I am trying to decide between upgrading Framemaker 8 to FM 10 or migrating to Madcap Flare. I need to produce both print and web outputs and most of the documents are structured. I have lots of legacy FM files.
I downloaded and installed Flare without problems but found that it does not have runin paragraph styles and some of the FM features that allow styles to cross columns.
I tried to install FM but got error messages. I downloaded the Adobe installer diagnostic tool and it said there were conflicting programs to the FM installation but was not specific on what they were. Basically I went down the same route and had the same problems as mentioned in a similar post about Robohelp installation problems:http://forums.adobe.com/message/3422315
Unlike Madcap, Adobe support is pretty difficult to contact and it has taken literally days to fix problems with other adobe programs.
I am using a 2011 Macbook Pro using Bootcamp Win 7 64 bit home version. I also have parallels installed and can run FM 8 on either system. Acrobat Pro X is installed.
Here is the error log (edited to remove redundant line breaks):
Exit Code: 7
-------------------------------------- Summary --------------------------------------
- 0 fatal error(s), 16 error(s), 15 warning(s)
WARNING: PayloadPolicyNode.SetAction: IN payload {AC76D478-1031-0000-3478-000000000004} Adobe PDF Creation Add-On 9 is required by {3E6C41F9-8CDB-4358-9A9D-D34D0550750E} Adobe FrameMaker 10 but isn't free.
WARNING: Payload cannot be installed due to dependent operation failure
ERROR: The following payload errors were found during install:
ERROR: - Microsoft_VC90_ATL_x86: Install failed
ERROR: - Microsoft_VC80_ATL_x86: Install failed
ERROR: - Adobe Linguistics 5.1: Install failed
ERROR: - Adobe FrameMaker 10: Failed due to Language Pack installation failure
ERROR: - AdobeTypeSupport CS5: Install failed
ERROR: - Adobe FrameMaker 10_AdobeFrameMaker10_en_US: Install failed
ERROR: - Suite Shared Configuration CS5: Install failed
ERROR: - Adobe PDF Creation Add-On 9: Install failed
ERROR: - AdobePDFL CS5: Install failed
ERROR: - AdobeCMaps CS5: Install failed
ERROR: - Microsoft .NET Framework 3.0 (Please wait... This might take a while): Install failed
ERROR: - AdobeHelp: Install failed
ERROR: - AdobeJRE: Install failed
ERROR: - Adobe ExtendScript Toolkit CS5: Install failed
ERROR: - Adobe AIR: Install failed
Hi ,
I work for Adobe. We need following information, so that we can nail down the issue.
1) Look into Control panel and search for FrameMaker 10.
2) If FrameMaker 10 entry is there, Uninstall it.
3) After uninstallation, make sure to clean your old FrameMaker 10 registry.
4) Restart your machine.
5) Go to %temp% directory and create a new file with the name ribs3debug ( please make sure that this file should not have any extension)
6) Go to <ProgramFileFolder>\Common Files\Adobe\Installers. And delete all content present at this location
7) Make sure no other Adobe product is running
6) Re-install FrameMaker.
Note:-
1) If problem persists after performing the above steps please share installation logs generated at [CommonFileFolder]\Adobe\Installer
folder with the name Adobe FrameMaker 10 (time stamp).gz.
Pankaj
