PPro CS5 GUI on mac really jerky
Mar 22, 2011 8:38 PM
  Latest reply: LFedit, Oct 25, 2011 11:33 AM
Replies 1 2 3 4 5 6 7 Previous Next
    Jul 15, 2011 9:39 AM   in reply to Wil Renczes
    I'm running a single apple 27" LED display @ 2560x1440
    Reducing the screen res was one of the first things I tried, I didn't make any difference at all, although it was still with the same monitor connected.
    This video from that other thread is very interesting as both macs are configured the same but one is a 3,1 with 22 gigs of Ram, the other is a 4,1 with 16 gigs.
    The 4,1 is the laggy one, again it's the newer mac that's suffering. Although the fact that the clips are not displaying properly on the older mac when dragging does complicate matters. It's probably a driver or display issue but maybe that's part of the reason why it is so responsive, it's not having to render the opacity and details.
    Jul 15, 2011 9:38 AM   in reply to Keith Moreau
    Hmmmmmm.
    Let's try another experiment if folks are interested: disabling CPU cores on a multi-processor 4,1 or 5,1 box.  I know this won't address those having problems with 3,1 or prior boxes, but play along here, please.
    Find the CPUPalette.app in /Library/Application Support/HWPrefs
    Once you fire it up, you'll see a graphical representation of each core.  For 2-processor machines, you'll have 2n cores (4-core x 2 processors = 8 cores, etc).
    Let's try knocking one of the entire processors down and then restart PPro.  Clicking on a core (called 'CPU' in the app) will disable it.
    Click on the last n cores, where n is the number of cores in EACH processor.  So if each processor in your machine has 6 cores, meaning you have a 12-core box, then click on the last 6 cores.  That'll disable the entire processor.  Once you've done that, fire PPro up again and give the black vid test another go.
    Don't forget to re-enable the cores when you're done.
    jas
    Jul 15, 2011 9:40 AM   in reply to Wil Renczes
    I'm running a older 30" cinema display (2560 x 1600) and a 1920x1080 second display having the timeline on either display I find my performance starts to improve if my timeline uses less than 400px in height
    Jul 15, 2011 9:46 AM   in reply to LFedit
    Excellent find LFedit, it's the same here, big response improvement when reducing the height of the timeline. In fact I think I'd go as far as to say that you've found the root cause and will probably give Adobe a big pointer in the right direction.
    Lets see what everyone else finds.
    Jul 15, 2011 9:52 AM   in reply to Paul Joy (UK)
    I can't take credit for the find, Butch2oc found that one, and it really helped me out, so cheers to him.  Just wanted to chime in and see if we can get this sorted out.
    Jul 15, 2011 9:54 AM   in reply to LFedit
    Thanks guys, I think we can work with this.
    Jul 15, 2011 10:00 AM   in reply to Wil Renczes
    Good stuff Wil.
    Although it's a bit of an anti-climax to discover that the issue was discussed and reported back in April.  I hope we helped in some way to strengthen the case anyway.
    Jul 15, 2011 10:16 AM   in reply to Paul Joy (UK)
    Just an update on the screen resolution fix, I just found that if the docked program, source, and project panels take up less than 400px and the timeline takes up the rest of the resolution the same speed increases apply.  I found it by using the maximize frame command and the timeline at full screen is super responsive, slowly start dragging it down, performance decreases.  Get outside of the 400px area, it lags horribly.  Can anyone replicate?
    Jul 15, 2011 10:19 AM   in reply to LFedit
    Yes, same here. Also the clips then become solid greys as in the video posted above. Good find, certainly appears to be some kind of display bug.
    Jul 15, 2011 10:25 AM   in reply to Paul Joy (UK)
    Thanks for replicating Paul.
    Jul 15, 2011 10:36 AM   in reply to Paul Joy (UK)
    OK, ignore my last post re: CPUs.  Cool, sounds like a potential win here.
    Can someone make a quick clip showing how you're changing the timeline resolution and whatnot?  I'll be happy to test the lag out on my old 3,1 and post a response later.
    jas
    Jul 15, 2011 10:38 AM   in reply to Jason Van Patten
    Thanks Jas, as requested.
    Jul 15, 2011 10:57 AM   in reply to Paul Joy (UK)
    I think I've found the culprit, at least for me. The workaround is not the greatest but it's a clue for Adobe. It also doesn't match Paul's video #4, but it's another solution. In any sequence, if the the sequence timeline is smaller than a certain percentage of the whole screen, Premiere Pro will draw a reduced opacity version of the clip when dragging. This seems to cause the lag. If the timeline is made larger, maybe 60% or larger of the screen real estate, I can drag around with no delay. This includes not only dragging stuff within the sequence, but dragging clips back and forth from the project pane to the timeline. Everything is snappy and immediate. The reason is that when dragging, on this no-lag version, there is no drawing of a reduced opacity representation of the clip, it's just a gray outline. The dragging is without any lag. In the code, Adobe probably just 'gives up' at some number of total pixels needing to be redrawn and just says, "I'm just going to draw the outline, forget about the reduced opacity version of the clip.' However this results in snappy performance.
    It's an example of a 'feature' that actually detrimental. If anybody knows of a way to 'turn this off' without having to manipulate the size of the sequence panel, please let me know. I don't necessarily like to have the sequence panel taking 60% of my 30" cinema display.
    This doesn't match Paul's 'no lag' experience because I see in his screen recording part 4 that there is still a reduced opacity version of the clip when dragged, but perhaps this is due to other factors.
    Also, for me it's 'total number of pixels', not percentage of screen, if I drag the sequence panel to my second, smaller monitor, I cannot get a 'non-lag version of the sequence, it always tries to render out the reduced opacity version of the clips and induces the drag.
    However obviously there is something in the Premier Pro clip drawing code that is slow on Macs, and perhaps looking at the power of the hardware makes some decisions about how much to draw the reduced opacity version, making more powerful hardware actually seem slower. Having an Adobe software engineer repro this problem with some new Mac Hardware, 30" large screen would probably be able to solve it in a few hours.
    Another poster who I private messaged with who had reported this problem to Adobe earlier this year and posted to another thread told me he just gave up and went to a Windows PC because it was much more responsive. I myself am tempted to do this, but I really, really don't want to go Windows / PC if I can at all help it. I'm sure that thousands of other former Final Cut 7 users are in the same boat so I think it behooves Adobe to fix this issue on Macs and make the choice easy for Mac users.
    Jul 15, 2011 11:13 AM   in reply to Keith Moreau
    That would make sense Keith, it seems that the larger the area the timeline uses the more the code that handles the rendering of the timeline struggles. Although in my case this doesn't influence the CPU at all, my CPU usage stays the same regardless of the size of the timeline. This is true both with and without hardware MPE.
    It does look like the code is triggering a failover and disables the clip drawing when the response slows down to a certain point.
    Lets hope Wil and his colleagues can finish this little story on a high note.
    Jul 15, 2011 11:37 AM   in reply to Keith Moreau
    Another thing to note is that you can also speed up the performance by reducing the width of the timeline, it seems to be that the smaller the area in general the faster it runs, that is until you hit the sounds barrier and get to turbo mode!
    Jul 15, 2011 1:44 PM   in reply to Paul Joy (UK)
    I think I found another small bug that may be related to the Jerky timeline. I have found that when trying to drag clips around the timeline, if I want to drop it somewhere where there is a tool tip, it will not let. The tool tip needs to be out of the way im order to release the clip where you want it. I never really noticed that till today and think that is a bug. The code realted to that may be in play with the jerkyness?
    Ray
    Jul 15, 2011 1:51 PM   in reply to Paul Joy (UK)
    I can reproduce this on my Mac Pro 3,1, all except for the last bit where you blow the timeline up to full screen and the video clip turns grey.  That doesn't actually happen for me.  The only thing that happens is: the larger I make the timeline window, the worse the lag gets.  Conversely the smaller I make the timeline window, the less lag there is.
    Hope this helps.
    jas
    Jul 15, 2011 4:33 PM   in reply to buraihan
    I dont have a MAC but it seems like this timeline work-around is at least a step in the right direction.
    Are there any changes if you un-dock the panels ?
    Or use the ~ and use full screen ?
    GLenn
    Jul 15, 2011 6:22 PM   in reply to Powered by Design
    Hey guys this is great news. A big thanks to all who have contributed. I am at home for the weekend so will try it out at work on Monday.
    If this really is the source of the problem then I can't see why the talented guys at Adobe won't be able to find a permanent solution.
    Great stuff. The thought of maybe going back to PC's did not really fill me pleasure.
    Now I'm excited!
    Alex
    Jul 15, 2011 6:32 PM   in reply to Alex Hawkins
    BTW I just tried this on my brand new 27" i5 iMac at home and lo and behold the same problem occurs when expanding the timeline out, (if you have the timeline at the default size there is not really a problem) to a point, and then when it gets so big that the greyed box thing occurs, suddenly the response is very snappy.
    Basically I'm getting the exact replica of Paul's Part 5 video.
    Cool Bananas!
    Jul 15, 2011 9:48 PM   in reply to Paul Joy (UK)
    Hi Paul
    I realized that I posted pretty much exactly what you posted a few minutes earlier about the threshold, but didn't see your post while I was investigating and posting mine, there is some synchronicity going on here.
    I did some further tests, and for me, in the laggy mode, there is pretty high CPU, in fact for me it easily pegs 100% on one CPU when dragging moderate to fast. When in the 'gray box' responsive mode, the CPU usage is quite a bit less, 25% to 50%. I didn't measure whether more lag equals more CPU, but I would suspect this might be the case, and if that Premiere Pro is using only 1 CPU thread, then it can only use up to 100% of one CPU, and when more is needed things just get slower. It just can't go faster than 100% usage.
    It's also pretty easy to make a code sample in the Activity monitor of what Premiere Pro is doing, and there is seems that a lot of stuff is going on during a drag. An Adobe engineer could do this (they have better tools as well to analyze it) to find out what routine might be causing the high CPU usage. I don't think that a simple drag should take that much CPU.
    I'm hoping that all this work on finding exact use cases will help Adobe determine the problem, I really want my Premiere on the Mac to be snappy!
    Thanks to you and everybody for all the information and cooperation on this thread. I think the formula is lag = timelinepixels * motion
    -Keith
    Jul 16, 2011 6:04 AM   in reply to Jason Van Patten
    Was just able to test this on a MacPro 3.1 and experience the same as Jason Van Patten.   No matter how the timeline is displayed I do not get the gray clip when dragging, and the larger the timeline window, including fullscreen the worse the lag. However, the lag on the Macpro 3.1 system is nowhere near as slow as it is on the 4.1.
    Jul 18, 2011 1:52 AM   in reply to LFedit
    Hi....
    as said earlier I am experiencing the lag and that extremely.
    Here are my system specs which are corresponding to what you are seeing on the 4.1 Model.
    I am using PPRO on a 30" Inch Cinema Display... Perhaps that is worse that on a 15" inch LCD.
    Hardware Overview:
      Model Name: Mac Pro
      Model Identifier: MacPro4,1
      Processor Name: Quad-Core Intel Xeon
      Processor Speed: 2.26 GHz
      Number Of Processors: 2
      Total Number Of Cores: 8
      L2 Cache (per core): 256 KB
      L3 Cache (per processor): 8 MB
      Memory: 32 GB
      Processor Interconnect Speed: 5.86 GT/s
      Boot ROM Version: MP41.0081.B07
      SMC Version (system): 1.39f5
      SMC Version (processor tray): 1.39f5
    Jul 18, 2011 1:42 PM   in reply to buraihan
    I have a Mac Pro 8 core machine running all the latest updates and have this same problem.  I acutally just put in a bug report to adobe about it. I edit with my entire second screen as the timeline because I get massive timelines with many graphic layers and audio layers.
    Jul 18, 2011 6:16 PM   in reply to buraihan
    2010 Mac Pro, 12 GB of RAM, SSD HD, and I have the same problem as well. Clips seem to take a loong moment to move with the cursor.
    Jul 18, 2011 6:46 PM   in reply to funkbomb
    I just ran a quick test on a fully loaded MAC Tower against a PC that was a fraction of the cost and has no storage subsystem. Editing Canon 5D raw h.264 clips. The PC is so razor sharp and responsive compared to the very sluggish MAC system. I realize we have the laggy issue that is part of this problem, but also the capture card as well. This is an all dialog driven edit and using the JKL features with the capture card on the MAC are simply non-existent. It simply is a joy to edit on the Win 7 system and a very sloooooow process on the top of the line MAC. If I didnt need ProRes and Final Cut on a daily basis, I would seriously be eyballing the Win7 system.
    Hopefully Adobe will take some additional time to optimize the MAC version and also get together with their hardware partners. We need help.
    MAC
    OSX 10.6.7
    12 Core @ 2.93GHz
    SSD
    32GB Ram
    Quadro 4000
    Fibre SAN
    Blackmagic Decklink Extreme HD
    Dual 24" Monitor
    PC
    Win 7 64
    i7 950
    SSD
    12 GB Ram
    GeForce GTX 470
    30" Monitor - (Runing 1920 x 1080)
    Jul 18, 2011 7:43 PM   in reply to Jason Van Patten
    Hi all,
    Just to let you know that since I originally posted this issue (http://forums.adobe.com/thread/785985) I had a few people respond with similar problems.
    I went down the "Adobe Support Road" with Americas T2, I managed to get them to recreate issue and they have come back to me
    saying that it's a bug and my lengthy customer support portal has been labeled withdrawn.
    Don't know if anyone can access it but the case number is 0182049590.
    I have received a message from Keith requesting me to provide any feedback I may have on offer... so...
    It's good to hear other people are now raising this issue because I hate it, you need a monitor with a res higher that 1920x1080
    to get around it by using the fill to screen mode. I am sick of cutting and pasting (as this is much faster than grabbing instances and moving them).
    Just in case some of you don't know... if you have a monitor that can give a display res of 2048 x 1152 you will get some joy out of your box.
    If you display your timeline in a window at full screen then the instances turn grey (i.e. do not show clip name etc) and can move around very quickly.
    I still believe it is purley a display resolution thing... Adobe knows about it.
    I was asked by adobe to upgrade to 5.5 to see if this fixed the issue, I suggested they did this to the system they had replicating the problem. I have not heard back but I now have 5.5 and will upgrade my system soon (when not so busy) and let you know.
    I would also like to ad that I have found installing adobe clean is the way to go and not upgrading on top of the previous version as this avoids other issues.
    When I rebuilt previously I produced a clone with just the OS + mail & net settings etc.
    I then added adobe ONLY and produced another clone.
    I then added all other software/plugins etc and produced another clone.
    All great for finding faults quickly and for doing clean installs when needed.
    I really hope adobe gets onto this because they are going to get a lot more macs using adobe now that final cut has lowered it's guard, it would be a shame
    for people to be turned off adobe because of 1 bug/fault/??????.
    Maybe if ALL (not just a few) of us put in a bug report again this issue may get looked at with a little more intent.
    Are we in?
    Jul 18, 2011 9:33 PM   in reply to Butch2oc
    I dont have any of the display issues mentioned, but the monitor resolution issue caused me to check out my 2  27" HD Cinema displays (Mac).
    They are displaying  at only 1920 by 1200 which is the biggest option.
    Here are the details of the system which may explain why Im not having issues with this monitor resolution...or not
    Im on a
    Mac Pro 3.1
    Quad-Core Intel Xeon 3.2 GHz
    OSX 10.6.7
    24 gigs ram
    Maxx Digital Raid array clocked at 745 mps.& Areca controller
    ATI 3870 Graphics card.
    USB wired mouse
    No blue tooth anything
    No lag with h.264 (but I do drop resolution to 1/2 resolution for real time playback)
    No lag with full format red R3D files  (also drop playback  to 1/4 resolution for real time playback)
    All other formats (Prores, P2, AVCHD, DVCPro HD, etc) playback fine at full resolution
    Not sure if this is helpful ,but I thought I would share.
    Jul 18, 2011 11:29 PM   in reply to Butch2oc
    Thanks Butch2oc for reporting this. For me the lag problem is identical with Pro 5. and 5.5. So I don't think you'll see a difference. So it too how long to have Adobe admit and repro the problem, haven't you been dealing with this since last year? Wow. What display do you have?
    Not to hijack the thread, but what issues have you seen with having 5.0 and 5.5 on the same machine, because I want to have both at the same time and I haven't noticed anything bad having both.
    Jul 18, 2011 11:57 PM   in reply to Keith Moreau
    I have a display that can only go as high as 1920 x 1080 (BenQ Monitors) the monitors that give rapid performance are old Dells that can give a max res of 2048 x 1152. When we swap monitors (even just one of them) the poor response follows with the monitor that can only go to 1920 x 1080. The only way I can get good (not rapid) performance with the 1920 x 1080 monitors is to reduce timeline size dramatically, but all of you are on to that from my previous posts.
    The support portal service was good as far as response time but sometimes they kept asking me to do the same thing, it was like they never read my responses... anyway... maybe all with this issue should bombard adobe with bug reports.
    ps thanks for the info re 5.5, I won't be rushing then.
    Cheers
    Jul 19, 2011 7:06 AM   in reply to Butch2oc
    It looks like something to do with the architecture of the new mac pros, as we have multiple reports of Macpro3.1 systems not being plagued with this slow GUI.  Having edited on both a 3.1 and 4.1 system, the 3.1 system without CUDA is SO much easier to edit H.264 material than the 4.1 system with a Nvidia 4000 card. Hopefully this can help adobe find a solution.  Also, I just got a support case opened and will update anything that comes of that.
    Jul 21, 2011 6:11 AM   in reply to LFedit
    Todd,
    Have you guys at Adobe been able to isolate the problem yet? Please keep us posted?
    Ray
    Jul 22, 2011 12:34 PM   in reply to buraihan
    Dear Todd, Adobe 'Official' & 'Unofficial' Forum Users, and other Adobe Employees:
    You have been very helpful .. and reasonable .. whereas I have been upset and demanding.
    Now the cat is out of the bag regarding the poor performance on high end Macs on your Forums regarding Premiere Pro .. and issues that have been driving me nuts for months ( Since JAnuary ) have surfaced. ... Wait till they find the one that erases all the dynamic links! ( Check my other posts )
    Now Lion has opened the door to more problems .. while Adobe has yet to solve the Snow Leopard issues.
    What is Adobe going to do?
    Time Magazine just featured a Apple / Adobe article that was spot on regarding Lion and the non-functional Adobe suite.
    http://techland.time.com/2011/07/22/adobe-os-x-lion-is-buggy-adobe-rea der-not-compatible/
    Be it as it may that Apple and Adobe's professional proprietary war concerns Flash and HTML5 .. this has nothing to do with the 'suite' .. save for Apple's embarrasing reviews of Final Cut X.
    Adobe should seize this unique moment and support Mac users like they never did before!
    Adobe needs to make a official statement. Hire programmers. Or things are bound to only get worse.
    I have a case report into Apple Senior Tech that I have yet to reply to // cause I was waiting for some relief from your Forums.
    I have been waiting for replies from Adobe tech regarding many bug reports and posts .. and I get nothing.
    Regardless of your continuous "Post Bug Reports Here:" to Forum users ... it obviously does not suffice, and response from tech direct is unacceptable. The call center is a joke for professional users .. not that I am one .. but in one month I seem to know more about it than the foreigner at the call center.
    Sorry to be so determined .. but I am a unsatisfied customer looking for a solution to the only software option I have .. with an approx. $9,000 investment in a terribly disappointing suite.
    Please respond.
    Jul 22, 2011 9:14 PM   in reply to Pharther Phurther
    I second the post by Pharther.  MacPro user, recent switcher from FCP, bought into the new system with a big investment, and I am completely dissatisfied so far with the performance, the bugs, the (mostly) PC-centric view in the forums and the complete lack of help from tech support so far.  There are big issues with editing with CS5.5 on a MacPro, and with the big push to get switchers from FCPx, it would be nice to see Adobe help make us early adopters (the early switchers) sing Premiere's praises with a smooth, working editing environment.  For now, I advise all Mac owners to steer clear for the time being.  I don't mean to be too negative, just letting Adobe know that some of our issues feel like they are on the back burner.  I see how amazing the Adobe editing platform can be, and my frustration comes from not being able to experience it fully, yet.
    Jul 24, 2011 4:40 AM   in reply to needles27
    Just to let you know, I placed this issue with Adobe sometime ago, and sure, it would be great to see this issue fixed but I would like to say that
    Adobe tech support have been very keen to get on top of it. All in all, their support has been great and they always respond.
    I emailed the person who handled my case and got a response back straight away.
    The response:
    "The bug is being looked upon by the engineering team.  You can keep the bug number handy. It’s “Bug # 2881825” .
    I don’t have details about when will it get fixed as it’s a higher level decision"
    I can only imagine what may be involved in solving the issue from an engineering sense, but at least they are on to it.
    Even with this issue (and it's workaround) I still think Premiere is far superior to FCP.
    Have faith, it's a great product and will only get better.
    Cheers
    Jul 27, 2011 10:10 AM   in reply to Butch2oc
    Hey Wil & Todd,
    Still waiting to hear if we found the problem yet and how we are going to fix it. I would hope a point upgrade is in the works sooner than later on this MAC GUI bug.
    Can anyoneone from Adobe comment on this. Its been since July 15th since Wil commented on the bug. Quite a while now with no word.
    Ray
    Jul 27, 2011 11:43 AM   in reply to Ray Tragesser
    I agree, it would be nice to have some kind of update as to the progress of this. For me the laggy timeline thing is just a small part of the general lack in performance that premiere achieves on the mac. Adobe have taken such huge strides forwards with CUDA enhancement and realtime playback etc but there's some very basic GUI issues on the mac version that PC users are not experiencing.
    I'm working on a project today that envolves a lot of DSLR footage and the way Premiere takes ages to display thumbnails in the project window is driving me nuts. It's not using the CPU, the memory or the hard drives so what exactly is it busy doing?
    http://www.youtube.com/watch?v=LzbJ_CcHN4o
    I'm striving forward through the pain in hope that someone at Adobe can help us but the lack of responce about all the mac performance issues on the forum isn't exactly filling me with confidense at the moment.
    Message was edited by: Paul Joy (UK)
    Jul 27, 2011 11:47 AM   in reply to Paul Joy (UK)
    We're working on fixes for several performance-related issues. We'll give an update when we have something useful to say.
    Jul 27, 2011 12:06 PM   in reply to Todd_Kopriva
    Thanks Todd.
    1.) Check Multi Camera Editing.
    2.) Check Mouse Click Double Click Drag Etc ..
    3.) Watch Activity Monitor ( Especially the Multi-Processor Option ) to see what processors are being used and what are not during intensive tasks .. such as Stabilizing and other effects.
    4.) Check I/ O drive performance.
    5.) Check Audio playback while starting / stopping video clips in single sequence / dynamic linked sequence / multi camera edits ... sound sometimes does not
    6.) WARNING: I have found a bug in using dynamic link between PP and AE. Most other Mac users have yet to discover it. If you do not address this there will be major problems down the road.
    Good Luck
    Jul 27, 2011 12:08 PM   in reply to Todd_Kopriva
    Thanks todd, any update is useful at the moment.
Actions
