Oh well... still not working. I tried the extension uninstall and the downloadable update. Couldn't locate the log file as described. Sorry, but I just can't bring myself to do the full reinstall. This is like a bad sitcom episode.
It's a bit of a shame, since I use Fireworks every day for all my web graphics. But it seems to be working fine so I'm not going to worry about it. Perhaps the solution is to turn off the Adobe Update alert in my menu bar. Yes... that fixed it.
I'm having this problem as well, and have tried all the steps mentioned above, including re-installing Fireworks. No luck.
It's funny: I have dozens of applications that update themselves all the time, most of them costing well under $50. Some of them are very full-featured apps. I only have this kind of problem with software from the Big Vendors: like Adobe, Microsoft.
i mabye got this wrong, i uninstalled the air extension of fireworks trough the extension manager. but i am unable to find these files again , nor do i find this special folder as described here and on this page - http://blogs.adobe.com/sarthak/2011/06/resolution-for-fireworks-cs5-ve rsion-11-0-1-update-fail.html
trying to reinstall of the extension /Library/Application Support/Adobe/Fireworks CS5/Preinstall/REMOVED/AIR Export using Extension Manager CS5 is not possible because i simply cant find this folder on my mac system
google search and forum search dont give me answers, so how do i fix this?
We have heard your feedback in regards to the update failures, so we have temporarily removed it. We will re-release the update as soon as we have fixed the install issues.
For those of you that have already successfully installed the update, there is no action required. The contents of the update will remain unchanged.
For more info, see: http://blogs.adobe.com/sarthak/2011/06/fireworks-cs5-update-has-been-p ulled-out-temporarily.html
Hi All,
Am Shubhashri from Fireworks Engineering team.We regret the inconvience caused by the Adobe Fireworks CS5 11.0.1 Update.We have worked on resolving the issues and the new update is now live.
We have made the new Patch available through Adobe Updater.(Help->Updates).Installer through Adobe.com site will be available in couple of days.Please install the update and let us know your feedback.
Please note that the Application has not been changed from what it was in older update(11.0.1.7) even the application version remains the same (11.0.1.7).Only the update shows version as 11.0.2 though internally it is same as 11.0.1.
FW Team
Can you please share the log file in this location
<installdrive>:\Program Files\CommonFiles\Adobe\Installers\Adobe Fireworks CS5 11.0.2 <date>.log.gz (32-bit Operating system)
Also screenshot of the error would be helpful for us to debug.
FW Team
Hi All,
New update for Fireworks CS5 (11.0.2) has been posted in Adobe.com as well.Please download the update from
http://www.adobe.com/support/fireworks/downloads_updaters.html .
As menitoned earlier the update is named 11.0.2 but the application has not been changed from what it was in 11.0.1.We have only fixed the installer issues in this new update.Application version would remain as 11.0.1 itself.
FW Team
Nope:
Still get this.
Adobe Fireworks CS5 has been moved or deleted improperly. Please launch or reinstall the application to update the location and try again. To remove the product from the system, please uninstall product using the aliases under "/Applications/Utilities/Adobe Installers". Error Code: U44M2P29
Error message says that you have either moved or removed the Adobe Fireworks CS5 from the installed location.So please follow the instruction below to get the update working.
"Please launch or reinstall the application to update the location and try again. To remove the product from the system, please uninstall product using the aliases under "/Applications/Utilities/Adobe Installers"
Shubha
I'm not being obstinate here … but I have never moved anything.
The folders are exactly where the installer put them in my Applications folder.
I get this alot with Adobe products. (mainly Soundbooth, Fireworks and InDesign).
Soundbooth has NEVER worked in CS4 or CS5 for me and I have had two different laptops (the one I'm on being the newest model).
This weekend I will uninstall EVERYTHING (again) in the CS5 Adobe Creative MasterSuite and do a reinstall.
Then I will let the updater do it's thing.
I don't understand why it thinks I have moved the software.
There is no other place I would put it.
I'm also getting an error when trying to update Fireworks via the Adobe Automatic Updater. I tried downloading the update from the site but also got the same error message. I've never used Fireworks. I don't see an icon for attaching files. This is my first time posting to this forum, so I'm not sure how to attach the log files.
I tried to installa latest update "Fireworks_11.0.2_All_AdobeUpdate.dmg" but from the application info I always see version 11.0.1.7.
I did not get any error from installation process.
I got the following messages from log file:
ERROR: The following payload errors were found during install:
ERROR: - Adobe Fireworks CS5_11.0.2_AdobeFireworks11All: Patch already installed
ERROR: - Adobe Fireworks CS5_11.0.2_AdobeFireworks11it_ITLanguagePack: Patch already installed
Why I still see the version 11.0.1?
Thanks.
R.Stijnman wrote:
Any news on this issue? I've just tried again to update but still.......... no luck.
Make sure you're installing the latest update (which most likely you are). Download the update from here to be sure: http://adobe.ly/FWUpdates
If you're still having issues, then they are not related to the issue discussed in this thread. See this article for help getting the update to install successfully: http://helpx.adobe.com/creative-suite/kb/troubleshoot-update-issues-cs 5-cs5.html
