Since the last upgrade (I got it last week a couple of days after I installed the program), it takes forever sometimes to open the simplest files. Up to 10 seconds to open a one-page file. More if the file is larger. This is really annoying, as I am opening files all the time. It doesn't help if I close the program after each file is printed, or leave it open and just closing the file. Anybody else experiencing this who knows what's happening?
Version 10.1.0.534
We have 200 employees, the majority of which need to open and print hundreds of pdf documents a day. They are all experiencing this severe slowness issue. At first I thought it was a network or server issue, then an antivirus issue, but I have eliminated those as possibilities which led me to this forum via a google search for acrobat issues.
This is a very severe issue! It has cut our employees' productivity in half and costing us $thousands per day! Adobe need to address this immediately!
I will attempt the solution proposed on other forums of rolling back to version 9, but that will take considerable time to do on 200 workstations and laptops. This update should have been much more thoroughly tested!
-RG
The below is an example which takes more than 30 seconds for executing a simple Acrobat JavaScript: app.launchURL:
http://www.openspc2.org/reibun/Acrobat8/javascript/app/028/sample/samp le.pdf
(I am using Firefox 5.0)
In the case of other versions of Acrobat, by clicking the button, in a second or two seconds, I see Yahoo! Japan.
But in the case of Acrobat X(10.1 My computer is Vista Ultimate SP2), it takes more than 30 seconds until I see Yahoo! Japan.
Loading PDFs takes more time in Acrobat Pro 10.1 but at the same time executing Acrobat JavaScripts seems to be really problematic.
I can confirm that this is also an issue for me — ever since the recent update.
Not only is there this weird slowness, Acrobat X periodically crashes whereas it was previously stable.
Surely Adobe already knows about this stuff from the Improvement Program data it collects? What is being done about it?
Anyone have any updates on this?
I just installed Adobe reader x and if I click on a link to a PDF on a site I can take the kids to school pick them up, do their homework then go out for a meal before a one page PDF opens.
Strangely I can right click and save it in an instant.
As an aside can I uninstall it and go back to 9 until this is fixed (I'm losing the will to live)
Thanks McP
Try this in Reader: Go to Edit / preferences / general - then uncheck the box "Enable protected mode at startup" . My Reader X was doing the same thing and this cured it straight away. I haven't tried it in Pro but see no reason why it wouldn't work there too. I'm not sure where that would be located in Pro.
I would recommend against disabling Protected Mode as this is:
· One of the new features of Acrobat
· Protects your machine from embedded malware.
What I’d like to see is acknowledgement from Adobe that it is investigating this problem.
Further, if there’s something broken, could it also mean that Protected Mode is also broken?
I think we need a security researcher to have a look at what’s going on here.
I recently did the update to both AcroX and Reader. The first PDF file opens up quickly. Any second file takes a considerable amount of time--too much time. Mainly this happen when I am trying to open up files over my companys network (a small business server). I find that local files on my computer do not appear to be affected by this. If the file is opened up over the network, any additional files can be simply dragged into the opened acrobat program and they open without problems. However, that is not a solution. Where is the "Priviledged locations" at?
Tried it, (yes I know I shouldn't but I made the pdf) this made no difference.
It's all right companies adding features, but when they stop the main program working...
Can anyone tell me an answer to my original query, can I kill this piece of junk (as no one from Adobe has an answer, yet!) and re install v9?
I tried different settings on both reader and acrobat. What appears to be working (right now) is to uncheck everything in the window of
"Edit/Preferences/Seurity(enhanced)" . I don't know the words used. I am using the Italian language version.
My computer:
- Windows XP Pro SP3
- Acrobat X
- nearly all microsoft updates
- recent updates for Acrobat and Reader
- gigabyte network to server
-AVG business edition 2011
maybe my server is just overly protective already?
Ciao!
Thanks for the suggestion (which did not work, nice try) this upgrade truly is a piece of junk, what with that and the fact IE9 with vista not printing from with web, this pc is in danger of being attacvked with a lump hammer.
Can I uninstall this and go back to Acrobat 9, or will that not work?
McP
Same problem here with version 10.1.0.534 from 6th of june 2011. Nothing works until now. The first document opens quickly, the next takes time. Went back to version 10.0.3 (via Windows system recovery), but then Acrobat crashed 10-15 seconds after opening the first file. We now re-installed our original CD-version 10.0.0 from january 2011, problem solved, so no more updates for us.
To Adobe: if you ask such a lot of money for your software this is something you should solve; at least react/inform your customers about the problem and offer a (temporary) solution. I keep my Foxit-reader installed, just in case.
Me, too. Just paid for the upgrade to X on 7/1. I'm using Windows XP SP3 with 4GB of ram. I "create" a .pdf from a word document, it pops up immediately, then gives me the Save page. After "saving", the file takes anywhere from 10 - 15 MINUTES to appear in the folder. What the hey? I got Version 10 (X) so that I could save forms as both Fillable & Savable with data, but this is insanely slow.
"Edit/Preferences/Seurity(enhanced) AND...?"
And uncheck "Enable Enhanced Security."
I'm using 10.1 Pro and was having the exact problem described (first document opened fine, but a second or third would take a good 20-30 seconds to open). After disabling Enhanced Security, I can open 3-4 documents in a row without any slowdown.
It really is a good thing (for Adobe) that Acrobat has no viable competition, because each version has been incrementally worse since version 7.
I'm seeing this issue as well on Acrobat Pro 10.1 but not on 10.0
Have not tested in Reader X
If you have 1 PDF open already from a mapped drive or network share, subsequent PDFs take 15 - 30 seconds to open instead of 2 - 3 seconds in version 10.0
Have not tested opening in the browser yet
This is on Windows XP SP3
I've filed a bug report and hopefully we can get more information.
For the other posters having the problem with Acrobat Pro X, what is your Acrobat version and what is your OS version?
It's the version of Office I was using, I was on 2000, Acrobat X is not compatible with this. It's totally screwed my Printers folder, too. I've upgraded to Office 2010, but I may need to reload XP sp3
Kathleen Tronsor
IT Systems Manager
Carolina Color Corporation
www.carolinacolor.com
704-637-7000
please consider the environment before printing this e-mail.
DISCLAIMER: This E-mail (including attachments) is confidential and remains the property of Carolina Color Corporation. If you are not the intended recipient, please contact the sender immediately about the error and permanently delete this email. The use of electronic communication is subject to interception, corruption and data loss. Carolina Color has taken reasonable steps to protect against viruses or other interference, but cannot accept liability for any damage resulting from this communication. Thank you.***
I disabled the "show common tasks in folders" and instead used "windows classic folders" (after disabling the "advanced protection" functions).
I did not notice any changes immediately.
However the program started to work normally after a day or so, and I can't exatly say why.
Probably with the computer restart and internet browser temp files deletion it fixed it.
I then enabled "show common tasks in folders"...and it continues to work normally.
I believe that the "common tasks" thing was addressed in Win7. But it does cause me some conflicts.
jimmytecguy : If i wanted to spend more money on worthless software and have to learn yet another program,...I would consider it.
Peddle your trash somewhere else.
I have had exactly the same problem. Since the update, it takes ages to load a PDF through either the standard reader or through Pro X. When it does open, it's open for a few secounds and then hangs. I had no problems prior to this. Using Windows Ultimate, SP1. With 16GB ram & 8 core processors, it doesn't hang for anything. I would love to gripe about the 'attempt' to give me some kind of support by Adobe on this issue but I won't go there.
To fix the load delay.. remove any non functioning or slow Rights Management Servers from Security Settings. Document open triggers UI items to get enabled, which fetches the set of policies that you can apply on a document, and show them within the menu. Somehow this seems to happen each time a document is opened.
