davy zhang
Textflow link element doesn't work after append to an existed textflow
Nov 10, 2010 2:05 AM
It's a strange problem
I have two textflow container : RichEditableText
the first one I new the textflow2 everytime I clicked the button,and append a link returned by getElement
the second one I initially new a textflow and reused it to append new link returned by the same function getElement
but the strange thing is , the first one works just fine ,but the second one 's link seems invalid with no hand cursor nor function
thanks a lot for any clue or comment
<?xml version="1.0" encoding="utf-8"?>
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
                           xmlns:s="library://ns.adobe.com/flex/spark"
                           xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="400" minHeight="300">
        <s:layout>
                <s:BasicLayout/>
        </s:layout>
        <fx:Script>
                <![CDATA[
                        import flashx.textLayout.elements.LinkElement;
                        import flashx.textLayout.elements.ParagraphElement;
                        import flashx.textLayout.elements.SpanElement;
                        import flashx.textLayout.elements.TextFlow;
                        [Bindable] public var textFlow:TextFlow = new TextFlow();
                        [Bindable] public var textFlow2:TextFlow = new TextFlow();
                        protected function button1_clickHandler(event:MouseEvent):void
                                textFlow2 = new TextFlow();
                                textFlow2.addChild(getElement());
                                textFlow.addChild(getElement());
                        private function getElement():ParagraphElement{
                                var linkSpan:SpanElement = new SpanElement();
                                linkSpan.text = "link";
                                var link:LinkElement = new LinkElement();
                                link.addChild(linkSpan);
                                link.href = "event:ok"
                                var p:ParagraphElement = new ParagraphElement();
                                p.addChild(link);
                                return p;
        </fx:Script>
        <fx:Declarations>
        </fx:Declarations>
        <s:RichEditableText editable="false" text="RichText" width="180" height="165"  textFlow="{textFlow2}" />
        <s:RichEditableText editable="false" x="196"   text="RichText" width="180" height="165" textFlow="{textFlow}" />
        <s:Button x="116" y="217" label="button" click="button1_clickHandler(event)"/>
</s:Application>
    Nov 10, 2010 3:48 PM   in reply to davy zhang
    I can reproduce this in TLF 2.0 and filed a bug.  I did observe that if I click on textFlow2 the link begins to work.  What version of TLF are you using?
    Richard
    Nov 11, 2010 2:33 PM   in reply to davy zhang
    Yes - Flex 4.1 is using TLF 1.1.  Thanks.
    I have fixed this in 2.0.  For a 1.1 workaround you can do this:
            <s:layout>
                    <s:BasicLayout/>
            </s:layout>
            <fx:Script>
                    <![CDATA[
                        import flashx.textLayout.compose.StandardFlowComposer;
                        import mx.core.mx_internal;
                        import flashx.textLayout.tlf_internal;
                                    ret2.mx_internal::textContainerManager.tlf_internal::convertToTextFlo wWithComposer();
                                    ret.mx_internal::textContainerManager.tlf_internal::convertToTextFlow WithComposer();
                                    link.href = "http://www.adobe.com"
                                    p.addChild(link);
                                    return p;
            </fx:Script>
            <fx:Declarations>
            </fx:Declarations>
            <s:RichEditableText id="ret2" editable="false" text="RichText" width="180" height="165"  textFlow="{textFlow2}" />
            <s:RichEditableText id="ret" editable="false" x="196"   text="RichText" width="180" height="165" textFlow="{textFlow}" />
    </s:Application>
    Nov 12, 2010 10:28 AM   in reply to davy zhang
    My fix hasn't been posted to the TLF sourceforge site yet - there's a lag because we have to run a script that get's odd timeout errors. A separate 2.0 bug with scrolled links demonstrated by your example was fixed a couple of days ago - build 200 contains all these fixes.
    In your sample code the call to updateAllControllers can cause a RTE.  The textFlow in a RichEditableText is not guaranteed to have a flowComposer. Normally flex takes care of composing for you and that line can be removed.
    If you do want to force a compose use this function:
    ret.mx_internal::textContainerManager.updateContainer()
    BTW thanks for the code examples - they're much easier to follow than verbal descriptions.
    Hope that helps,
    Richard
    Nov 15, 2010 3:07 PM   in reply to davy zhang
    Can't comment about 4.5 dates beyond what's posted here:
    http://opensource.adobe.com/wiki/display/flexsdk/Hero
    Richard
    Jun 29, 2011 1:06 PM   in reply to davy zhang
    I'm facing the same issue and i'm using 4.5 SDk.
    Here's my code. Works fine if textFlow value is not bindable, else shows nothing(Blank).
       creationComplete="init()">
    <s:layout>
    <s:VerticalLayout/>
    </s:layout>
    <fx:Script>
    <![CDATA[
    import flash.text.engine.FontWeight;
    import flashx.textLayout.conversion.TextConverter;
    import spark.utils.TextFlowUtil;
    private var hi:String="my code"
    private var cnt:int=10;
    var markup:String="hello";
    private var text:TextFlow;
    private var levelName:String = "family"
    public function init()
    trace("here");
    markup += "world";
    if(levelName == "family"){
    markup +="<span fontSize='15' color='#ff0000' fontFamily='Verdana'>"+ hi + "</span> (<span fontSize='12' color='#007fc5' fontFamily='Arial'>"+cnt+") > </span>";
    trace("string::"+markup)
    text=TextFlowUtil.importFromString(markup,TextConverter.TEXT_FIELD_HTM L_FORMAT);
    private function clickBtn(event:MouseEvent):void{
    markup += "world";
    rTxt1.textFlow =TextFlowUtil.importFromString(markup,TextConverter.TEXT_FIELD_HTML_F ORMAT);
    </fx:Script>
    <s:RichText>
    Hello
    <s:span fontSize='16'>BIG NEW</s:span>
    World!
    </s:RichText>
    <!-- Or the TextFlow child tag. -->
    <s:RichText id="rTxt" textFlow="{text}"/>
    <s:RichText id="rTxt1" />
    <s:Button click="clickBtn(event)" label="Click"/>
    </s:Application>
    Jun 30, 2011 12:52 AM   in reply to kanukukreja
    Replace the line
    with
    var imp:ITextImporter = TextConverter.getImporter(TextConverter.TEXT_FIELD_HTML_FORMAT);
    rTxt1.textFlow = imp.importToFlow(markup);
    Then your code will work.
    flashx.textLayout.convertion.TextConverter is the converter in TLF, which work well. TextFlowUtil is not under our control.
    Jun 30, 2011 1:15 AM   in reply to Jin-Huang
    Hi Jin,
    Thanks for the response, but its not working for me.
    Its not working for when i'm binding the value.. can you please once lok at it and helping me in resolving this issue.
    <s:layout>
    <s:VerticalLayout/>
    </s:layout>
    <fx:Script>
    <![CDATA[
    import flashx.textLayout.conversion.ITextImporter;
    trace("here");
    markup += "world";
    text = imp.importToFlow(markup); {Your code}
    //text=TextFlowUtil.importFromString(markup,TextConverter.TEXT_FIELD_H TML_FORMAT); {my code}
    markup += "world";
    </fx:Script>
    <s:RichText>
    Hello
    World!
    </s:RichText>
    <s:RichText id="rTxt" textFlow="{text}"/> {not working this way}
    <s:Button click="clickBtn(event)" label="Click"/> {Working this way}
    </s:Application>
    Jun 30, 2011 1:47 AM   in reply to kanukukreja
    [Bindable]
    Declare text as Bindable
    Besides, I found that two types of import show different results. Choose the one you like
    Jun 30, 2011 1:53 AM   in reply to Jin-Huang
    After binding i can see the text but without formatting...so my problem is still at the place from where i have started
    Am i missing anything?
    Message was edited by: kanukukreja
    Jun 30, 2011 1:59 AM   in reply to kanukukreja
    One more thing which i just noticed is that after removing textFlowUtil from the clickEvent, its also started showing the text without formatting.
    markup += "world";
    //rTxt1.textFlow =TextFlowUtil.importFromString(markup,TextConverter.TEXT_FIELD_HTML_F ORMAT);
    Jun 30, 2011 2:11 AM   in reply to kanukukreja
    TextFlowUtil.importFromString will give you text with sytles, while  imp.importToFlow cannot. I will investigate if it's a TLF bug.
    (At the very beginning, TextFlowUtil.importFromString does not show any text, but importToFlow can. But now importFromString works. I'm not sure what's going on. My answer at #9 is wrong.)
    Jun 30, 2011 2:20 AM   in reply to Jin-Huang
    Thanks a ton Jin for the quick responses, please share if you find anything regarding the same.
    >>> Let me know if you find any solution for the same.
    >>> Only in the case of bindable textflow values otherwise it shows the formatted text.
    >>> importFromString still works but not with the bindable texts. Thats the only issue.
    Jun 30, 2011 2:40 AM   in reply to kanukukreja
        <s:layout>
            <s:VerticalLayout/>
        </s:layout>
        <fx:Script>
            <![CDATA[
                import flashx.textLayout.conversion.*;
                [Bindable]
                    trace("here");
                    markup += "world";
                    text = TextFlowUtil.importFromString(markup,TextConverter.TEXT_FIELD_HTML_FO RMAT);
                    markup += "world";
        </fx:Script>
        <s:RichText>
            Hello
            <s:span fontSize="16">BIG NEW</s:span>
            World!
        </s:RichText>
        <s:RichEditableText id="rTxt1"/>
        <s:Button label="Click" click="clickBtn(event)"/>
    </s:Application>
    Jun 30, 2011 11:36 PM   in reply to Jin-Huang
    Thanks a Jin, its working fine now.
    I found one more way of doing the same, please have a look below:
    <s:layout>
    <s:VerticalLayout/>
    </s:layout>
    <fx:Script>
    <![CDATA[
    [Bindable]
    private var textFlowTxt:TextFlow;
    private var markup:String="hello";
    private var levelName:String = "family";
    private function createTextFlow():TextFlow {
    var htmlText:String = "<span fontSize='15' color='#ff0000' fontFamily='Verdana'>"+ hi + "</span> (<span fontSize='12' color='#007fc5' fontFamily='Arial'>"+cnt+") > </span>";
    var textFlow:TextFlow = TextFlowUtil.importFromString(htmlText, TextConverter.TEXT_FIELD_HTML_FORMAT );
    return textFlow;
    </fx:Script>
    <s:RichText>
    Hello
    World!
    </s:RichText>
    <s:RichText id="rTxt" textFlow="{createTextFlow()}"/>
    </s:Application>
