I have noticed the last couple of times I have used the search function that, although the word I am searching for is being found, it is not necessarily being highlighted, so that I can see where it is on the page. Sometimes I get a vertical line (like this | ) next to the word, as if the cursor is there, but that is really hard to see on a page full of text. Once today I got one out of three occurrences of the same word on a page highlighted in blue (great!) but the other two were not highlighted at all when searching forward. Having got the third one highlighted, I then used search backwards and one of the other two (but not both) got highlighted in blue.
Surely this has something to do with Adobe Reader, rather than my laptop settings. I did install the latest update this morning (I think there was also one either yesterday or the day before) and am now on version 9.4.5
MClareS
I have the same exact issue, I use the search feature about 300-350 times a day. It only started after the last update, a day or a few ago.
For me the issue is primarily when there is only 1 search result on a page, if there are multiple search results on the same page it will highlight the 2nd one, and then I can hit the reverse search button and it'll find the previous search result on that page and highlight it as well.
It is very annoying, I hope there is a fix/patch/update soon.
It is unusual to get bugs fixed that quickly. If they tell you about a week, then be happy that is as long as it takes. Flooding tech support with phone calls will not help it go faster. The update must go through quality insurance. While the bug did get through Adobe's bug checking process, it may have been rushed to avoid security issues. Relax, it will get done. If you want to express its importance, then it is much easier and more helpful to use the Adobe Bug Reporting form:
https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
Thank you "Michael the Adobe apologist" for letting me know what I shouldn't or should be happy about. Something as big as that error, with as many people having it, should have certainly been caught, or at least Adobe should have let us know that the feature isn't fully implemented yet so caution when updating your Adobe Acrobat version. I've reported it via the bug report form but I am pretty darn positive Adobe reads these forums for feedback, and Adobe won't understand the level of frustration amongst their uses unless they do.
In my industry I deal with 1,200-1,500 page .pdf documents where I need to quickly reference certain keywords, and searching with my eyes down an entire page is not very conducive to getting business done.
-Frustrated Adobe Acrobat customer
Same issue after the last update. I have the full version of Adobe Acrobat Standard (9.4.5) and not just the reader. Not sure if this works in the reader but a workaround I found is to use the Full Acrobat Search and then double click on each of the results in the search results window. Not a very efficient method but at least it works until this bug is fixed.
I got a message that Adobe is working on this issue:
Hello
Thank you for taking the time to notify us of this unexpected behavior after updating to Acrobat 9.4.5. This has been identified as a bug by our Engineering team. They are hard a work adding a fix to be included in the next update. There is no time frame for this patch to be released.
We apologize for the inconvenience and hope to have this issue resolved in the future.
Ed Hutton
Adobe Systems Inc
I am having problem with text search in Adobe reader latest version 9.4.
One pdf file generated through a pdf printer inside a word processing program and has around 100 pages. So there is no issue of having a scanned document which is not searchable.
In this document, when I try to search the text inside the pdf file using Adobe Reader 9.0, it is working alright and it is recognising the text searched for.
However, When the same pdf file is searched using Adobe Reader 9.3 and 9.4 etc it is not searching the text which is present at more than five places in the document.
Please advise.
Other issues have been created with this last update (for full Pro users on 9.4.5 at least).
Worst for me is that you can't select the pages you want in page view (to move, delete or extract them).
I'm getting sick of hearing "This has been identified as a bug by our Engineering team. They are hard a work adding a fix to be included in the next update. There is no time frame for this patch to be released."
FIX IT already.
I'm having the same problem as many others with the search highlighting problem in Acrobat Standard (not Reader) version 9.4.5. I also just confirmed that the same problem exists in Reader version 9.4.5. Your suggestion to upgrade to Reader version 10 might fix the problem with Reader 9.4.5, but it appears that those of us posting the problem aren't using Acrobat Reader, we're using Acrobat Standard.
With the range of software products currently available, it's easy enough to confuse one for another, especially wth the popularity of Acrobat Reader. I think it's safe to say that Acrobat Reader is the 'standard reader' for PDF documents. The idea that Acrobat Reader is the standard for PDF documents is a point of confusion, because now we have to decide if the standard reader is Acrobat Standard or Acrobat Reader. Maybe Adobe could have chosen a better name for Acrobat Standard, something like Acrobat Writer, or Acrobat Creator. Anyway...
I'm not criticizing your suggestion, or flaming you for contributing an idea that may be helpful for some, but not necessarily for others. I use Acrobat Standard because Acrobat Reader is not capable of doing what I need to do. My particular situation requires the ability to search a document (not necessarily a PDF document) for a word or words, highlight them, comment the document, and save the commented document in PDF format. I may also need to combine several documents into a single PDF document for ease of Emailing them to someone. It may be a poor comparison on my part, but Acrobat Standard is like a TV boradcast station in that it creates content to be viewed elsewhere, and Acrobat Reader is like the TV set, in that it is intended to view the content created at the TV broadcast station.
Just adding my voice to register my frustration with this problem as well.
Highlighting of search terms was working fine until we ugraded from Adobe Standard 9.4.4 to version 9.4.5. It is not only annoying to not have this working, it is very time consuming as well. I have actually had to install FoxIt reader on my system so that I can get functional again.
I have submitted a bug report as suggested by another poster. Hope they are getting the message that this is a HUGE problem fo rmany users.
Just discovered something interesting.
Under "Preferences -> Search" there is an option called "Enable Search Highlights From External Highlight Server". It was disabled when I first opened these settings, so I tried enabling it and now highlighting of search terms seems to be workinga little more consistently for me (well actually working at all versus not working at all), although it is still skipping some terms when I click the arrow to go to the next match. I've also noticed that when it does skip highlighting a match, if I then click to go to the next match and then click to go back to the previous match, it then hightlights the previously unhighlighted match.
Obviously not a solution to the problem as this is defnitely a bug, however, maybe it will help out in some instances.
Also, does anyone know what "Enable Search Highlights From External Highlight Server" this setting is for? It is kind of self explanatory, but what is an "External Highlight Server" in relation to Adobe PDF applications?
I'm no expert, but I BELIEVE that the external highlighting is from your computer's system. If you're on Mac, then your highlighting is set up a certain way in your system prefs "appearance"
I could be wrong.
I too found that little preference in Acrobat last week, but it's still not a solution. So frustrating!
Definitely not working since 9.4.5. Whatever happened to beta-testing properly? It should be simple enough to fix the code on this - the bug was introduced by the last update, so check the code for that and fix it NOW!
It's bad enough that Acrobat is the only plug-in that regularly crashes my browser when a file download does not quite complete. Firefox 5, IE9, both same problem, as with older versions.
Possible workaround:
When the highlighting doesn't occur, and insertion point "|" is placed at the search text, it is possible (on Windows at least) to press SHIFT + LEFT ARROW, and then the text will be highlighted (for as long as you hold the keys down).
OK, so this isn't ideal, and we still want it fixed, but it makes it much easier to spot where the search result is on a crowded page of text.
I hope this helps people somewhat until Adobe are able to release a patch.
J
I'm quite surprised the problem is still not solved. I filled in the bug report form on Adobe's website two days ago and still no response.
I thought Adobe was much more serious.
About 600 people are impacted by this problem at my job and I cannot migrate to version 10 because it doesn't support the "enable highlight from external server" option wich is needed by DTSearch.
I had to prepare an unistallation package for version 9.4.5 and a new installation package for version 9.4.4.
Il Adobe doesn't release the patch today, I'll have to launch my packages on all computers :-(
Problem with me is solved:
I use Acrobat Reader 9.4
1. Uninstalled the program
2. Deleted folders where was installed, but didn't succeeded with normal delete, cause windows said I didn't have permision or smth like that. So I used program for optimizing computer software like TuneUp, to delete the folders.
3. After reinstalling AR 9,4 search highlight worked fine.
Fortunately version 9.4.0 is available here:
http://get.adobe.com/uk/reader/otherversions/
and Search is OK in that. I recommend you uninstall your current version before installing 9.4.0
Not yet a solution, but...
I use the brazilian portuguese version, and there's a search option called "Abrir Pesquisa Total do Reader" - Shift+Ctrl+F ("Open Readers Full Search", or something alike).
In there, the search highlights the results, but it may be needed to click twice on the result in the search window.
Cruz
I am glad to see the problem is prevalent enough that a fix is probably in the works, and that it's not just me. Meanwhile, I have found a consistent way (so far) of seeing the highlighting, though more cumbersome than the way it is supposed to work. Instead of using "Find," I open the "Search" window by clicking on the binoculars on my toobar, or by going to Edit>Search. Whether advanced options are used or not this search will show a one line portion of all the passages that contain the phrase or word in this window. Upon double clicking on these lines one at a time, you are taken to the page and the word or phrase will be highlighted like you would expect.
I wll probably keep doing this until the next update of either Acrobat or Reader. The Find feature is enormously helpful to me in my business use.
I have looked at several other pdf readers, including Adobe 10, and found that each has its own unacceptable 'problems'.
My conclusion is that Adobe is actually the best, and so waiting for their 'fix' to save their own TAIL, I am using Adobe 9.4, and zealously turning off their automated 'update' service, matching the zeal of its desire to EXECUTE!
By the way now using Adobe 9.4 again has brought wonderful peace of mind, not to mention productivity.
