I am wondering if there is an easy way of setting a photo as desktop background using lightroom (similar to picasa)?
There's not a built-in "set as desktop" feature like Picasa has, but it's not difficult.
I created an Export preset called "Export to Wallpaper", which sizes the image(s) to my screen size (1920x1200) and saves them to the folder where I keep all my wallpaper images ("Public Pictures" in my case, on Windows 7). So I select one or more images in LR, and choose Export->Export to Wallpaper.
Then just use normal Windows features to select your wallpaper images. In Windows 7, I usually use the right-click->Personalize shortcut or you can use the Control Panel. (Note also that Windows 7 lets you select multiple images as wallpaper, and it will rotate thru them like a slide show - nice!)
Bob12312321 wrote:
seems a little silly that a $300 program does not have all the features that you can get for free!
Seems a little silly that you would want a professional app to do something so unrelated to a raw image workflow, and so trivial you can do yourself easily.
Any modern OS can change the background based on a folder of images. Set up a publish service to a folder that the OS looks at for this purpose.
The resolution you want is the resolution you need -- only you can know for sure. Set your export options accordingly.
It's free because it's a gimmick - a gadget.
I for one don't want my "serious" software stuffed with toys entirely unrelated to the job its designed to do.
Besides it is readily available - for free - in umpteen other places (does anyone not have Irfanview or an equivelent viewer on their machine?), so it can't even be convincingly argued there's a "need" for it in Lr.
Bob12312321 wrote:
If you had read the title you would know my os is NOT modern!
and lightroom advertises itself as being a complete workflow! for me setting as desktop background is PART of a complete workflow.
I can't tell if you are being serious or not. Let's try again:
Any OS that a recent version of Lightroom runs on can display background images from any local folder. Make a publish service that publishes to that folder.
Publishing images to your computer desktop will never, and should never, be considered part of any photographic workflow. If you need to stare at your own images so much, find a way to do it with exported renditions.
You just need to export a JPEG at the correct dimensions -- something only you know. The resolution in pixels (or "dots") does not matter for on-screen images.
What you need to really care about for desktops, other than dimensions, is contrast and sharpening. You need enough of each, but not too much. Once you have learned this, grasshopper, it will be time for you to leave us.
Here is step by step instruction on how to check for your screen resolution on Window Vista. I'm using WinXP, my system is even older than yours.
http://www.vistarevisited.com/2008/11/30/adjust-your-monitors-screen-r esolution-in-vista/
Here's a much easier way to determine your screen resolution setting:
http://www.whatismyscreenresolution.com/
Make sure it is set to the "native screen resolution" by referring to the manufacturer's specification in the manual, or check your display model # online.
You can also setup a desktop slideshow in Vista, but why wouldn't you just use Lightroom's slideshow module?
http://windows.microsoft.com/en-US/windows7/create-a-desktop-backgroun d-slide-show
The only time I see the desktop on my system is on initial startup and shutdown! Actually with Vista and Windows 7 in Aero mode you can see a tiny portion of the desktop through the transparency at the top of the application. But IMHO it’s hardly enough to worry about what's on the desktop background.
IMHO the desktop background should be as neutral as possible, so it doesn’t interfere with processing your pictures when it is visible!
You can usually tell the workstation where serious photo work is done. It will have a neutral theme (or the "less purple and blue highlights, please" option on a Mac) with no background, or a simple low-contrast monochrome background. And the monitors (there are always more than one) will be set well down from the factory brightness, which is measured in Kelvin, and can set newspapers on fire at 10 inches.
Finally, the colorimeter will be within reach of the chair, the packaging for it long thrown away.
Bob12312321 wrote:
True. seems a little strange though.
Since Lr doesn't /really/ know if you are exporting your images for print or screen (you could be exporting cheap and cheerful test shots or something) the resolution setting is always available.
On a fixed resolution device like a screen, it just doesn't matter. Only when interpolating those pixels on some other device does the resolution come into play.
Does this thread have anything to do with Lightroom????
I think the Lightroom forum has slowed down a bit on interesting posts. I guess a few of us are "milking" this one for all it's worth!
Some of the post requests of late seem to be from beginer-level or non-photographers who have taken up an interest in Lightroom. Perhaps they don't understand that Lightroom is designed and intended for use by serious amateur and professional photographers. Hopefully we (and Adobe) can keep it that way!
