Is InCopy CS5.5 compatible with InDesign CS5?
Jun 2, 2011 12:46 PM
I'm using InDesign CS5.
My editor has InCopy CS4, so they can no longer upgrade to CS5. Now, if they upgrade to CS5.5, will they be able to work on my InDesign CS5 files without any problems? If they check out/check in stories will I have any problem working with them?
We use a Dropbox workflow.
FWIW, I could work in InDesign 5.5, but there are other designers who need access to the files, so it's best if we can keep the job in CS5.
Thanks for the help!
    Jun 2, 2011 1:56 PM   in reply to Mayerchak
    If you use ICML, I'd cautiously say that you should be okay.
    InCopy CS5 cannot open InDesign CS5.5 documents.
    Harbs
    Jun 2, 2011 2:08 PM   in reply to Mayerchak
    I'm going to say that it should work okay, too. The text engines haven't changed any so I so think you should be alright.
    I would however recommend a test or two.
    Bob
    Jul 20, 2011 1:10 PM   in reply to Mayerchak
    Hi there,
    I have the same problem and as I see, the question is not answered finally.
    My customer wants to buy InCopy CS 5.5 for Windows. We work with InDesign CS 5 for Mac-OS. I installed the tryout-version of InCopy CS 5.5 (7.5.1) on windows.
    In my local network this combination works very well. In a so-called live-edit-workflow with parallel working on the same InDesign-document with InDesign and InCopy simultanously I see no problems. Check in and check out and text changes are in real time. Very nice.
    The problem is, that my customer is far away and not in my local network. So we can't work simultanously on the same InDesign-document. And we don't want that. We don't want to give our layout-files to the customer. So I've tested the so called remote-workflow by creating packages. Of course the newer InCopy can open the package from the older InDesign. After apply some changes I repack the new package for InDesign. But in InDesign CS 5 I can't open the package from InCopy CS 5.5. While opening the package InDesign it shows an error-message like this:
    "The package-file has a task, that not exists in *filename*. Your package-file is old or connected with another document. What would you do?
    a) search for correct document
    b) save content of package to disk"
    (my poorely translation from german to english)
    With both options I couldn't open the document and apply the changes from InCopy. With InDesign CS 5.5 it works very well.
    I'm wondered if this is normal? Why is it working in the live-edit-workflow but not in remote-workflow with packages? This concept was named so from Haeme Ulrich from Switzerland.
    An answer would be nice.
    Best regards
    Jul 20, 2011 1:41 PM   in reply to Mayerchak
    Hi Matt,
    I don't want to share my InDesign-files with my customer. So I must work with packages and e-mail-transfer. I think this is not a problem. The problem is, that InCopy CS 5.5 and InDesign CS 5 are not compatible in this workflow. I must say so after my own tests with some files. If I understand you correctly, you updated your InDesign to CS 5.5 for full compatibility? No way without that?
    Best regards
    Jul 20, 2011 1:56 PM   in reply to Mayerchak
    If you have some minutes, could you test it in the email package workflow with ID CS 5 and IC CS 5.5? That would be great if you can post your experiences here so that I can check, if there is a problem on my installation or in general. Also I would ask Adobe here in Europe for that problem. Thanks.
    Jul 20, 2011 3:25 PM   in reply to Mayerchak
    I have not tested this thoroughly, but I'm not entirely surprised that InDesign CS5 can't read packages created by InCopy CS5.5.
    You already know that InDesign CS5 cannot open InDesign CS5.5 layout (INDD) files, I assume. Adobe actually changed the file format.
    So as has always been the case, more recent versions can open older versions, but not vice versa. So InCopy CS5.5 can open the ICAPs created by InDesign CS5, but when InCopy CS5.5 creates the *return* IDAP package, that is a later version of InCopy that is creating the file, right? So InDesign CS5 cannot do anything with it. It's a shame and aggravating, too, since obviously the ICML (native InCopy) format is unchanged.
    The solution is to use the Dropbox for a layout based workflow, or use it for an assignment-based workflow (keep your ID file on your local drive outside of Dropbox, but point ID to the shared subfolder in Dropbox folder when creating assignments and exporting stories to the workflow).
    But to me, it makes the most sense for you as the designer to upgrade to 5.5. You can run both 5 and 5.5 on the same machine. Then you can create ICAPs and open the IDAPs your client sends in return without an issue.
    Mixing versions between ID and IC is seldom a good idea as a permanent solution, only as a stopgap. Even if they "work," their will always be slight differences in text composition
    AM
    Jul 21, 2011 1:40 PM   in reply to AnneMarie Concepcion
    I've tried this with no success. I have the same error-message in InDesign like above. I think you are right to use the same versions. Thanks for your honest answer.
    Best regards
