I have Adobe CS5 Web premium, Windows 7 64-bit. (All updates on both)
My problem is that when I press create on Device Central it doesn't set up the flash document specs for the particular device I am trying to build an app for. It does the same thing when I try to create a new Adobe Device Central document in flash. However when I try and create mobile documents for photoshop, illustrator or fireworks it works fine. It is just when I try and create one for flash.
Any suggestions?
I realize this is an old thread, but I am having the same problem. In Device Central CS 5.5, I first selected Browse and dragged the HTC Droid Incredible, Motorola Droid 2, and Motorola Droid X to the Test Devices pane. Then I selected Motorola Droid 2 and clicked the Create button. At this point, the three devices that I added are grayed out, and the New Document pane says "To start, please select device(s) in the 'Test Devices' panel." The Motorola Droid 2 is still selected in the Test Devices panel, but as I said, it is grayed out.
What am I msising?
Hi tnewman772,
After clicking on "CREATE", have a look at the "Player Version", "ActionScript Version" and "Content Type" settings and adjust them such that they are supported, and you will notice that once you get them right you can proceed with the workflow. I hope this helps.
Nandi
