I have downloaded this Widget using the Widget Browser and started with a fresh page as a testpage . http://www.taylorslakesfc.net/sponsors_test.html
Within the Widget Browser - the default show the 5 pictures perfectly.
In Dreamweaver, I insert the Widget, selecting the Default and I have double checked that the DocType is set as shown in the example code and that scripts has correctly inserted in the Head and Body of the document.
In Dreamweaver - Live View - it loads forever!
I have moved the Spry-UI-1.7 folder to the server.
In IE8 - All I can see is the bulleted images, HOWEVER, it work fine with Safari 5.0.4 and Chrome 10.0.648.204
In IE8 - The page displays with Errors - SpryWidget.js Line 82, Char 2 Length is null or not an object.
Help will be greatly appreciated.![]()
Have you received any feeback on this?
I am experiencing the exact same error in IE8. The slideshow widget works perfectly in Fire Fox, but when it loads in IE8, all I get are the thumbnails as bullet points.
Message: 'initialize' is null or not an object
Line: 501
Char: 3
Code: 0
URI: file:///F:/Marketing/London%20Trips/Golf%20Outings/London%20May%20201 1/Web%20Slideshow/Spry-UI-1.7/includes/SpryWidget.js
The exact lines it takes issue with are within the SpryWidget.js and read as follows with the red denoting the actual character it stops on.
// Instantiate each plugin.
for (var i = 0; plugIns && i < plugIns.length; i++)
if (plugIns[i].initialize)
plugIns[i].initialize(this);
The really odd thing, is this worked perfectly a few days ago. I made some minor changes (which should not affect the SpryWidget at all!!)
