quote:wouldn't the first step to trouble shooting be to reinstall it? i mean, logically speaking...
Originally posted by: hexagon4
I've uninstalled Flash9 and not reinstalled it but still I have the "Can not find Macromedia Flash" pop up when idle which is driving me mad !!
I don't have a C:\WINDOWS\system32\Macromed\Flash\Flash9.ocx anymore to try the above workaround as obviously I've unstalled
quote:
Originally posted by: vèédub
genius! i tried renaming the file from "flash9.ocx" to "flash.ocx" but it wouldn't let me because it is a read-only file. never thought of copying it and renaming though. worked perfectly. my screen saver worked in the "screen saver preview," now i just gotta wait 5 minutes to see if it really works. thanks for the help.
quote:
I would like to second this opinion! Genius might just be an understatement! I did everything Adobe said to do first with no success at all. Then I tried this technique and viola it is now perfect!!! Thank you! Thank you! Thank you! For anyone out there having the same problem, try this! It will save your sanity!!!
quote:
Originally posted by: svtdragon
I think I solved the problem.
I went to C:\WINDOWS\system32\Macromed\Flash and copied "Flash9.ocx" and then pasted it back in the same directory. This created "Copy of Flash9.ocx" which I then renamed to "Flash.ocx." (Thus I had "Flash.ocx" and "Flash9.ocx", both the same file with a different name in the same directory.) Everything in IE seems to be working normally now; I'm not sure yet about my screensaver, but time will tell.
