'ConnectSessionContainer' declaration must be contained within the <Declarations> tag, since it is not assignable to the default property's element type 'mx.core.IVisualElement'.
i am following the tutorials but keep on getting one error after another
I want to deploy this in an AIR app
I went from using LCCS flash player 10.1 vesrion -> 10 and still issues...
first it was
Could not resolve <rtc:AdobeHSAuthenticator> to a component implementation
and now this
Is there a fully working flex/air demo available so I can check all my settings
Total Likes
I cant find a place to add the specific flash player I am targeting with my AIR app properties - could be the issue
Why are these settings so sensitive - I am really frustrated - the "simple" examples does not work for me
I even have RED5 going but cant get this solved
Total Likes
Yeah a working sampleApp is in: <path to the SDK>/com.adobe.lccs/sampleApps/Recording/ ( the container is an MXML component, you probably want to init the ConnectSession class on your own if you want to avoid the default flow )
You'll obviously need to setup your webdav for the recording based on PDF attached here: http://forums.adobe.com/thread/860525?tstart=0
Hope that helps
Alex
Total Likes
It is still not a full AIR app
"The folder does not contain a valid Flash Builder Project."
I cannot import it
I think my problem must lie in some obscure setting/configuration of the air runtime
My adobe LCCS swc is referenced correctly and I declare
xmlns:rtc="http://ns.adobe.com/rtc"
as per example
and when I start to type <rtc
it gives me code-completion of possible components
but the error stays :
Description Resource Path Location Type
'ConnectSessionContainer' declaration must be contained within the <Declarations> tag, since it is not assignable to the default property's element type 'mx.core.IVisualElement'. chatComponent.mxml /bhServerApp/src/components line 219 Flex Problem
1067: Implicit coercion of a value of type com.adobe.rtc.session:ConnectSessionContainer to an unrelated type Object. chatComponent.mxml /bhClientAppFromCatalyst/src/components Unknown Flex Problem
1176: Comparison between a value with static type Object and a possibly unrelated type com.adobe.rtc.session:ConnectSessionContainer. chatComponent.mxml /bhClientAppFromCatalyst/src/components Unknown Flex Problem
and so on...
Total Likes
1) Yes it's not a full AIR app, but you can create an AIR app yourself and manually import those files.
I'd suggest the folllowing:
1) Create a new Flex project
2) Copy paste the 3 files ( Recording.mxml, Playback.mxml, PlaybackBar.as ) into your newly created project
3) Add the LCCS swc to your project's lib path
4) Build the Recording.mxml and Playback.mxml
If you get these steps working then you can try creating a new AIR project and doing the same.
Total Likes
Sorry - but this is still driving me crazy I just keep on getting errors - the basic examples just does not work for me
I wan to incorporate this in my own project obviously and not just run basic examples -
Are there any other things I need to do - like declare
-swf-version=12
I saw in my own project although I specifically have both spark and halo selected (mx and s) the
xmlns:mx="library://ns.adobe.com/flex/mx"
declaration was missing in my mxml file
rtc cmponents are build with halo right???
so the
<rtc:ConnectSessionContainer
does not want to reside in a spark environment???
- although the examples have it this way
- I still get this error
Flex Problem
Flex Problem
Child elements of 'WindowedApplication' serving as the default property value for 'mxmlContentFactory' must be contiguous.
Flex Problem
Total Likes
Could you post a small bit of code that shows this problem? Also, which Flash Builder are you using?
thanks
nigel
Total Likes
I am using Flash Builder 4.5 (for PHP)
It seems that even though I did select spark+Halo components in my Project build propertie, the
declaration was not automatically added to my mxml file
I have to add it manually where-ever I use any of the lccs components or declare
I do not know if declaring mx before rtc is necessary - that might also have caused the app to throw errors
- I'll test it later
- Lifecycle components are build with the Halo framework nd needs the declaration in the header of the xmlns file
Also - I am using the lccs.swc library for player 10.1
my target platfrom is 10.2+ anyway - and I would love to target 10.3 to try the noise cancelation
thanks for the interest in my issue - it has been solved now
Total Likes
I've got same issue. How did you solved it?
Total Likes
Likes
Likes
Likes
