I use a combo of InDesign, Illustrator and Photoshop for my technical writing work. The user interface and integration in these applications is excellent. Adobe managed to keep the UI out of the way very well.
Since my work is mostly made of typing, I still miss some better way of zooming and scrolling without getting my hands away of the keyboard.
Also, the way automatic scrolling to follow the text input cursor could be greatly improved. Sometimes, I find myself typing out of the visible area, without InDesign adjusting the view.
I also use Premiere and After Effect from time to time, and find them as well integrated as the publishing combo. Making Premiere a bit less cluttered of unneeded controls (for example, making them appear only when needed) could be a good idea to clean-up things.
Dreamweaver, on the other side, is a disaster. I cannot see any logic in how commands are organized in menus and palettes. And there are menu ridiculously long, with no apparent hint of organization.
Paolo
I use the Production Premium CS5 suite. I use most of the programs on a semi-regular basis. It's nice that the UIs look more or less the same, and that the panels dock and undock the same way.
But it's the little things that are a killer. Adobe should think about standarizing the tools all the way down to the small details. For example, is it "delete", "cut", or "clear"? Pick one. Is transparency shown with a white/gray checkerboard (Photoshop) or black (AE), or something else? Again, pick one (I vote for black actually).
And for goodness sake, spend some time with some tech. writers on the actual words used in the UI. When I want to move from working on a project in PPro to working on it in AE, I do NOT want to "replace with AE composition" in PPro -- I want to continue working on the project I'm working on, just using another tool! IOW, I want to build on what I'm doing, not replace it with something else! And you wonder why newbies have such a hard time learning Adobe? I've been using this stuff for a year and I'm *still* a newbie, partly because of things like this.
For another example, what do I have to do in Encore to re-transcode a sequence? I have to "revert to original". WTF? Are you kidding me? What I want, is to do the transcode again, or at least to mark the sequence as un-transcoded so that Encore with transcode it again. Making me guess that the answer is "revert to original" is just user hostile. It's just not right.
I'd like to see dynamic link become more useful too. It's faintly rediculous that when I have to add some footage to a project in PPro, I see the sequence get longer in Encore, but not the timeline that Encore uses to run the sequence. Not even a warning -- it just lops off the end of your sequence on the DVD you just burned. And no way to manually increase the size of that timeline that I can find -- the answer seems to be to throw away the existing timeline and make a new one (and redo your entire flowchart in the bargain). I mean, come on -- think! How did this make it through testing?
I was a software developer for 25 years, I know a great deal about the complexites of architecting, designing, writing, and testing code. It ain't even slightly easy, and Adobe is to be congratulated on what they've done so far. I'm just sayin' that we aren't at the end of the path yet, so please keep going.
Hi guys.
You need to look at this one site for reviews. http://adobegripes.tumblr.com/
CFG,
just a couple notes, & I agree with you that Adobe is doing well and should keep it going & evolving, as well as that little things between the programs really need standardized (like my post about shortcuts!) ![]()
In AE you can turn off the black and it becomes a transparency grid, the grid is the stardard for showing transparency. But designing on transparency grid can be tough so AE has it black by default (maybe the default should be swapped).
Also, deleting & cutting should be available in both forms in all software; delete just gets rid of the selection; cut "cuts it" and puts it on the clipboard to be pasted. These are universal in all software (i.e. delete on your keyboard, versus ctr-x on your keyboard).
Anyway, great points. Yeah dynamic link certainly has more potential and I seems to be further developed every version. It definitely needs some fine turning, like the Encore issue. I don't mind 'replace with AE comp' or 'revert to original', they make sense in my mind & seem to do what you'd expect. I personally think Adobe's much easier to learn than any of the competition.
- wb
As a compliment to having keyboard shortcuts, it would be nice to be able to make a shortcut button and put it in the top menu bar.
I am tired of using inconsistent and deep menu structures to do things like delete pages, layers, etc. Since I don't believe Adobe is serious about making FW any better in a real way (othewise why have they not done it yet?), it would just be nice if I could take all those disparate, deep UI actions, assign them to a button each, and put them in the top bar.
That would be nice.
I'd just like some common shortcuts and capabilities between applications.
Duplicate
Move
Rename
Timeline fwd/rew
New project
New layer/comp
Group
If you have what is essentially the same function in one application, it should be standardised to the others.
Ideally it would be great to see Adobe adopt a versatile, customisable UI much like 3D programmes eg Cinema 4D where pretty much everything can be changed to suit the user, including macros, icon sets, tabs and palettes.
Dan
I'm still stuck in AE CS3 so maybe this has been addressed, but it sure would be nice if, while rendering, you could reorder and check, uncheck the items in the Render Queue. Obviousely, this would run the risk of breaking comps if a later comp required the output of an earlier comp, but in most cases it wouldn't be a problem. I was hoping I'd be able to uncheck some comps in the Render Queue by pausing the render, but that wasn't the case.
I understand the prefered workflow now is to use Media Encoder to render in the background, but I don't have that yet.
I'd like to second Dan's post. I would like to get rid of my shortcut cheat sheets and frequent, "I did I think it was here" moments. Though, by being a master of none, just an apprentice of all, it seems that I may not know the meaning behind certain design decisions that go into these programs. I figured that placing an object in InDesign and Photoshop would be the same, or that the shortcut for the pen tool would be the same across all programs, but I assume they aren't for a reason I won't know until I become more masterful of the software I use.
First, thanks for asking. I believe you guys might see a huge increase in users after the FCPX nightmare.
I have been a long time user of AE and would really like to get into PP
AE:
great if you could some how expand a pre comp to edit its contents. A lot of the time in will be in a precomp make an adjustment, then I have to go the main comp and see if that was correct given all the other layers in the master comp. It would be great, if you could hit a button and open up the pre comp, edit the layers and see how it will effect your project.
Premiere Pro.
I think most of it has been covered, however, I would like to see a better color correction workflow. My biggest grip is that you have to select the clip you want to edit everytime you want to alter an adjustment. It would be great if you could some how create a mode that where ever the playhead is the effects of that clip are in the editor. COLOR works in that fashion and it is great way to do color correction. Also if you could group clips to have the same CC. I love the built CC effects. The curves are great and I think you guys are almost there. That would be my biggest problem. No real CC workflow. Especially when dealing with a huge timeline.
Are you saying you'd like an easy way to pop into a precomp? (There is, double-click it in the timeline.);
Or are you saying you'd like a way to edit the precomp while you look at the main comp? (There is, open another viewer window.)
Here are some resources on Edit This Look At That in AE..
I think all the UI's are fantastic and they can't possibly get any better than they are.
If you're looking to something marketable by shaking things up why don't you just add a new level "Use Gradients". Make a third option with some contrast and bevels and stuff to make it look more like FCP X. Then you sell that as something new, but of course, leave the option to have that, use gradients, or just plain flat (which I think most of us will continue to use). You might scare up a storm of uninformed complaints like FCP X did.
Adobe has a monopoly on most of the areas it's programs cover. Why not spend more time fixing things, adding things that are missing instead of considering changing the UI or adding over-hyped features you'd rarely use (like perspective drawing in AI).
Adobe is here, firmly planted, and we all love you... but at the same time we all HATE you.
Why are Wing Menu's so tiny?
Why doesn't AE have color swatches. Does that even make sense that it doesn't?
Why is AE's Curves panel so small and useless compared to Photoshop's?
Why are Opacity Masks so hidden in AI?
Why the HELL is there a big hole (No "application frame") behind the Dreamweaver panels when no doc is opened?
Why are Photoshop panels so sensitive that they undock if you even look at them funny?
Why is it often difficult to get the mouse over just the right spot between panels? Are you trying to hide the hotspots?
Why does snapping in Photoshop suck?
Why does easing in Flash CS5 applied to the entire tween instead of between keyframes (whatever they're called now)?
Why can't type be treated more like Corel Draw in AI? Why have this HUGE, SELECTABLE text box around text? It's a vector program, we're not making books in here, we don't need the boxes around Point Type. We want to make word art and text in AI just gets in the way.
How about fixing those (boring in your book, I guess) issues instead of making fancy new welcome screens?
And how about new features like being able to add some kind of "folder" structure to AE's timeline? (No, Shying layers is NOT the answer). What about being able to expand PreComps in the main timeline? This can't be hard. The only issue is making it clear what's going on with the UI.
Anyway, I hope you don't make any major changes to the UI. It's 90% PERFECT.
PP/AE
Speaking of 'fcpx', let's get some waveform improvements.
One of the biggest raves is how "beautiful" X's waveforms are.
However these is supposed to be about UI.
I have one request on Workspaces--I'd LOVE to see Adobe expand the functionality of these. Right now they are good, but basic.
One of the huge pluses of Media Composer is the ability to link Workspaces to ALL of it's settings. Keyboard layouts, UI brightness, track colors, etc. One big one Adobe is missing is presets for the timeline--track heights need to be savable. This saves wonders of time switching between working with audio, color, normal editing, etc.
Also, saving workspaces is bad right not. You need a "save current" button. Right now if I tweak something and want to change it, I have to go to "new workspace" and try to remember what the Workspace was called so that it will overwrite.
Problem with 'save as you go' workspaces -- is, especially in Premiere, you'll accidentally drag a panel out and accidentally dock it somewhere totally screw up the whole layout. It saves this automatically, and I can't restore the workspace by going back to one that I'm already on. As a result, right now I'm forced to save a backup copy of my workspaces as well, and overwrite those as well, every time I make a change to my workspace that I want.
This 'saving workspaces' process could be improved, and the whole concept could be made more powerful if it was as flexible as MC's, linking it to other settings--like track height.
- wb
I shoot RAW stills and color grade them using the current version of Adobe Lightroom almost daily. Years ago I was trained as a digital colorist on the DaVinci Renaissance video color correction system, and I like that the image "color grading" concept of Lightroom is similar in many ways. It would not surprise me if the convergence of stills and moving images drives Lightroom to one day offer the ability to process both stills and video, but that is not my immediate concern.
A couple vital "colorist" style UI features I would like to see added to Lightroom immediately are:
*Three-Way Color Corrector-style Hue Balance Tool in the Lights, Mids, and Darks of any image. This is really the heart of any pro color grading system, and it is conspicuously lacking in Lightroom. The (overall) White Balance Tool is still necessary, but the Split Toning Tool is woefully inadequate for images with complex color balance problems. I use a Nikon pro-model film scanner, and vintage film scans can reveal color problems which require time-consuming curve manipulation in the scanner software, and often still require further color work in Photoshop. I would rather spend less time with curves by scanning an image which has the color in the ballpark, and then use Lightroom to do the final color grading at full resolution. Additional restoration will still likely require Photoshop, but a 3-Way Hue Balance Color Corrector Tool in Lightroom will eliminate much of the work I am doing in the scanner software and Photoshop now. A 3-Way Color Corrector can of course be used creatively on well-balanced digital images for effect, as well. Add in the ability to convert to or from negative to positive (including correction of color neg orange mask) and Lightroom will be a much more powerful tool in a scanning workflow.
*Integrated Support for Colorist Control Surfaces with simultaneous parameter input. So for example, you can adjust both hue and exposure of an image at the same time. This is the way to really rip through a lot of images.
*Ditch the Catalog. Okay, don't ditch it completely, I can see it's usefulness to some extent. I suppose it doesn't necessarily have anything to do with Colorist-syle UI's. But it is frustrating and time-consuming to do the whole import rigmarole. Just let me browse images on my hard drive in the left-hand pane in the Library module. Give it a "live" view so that images don't go "missing" when moved or renamed in another app. My free Canon Digital Photo Professional even does this. You can give us a right-click for an "add this here image to catalog" prompt when browsing in the left pane if you want to continue with the whole "Catalog" concept. Or just automatically add any image to the catalog that is opened and viewed. Personally, I dislike the Catalog concept in general, and I would appreciate a non-catalog mode. I do like the non-destructive nature of Lightroom. I save XMP sidecar files. But copying and moving images within Lightroom is not only a slow pain, it is required if I want my catalog to remain organized. I would really appreciate a "copy image" (not just "virtual copies") included in the dialog when right-clicking an image or it's thumbnail. The Catalog concept as it is now is one of the biggest impediments in the Lightroom UI in my opinion.
*Allow me to drag-and-drop images from Lightroom into my Windows folders or desktop.
Overall I think Lightroom is great. Thanks for the opportunity to offer this input.
The file import dialog in After Effects and Premiere Pro needs improvements when it comes to importing file sequences.
1. There should an option to collapse file sequences. Browsing/scrolling and importing footage from folders with multiple file sequences can be a real pain.
2. There should be an option to split sequences with "gaps" in the frame numbering. Often material from telecine comes delivered as sequences with "time-code file names" rendered to one single folder. Afx and Premiere will bring in this as one long clip with missing frames. On import there should be an option to split these to separate clips.
3. To bring in media arranged in multiple subfolders can be a slow and painful manual process (Red and Alexa footage is arranged like this for example). There can be hundreds of folders to walk through. If there was an option to scan subfolders for available footage we could save loads of time when bringing in material.
Look at Apple's pro software, as much as they're having a bad time at the moment and rightly so, they do nail UI. I've always wanted the greatness of AE with the UI of Motion. AE just feels clunky even compared to Motion 2.
This is obviously only a personal opinion and realise not everyone will agree.
In online and file based workflows it is very common to relink offline media with new high resolution graded media. Often in the form of DPX sequences with time code. In that regard I find the "Link media..." menu extremely limited. Search and replace options aren't good enough. There should be options to link files by criteria like time-code, file type, resolution, framerate etc. Media often change names from offline to online so just matching exact file names isn't going to be enough. And no support for image sequences is sad. The manual is suggesting "import new still-image sequences, and place them into timelines manually". That is not a solution and just plain ridiculous. This process needs to be automated. Look at Smoke/Autodesk for how it should be done. Thank you.
I Think adobe's UI is excellent.
The idea of being able to move and drop them about as one pleases is huge.
Only thing I have to add is that the graphics of the GUI, at least compared to FCPx, is somewhat outdated.
When working in an app it is VERY important that the user feels GREAT. First thing to GREET any user when he launches the app is the GUI of the APP.
While adobe's GUIs are good the are old-fashioned (looks only not feature-wise) and not at all state-of-the-art.
I hate FCPx but its GUI is the BEST I have ever seen on ANY computer !
Hands down
I don't think Adobe's interface is outdated. In fact, I think FCPX is the one with the outdated interface. When I first saw it I thought it looked like a little step backward. I say little because the interface of FCP 7 was also outdated. Bevels, shiny stuff, buttons that try to look like buttons is outdated. And what the hell is up with that subtle scratched pattern background in FCPX? All the cheap apps from 10 years ago looked like that. One of the reasons why I liked Adobe's interface is that it seemed to step beyond all that nonsense and get to business with a simple, clean, flat set of graphics. This is especially true for designers, photographers and editors. These people need to pay attention to what they're working on, not shiny doodads surrounding their work. I will say this though: it seems maybe Adobe's approach is mature enough to be mistaken for being old now itself. I would think the next step would have to be something "new". But if it's a choice between keeping what Adobe has now and going backward to make things look 90s-ish then I pick what we have now.
ahmmmm...
I am one of those people. And I LOVE and NEED and inspirational interface.
If you care to do the research, there are plenty case studies over folks and how a GUI can affect them, creatively.
Even AVID acknowledged that as they brought about Protools 8. This stuff DOES matter.
Whether you like it or not ;-)
vfxjfb wrote:
Second that. I like the GUI as it is now. Simple and clear. No fluff and shiny 3D buttons.
With all due respect... What an odd and void comment.
Adobe IS using Shiny 3D buttons. Just take a good look at your interface.
FCPx's buttons are LESS 3D as are their respective RGB values for each button.
The contrast-relationships governing adobe's user interface is MUCH higher than that of apples.
And a HIGH contrast interface is going to INTERVENE with the user's ability of concentrating on what matters...
The FOOTAGE !!!
AS of now, adobe's buttons are competing with the footage of ANY take. And THAT is not state-of-the-art...
And the text in all adobe's interfaces is simply too bright. Bring down the opacity to 85% and the whole look will appear MUCH
more professional and save your eyes.
1st - FCPx
2nd - AE
MUCH more easy to look at FCPs buttons. Less obtrusive. GUI creation is an art... Apple despite of too much eye-candy, is mastering this.
Look at their website... Today, most companies are imitating it. Only much less successful.
Quite frankly I'm not looking at the buttons much when I working, whether it be After Effects, Premiere, or Final Cut.
I usually take these tool panels and throw them off to the very of the screen where they are out of the way. Can't do this in FCPX though lol. Thank you for the awesome panel based UI, Adobe. (I just want to be able to lock them so I stop accidently grabbing panels)
Okay, yes, I do like FCP's icons more than AE's. I agree with you on that.
what I don't like is that they're lopped into a box with curved corners that by the nature of proximity requires space around it for it to exist visually. That's a waste of space. And the curved corners looks cheap. AE's icons are in the panel and that's it; no fluff around it. Makes better use of space. But I do like the FCP icons better.
What I meant by shiny buttons is more like Avid's over gradient-crazy interface. FCP 7 is a little better than Avid in that area, although it has a strong "Look at me, I'm all metal!" feel to it. FCP X looks like a cheap program. It looks like it's targeted to consumers. Why are the... what do you call them now? The new version of clips in the bin, why do they have distracting curved corners and ... ugh ... drop shadows? What's with that 90s background texture when you first open it up? I'm not saying it's totally bad. I like the blacks and grays. I like that the fonts are easy to read. Adobe's interface font is okay, but I think that might be something worthy of exploring replacements for.
BTW, I was never a fan of tools with icons. I often scratch my head when looking at some of them and think "what the hell is that supposed to be?"
When working, stopping to 'translate' icons often takes me out of my "flow". I wouldn't mind an interface preference setting that would replace some or all of these icons with just words in buttons. Something like the AutoDesk apps do.
Thing is, GUI-taste is huge thing. Some like it X and some prefer Y...
Be that as it may, taste is something that shouldn't be discussed but accepted as a fact.
The Pro Audio Industry has been dealing a lot with this the past years.
The only app there which really solved the problem smartly was MOTU.
Instead of providing ONE theme to look at, the provide MANY and one can even make his own theme.
Check this link, there is a window that keeps changing theme.
The app is called Digital Performer and is DAW
One might argue, WHY does a music recording/composing app need to be beautiful?
Easy, people like to customize the environment in which they dwell !!!
People have been customizing just about ANYTHING they have developed a passion for, since the dawn of mankind.
Well, software is starting to play a HUGE part in the environment in which we live... I personally spend more than HALF my 24 hours
infront of either a Video or Audio app....
So I for one would like to be able to customize my LIFE which in this case is the app in which I make it happen ;-)
And WHO looses ANYTHING if there a multiple choices of themes... NO ONE...
We all loose if there is but ONE theme...
So Choices ==== Please ;_)
Illustrator, photoshop and InDesign are my regular programs until the CS series came out. My major complaint is the palettes are WAY TOO SMALL and hard to see. When I type in a value, I cannot see what I typed in. I cannot see the icons very well and this has forced me to stop using Adobe software. Is there any way to display the palettes not just a larger size, but with larger images in black (not just grey), larger bold fonts, etc? Pretty please?
One of my thoughts about things i love to see covered in the new versions:
Live preview check box available when changing color proprieties of Lights.
For almost everything else we have the live preview option now but nor for color propriety of lights.
In Adobe Premiere Pro it would be nice if one would be able to create subclips with soft in and out, somewhat like clip instances that would be available for the project management. If I create a subclip now (when chopping up a long clip) I get hard beginning and end of a clip and cannot change it easily.
In Premiere Pro it would be cool if you could manipulate values in panels the same way you can in After Effects where you can use arrow up and down to adjust a value.
Or even better if you can copy the way you do it in Nuke (from The Foundry), there you can also use arrow left and right to choose if you want to adjust in 0.1, 1, 10, or 100 and so on). You should do that for the whole range of Adobe apps. It's a really neat and fast way of adjusting values with the keyboard only.
In Premiere Pro's timeline i find the way that clips get "auto-placed" in certain places most annoying and hard to control. When you move a clip it is very easy to accidentally drop it on another layer or that it places itself in positions where you did not intend it to end up. This auto-place feature should be tweaked in sensitivity for a better user experience.
Just a few of today's gripes:
The Graph Editor in AE blinks on and off as you drag handles and is generally very stiff and slow to use.
The HUD Color Picker in PS could do with an option to make it stay on screen until you click on the image underneath, the current ctrl-alt-Cmd and spacebar methods are tricky and cumbersome.
Where is the consistency and (user, not programmer) logic behind what constitutes an undo-able action? Switching in and out of Graph Editor in AE is undo-able but switching comps is not (which makes tracking changes across multiple comps VERY challenging). I often wish I could undo a change to foreground colour or some other slider in PS (although at other times it would not be helpful).
Why is there no scrubby zoom or scrubby sliders in AI? I really think Illustrator needs the most attention in its UI, it lags behind PS and AE for fluidity of operation.
After Effects stops loading when the 'Missing plug in, 'created with earlier version, 'etc' ' dialogue boxes open up. I wish the program would open anyway (without me having to Okay it) and just leave a sort of stick note with the Alert information.
Also, I miss in older versions of AE that would let you know that an image was altered in another program. For instance, even if I changed one pixel in a Photoshop document AE would let me know that the file had been altered (though I'd like to see it as a sticky note).
thank you,
kurt murphy
Many times I'll double-click a Layer name and inadvertently open the Layer Styles menu. I wish that within the layer Styles menu a Layer name was present so that I could ALSO type it in there (instead of Canceling, then re-double-clicking the layer name).... It'll save me a step.
thank you,
kurt murphy
I'd LOVE if AE would put a dot next to any footage that I've used in a project. Sometimes I've got hundreds of video files that I'm trying to use and I don't know which one's I've used which I haven't. Selecting each and every one to see is time consuming. If a red dot was placed before the footage if it was used would be a real timesaver. Perhaps a red dot for footage used once and a green dot for footage used multiple times.
thank you,
kurt murphy
