Captivate 5.5 to Android and/or iPhone App
Jun 24, 2011 2:17 PM
Can someone please tell me of any tutorials about how to get an App to Android/iPhone via Captivate 5.5? I don't know the first thing about apps, at the moment, but often use Captivate to make nice applications etc. I would essentially like to know how can I design something in Captivate and then transform it into an app which I can then advertise as such for Android/iPhone users to download.
Your help is much appreciated!
Paul.
    Jun 24, 2011 2:24 PM   in reply to Paul7411
    By coincidence I just saw a post on this in the LinkedIn Captivate forum:
    http://www.linkedin.com/groupAnswers?viewQuestionAndAnswers=&discussio nID=59420012&gid=683507&readyToAnswer=true&trk=disc_comment
    Michael Hinze has started a discussion: Deploying Captivate demos on Android Devices
    "After the recent discussion about converting Captivate demos to iPad/iPhone apps, I wondered if it is possible to deploy Captivate demos on Android devices as well. Android-powered phones and tablets are rapidly becoming more popular. After some research and testing, I succeeded in installing a Captivate demo on my Samsung Galaxy II Android phone. The conversion process is not very intuitive and required the use of Adobe’s AIR application (included with Flash CS5 and 5.5), but does allow you to convert a Captivate file to an Android app. The basic steps of the conversion are as follows: 1. Publish your Captivate project as a .swf file 2. Create a self-signed certificate (the easiest way to do this is through the AIR for Android settings screen in Flash CS 5.5) 3. Create the required XML-based manifest file that includes application description and permissions 4. From a command line, run the ‘adt’ command (see Flash CS5 help files for details) to compile the swf file into an Android app (.apk) 5. From a command line, run the ‘adb’ command (see Flash CS5 help files for details) to install the app package on your Android device. This is yet another option to re-use Captivate demos!"
    Jun 25, 2011 12:48 PM   in reply to Paul7411
    Or just point to wherever the Captivate file is on the web - Android
    phones and tablets support the full Flash player.
    Steve
    Jun 29, 2011 1:08 AM   in reply to Paul7411
    Steve got a point and it seems like Captivate production isn't a problem with all phones except iOS !
    So I too have a question, how to bridge that iOS gap ?
    OR is it mission impossible cos of the ongoing Adobe vs Apple WAR !
    Any ideas ?
    Jun 29, 2011 3:13 AM   in reply to Paul7411
    Yes.
    Steve
    Jun 29, 2011 3:14 AM   in reply to HenryNNN
    It's not Mission Impossible - you can deliver Captivate to iOS in a
    number of ways, you just have to make a little extra effort.
    Steve
    Jun 29, 2011 6:53 PM   in reply to Steve Howard, ACP UGM
    Wow ! Steve
    Great news indeed, so is it convenient to share that 'little extra effort' ?
    * This IOS thingy is driving me away from captivate, forcing me to build iOS apps using online appps builder *
    I'm all ears ...
    Regards
    Jun 29, 2011 7:03 PM   in reply to HenryNNN
    Sarcasm?
    Soooo - publish to iPhone (and iPad) then following these instructions
    is too onerous?
    http://blogs.adobe.com/captivate/2010/09/publish-to-iphone-from-captiv ate-5-and-elearning-suite-2.html
    http://blogs.adobe.com/captivate/2011/03/create_elearning_content_for_ i.html
    yes you need to consider the screen size and not everything is
    perfect, so some experimentation is necessary, but the same is true
    for any mobile application and device.
    Steve
    Jun 29, 2011 7:08 PM   in reply to Steve Howard, ACP UGM
    No sarcasm intended, Steve
    Just a guy desperately in need of help.
    Thanks lots
    Will try out ....
    Jun 29, 2011 7:16 PM   in reply to HenryNNN
    OK
    Sent from mobile
    Jul 5, 2011 11:33 PM   in reply to Steve Howard, ACP UGM
    Actually Steve, not all Androids support Flash; I believe anything below android 2.2 doesn't support it, and quite a few current devices still run below this (my phone came with 1.6, and the latest update is only up to 2.1, with no plan for an official 2.2 release)
    Best bet for cross-platform would probably be html5
    Jul 6, 2011 5:24 AM   in reply to RoGuE_StreaK
    Some 2.3 phones don't support Flash either.
    But good luck finding an elearning content development tool that produces suitable HTML5 output
    Jan 19, 2012 6:06 AM   in reply to brightonjon
    Before I get deep into taking my Captivate projects and getting them to work on iPhone, iPad and Android platforms, can anyone tell me if these apps will still be SCORM compliant?  I have a requirement to track usage, knowledge transfer and quality through my Learning Management System which the web users do just fine at the moment.  Would this still be the case if the users were to access the eLearning through smart phones?
    Anthony
    Jan 19, 2012 11:58 AM   in reply to Ray_Tupper
    Please let me know if you get a response to this. I have a client that requires an iPhone course to be pushed to SCORM and has specified Captivate as the software of choice. I have provided mobile solutions to LMS via Lectora but not Captivate 5.5. When checking publishing options for a Captivate iPhone template, the choices were F4V which was housed in a different location than the swf zipped SCORM package.
