Custom authentication with BlazeDS on Tomcat
Nov 4, 2010 4:45 AM
Hello!
I did the following:
You need to perform the following configuration steps to use custom authentication with
BlazeDS on Tomcat:
1. Put flex-tomcat-common.jar in tomcat/lib/blazeds.
2. Place flex-tomcat-server.jar in tomcat/lib/blazeds.
3. Edit the catalina.properties file which can be found in the tomcat/conf directory. Find the common.loader property and add the following path to the end of the list: ${catalina.home}/lib/blazeds/*.jar
4. Add <Valve className="flex.messaging.security.TomcatValve"/> tag to the Context Descriptors.
5. Restart Tomcat.
You will now be authenticated against the current Tomcat realm. Usually, for this authentication the user information is in conf/tomcat-users.xml. See the Tomcat documentation for more information on realms. See the Flex documentation for more information on BlazeDS custom authentication.
When I started Tomcat 7 from Eclipse I got the stacktrace below.
Seems to be a version clash.
Any tips?
Stefan
java.lang.VerifyError: class flex.messaging.security.TomcatValve overrides final method start.()V
    at java.lang.ClassLoader.defineClass1(Native Method)
    at java.lang.ClassLoader.defineClassCond(ClassLoader.java:632)
    at java.lang.ClassLoader.defineClass(ClassLoader.java:616)
    at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:14 1)
    at java.net.URLClassLoader.defineClass(URLClassLoader.java:283)
    at java.net.URLClassLoader.access$000(URLClassLoader.java:58)
    at java.net.URLClassLoader$1.run(URLClassLoader.java:197)
    at java.security.AccessController.doPrivileged(Native Method)
    at java.net.URLClassLoader.findClass(URLClassLoader.java:190)
    at java.lang.ClassLoader.loadClass(ClassLoader.java:307)
    at java.lang.ClassLoader.loadClass(ClassLoader.java:248)
    at org.apache.tomcat.util.digester.ObjectCreateRule.begin(ObjectCreateRu le.java:140)
    at org.apache.tomcat.util.digester.Digester.startElement(Digester.java:1 282)
    at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.startEle ment(AbstractSAXParser.java:501)
    at com.sun.org.apache.xerces.internal.parsers.AbstractXMLDocumentParser. emptyElement(AbstractXMLDocumentParser.java:179)
    at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImp l.scanStartElement(XMLDocumentFragmentScannerImpl.java:1343)
    at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImp l$FragmentContentDriver.next(XMLDocumentFragmentScannerImpl.java:2755)
    at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(X MLDocumentScannerImpl.java:648)
    at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImp l.scanDocument(XMLDocumentFragmentScannerImpl.java:511)
    at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(X ML11Configuration.java:808)
    at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(X ML11Configuration.java:737)
    at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser. java:119)
    at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Ab stractSAXParser.java:1205)
    at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.p arse(SAXParserImpl.java:522)
    at org.apache.tomcat.util.digester.Digester.parse(Digester.java:1543)
    at org.apache.catalina.startup.Catalina.load(Catalina.java:529)
    at org.apache.catalina.startup.Catalina.load(Catalina.java:567)
    at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
    at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl. java:39)
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAcces sorImpl.java:25)
    at java.lang.reflect.Method.invoke(Method.java:597)
    at org.apache.catalina.startup.Bootstrap.load(Bootstrap.java:262)
    at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:417)
java.lang.reflect.InvocationTargetException
Caused by: java.lang.VerifyError: class flex.messaging.security.TomcatValve overrides final method start.()V
    ... 6 more
    Jan 5, 2011 9:07 PM   in reply to yankee2003
    After recently coming across this exact same error following the Tomcat setup steps described on the site at the following link:
    http://livedocs.adobe.com/blazeds/1/blazeds_devguide/help.html?content =services_security_5.html
    I have yet to make it past this error.  Any luck on your end or input from anyone at Adobe?
    Wembley76
    Mar 23, 2011 5:28 AM   in reply to Wembley76-Mbzl9l
    Hello,
    Just came accross the same error! Migrated from BlazeDS 3 to BlazeDS 4, after reading this post http://forums.adobe.com/thread/777748 but that does not fix the problem.
    Apparently Tomcat 7 deals with Valves differently. I'm going to dig on that side ...
    If anybody has an update on this, I'm interested !!!
    Olivier
    Mar 23, 2011 6:00 AM   in reply to ogerou_screenname
    Yes, there are issues for supporting Tomcat 7 because of security framework and API change.
    We have fixed it but the release is not out yet.
    You can search the BlazeDS bug database to find out the issue.
    "Tomcat 7, Login"
    Jun 6, 2011 6:18 AM   in reply to yankee2003
    I'm actually having an issue with Tomcat 6 and authentication.  I cannot start the server because it doesnt find the class TomcatValve (java.lang.ClassNotFoundException). on Windows, Eclipse Ganymede
    I dont know where to look anymore, my config is the following:
    catalina.properties
    common.loader=${catalina.base}/lib,${catalina.base}/lib/*.jar,${catali na.home}/lib,${catalina.home}/lib/*.jar,${catalina.home}/lib/blazeds/* .jar
    server.xml
    <Context docBase="Project" path="/Project" reloadable="true" source="org.eclipse.jst.j2ee.server: Project ">
    </Context>
    The jar files( flex-tomcat-common.jar, flex-tomcat-server.jar  ) are in Project\WebContent\WEB-INF\lib\blazeds
    I tried cleaning, restarting publishing etc. but the tomcat doesnt seem to recognize the files.
    Does anybody has an idea what i didnt see?
    Thanks in advance!
    Matt
    Jun 6, 2011 7:19 AM   in reply to FlexMatt
    you need to find tomcat related security jar files under blazds/resource/security and put into the Tomcat server classpath
    Jun 6, 2011 8:02 AM   in reply to Don Hu
    thanks for the hint, though, which are these relevant files? flex-tomcat-common.jar, flex-tomcat-server.jar ? Or more are more jars neccessary for authentication? these two are in the classpath (web-inf/lib) folder.
    Which folder do you mean by  blazds/resource/security? In the BlazeDS 4.0.0.14931 turnkey archive there are jars in resources/security/tomcat
      flex-tomcat-common.jar, flex-tomcat-server.jar, flex-tomcat-server-4150.jar . I copied those into my web.inf/lib folder, but still same error.
    Matt
    Jun 6, 2011 8:28 AM   in reply to FlexMatt
    put them into server classpath, not in the web app lib.
    Jun 7, 2011 1:45 AM   in reply to Don Hu
    after some copying and re-registering a new server config in Eclipse it finally worked. I copied the files into the $catalina_home/lib folder. I actually thought, it should work, when I copy these files into the respective wepapp. Well, I'll give it another try later on maybe
    Thanks again for the help, and sorry for interrupting the discussion about the Tomcat 7 issue!
    Matt
    Feb 19, 2012 12:45 AM   in reply to yankee2003
    Hello.
    You're using wrong version of Tomcat Valve for Tomcat7.
    You need Tomcat7Valve from flex-tomcat-server-708.jar
    If you're building BlazeDS from trunk then check also ant build scripts in opt. There is condition based on environment variable:
    <target name="build.for.tomcat7" if="env.JAVA16_HOME">
    If you want to build it with Java7 then remove that condition.
