007 Adobe Photos
20:21:03 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000009 Adobe Photos
20:21:03 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000006 Adobe Photos
20:21:04 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000019 Adobe Photos
20:21:04 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000008 Adobe Photos
20:21:04 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000007 Adobe Photos
20:21:04 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000006 Adobe Photos
20:21:04 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000005 Adobe Photos
20:21:26 access_extended /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000011 Adobe Photos
20:21:26 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000009 Adobe Photos
20:21:26 listxattr /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000006 Adobe Photos
20:21:26 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000006 Adobe Photos
20:21:26 open /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>> 0.000015 Adobe Photos
20:21:26 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000018 Adobe Photos
20:21:26 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000008 Adobe Photos
20:21:26 setattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000012 Adobe Photos
20:21:26 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000007 Adobe Photos
20:21:26 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000011 Adobe Photos
20:21:27 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000020 Finder
20:21:27 open /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>> 0.000014 Finder
20:21:27 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000037 Finder
20:21:27 open /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>> 0.000023 Finder
20:21:27 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000007 Finder
20:21:27 open /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>> 0.000008 Finder
20:31:59 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000040 Adobe Photos
20:31:59 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000008 Adobe Photos
20:31:59 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000010 Adobe Photos
20:31:59 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000007 Adobe Photos
20:31:59 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000012 Adobe Photos
20:32:01 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000019 Adobe Photos
20:32:01 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000008 Adobe Photos
20:32:01 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000007 Adobe Photos
20:32:01 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000006 Adobe Photos
20:32:01 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000005 Adobe Photos
20:32:23 access_extended /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000016 Adobe Photos
20:32:23 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000010 Adobe Photos
20:32:23 listxattr /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000006 Adobe Photos
20:32:23 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000007 Adobe Photos
20:32:23 open /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>> 0.000015 Adobe Photos
20:32:23 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000019 Adobe Photos
20:32:23 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000009 Adobe Photos
20:32:23 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000008 Adobe Photos
20:32:23 setattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000013 Adobe Photos
20:32:23 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000011 Adobe Photos
20:32:23 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000006 Adobe Photos
20:32:24 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000013 Finder
20:32:24 open /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>> 0.000014 Finder
20:32:24 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000035 Finder
20:32:24 open /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>> 0.000024 Finder
20:32:24 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000007 Finder
20:32:24 open /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>> 0.000008 Finder
20:40:02 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000037 Adobe Photos
20:40:02 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000007 Adobe Photos
mdls 20:42:44 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000025 Microsoft Wo
20:42:44 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000017 Microsoft Wo
20:42:44 getattrlist /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd 0.000008 Microsoft Wo
/Volumes/Macintosh\ HD\ 3/Lendon/Heineken/Heineken_fin3.psd
