Karel VDH
BUG: navigateToUrl always opens new tab in browser, also when window parameter is specified
May 11, 2011 4:12 PM
I have a problem navigating to a Url in the default browser in an Adobe Air project.
air.navigateToUrl(request, windowName) launches the browser and displays the page, but it displays a new tab for every request.
Here is a very simple example that shows the problem:
Flex:
<?xml version="1.0" encoding="utf-8"?>
<s:WindowedApplication xmlns:fx="http://ns.adobe.com/mxml/2009"
   xmlns:s="library://ns.adobe.com/flex/spark"
   xmlns:mx="library://ns.adobe.com/flex/mx">
<fx:Script>
<![CDATA[
import flash.display.Sprite;
import flash.net.navigateToURL;
import flash.net.URLRequest;
protected function button1_clickHandler(event:MouseEvent):void
NavigateToURLExample();
public function NavigateToURLExample():void {
var url:String = "http://www.adobe.com";
var request:URLRequest = new URLRequest(url);
try {
navigateToURL(request, "testWindow");
catch (e:Error) {
// handle error here
</fx:Script>
<fx:Declarations>
</fx:Declarations>
<s:Button x="169" y="165" label="Button" click="button1_clickHandler(event)"/>
</s:WindowedApplication>
HTML:Javascript:
<html>
    <head>
        <title>navigateToURLTest</title>
        <script type="text/javascript" src="lib/air/AIRAliases.js"></script>
    </head>
    <body>
        <a href="#" target="testp"  onclick="javascript:air.navigateToURL(new air.URLRequest('http://www.adobe.com'), 'TestWindow');return false;">Same Tab</a>
    </body>
</html>
How can I open the url in the same window/tab?
Message was edited by: Karel VDH
    Jun 6, 2011 9:18 AM   in reply to Karel VDH
    Hi..
    I am struck with the same issue as well.
    It works for few sites like "http://www.adobe.com" and "http://www.google.com", but most of the sites open up in a new window, even if I specify custom name, like:
    navigateToURL(new URLRequest("http://www.britishairways.co.uk"), "MyWindow");
    Also tried through ExternalInterface viz:
    ExternalInterface.call("window.open", new URLRequest("http://www.britishairways.co.uk"), "MySameWindow", "");
    Please reply whether it is a bug, or there if there are any alternative approaches.
  • Chris Campbell
    May 4, 2010
    Jun 8, 2011 10:48 PM   in reply to PreePrave
    I'll ask around about this behavior and see if I can get additional info.  In the meantime, would you mind creating a new bug on our online bug database?  Please post back with a URL so others can comment and add their votes.
    Chris
  • Chris Campbell
    May 4, 2010
    Jun 13, 2011 4:04 PM   in reply to Karel VDH
    Karel,
    Nothing yet but I'll forward along to the team that triages these bugs and see if they can take a look.
    Chris
    Jun 29, 2011 1:55 AM   in reply to Karel VDH
    Hello All,
    I am able to open pdf using navigateToURL method.
    But the title of the web page/tab shows the entire url... is there any way to change the title of the page/tab to something else?
    any help is appreciated
    Jun 29, 2011 1:56 AM   in reply to Chris Campbell
    Hello All,
    Aug 7, 2011 6:27 PM   in reply to Karel VDH
    I have seomthing like this inside a class or package
    function foo(event:MouseEvent):void
                    var result:String = ExternalInterface.call("callHome");
                    var fooURL:URLRequest = new URLRequest(result);
                    navigateToURL(fooURL, "_self");
                logoButton.addEventListener(MouseEvent.CLICK, foo);
    and this on every html page
    <script type="text/javascript">
    function callHome(){
        return "http://localhost/fooproject/index.html";
    This is a flash button of course I am not sure if it helps, but this worked out for me.
    May 18, 2012 8:46 AM   in reply to Karel VDH
    Hi Karel,
    I know this post is kind of old, but were you able to find a workaround? I'm having the exactly same problem in Adobe AIR.
    Marcio
  • Chris Campbell
    May 4, 2010
    May 21, 2012 3:14 PM   in reply to Karel VDH
    Was there a bug entered?  I'd be happy to look up the status.
    Chris
    May 21, 2012 3:45 PM   in reply to Chris Campbell
    Thanks for your reply Karel!
    Hi Chris,
    I found this bug report made by Karel last year (https://bugbase.adobe.com/index.cfm?event=bug&id=2895041) Bug 2895041, but unfortunately, it was closed as not an AIR SDK issue.
    I read Ru Wan's note, but in my opinion, that's not exactly the case. The navigateToUrl function should work exactly as a normal javascript 'window.open' - that's open in a new window if I specify '_blank' or in a specific window if the second parameter is saying so. Maybe you could reopen this issue.
    Thanks in advance for your help.
    Marcio
  • Chris Campbell
    May 4, 2010
    May 23, 2012 12:37 AM   in reply to Karel VDH
    I'd recommend opening a new bug and try stating your case again. From what I've read, Ru's statement that this is a configuration preference of the browser appears to be correct.  Regardless, if you do open a but It would really help if Karel and others affected take a minute vote for the bug and add their comments.
  • Chris Campbell
    May 4, 2010
    May 23, 2012 4:40 PM   in reply to Karel VDH
    I do agree that whatever the outcome, the documentation should be improved here.
    May 24, 2012 6:29 AM   in reply to Chris Campbell
    Chris,
    I added a note to the bug report. Should I create a new report or the note on the closed one is fine?
    Marcio
  • Chris Campbell
    May 4, 2010
    May 25, 2012 1:42 PM   in reply to marciohdantas2012
    I suspect you'll get better visibility on a new bug report.  I'd references both this post and the closed bug, again making your case why you think it was closed erroneously.
    May 25, 2012 3:22 PM   in reply to Chris Campbell
    Hi Chris and Karel,
    I opened a new bug report there - https://bugbase.adobe.com/index.cfm?event=bug&id=3199139
    I think it may help if others could vote there or add notes.
    Marcio
