Menu bar is hidden by default - Reader X
Guest
Jun 17, 2011 Jun 17, 2011
After downloading the newest update for Adobe Reader X (10.1.0.534), opening a pdf from a browser in normal mode (not "Read Mode") forces us to press F8 to unhide the menu bar by default. We are using IE8.
I can't find any setting to stop this behavior. Is this by design? Because it is really annoying.
We have Display PDF in browser checked, but Display in Read Mode by default is unchecked.
Under Documents, I have unchecked 'Allow documents to hide the menu bar, toolbars, and windows controls'
And checked "Restore last view settings when reopening documents"
Any ideas? We would love to have every pdf opened in a browser with the menu and toolbars open by default.
80.8K
Once you have the toolbar open you can save a copy of the file. I've found that, when you open that copy, the toolbar opens with it.
Jim B.
Guest
Unfortunately, this is not going to work as the users who have this issue open many many pdfs a day. They are using a web interface to view pdf files and need the menu and toolbars to open with the files. I don't understand why this was changed. It worked fine before the previous update, which we were forced to do for security.
Jun 20, 2011 Jun 20, 2011
We are experiencing the same issue on most streamed PDF's resulting in no Toolbar.
We are using the setting with display in read-only disabled:
[HKEY_CURRENT_USER\Software\Adobe\Acrobat Reader\10.0\AVGeneral]
"bBrowserDisplayInReadMode"=dword:00000000
We have to hit F8 to refresh the screen to see the toolbar.  This seems like a bug introduced in 10.1, as it works fine in 10.0.1 and 9.4.5.
Example of a file that does not work:
http://samplepdf.com/sample.pdf
Example of a file that works:
http://help.adobe.com/en_US/reader/using/reader_X_help.pdf
Jun 21, 2011 Jun 21, 2011
Yes it's a bug, sorry. It affects Reader X 10.1 and Acrobat X 10.1 (the latter running in Protected View or not). Changing your preferences has no effect.
The reason your first link fails to show the toolbar and the second one does, is that the second one's IV preferences are set to "document and bookmarks". As I've said in the past, any initial view setting which includes one of the side panes (bookmarks, thumbnails, etc.) will break out of Read Mode and force display of the full toolbar chrome. Unfortunately you can't set that globally in your app preferences, it's a per-document thing.
I know you don't want to hear it, but the "fix" right now is to press F8, which toggles the toolbar chrome on and off.
Experiencing the same issue. Has anyone filed a bug report?
Any other workarounds other than pressing F8?
Guest
Jul 13, 2011 Jul 13, 2011
Any idea when Reader v10.2 will be released and if this bug will be swatted in that rev?
I have had the same problem.  All you can do is go into Internet within Page Display Preferences and make sure both Display PDF In Browser and Display In Read Mode By Default are ticked.  Then you can make the toolbar switch between hovering near the bottom of the page or becoming pinned to the top of the page by pressing F8 - but you have to do this each time you open a document.  Seems like a bug with the update as you never used to have to do this ?
Jun 26, 2011 Jun 26, 2011
...as anyone found a proprer workaround? My F8 key is geeting a bit overused...
bugger...
Jul 07, 2011 Jul 07, 2011
This is really an issue.  We noticed it too and are going to wear out the F8 key.  Everything we generate in a pdf is either saved or printed.  Adobe, Please fix this in an update. Thanks
There is no "proper workaround" - it will be fixed as part of the regular product update cycle. We knew about it from day one, many people have told us about it since then, but the details of forthcoming updates is not something Adobe confirms in advance.
To clarify the situation as it affects Acrobat and Adobe Reader 10.1:
  • If you choose to display PDF documents in a browser using Read Mode (Preferences > Internet > Display in Read Mode by default) then when a PDF opens which does not set any panes, you will see the black HUD toolbar. Clicking the Trefoil icon on the HUD displays your full toolbars.
  • If a PDF document sets panes (initial view with thumbs, bookmarks etc. open) then Read Mode will never activate, and the toolbar will always show.
  • If a PDF does not set panes and you are not using Read Mode by default, there will be no toolbar. This is a bug.
As an example, turn on the Read Mode default preference and view this file, which has no pane settings. Compare it to this one, which sets the bookmarks pane, and you will see the different UI layouts.
Sep 15, 2011 Sep 15, 2011
Does any know if this has been fixed on the 10.1.1 release?
Jeremy
Sep 16, 2011 Sep 16, 2011
Yes, it is.
Guest
Dec 15, 2011 Dec 15, 2011
I don't see anything in the release notes for 10.1.1 about fixing this toolbar issue.
Can you confirm it was fixed with this release or will it be in a future release?
Chuck - I can confirm that the toolbar issues is fixed in v 10.1.1.  Adobe never mentioned that they broke it, so I guess they didn't feel the need to mention that they fixed it.
Guest
How do you change your settings to have the toolbar shown as default?
I still have to press F8 and haven't found anything that changes it under preferences.
Thanks Texas!
Edit --> Preferences --> Internet --> untick the "Display in Read Mode by default" option.  Probably need to restart Acrobat and all should be the way it should be.  (I'm not a fan of the floating toolbar.)
How can I go backwards from 10.1 to 10.01?
