sascha/hdrs
Error during sample compile
Mar 20, 2009 12:14 PM
I've followed the install and test guide (at http://labs.adobe.com/wiki/index.php/Alchemy:Documentation:Getting_Sta rted for Window). Everything seemed to went right until I started to compile the test file (stringecho). There I get two error messages that the two files global.abc and playerglobal.abc could not be found ....
[Compiler] Error #1063: Unable to open file: /cygdrive/c/Users/sascha/Applications/Alchemy/flashlibs/global.abc.
[Compiler] Error #1063: Unable to open file: /cygdrive/c/Users/sascha/Applications/Alchemy/flashlibs/playerglobal. abc.
therefore the resulting swc file in not valid (1.23Kb). It would be cool to get some help here, I'm a total beginner with Cygwin/Unix and Alchemy and have no clue where the problem could be.
sascha
    Community Member
    Mar 20, 2009 2:19 PM
    There must be correct script hacks.pl
    it is in the folder / ahacks /
    if ( `uname` = ~ / CYGWIN /)
    change in
    if ( `/ bin / uname` = ~ / CYGWIN /)
    Community Member
    Jul 30, 2009 8:38 AM
    Thanks so much, I had this problem too but it worked like a charm. This step should really be added to the installation guide.
    Adobe Employee
    Jan 11, 2010 12:08 AM
    notnick, I also faced this problem. Thanks for posting the work-around.
    Community Member
    Jul 1, 2010 5:59 AM
    Thanks notnick. Solved my problem too
    Community Member
    Jan 18, 2011 6:06 AM
    Thanks also. Fixed mine also.
    Community Member
    Jan 30, 2011 10:19 PM
    When I did the change as described above
    I did get this response ...
    $ gcc stringecho.c -O3 -Wall -swc -o stringecho.swc
    cygwin warning:
      MS-DOS style path detected: N:/cygwin/alcsdk05/avm2-libc/include
      Preferred POSIX equivalent is: /alcsdk05/avm2-libc/include
      CYGWIN environment variable option "nodosfilewarning" turns off this warning.
      Consult the user's guide for more details about POSIX paths:
        http://cygwin.com/cygwin-ug-net/using.html#using-pathnames
    WARNING: While resolving call to function 'main' arguments were dropped!
    This is cygwin 1.7.
    In the end, the new stringecho.swc worked.
    EchoTest.as printed echo to the Output console as expected.
    My thread
    http://forums.adobe.com/thread/784401?tstart=0
    Community Member
    Jun 30, 2011 3:40 PM
    thanks, worked for me
Legend
  • Correct Answers - 10 points
  • Helpful Answers - 5 points
