I can't find how to make a contact sheet from Bridge 5. I did find something that creates a pdf but it's no where near as good and fast as the way to do it in Bridge 3. I used to be able to select 'make contact sheet' through the Tools menu - photoshop
tog27 wrote:
I can't find how to make a contact sheet from Bridge 5.…
"Bridge 5"? The Bridge that comes with CS5 (Photoshop 12.x) is Bridge 4. "Bridge 5" does not exist yet.
tog27 wrote:
… I did find something that creates a pdf but it's no where near as good and fast as the way to do it in Bridge 3.
You are confused.
Bridge 3 came with Photoshop CS4 (11.x), and that function had been moved to the Bridge Output panel in CS4 already.
Maybe you meant Bridge 2, which was the one that came with Photoshop CS3 (10.x).
In any event, you can download an optional plug-ins set for CS5 that will restore the Contact Sheet. See:
http://blogs.adobe.com/jnack/2010/05/optional_plug_ins_available_for_p hotoshop.html
Wo Tai Lao Le
我太老了
That something is called the Output Module and gives you a lot options to
create a contact sheet with custom settings (and you can create templates
that can be saved so easy to get that for the next time).
An I disagree hat it is slower then the former contact sheet in PS,
especially with multiple pages the Output Module is much faster ![]()
The only downside for Output Module is that you can't export as a jpeg or
tiff, this is a long standing wish and you may add this also as a feature
request. The more that want this, the greater chance it will get realized.
However you still be able to use this old contact sheet (see the link Tai
Lao just provided you to download it) but there is a but...
After installing the script according to the read me file you will see this
in the Tools menu for Bridge but it only works in 32 bit mode (this old
script has official been discontinued and won't get updated to 64 bit). By
default PS is running in 64 bit and therefore won't recognize the script.
To use it you have to first quit PS, in finder select the application icon
for PS, press 'get info' (cmd+i) and in the provided info window check start
PS in 32 bit mode.
Now you can use it as before.
I use Win 7 64 BIT
I make pdf output in Bridge CS5 but not work.
I downloaded optional filters and I tried in to read me files path but it doesn't work.
Now I find a new path and put in the "bridge Startup Scripts" file there. They working perfectly.
The path is the bottom:
... /Program Files(x86)/Common Files/Adobe/Bridge CS5 Exkensions/Adobe Output Module/Resources/Scripts
Copy all files and folders "PSCS5OptionalPlugins_Win_en_US/Bridge Sturtup Scripts" paste in to this folder at the path
enjoy ....
Probably unbelievably obvious, but just in case anyone is scratching their head because they can't seem to see the 'output' options, they're in a panel that may be minimized – it lives on the right of the window. Once I expanded the margin I found it hidden away, and there are all the options I was looking for.
