I was trying to download the most updated version of adobe. It said it downloaded successfully. Then when I tried to open it it said that it did not download successfully. I called a friend and he told me to uninstall adobe so I uninstalled all the adobe files in my programs and now when I try to download adobe reader a box comes up that is titled UI_ReaderInstaller and inside the box it says "Only a single instance of this application can run". What do I need to do to download adobe
As this is a user to user forum, responses are not always instantaneous.
You may want to try the following.
Use the Windows Installer Cleanup Utility to remove all traces of Reader from your system. This is no longer supported by Microsoft because it can produce problems with Win 7, but you can still download it from from places like
http://majorgeeks.com/download.php?det=4459
Then, download the Reader installer from
http://get.adobe.com/reader/enterprise/
and perform a clean install.
I have the same problem: attempt to install Adobe Reader 10.1.0 produces the error:
UI_ReaderInstaller
There was no other version running, as verified by the process view of Windows Task Manager.
I had ver. 9.4.5, attempting to install/upgrade to 10.1.0 failed. I then removed 9.4.5 with Windows Add/Remove Programs, but install of 10.1.0 still failed.
I then tried the Windows Installer Cleanup Utility, but it didn't show any version of Adobe Reader to uninstall.
Since 9.4.5 broke search highlighting, a solution is upgrading to ver. 10. However this isn't possible on some systems due to this install bug.
Search highlighting problem: http://forums.adobe.com/thread/865778
System Config:
Windows 7 Home Edition SP1 64-bit
Motherboard: EVGA P55 FTW (A72 BIOS)
CPU: quad-core Intel i7-860 @ 3.8Ghz, hyperthreading on, RAM: 8GB DDR3
System disk: 300GB Velociraptor, 10k rpm SATA
Data disk: 2 x 1.5TB Barracuda, 7200 rpm SATA, RAID 0
Video: EVGA nVidia GeForce GTX-275 896MB, driver: 8.17.12.5896(258.96)
Network: AT&T U-Verse (12 megabit down, 1.5 megabit up).
Browser: Chrome 12.0.742.122, IE 9.0.8112.16421 (32 & 64-bit), FireFox 5.0.
VLC 1.1.7, WMP 12.0.7600.16667
ok i had this probelme and i get to fix it
run the adob installer when th error message appear dont clos it do this
clic "ctrl and esc" as same time the windows task manager will appear
the go to "processues" and search for "install_reader_(en or fr)_mssa_aih.exe" right clik with mouse and choos "open the file location"
a window will appear with a lot of adobe install programe (if you execute the installation many times) you have to delet theme but one then you close the error message and execute the one you didnt delet and "voila" the set up will begin
if this is not clear just tel me
