emfahmy
Looking for xfa.signature.sign/verify example with all parameters used
Jul 15, 2011 12:17 PM
Hello all,
I'm trying to extract information from a data signature to copy into another field.
I can access the data signatures in the document through the enumerate method:
var oSigs = xfa.signature.enumerate();
var iNum = oSigs.length;
for (var i=0; i < iNum; i++)
     var oChild = oSigs.item(i);
    // Display dialog box.
     var iVerify = xfa.signature.verify(oChild,"1");
    xfa.host.messageBox("Validity of signature integer value: " +
iVerify);
What I'd really like to do is specify an output SignatureInfo object in the "sign" operation so that I can extract the common name of the signer, date, certificate, etc.... through the signatureInfo() method.
Syntax is:
Reference_Syntax.sign( OBJECT param1, STRING param2, STRING param3 [, STRING param4 [, BOOLEAN param5 [, OBJECT param6 [, OBJECT
param7 ] ] ] ] )  where param7 "Represents an output SignatureInfo object containing the writable properties of the signature."
(From http://help.adobe.com/en_US/livecycle/9.0/designerHelp/001413.html#10. ..)
I have not found an example that includes any of the optional parameters.
Can anyone help with this?
Eanass
    Jul 19, 2011 12:45 PM   in reply to emfahmy
    Eanass
    I have created a simple sample that shows how to get the signatureInfo object (using JavaScript on an XFA based PDF form)
    Sample script is as follows...
    // Get particular info
        var Info = event.target.getField("form1[0].Page1[0].SignatureField1[0]").signatu reInfo()
        // Some standard signatureInfo properties
        app.alert("name = " + Info.name);
        app.alert("reason = " + Info.reason);
        app.alert("date = " + Info.date);
        // Get the certificate; first (and only) one
        var certificate = Info.certificates[0];
        // Common name of the signer
        app.alert("Signer Common Name = " +  certificate.subjectCN);
    I have also attached the sample file.
    Hope this helps.
    Steve
    Jul 20, 2011 11:15 AM   in reply to emfahmy
    I'm continuing to investigate... hopefully I'll have something soon.
    Regards
    Steve
    Jul 25, 2011 11:44 AM   in reply to emfahmy
    I am waiting on confirmation, but it appears that the ability to create a SignatureInfo object (for an XML data signature) when using the "sign" method with the optional parameter is broken.
    Regards
    Steve
