How do I turn this off?
I'm getting four lines of green text in the upper left of the screen when I output to Matrox AVI from premiere CS4. I haven't seen this before so I must have inadvertently switched something on, but I can't determine what it is. The lines are: Current Frame, CPU Load, Input Size and Output size.
They are a permanent part of the video when it is output as a Matox AVI.
Can you help me get this off the screen.
Nothing to do with Matrox.
Sounds like it's the OSD (on screen display) stats from a ffdshow decoder. Do you have ffdshow installed on your PC? If so you can select or deselect these items or untick OSD in the left pane of the "ffdshow video decoder configuration" utility under "ffdshow" of your installed programs.
I've not encountered any specific problems with ffdshow (when I've had it installed).
The "Merit" and "Don't use ffdshow in" and "Show dialog when unknown application tries to load ffdshow" controls in the "Directshow Conrol" options can usually be used to tell ffdshow to keep out of the way for specific programs.
Steve,
FFDShow can be installed from several sources. One common one is with the K-Lite CODEC Pack, but there are others.
Good luck,
Hunt
PS - there might be some background in the hits in this Google Search. I would read a few of the Adobe Premiere Forum threads.
You might get a clue by looking at the list of programs in its "Use ffdshow in" and "Don't use ffdshow in" lists. These are effectively black and white lists of programs that ffdshow will allow or disallow itself to be used with.
To uninstall, just do what you would do with any other program - there is a ffdshow uninstall entry in the windows Control Panel's "Add/Remove Programs" or "Programs and Features" icon.
