Hi I have a feeling there is a very simple answer to this. My photos which I mainly process in Lightroom 3 (with some adjustments in Photoshop CS3) print and show desaturated colors wether or not they are RAW or JPEG. I have applied camera profile settings such as landscape, to raw files but when I export them as a jpg and send to a photo shop to print they are still desaturated. Also when I send a stand alone file to a media contact it shows desaturated to them. If I deliberately adjust my monitor to Pro RGB it appears to show the true colour that others are seeing. I have attempted to over saturate to get a reasonable print but clearly this is not correct.
Proberbly an easy question for someone out there but I am having trouble resolving it.
Many Thanks
Steve
Please click on the link below and read the entire site carefully. Then follow the instructions to the letter.
http://www.gballard.net/psd/cmstheory.html
In a nutshell:
• Calibrate and profile your monitor. Set the resulting profile as your monitor profile. Never use a device independent color space (such as ProPhoto RGB, Adobe RGB or sRGB) as your monitor profile. Only use your calibrated profile specific to your monitor.
• honor the embedded profile in each file;
• when sending your images to a run-of-the mill lab, convert your images to sRGB (do not use assign profile; use CONVERT to profile) and embed the sRGB profile in them.
The above site explains it all to you.
____________
Wo Tai Lao Le
我太老了
