XMLSigningSerializer.php generates incorrect <hmac>
Jan 19, 2011 5:06 AM
I performed a test comparing the Admin Console API inspector to the PHP serialization class.
When using the exact same request when testing, two different <hmac> values are generated.
Below I'm requesting resources available for a specific distributor uuid.
The call is made to /admin/ManageResourceItem using builtin auth.
Request generated in Admin Console API Inspector, ported directly into PHP:
$request  = '<request action="get" auth="builtin"  xmlns="http://ns.adobe.com/adept">';
$request .=  '<nonce>nf55dgAAAAk=</nonce>';
$request .=  '<expiration>2011-01-19T11:47:36-00:00</expiration>';
$request .=  '<distributor>urn:uuid:62dbe983-b28b-4910-9a44-c5f55bf152dd</distribu tor>';
$request .=  '<limit><start>0</start><count>24</count></limit>';
$request .=  '<hmac>UDH0SOSRlAq3s7Y+haHOFhd7jWU=</hmac>';
$request .=  '</request>';
This hardcoded request passed to web service, works 100% and in response I get the proper XML data.
Next remove the <hmac> and provide the $request below to XMLSigningSerializer in PHP:
     <distributor>urn:uuid:62dbe983-b28b-4910-9a44-c5f55bf152dd</distribut or>
</request>
$xmlObjectPackage = new  DOMDocument('1.0', 'UTF-8');
$xmlObjectPackage->formatOutput  = true;
$xmlObjectPackage->loadXML($request);
$packageNodes =  $xmlObjectPackage->getElementsByTagName('request');
foreach ($packageNodes  as $packageNode){
signNode($xmlObjectPackage,$packageNode,$serverPassword);}
The <hmac> element is inserted into the DOM and the signed $request is returned as:
     <hmac>Hc/jN53W65d3r6EdzGGj9lJ3BtE=</hmac>
</request>
All elements identical, then signed produces:
Admin  console   :  <hmac>UDH0SOSRlAq3s7Y+haHOFhd7jWU=</hmac>
PHP  Class        :  <hmac>Hc/jN53W65d3r6EdzGGj9lJ3BtE=</hmac>
<hmac> produced by the PHP class is not correct and returns: E_ADEPT_DISTRIBUTOR_AUTH
I used the PHP file from the snippets folder as suggested.
Has this file been revised since its original deployment with the ACS4 distribution?  Please let me know if a corrected file is available?
Or have I done something wrong during the serialization process?
Thanks in advance
- Anthony
    Jan 19, 2011 8:45 AM   in reply to Anthony_ZA
    Did you check that you are using the correct key, and that you are sending the key into the HMAC appropriately?
    The key sent to the HMAC  (since you are using "builtin" ) should be the results of a SHA1 hash of the password (that you use in the admin console).
    Also you must make sure (and this can be tricky in PHP), that the results of the SHA1 hash is kept in binary form.
    Feb 24, 2011 4:45 AM   in reply to Anthony_ZA
    Hi, I have the exact problem as Anthony.
    I have downloaded ADBE_ContentServer4_1.zip from store1.adobe.com, inside snippets-2010_11_12.zip
    there was this library XMLSigningSerializer.php
    I have copied a simple request from /admin/console, something like this:
      <nonce>VzNBhgAAAAM=</nonce>
      <expiration>2011-02-24T10:55:00-00:00</expiration>
      <limit>
        <start>0</start>
        <count>24</count>
      </limit>
      <hmac>cQC4fYnJ0dxI/56luJpBW4WEW0c=</hmac>
    </request>
    Sending this request programmatically though Php/Curl to /packaging/Package works just fine.
    If I remove the <hmac> tag and I use XMLSigningSerializer to attach the HMAC,
    the request doesn't work anymore and the HMAC created by XMLSigningSerializer is different that the
    one found in the original request from above.
    The error in this case is:
    <error xmlns="http://ns.adobe.com/adept" data="E_ADEPT_DISTRIBUTOR_AUTH http://server:8080/admin/ManageResourceItem urn:uuid:00000000-0000-0000-0000-000000000001"/>
    The questions are:
    - should i use a different version of XMLSigningSerializer.php ?
    Other than the one from snippets-2010_11_12.zip
    - do you have a fully working example in PHP for packaging or sending other requests ?
    - if I send you the PHP code, will you be able to indicate the errors ?
    Mar 6, 2011 5:32 AM   in reply to Anthony_ZA
    Hello Anthony, Jim ...
    Here is my code that generates an incorrent HMAC:
    Jim, it would help us immensely if you could spot the errors in the code.
    The XMLSigningSerializer.php was found in snippets-2010_11_12.zip
    <?php
    require_once 'XMLSigningSerializer.php';
    $password = "password";
    $serviceUrl = 'http://server:8080/admin/ManageResourceItem';
    function signNode( $xmlDoc, $xmlNodeToBeSigned, $secretKey )
        $ADEPT_NS = 'http://ns.adobe.com/adept';
        $serializer = new XMLSigningSerializer( false );
        $signingSerialization = $serializer->serialize($xmlNodeToBeSigned);
        $hmacData = base64_encode( hash_hmac("sha1", $signingSerialization, $secretKey, true ) );
        $hmacNode = $xmlDoc->createElementNS($ADEPT_NS, "hmac", $hmacData );
        $xmlNodeToBeSigned->appendChild( $hmacNode );
    function sendRequest($requestData, $requestURL)
        $c = curl_init($requestURL);
        curl_setopt($c, CURLOPT_RETURNTRANSFER,     true);
        curl_setopt($c, CURLOPT_POST,               true);
        curl_setopt($c, CURLOPT_POSTFIELDS, $requestData);
        curl_setopt($c, CURLOPT_HTTPHEADER, array('Content-type: application/vnd.adobe.adept+xml'));
        $html = curl_exec($c);
        curl_close($c);
        return $html;
    function request($password) {
        $serverPassword = hash("sha1", $password, true);
        $request = <<<DOC
      <nonce>i03+cQAAAAw=</nonce>
      <expiration>2011-03-06T13:44:27-00:00</expiration>
      <limit>
        <start>0</start>
        <count>24</count>
      </limit>
    </request>
    DOC;
         * I took the above request from /admin/console
         * I have removed the following tag: <hmac>6D4gRi6NF5F0uD4jSOLixNhGbTU=</hmac>
        foreach ($packageNodes as $packageNode) {
            signNode( $xmlObjectPackage, $packageNode, $serverPassword );
        return $xmlObjectPackage;
    $xmlObjectPackage = request($password);
    print $xmlObjectPackage->saveXML();
    die();
    * The request looks like this, notice how <hmac> is different:
    <?xml version="1.0"?>
    <request xmlns="http://ns.adobe.com/adept" action="get" auth="builtin">
      <limit>
        <start>0</start>
        <count>24</count>
      </limit>
    <hmac>T0kdAb//TbkcrtaipLh3ko+ySv4=</hmac></request>
    #$response = sendRequest($xmlObjectPackage->saveXML(), $serviceUrl);
    #print $response;
    Jun 30, 2011 8:54 AM   in reply to Anthony_ZA
    I'm seeing the same thing. Were you able to find a solution? or an updated XMLSigningSerializer.php?
    I've also noticed a PHP notice being thrown from the provided file:
    PHP Notice:  Undefined variable: nodeId in /home/user/hmac/inc/XMLSigningSerializer.php on line 61
    Jul 4, 2011 9:21 AM   in reply to Jim Lester
    I've used the code from this thread to use the XMLSigningSerializer.php script to generate an hmac
    Using a responce fro the server I've removed the hmac passed it through the script but the hmac comes up wrong. I've used both the server password and the shared secret to sign the responce but both give me an incorrect hmac.
    Can you shed some light on why this is?
    Jul 14, 2011 9:34 AM   in reply to T.David
    I am experiencing the same issue.  I'm going to start going through XMLSigningSerializer.php line by line and comparing with UploadTest, which I have no doubt y'all have already done, but if anyone has found a solution for this, please post here asap!
    Many thanks!
    -Julie
    Texas
    Jul 14, 2011 10:25 AM   in reply to FireFeatherWD
    Also, I'm not sure if this helps, but here is the debug data for the XML serializer when it's run over the follow XML:
      <nonce>KXRwPwAAAAY=</nonce>
      <expiration>2011-07-14T16:52:02-00:00</expiration>
      <distributorData/>
      <limit>
        <start>0</start>
        <count>24</count>
      </limit>
    </request>
    Like the others, this XML was taken directly from the admin console and the hmac has been removed.
    Starting Serialization
    Serializing Element:  request
    Getting name for request namespaceURI -http://ns.adobe.com/adept-                             prefix --  localName -request- baseURI -file:///C:/wamp/www/acs4/test/-
    outString | http://ns.adobe.com/adept| length = 27 byte1 = 0 byte2 = 25 | 25
    outString | request| length = 9 byte1 = 0 byte2 = 7 | 7
    Serializing Attributes for request
    Serializing attribute - action - get
    Getting name for action namespaceURI --                             prefix --  localName -action- baseURI -file:///C:/wamp/www/acs4/test/-
    outString || length = 2 byte1 = 0 byte2 = 0 | 0
    outString | action| length = 8 byte1 = 0 byte2 = 6 | 6
    outString | get| length = 5 byte1 = 0 byte2 = 3 | 3
    Serializing attribute - auth - builtin
    Getting name for auth namespaceURI --                             prefix --  localName -auth- baseURI -file:///C:/wamp/www/acs4/test/-
    outString | auth| length = 6 byte1 = 0 byte2 = 4 | 4
    outString | builtin| length = 9 byte1 = 0 byte2 = 7 | 7
    Finished Serializing Attributes:  -  action get  auth builtin -
    Inspecting child node #text with Type: 3
    Inspecting child node nonce with Type: 1
    Serializing Element:  nonce
    Getting name for nonce namespaceURI -http://ns.adobe.com/adept-                             prefix --  localName -nonce- baseURI -file:///C:/wamp/www/acs4/test/-
    outString | nonce| length = 7 byte1 = 0 byte2 = 5 | 5
    Serializing Attributes for nonce
    Finished Serializing Attributes:  - -
    Node Value for nonce is: KXRwPwAAAAY=
    outString | KXRwPwAAAAY=| length = 14 byte1 = 0 byte2 = 12 | 12
    Done Serializing Element nonce - serialization:   http://ns.adobe.com/adept nonce  KXRwPwAAAAY=
    Inspecting child node expiration with Type: 1
    Serializing Element:  expiration
    Getting name for expiration namespaceURI -http://ns.adobe.com/adept-                             prefix --  localName -expiration- baseURI -file:///C:/wamp/www/acs4/test/-
    outString | expiration| length = 12 byte1 = 0 byte2 = 10 | 10
    Serializing Attributes for expiration
    Node Value for expiration is: 2011-07-14T16:52:02-00:00
    outString | 2011-07-14T16:52:02-00:00| length = 27 byte1 = 0 byte2 = 25 | 25
    Done Serializing Element expiration - serialization:   http://ns.adobe.com/adept expiration  2011-07-14T16:52:02-00:00
    Inspecting child node distributorData with Type: 1
    Serializing Element:  distributorData
    Getting name for distributorData namespaceURI -http://ns.adobe.com/adept-                             prefix --  localName -distributorData- baseURI -file:///C:/wamp/www/acs4/test/-
    outString | distributorData| length = 17 byte1 = 0 byte2 = 15 | 15
    Serializing Attributes for distributorData
    Done Serializing Element distributorData - serialization:   http://ns.adobe.com/adept distributorData
    Inspecting child node limit with Type: 1
    Serializing Element:  limit
    Getting name for limit namespaceURI -http://ns.adobe.com/adept-                             prefix --  localName -limit- baseURI -file:///C:/wamp/www/acs4/test/-
    outString | limit| length = 7 byte1 = 0 byte2 = 5 | 5
    Serializing Attributes for limit
    Inspecting child node start with Type: 1
    Serializing Element:  start
    Getting name for start namespaceURI -http://ns.adobe.com/adept-                             prefix --  localName -start- baseURI -file:///C:/wamp/www/acs4/test/-
    outString | start| length = 7 byte1 = 0 byte2 = 5 | 5
    Serializing Attributes for start
    Node Value for start is: 0
    outString | 0| length = 3 byte1 = 0 byte2 = 1 | 1
    Done Serializing Element start - serialization:   http://ns.adobe.com/adept start  0
    Inspecting child node count with Type: 1
    Serializing Element:  count
    Getting name for count namespaceURI -http://ns.adobe.com/adept-                             prefix --  localName -count- baseURI -file:///C:/wamp/www/acs4/test/-
    outString | count| length = 7 byte1 = 0 byte2 = 5 | 5
    Serializing Attributes for count
    Node Value for count is: 24
    outString | 24| length = 4 byte1 = 0 byte2 = 2 | 2
    Done Serializing Element count - serialization:   http://ns.adobe.com/adept count  24
    Done Serializing Element limit - serialization:    http://ns.adobe.com/adept limit   http://ns.adobe.com/adept start  0   http://ns.adobe.com/adept count  24
    Done Serializing  Element request - serialization:    http://ns.adobe.com/adept request  action get  auth builtin   http://ns.adobe.com/adept nonce  KXRwPwAAAAY=   http://ns.adobe.com/adept expiration  2011-07-14T16:52:02-00:00   http://ns.adobe.com/adept distributorData    http://ns.adobe.com/adept limit   http://ns.adobe.com/adept start  0   http://ns.adobe.com/adept count  24
    Finished Serialization
    Jul 22, 2011 9:42 AM   in reply to FireFeatherWD
    So I got a solution that work with PHP code, but only via a custom made .jar file.
    What I did was take the UploadTest.java document, create my own java project using Eclipse using the source files provided by Adobe, then pared it down so that all it does is take in XML via the command line and return the HMAC using the XMLUtil.java resources.  This has worked like a charm for us and our PHP code communicates with it via exec().
    Jul 22, 2011 11:25 AM   in reply to FireFeatherWD
    We ended up doing the same thing. I've been waiting for approval from management to relase the code and jar, I'm unsure if I willl get it.
    Oct 19, 2011 6:05 AM   in reply to Anthony_ZA
    Expecting a reply from Adobe is simply naive, as is any attempt to reimplement the braindead signing in anything other than the one-true-language. The "algorithm" has been intentionally made so that any attempt to reimplement it is bound to fail.
    No. Really. The adobistas expect everyone to learn their preferred language just to be able to upload a file into their beloved, overpriced and undersupported crap. Or ... horrors ... even to assign it to other than the default distributor.
    Apr 21, 2012 3:55 PM   in reply to JendaXXX
    It has been almost 5 months since the last post on this thread. Has anyone found a solution?
    I have done some digging in the code (looking at the Java code and comparing to the PHP code). There are differences, but I could not find the reason for the PHP serialization to fail.
    So far I have identified (for the code in snippets-2010_11_12.zip)
    a) The call to usort, to sort the attributes is wrong and generates a warning. The name of the comparison function (second parameter) must be a string, so " " must be added around it. On most cases there are not too many attributes and it will be a problem only if they are not "in order". Exemple: auth and action in a "request".
    b) When dealing with 0-length strings, the serialized representation is 0x0000. The code has a $NodeId prefixing the 0x0000 (char(0).char(0)). Here the default PHP action is to the $NodeId to an empty string that is fine.
    But those alone are not the reason for the wrong HMAC.
    I have manually checked the serialized output and it seems to be correct, at least to the written specs.
    Anyone with the "java" serializer, please send me a copy (source??) I plan to dump the serialized representation and compare with the PHP one.
    I will also look in reports that it fails for large strings that are broken into pieces. If I can make it work, I will create a fully funcional example and library, with code improvements (there are some really bad PHP code there) and support code.
    Sep 25, 2012 4:10 AM   in reply to AHVLima
    Hello, I am new in ACS and in this comunity. I need ASC 4 for my job. I'm trying to update ebook but I don't get it. I need help please!!
    I use this xml code for the update, where XXX is the correct data:
    <request xmlns="http://ns.adobe.com/adept" action="update" auth="builtin">
    <nonce>XXXXXXXX</nonce>
    <expiration>XXXXXXXX</expiration>
    <resourceItemInfo>
    <resource>XXXXXXXX</resource>
    <resourceItem>X</resourceItem>
    <metadata>
    <title xmlns="http://purl.org/dc/elements/1.1">XXXXX</title>
    <creator xmlns="http://purl.org/dc/elements/1.1">XXXXX</creator>
    <description xmlns="http://purl.org/dc/elements/1.1">XXXXXX</description>
    <languaje xmlns="http://purl.org/dc/elements/1.1">XX</languaje>
    <publisher xmlns="http://purl.org/dc/elements/1.1">XXXXXXX</publisher>
    </metadata>
    </resourceItemInfo>
    <hmac>XXXXXX=</hmac>
    </request>
    but the server responds me this:
    <error xmlns="http://ns.adobe.com/adept" data="E_ADEPT_INTERNAL XXXXXXXX/admin/ManageResourceItem null"/>
    Anybody knows because the server return this?? And is possible update a packaging ebook??
    Thanks in advance
    Sep 25, 2012 4:24 AM   in reply to BaldreuBrozoso
    Hello,
    You can't update metadata! If you want update it, you may
    repackaging the book.
    Regards
    Sep 25, 2012 4:50 AM   in reply to Boledo
    Ok, thanks for you reply.
    You have been a great help
