Error when launching Flex 4.5 mobile app.
May 15, 2011 5:02 PM
Any ideas why I'm getting this? Its an AIR app, not Firefox, so ???
TypeError: Error #1009: Cannot access a property or method of a null object reference.
at ominds::Firebug$/connect()
at flashfirebug/allCompleteHandler()
    May 18, 2011 11:53 AM   in reply to Gregory Lafrance
    Looks like you've pulled in Firebug as a dependency in your library path?
    Jason San Jose
    Software Engineer, Flex
  • mattdwm
    Sep 6, 2010
    Jun 1, 2011 9:43 AM   in reply to Gregory Lafrance
    I'm getting this error too. It seems to be related to the desktop player. If I debug it with my phone there's no problem.
    Jun 6, 2011 10:43 PM   in reply to Gregory Lafrance
    Hi, there.
    I get same error too.
    Looks like installing "FlashFirebug" is the reason of this error.
    Here is the solutions:
    1) Quit "FireFox" when using FlashBuilder.
        If FireFox is available behind FlashBuilder working, it catches SWF publishing and try to connect it (that causes error).
    2) Edit "mm.cfg" file.
        Delete the line "PreloadSWF=...\flashfirebug@o-minds.com\chrome\content\flashfirebug\flashfirebug.swf" thing from mm.cfg.
    Either way works for me.
    Jun 6, 2011 11:12 PM   in reply to yuck
    I just realized that you can solve the problem with the solutions I posted before though,
    you are still messed up when using "Profiler".
    You just can't exec FireFox while you do "Profile" with FlashBuilder
    (editting mm.cfg won't work this time.  PrealodSWF is set to FlashFirebug thing).
    I don't recommned to install "FlashFirebug extension" for the time being.
    Jan 6, 2012 1:40 AM   in reply to yuck
    The option to disable firebug and quit firefox didn't work for me, but yes removing the line
    fromt mm.cfg (C:\Users\UserName\mm.cfg) worked for me.
    Thanks for the solution.
    Saurabh
