Saved_n_kept
Flash Player Freezing
May 16, 2011 7:04 AM
As a pensioner I do not know too much about computers, so I wonder if someone could help me?  I am using Windows 7 Home Premium 32 bit and the web browser is Firefox version 4.0.1 Adobe Flash Player is version 10,3,181,14.  When playing a live video stream from one particular site, the picture freezes after exactly ten minutes and then goes to a black screen with a "play" button. Clicking on this immediately restores the video for a further ten minutes and then the same thing happens. This problem first appeared about a month ago. I also simultaneously record the video and have noted that the recording is not affected. The player has this problem even when the recorder is not operating. The problem also happens if I use Internet Explorer. Two different technicians have checked the computer and can find no fault. Website informs me that they have no problems. Any ideas? Thanks.
    May 16, 2011 2:35 PM   in reply to Saved_n_kept
    Hi, Could you try to turn off the hardware acceleration and see if that helps?
    go to this site: http://www.adobe.com/software/flash/about/. Right click on the Flash logo, Settings,
    then UNcheck the hardware acceleration in Display Settings.
    eidnolb
    May 16, 2011 5:57 PM   in reply to Saved_n_kept
    Hi again, ok that is fine. Just reply back when you can. That may help, but if not, let me know. Hopefully it's something simple, perhaps an addon etc. Just don't do anything drastic trying to "fix" it until we know what the problem is
    eidnolb
    May 18, 2011 5:52 PM   in reply to Saved_n_kept
    Hi Brian, Glad you tried the website even tho it's not the program you were having a problem with. I have one that I listen to (just audio) and it buffers(hesitates) but I just leave it alone and it recovers itself and plays ok. I try not to have any other window open and that seems to help too.
    Hopefully that will continue to work for you, but if not, you can always post a message on this same thread. It doesn't close.
    Computers are getting more complicated and it makes it difficult for people that don't deal with all of the various problems every day like we do here.
    Thanks for marking your thread as answered as well.
    I appreciate your screen name also:-)
    eidnolb
    May 19, 2011 7:34 AM   in reply to Saved_n_kept
    Yep, gooooood solution, not work, turn off. For example hardware acceleration, not help, turn off player (uninstall). Not help, turn off IE, not help -> burn PC . Thx to all who make for us pc, hardware and software .
    Jun 2, 2011 7:05 PM   in reply to Saved_n_kept
    Hello Brian, If after running that British Telecom troubleshooter and restarting your computer, the broadband connection is restored, sounds like an ISP issue. Are you losing your internet connection first, and then you run the troubleshooter?
    I've lost my internet connection before and usually the webpage will say cannot open the website or show the Diagnose
    Connection Problem. This comes from the Tools menu and I run it. Not the easiest info to read, but gives some info. Then when I call my Internet Service Provider (ISP) I have that to give them.
    Maybe the troubleshooter you are using is something like that. What you could do is when that happens again, click on Tools and run the Diagnostic Tool. Maybe that info would be helpful to give to your ISP. I'm able to call them by telephone.
    Do you use a Router or just connect with the modem? If you only have one computer, you wouldn't need a Router. There are a couple of things you can try.
    If it's a Broadband connection problem, then they should be able to solve it.
    Let me know,
    eidnolb
    Jun 3, 2011 10:23 AM   in reply to Saved_n_kept
    Hi, It's no bother since you are still having problems. Thanks for the add'l info. I have a few questions if you don't mind.
    1. Do you have Flash Player Installed in Internet Explorer?
    2. What version of Internet Explorer do you use? If you don't know, click on Help at the top of the menu bar and click on About Internet Explorer. There you will find the version of IE.
    Do you know how to find your Flash files? Go to C:\Windows\System32\Macromed\Flash  Right click on the Flash folder and let me know what files are listed there. I don't need you to open any, I just need to know what is listed. For example, one would be FlashUtil10q_Plugin.exe and etc. The NPSWF32.dll file, you will need to right click on and then click on Properties in order to obtain the version number. These are the Flash files for Firefox.
    If you have Flash Player Installed in Internet Explorer then you will have Flash files listed for that browser also. For example, one would be Flash10q.ocx, etc.
    Next, using Firefox, go to the plugins and let me know if you have the Shockwave Flash Plugin Enabled and what version is listed.
    If you have Flash Player Installed in Internet Explorer, then go to Tools, Manage addons under "Show"(very light text) and look in those categories for Shockwave Flash Object. Let me know if it's Enabled and what version is listed.
    All of this info will let me know if Flash Player is Installed correctly. Then we can proceed from there.
    eidnolb
    Jun 3, 2011 12:23 PM   in reply to Saved_n_kept
    Hi, Thanks for the info. Yes, that is exactly what I needed  Now, you happen to have two different versions of Flash Player Installed. That was probably due to the Uninstall/Install. So what needs to be done is a complete Uninstall of both of those for IE and FF and then Install just one correct version.
    On the NPSWF32.dll file, when you right click on that a window should have opened. At the bottom should have been the word Properties. Then when clicking on that another window would have opened and at the top you should have seen Version. This is just information for you in case that info is needed again. It doesn't matter now, since we are going to Uninstall all anyway.
    I'm going to get the procedure ready for you and this will be a manual Uninstall/Install which works well. There are a couple of things you will be doing and one is you will disable any instant messenger service(s) from the system tray(area near the clock) Also you will disable your Anti-Virus Program.
    So I will need to know what Anti-Virus Program you use, so we'll be sure to disable it correctly.
    Also you said you record sometimes; is there an icon in the system tray for that? If so we'll disable that also. The point is that we don't want anything there that uses Flash Player running.
    Let me know on that please.
    eidnolb
    Jun 3, 2011 3:37 PM   in reply to Saved_n_kept
    Hi, maybe the Technician didn't know where the Flash files were  Now you know more that he did, LOL
    Ok on the recorder. We'll disable McAfee and Adblock Plus. I'll give you the info now on the disabling of McAfee, but don't do that until you see in the Steps I'll provide. I'll just say Disable McAfee and you'll know what to do. Same thing with Adblock Plus. Now you won't be on the Internet so there won't be any problem in Disabling McAfee in case you wondered about that.
    You'll see in the steps.
    I just want you to review this now, so if you have any questions about it before you need to do that, you can ask.
    Double-click the taskbar icon to open Security Center
    Click Advanced Menu (bottom left)
    Click Configure (left)
    Click Computer & Files (top left)
    You can disable VirusScan in the riught-hand module and tell it for how long
    Click Internet & Network (top left)
    You can do the same with Firewall there
    Now, I'm going to have you SAVE the Uninstaller to your Desktop and also the FP Installer for IE and the FP Installer for FF. You won't do anything with them yet, other that put them on your Desktop. We want to be sure everything is ready beforehand.
    If you have any problem doing this, let me know. I'd rather it all be done correctly the first time:-) Not that you wouldn't, but if you haven't Uninstalled & Installed Flash Player this way, it may be a different procedure.
    Download and SAVE to your Desktop the Uninstaller:
    http://kb2.adobe.com/cps/141/tn_14157.html
    Download and SAVE to your Desktop the Installer for IE- use the EXE Installer from:
    http://www.adobe.com/products/flashplayer/fp_distribution3.html
    Download and SAVE to your Desktop the Installer for FF- use the EXE Installer for plugin based (from the same site)
    I know it's late in your time zone, so get back with me at your convenience. What you are doing now is pre-Uninstall/Install work.
    eidnolb
    Jun 3, 2011 4:45 PM   in reply to Saved_n_kept
    Hi, That it's different doesn't surprise me since they have different versions. Yes I think your way would be best. That way you have it all covered. Anti-Virus programs, especially McAfee & Norton and a few others will interfere when Installing the IE Flash Player Active X Control. Now keep in mind that in the steps after you Uninstall & Reboot and BEFORE you use either Installer, you'll see I'll have you check to make sure McAfee is still Disabled first. This is because after the Uninstall & that Reboot, McAfee has a habit of re-enabling it self and then blocking that ActiveX Control.
    If you have McAfee under control and the Uninstaller and both Installers on your Desktop, then I'll post the procedure next. That way you'll have it for tomorrow morning. I'm about 5 hours earlier than you. 7:45pm my time as I post this.
    eidnolb
    Jun 3, 2011 5:55 PM   in reply to Saved_n_kept
    Hi, Yes It is late for you! I'm not going to give you the rest of the instructions until I know you are sound asleep, So you can rest easy, nothing to do until tomorrow. I'll be sure you have the info before I turn in though.
    I've got a few friends in your area too, email friends that is. Never been over there nor outside the US except Mexico. Almost forgot about that. I try to email or answer the threads here on the Forum for those outside the Country since the time zone makes it necessary. Usually answer my overnights as early as possible.
    I forgot about that Download folder. Glad you know where they are.
    So you are doing well, so far so good. This all sounds more difficult than it really is. Something like spending 3-4 hours or more cooking dinner and it only takes 20 -30 minutes to eat
    Remind me to give you a link for the next time a FP update comes out, you won't have to do a thing except click on "Install Now" and it's all automatic:-)
    Have a good night,
    eidnolb
    Jun 3, 2011 10:27 PM   in reply to Saved_n_kept
    Good Morning, Take your time with this and you'll be fine.
    Close all browser windows, you only want to be looking at your Desktop.
    Disable any messenger services, as yahoo, msn, etc in the system tray(area near the clock)
    Disable Your Anti-Virus as discussed and Adblock Plus
    Be sure to use the Administrator Account.
    Run the Uninstaller and when finished, Reboot(restart) your computer.
    Now go to C:\Windows\System32\Macromed\Flash  If any files are listed other than a text doc, then use the Uninstaller again & Reboot & re-check
    Check to make sure the Anti-Virus & Adblock are still Disabled
    Run the Installer for IE and then  Run the Installer for FF and when finished, Reboot.
    Re-enable your Anti-Virus BUT NOT THE ADBLOCK PLUS UNTIL AFTER YOU TEST EACH BROWSER.IF YOU SEE THE FLASH PLAYER LOGO ANIMATION, THEN ENABLE ADBLOCK.
    Then go to this test site and test each browser:
    You may want to print these instructions to make it easier to follow. If you have any questions, let me know.
    Hope this goes well for you, let me know. I'll check into the Forum later.
    eidnolb
    Jun 4, 2011 7:43 AM   in reply to Saved_n_kept
    Good Morning again,
    It sounds like you were successful You did a very good job following all of the instructions and I'm sure all of the Flash files are correct. If you'd like to post what Flash files are now Installed, that would be fine too. You may have FP version 10.3.181.16 for the Internet Explorer and FP version 10.3.181.14 for the Firefox browser. Normally the versions would be the same, but Adobe released the .16 version just recently for the Windows Platform that uses that ActiveX Control. Now the Windows Platform that uses other browsers that use the Plugin, as Firefox does, the version would be the .14.
    On the hardware acceleration, I would check your favorite sites and if you see a problem, then you can turn it off.
    Now to make this easy for you the next time the Adobe Flash Player is updated, you can go to the Notification Setting. Put a check mark in the box and then indicate how often you want to be notified when an update is available. I have mine set to 7 days. Then you would get a prompt from Adobe saying an update is available. You have a choice to click on "Install Now"; "Remind me later" or "Don't Install". This method to update is done in under 2 minutes and you don't have to do anything, it's all done automatically!!
    Link: http://www.macromedia.com/support/documentation/en/flashplayer/help/se ttings_manager05.html
    I'm just as happy as you are that everything went smoothly for you. That is why we did all of the prep work, so that the Uninstall/Install would be successful
    If I ever did go to Scotland, I certainly would look you up!! Thanks for the invite.
    Anytime you have a question about Flash Player, let me know.
    eidnolb
    Jun 4, 2011 10:57 AM   in reply to Saved_n_kept
    Hi Brian, Your Flash files are all  correct and your FP browser addons for IE & FF as well. So nice to see
    Ok on the Notification Setting also.
    Thanks for posting that info. Now the websites should work well for you. I think before with the mixed files that FP and the websites were confused, Ha-Ha.
    Have a great weekend, sunshine here:-) Maybe some rain coming, but that's ok too.
    eidnolb
