I am porting a coldfusion application from 32-bit ubuntu to 64-bit and have run into an odd snag. For some reason, I am able to perform file operations in a directory but am completely unable to get a directory listing using cfdirectory.
The CF server is Ubuntu 10.04 64-bit running coldfusion mx7. It is joined to active directory using centrify express, and has the centrify samba package installed instead of regular samba. The directories in question actually reside on windows servers - Windows Server 2003 and 2008. The shares are mounted on the CF server using the following lines in fstab:
//server2003/share /network/server1/share smbfs _netdev,noperm,credentials=/root/.smbpasswd,uid=0,file_mode=0777,dir_mode=0777 0 0
//server2008/share /network/server2008/share smbfs _netdev,noperm,credentials=/root/.smbpasswd,uid=0,file_mode=0777,dir_mode=0777 0 0
Coldfusion jrun process is running as root. The directories are browsable with no apparent problems when logged in via ssh. Coldfusion can create new files in directories with cffile, and FileExists works with one of the files I'm trying to list, but cfdirectory always returns an empty list. I tried using the undocumented FileInfo="name" option to avoid running java's stat() command, but that yielded an empty set as well.
After getting some advice on Experts Exchange, I tried getting a directory listing with java:
<cfset obj = createObject("java", "java.io.File").init(testPath)>
<cfoutput>
listRoots = #arrayLen(obj.listRoots())#<br>
listFiles = #arrayLen(obj.listFiles())#
</cfoutput>
... no dice. Empty result sets as before, though java could see that the parent directory was there, and obj.canRead() and obj.canWrite() both returned True.
I think I've already summarized all I've tried, but here's a link to the question thread on experts exchange, in case I missed something: http://www.experts-exchange.com/Web_Development/Web_Languages-Standards/Cold_Fusion_Markup_Language/...
I have no idea what's going on here... any help would be greatly appreciated!!
*bump*
Any guesses? Crazy notions? I've considered ritual sacrifice at this point, so any theories at all would be helpful... I just don't know what else to try.
Just to confirm: you're getting (basically ~) the same results with Java file operations as you are with CF's?
That being the case, you might be better of rephrasing your question on expert-sex-change to be more Java-centric: ultimately it'll be a Java issue, and the Java community is much bigger than CF's. Additionally, stackoverflow might be a better place to post?
Are you in the position to install a dev version of CF9 in the same environment and test if that works any better?
Adam
.. that just made me spit coffee all over my screen
That's a good idea, Adam - We've already posted on stackoverflow, but I'll go ahead and post again on expert.s ex.change in the java section. You are correct in your analysis. Java appears to have the same problems.
Cool. I'd be keen to know what the answer is (just out of interest) if you track it down...
Adam
Same problem here...
Let's look on stackoverflow.
