Confirmed on all 4 Adobe Acrobat 9.4.5 users at my org since the update yesterday.
Before, if you held the CTRL Key, you could select multiple pages in the Pages Pane to Delete/Extract/Ect.
THIS NO LONGER WORKS! And we use that functionality A LOT.
What is the best way to get this info to the powers that be?
-Sam
This bug has been fixed in the Acrobat 9.4.6 update:
Windows:
http://www.adobe.com/support/downloads/detail.jsp?ftpID=5244
Mac:
http://www.adobe.com/support/downloads/detail.jsp?ftpID=5238
You can submit bugs here: https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
Done and Done, thanks. Is there a way to create online support tickets? I want a workaround, we can't wait until their next patch cycle. I requested 2 'Call Backs' but get disconnected each time
Do you have a problem with going back to a previous version?
Yes, I have a problem going back to the older version:
1. Multiple CRITICAL security vulnerabilities (http://www.adobe.com/support/security/bulletins/apsb11-16.html)
2. You cannot uninstall updates, you have to completely uninstall, then reinstall an old version, then update it to 9.4.4. This is VERY time consuming.
3. I shouldn't have to
Actually, you probably could not patch a re-install to 9.4.4.
A system restore would set you back prior to the 9.4.5.
I concur. This no longer works.
You can still select multiple pages with the mouse, but that doesn't help
when you want to select non-consecutive pages.
You can report this as a bug here:
Same problem here. I had a restore point before the 9.4.5 update, so I rolled the system back, then I turned off the auto update. I wish Adobe would fix the bugs without creating more. Maybe they just want to force people to upgrade to Acrobat X.
That just gave me a great idea! I can afford a few of a those upgrades
I can also confirm the 9.4.5 bug. I'm using Acrobat 9 Std and Windows 7 Pro. Multi-select works normally in Acrobat Std 9.4.4 installed on an identically configured Windows 7 Pro laptop.
confirmed this bug is still in effect. I do multiple selects many times a day so this bug is not huge in terms of fuctionality but a big break on working speed. There is no work around i have found, you just have to right click and them type in page numbers to select multiple pages.
It is more of a problem when i need to rearrange pages and have to do it one page at a time.
This report sealed my decision NOT to apply the 9.4.5 update. I had tried before after a loused-up windows update fiasco. When I tried to start Acrobat 9 Pro after applying the update, I got an error message that said Acrobat was unusable. I had to uninstall and reinstall Acrobat 9 Pro from the CD and apply all the updates in sequence. Talk about an ugly scenario!! Yuck!!!
Ken Friedman
working with xp, my workaround was a xp system restoration to the state before update.
meanwhile I open "risky" PDF-files with the parallel installed fresh updated Reader X ...
german support confirmed this bug and told to wait for next update ...
A system restore is how I got out the mess I was in. Basesd on wht you say, I'll
not apply the 9.4.5 update.
Ken Friedman
Confirmed on Acrobat Pro 9.4.5/ Win7
Just raised a discussion on this too - then saw this one. (Have removed my one now)
I've got an upgrade to CS 5.5 waiting - was only putting it off due to testing my custom Actions/settings. Time to jump onto 'X' I think...:)
I am not going to spend one more red cent on Acrobat and reward Adobe for their lack of effective testing. As a long time Acrobat user and a former tester of software, it seems they do not do a good enough job regression testing their fixes to see if what they fix does not affect other parts of their product. I wonder how many other bugs are waiting for me if I upgrade to Acrobat X.
I really wonder if Adobe knows that there are a few good alternatives to Acrobat out there. And I do not want to discuss which ones are best.
Ken Friedman
Definitely true. Windows 7 32-bit or XP. same problem.
When did this update come out? i need to try a restore point.
Same problem here - XP user. Very annoying
OP Here.
What's worse, is that when trying to schedule a Support Call with them, I GET DISCONNECTED EVERY TIME they transfer me. This has happened 3/3 times so far. Not even sure Adobe is even aware of the situation yet
Come on Adobe, get it together.
-Sam
Did you report it using their online bug submission form linked to in the reply #1 and 2?
Yes they replied
Raymond Rocha
sent from iphone
adobe said they know about the bug and are 'working on it'
You got word from them? Thanks for posting that info.
I have tried to repair and it didn't work. Since you can't select multiple pages, the print "selected pages" option is also gone. Just as I go to print multiple books. Will take me a lot longer without ability to select multiple pages. big bummer.
Has anyone tried to run a repair under Windows add/remove programs. You can't just remove the lastest update but you can run a repair.
