kevin.gaffney
Scroller null focusManager exception
Jul 7, 2011 6:55 AM
Currently working on a project that needs to take a component & pop it out of it's parent to the top level app. I am using a spark textAera. Initially when the textArea is "unpopped out" the textAera works fine. However, when it is popped out and a user then focuses in on the textArea a null object reference is thrown from the Scroller class focusInHandler method.
Currently to remove and pop out the component the code I am using is:
IVisualElementContainer(resizeComponent.parent).removeElement(resizeCo mponent);
FlexGlobals.topLevelApplication.systemManager.addChild(resizeComponent );
where resizeComponent is the component I want to pop out.
Exception occurs when focusing in, Scroller.as:
override protected function focusInHandler(event:FocusEvent):void
        super.focusInHandler(event);
        // When we gain focus, make sure the focused element is visible
        if (viewport && ensureElementIsVisibleForSoftKeyboard)
            var elt:IVisualElement = focusManager.getFocus() as IVisualElement; //null object excpetion thrown here
            lastFocusedElement = elt;
What am I doing wrong?
Kevin
    Jul 7, 2011 12:01 PM
    Kevin,
    The problem is that your popup doesn't implement the IFocusManagerContainer interface.
    Implementing IFocusManagerContainer allows the system to assign a FocusManager to the popup, and this error goes away.
    Haim Arazy
Legend
  • Correct Answers - 10 points
  • Helpful Answers - 5 points
