Fill in a PDF Form from source code.
Jun 10, 2011 5:07 AM
Hello:
I have a PDF form made with LiveCycle. This form read the data from a xml file. I'm trying to fill it programatically but i don't know how. I'd like to know if there is some way to do this action, from source code or with a command line.
Thanks a lot.
    Jun 11, 2011 9:48 PM   in reply to Osmosys73
    This is pretty easy.
    What language do you use to fill the form data programatically? e.g Java/ .Net ??
    Nith
    Jun 13, 2011 10:23 PM   in reply to Osmosys73
    iText is an API which has the PDF edit capabilities.
    Read this link : http://www.itextpdf.com/
    If you have Adobe LiveCycle Forms ES/ES2 solution component, you need not go for iText; Instead, you can invoke the LC APIs through C#.net and merge the XML data into the PDF.
    If you would go with option#2, let me know. I will share you my ideas.
    Nith
