dor_sakal
application update problem after switching to air 2.6 sdk
Apr 27, 2011 8:03 AM
Hello all,
Until now I compiled my air app with the Air 2.5 sdk.
Accordingly, my update.xml file used the following namespace: <update xmlns="http://ns.adobe.com/air/framework/update/description/2.5">
And the adobe update mechanizem worked great!
Now I want to switch to Air 2.6 sdk.
My compilation works, but when I switch the namespace to: <update xmlns="http://ns.adobe.com/air/framework/update/description/2.6">
I don't get an update.
When I ran the application in debug mode (FB4), I noticed the following error in my console: "updater error unknown update descriptor namespace".
Why does is not recognze the 2.6 namespace? Can anyone think of a reason for why this happens?
p.s
If I switch the namespace back to 2.5, I get the update window, but it fails to update (understood since the app is now compiled with the 2.6 sdk)
    Adobe Employee
    Apr 27, 2011 12:43 PM
    I believe you'll want to keep your updater xml set to 2.5.  I'm using this on an app built with 2.6, though I admit that it took a bit of trial and error on my part.  What error message do you get when you do run against 2.5?  Do you mind posting the contents of your update.xml file?
    Chris
    Adobe Employee
    Apr 28, 2011 6:39 PM
    I'm not exactly sure what I did, though it's possible that it ended up being what you suggested.  I might have just built a 2.6 app, then updated with a newer 2.6 version.  I was trying a number of things to correct the problem and wasn't as methodical as I should have been (this was after 6 hours of continous coding on Easter and my wife was "urging" me to stop )
    I've asked the team responsible for the Updater Framework to take a look at this thread so hopefully we'll find out more soon.  I'll also try and find some time to try and recreate the problem.
    Community Member
    Apr 29, 2011 2:09 AM
    I have a similar issue with implementing the updater on Windows XP
    AIR Runtime installed 2.6.0.19140
    adl.exe  Version 2.6.0.18830 2.6.0.19120
    update.xml
    <?xml version="1.0" encoding="utf-8"?>
      <versionNumber>1.3</versionNumber>
      <url>http://www.url.com/app.air</url>
      <description>
            <text xml:lang="en">Version v1.3</text>
      </description>
    </update>
    updateConfig.xml
    <configuration xmlns="http://ns.adobe.com/air/framework/update/configuration/2.6">
        <url> http://www.url.com/update.xml</url>
        <delay>0</delay>
         <defaultUI>
           <dialog name="checkForUpdate" visible="false" />
           <dialog name="downloadUpdate" visible="true" />
           <dialog name="downloadProgress" visible="false" />
           <dialog name="installUpdate" visible="true" />
       </defaultUI>
    </configuration>
    Throwing the following error  for
    updater.addEventListener(ErrorEvent.ERROR, onError);
    Adobe Employee
    May 2, 2011 12:01 PM
    For those following along, I've got a small update.  It appears that this was a known issue in 2.6, but there is a solution.  I don't have detailed steps yet (the team that works on this is based in Europe, so I should have either a link to a knowledge base article or detailed steps tomorrow) but I've heard it's something like: "users must first update their current app with an application that contains the new application updater framework (the one from AIR 2.6) and after that make another update to their app with the 2.6 NS."
    I'll post again as soon as I learn more.
    Chris
    Community Member
    May 3, 2011 1:57 AM
    Thanks for the update and the info that you the team is on it.
    Though I'm not sure if this solution works for me since I'm developing a new application right now, so its not deployed yet. I have the update-issues in debug and release builds that I launch from Flex Builder. I'll give it a try again soon and keep watching this post here.
    Adobe Employee
    May 3, 2011 2:01 PM
    Hi Matt,
    In the updateConfig.xml, could you try changing
    to
    From my understanding, this namespace version hasn't changed regardless if you were using AIR 1.x or 2.x.
    Chris
    Adobe Employee
    Jun 13, 2011 4:20 PM
    Here are some additional details.  Due to a bug in the AIR 2.5 application updater framework (internal bug #2793950), updating 2.5 applications to 2.6 still requires a three step process. However, this should be in no way different from the three-step process needed to update from 2.0 to 2.5.
    The original KB article can be found here:
    http://kb2.adobe.com/cps/873/cpsid_87300.html .
    An article describing the process when using Flash Builder can be found here:
    http://www.adobe.com/devnet/air/articles/air_update_framework.html#art iclecontentAdobe_numberedheader_4
    I hope this helps and please us know if you run into any issues.
    Chris
    Community Member
    May 4, 2011 6:19 AM
    Hi Chris,
    thanks for finding this little number-error. Works for me now this way with the 2.5 SDK .
    Community Member
    Jun 8, 2011 5:34 AM
    I am alos having same problem.. update manager not working for 2.6 descriptor... it was fine up to 2.5 any idea...?
    Adobe Employee
    Jun 8, 2011 10:10 PM
    Hi Shiju,
    Did the steps and documents that I referenced in this post help you at all?
    http://forums.adobe.com/message/3653528#3653528
    Chris
    Community Member
    Jun 9, 2011 11:14 AM
    Hello chris..
    i tried all the options as mentioned above .. but not working
    also the urls you mentiond for reference---http://kb2.adobe.com/cps/873/cpsid_87300.html .....http://www.adobe.com/devnet/air/articles/air_update_framework.html#art iclecontentAdobe_numberedheader_4
    not working now
    any idea???
    Adobe Employee
    Jun 13, 2011 4:21 PM
    Sorry about the broken links.  Not sure what happened there.  They should be fixed now.
    Chris
    Community Member
    Jun 20, 2011 12:54 AM
    Finally fixed the problem..
    May 4, 2010
    is the fix for the issue.. My issue was i was testing the aplication works or not just by changing it in update.xml(this testing was successfull in my previous projects upto 2.5), I assuming this technique changed and each time you want to test with a new update first compile the project with new verson umber then update the xml..this will work
    Thank you
Legend
  • Correct Answers - 10 points
  • Helpful Answers - 5 points
