Premiere Pro and Davinci Resolve?
Jun 24, 2011 1:35 PM
Hello
as a ex-Final Cut Pro editor coming to Premiere Pro, the only thing that I'm missing is Apple Color. I mainly edit h264 Canon 7D and 5D files now directly in Premiere Pro. I'm thinking about using Davinci Resolve to color correct my footage. Is there any one who use Resolve with Premiere Pro? Can you export Premiere Pro project and color correct it directly in Resolve? Is there some issue with it?
Thanks for you help,
Philippe
    Jun 24, 2011 1:44 PM   in reply to Philippe Kiener
    I'm not familiar with Resolve, but Colorista II from Red Giant gets high marks around here.
    http://www.redgiantsoftware.com/products/all/magic-bullet-colorista-II /
    Jun 24, 2011 4:59 PM   in reply to Philippe Kiener
    I too would love to hear more about this workflow. Now that apple has dropped the bomb I am hoping Premiere will be my new editor, easier to pick up at this point then avid and since I already have production premium I can spend the $1000 on Resolve and have a fairly complete solution for edit/graphics/finish. It seems like exporting an EDL from Pr and conforming in Resolve would be a straight forward workflow but what about getting back to Pr? Anyone have experience with this workflow?
    Kevin Stanley
    Local 600 DIT
    Orange County CA
    Jun 24, 2011 6:00 PM   in reply to KevinStanley01
    I regularly take footage (AVCHD, QT, DNxHD) and an EDL into Resolve at a facility I use.
    From Resolve we go into Flame and finish.
    Works well.
    Jun 24, 2011 6:17 PM   in reply to shooternz
    Thanks, what about roundtripping back to Pr for export, does that also work well? Ideally I'd like to roundtrip from Pr to Resolve (Color Correct) and back to Pr for export using matrox max h.264 for timed dailies and use the Q4000 for accelerated export of timed prores or MXF deliverables from Resolve at the same time.
    All input is greatly appreciated.
    Kevin Stanley
    Local 600 DIT
    Orange County, CA
    Jun 25, 2011 6:05 PM   in reply to Philippe Kiener
    Black Magic announced in April that they will support CS5.5.
    Here's a link to their press release.
    http://www.blackmagic-design.com/press/pressdetails/?releaseID=11838
    Although it doesn't mention Resolve specifically, I can't imagine that it's not supported now.  I would contact them directly.
    You may also want to take a look at Color Finesse.  It's a plugin that comes bundled with After Effects.  I fell in love with it and purchased the full version so I could access it in Premiere Pro.
    Here's their link.
    http://www.synthetic-ap.com/products/cf/index.html
    Hope that helps.
    Jun 26, 2011 1:16 PM   in reply to dmcclin
    Thank you for the info regarding BM support. I will give color finesse a look as well.
    Kevin Stanley
    Jun 26, 2011 1:46 PM   in reply to KevinStanley01
    Dont totally ignore the CC tools inside of Premiere just to get a prettier GUI form a 3rd party plugin. .
    Even the Secondaries in PPRO can do a great job.
    Big advantage of using PPRO CC tools if you have MPE / CUDA etc...is Realtime CC and playback..
    Jul 27, 2011 11:57 AM   in reply to Philippe Kiener
    > It seems that Adobe is working on a fix for that.
    Yes, we are.
    Sep 12, 2011 4:03 PM   in reply to Todd_Kopriva
    Here you go.
    Install the Premiere Pro CS5.5 (5.5.1) update and let us know how it works for you.
    Oct 4, 2011 4:36 AM   in reply to Todd_Kopriva
    Export XML from Premiere 5.5.1
    Import this into Resolve.
    It's working!
    Export XML from Resolve
    Import this into Premiere.
    It work's also, but the Sequence lost it's interlace setting.
    (Allow Field Render in Resolve is ticked)
    Oct 4, 2011 2:20 PM   in reply to Huenkaboink Gasurksel
    Interestin flashomatik. Can you file your issue on the bug/feature request form? http://www.adobe.com/go/wish
    Oct 23, 2011 7:56 PM   in reply to Philippe Kiener
    I have the same problem... a long (1 hour) talk, and would prefer to grade in Resolve. Unfortunately, I can't figure out how to bring the sequence into Resolve using Premiere Pro's Export XML.
    Jun 17, 2012 10:48 AM   in reply to Philippe Kiener
    Very annoyed by this as well, have CS6 and it's not an easy task to go back and forth. Resolve is a standard so I fail to understand why Adobe hasn't included the correct XML version in their latest CS6.
    Jun 17, 2012 4:50 PM   in reply to Huenkaboink Gasurksel
    Do you mean interlacing or frame blending? It should keep it's interlacing, but Resolve doesn't support frame blending so this info gets lost in the xml interchange. I'd love it if Da Vinci at leasts carried the frame blending setting through the xml, so this info was retained when re-importing the finished xml back to an nle.
    You can always export a flattened movie file, and then have Resolve's scene detector cut it up. It does a pretty good job.
    Jan 21, 2013 4:44 PM   in reply to Philippe Kiener
    There is a tutorial here: http://www.youtube.com/watch?v=-0S2MJT9wDY, but if you can get it to work, you are a magician.  From what I read it is supposed to work most of the time.  That would not be helpful to me even if I could get it to work.  The problem is that Resolve links the wrong clips to it's timeline (yes, even ones with entirely different names).  Color Finesse is a pretty good program if you're doing very basic stuff, but it is seriously lacking otherwise.  It does not have the ability to use masks, let alone track them.  I was very excited for Speedgrade when I upgraded to CS6, but Speedgrade is pathetic at best.  There is only one color correction control, no curves adjustment, and the only way to be able to see the controls to  use them is to minimize the monitor panel to the point where to clips are too small to be useful.  Aside from a so-so tracker, you'd probably have better luck using the three-way corrector in Premiere.  Davinci is a powerhouse, unfortunately no one was smart enough to make it useable with any of the big-name editing software.  If someone has found a better way PLEASE let us know.
    Mar 12, 2013 8:47 AM   in reply to RFDPiper
    Yeah, after two months of experiments with different versions I found a R3D-Premiere-Resolve workflow that really works for me.
    1.  Edit R3D in Premiere 6.0
    2. Export Final Cut Pro XML from Premiere.
    3. Add used R3D files into Media Pool in Resolve 9.1.1 Lite.
    4. Import XML to Resolve.
    5. Grade.
    6. Export using easy setup - Final Cut Pro XML Round-Trip, but change codec to QuickTime Uncompressed RGB 8 bits (that one works only, without any problems).
    7. Go to Conform page and export EDL.
    8. Import EDL to Premiere and Link Media.
    Done)
