The BIOS utility for the P8P67 Pro B3 Board has an EZ Mode that allows you to select from 3 performance presets: Powersaving, Normal, and Overclock mode. When I set it to Overclock, the system becomes unstable - won't bootup or will freeze during some operation.
There is also a tool for overclocking from within Windows after bootup. Again, anything other than the stock setting causes instability.
I had hoped to overclock the traditional manual way, but don't think it's a good idea if the presets don't work. I was wondering if anyone else had similar problems or should I disregard the presets.
CPU i7-2600k
16 GB RAM
@ Scott: thanks for that advice. I planned to OC the traditional way. I just thought it strange that the OC preset designed for its own board would be unstable. It actually pushed the clock speed to 4.3Ghz. Not too conservative, is it?
The software is part of the BIOS utility. It has an EZ Mode and AI advanced (manual) mode.
Here's the Asus ''easy to OC'' board
http://www.asus.com/Motherboards/Intel_Socket_1155/P8H67M_PRO/
My Q6600 is with org. cooler and no OC 65 degrees celcius, with 30 % OC and zalman cnps 7500 cpu cooler below 60 degrees celsius.
