lionel.whj
Using Microsoft Network Load Balancing for Livecycle ES 2/2.5 with JBoss clustering?
Jun 26, 2011 9:24 PM
Has anyone tried using Microsoft NLB for Livecycle with JBoss clustering and get it working? Able to login to livecycle's admin ui page with the NLB IP
My enviroment:
- 2 jboss application server (different IP address)
- Horizontal clustered
- LC ES2 installed on both servers
For those who setup successfully, hope you can share your experience.
Thank you.
    Jul 15, 2011 8:25 AM   in reply to lionel.whj
    Lionel, are you having a specific problem getting your configuration to work, or are you just looking for others using this combination?
    Jul 15, 2011 9:07 PM   in reply to Gardner Buchanan
    Hi Lionel,
    I'm doing the same configuration but still haven't finished.
    When installing, did you choose the "Partial turnkey (separated DB)" or "LiveCycle Only" and using the pre-configurated JBoss ?
    Jul 19, 2011 1:01 AM   in reply to lionel.whj
    Hi Lionel,
    Actually I find the documentation a bit confusing. I'm trying to perform some tests and for that I have 2 Virtual machine (VMWare) and the windows NLB configured for those 2. But in the same LC documentation it says to run the installer normaly and proceed to configuration manager, whereas in another section says that we need to copy the pre-configured JBoss and do the configuration manually.
    So, which should I follow? I just need to install Rights Management service.
    Cheers!
    Jul 24, 2011 6:13 AM   in reply to lionel.whj
    Hi Lionel,
    Yes, I'm following that documentation. In this case, are you pointing the 2 app servers to the same database?
    Jul 27, 2011 12:09 AM   in reply to lionel.whj
    Just a few more questions...hehehe
    In the document: Configuring LiveCycle ES2 Application Server Clusters Using JBoss.
    Page 35 item 3.4. Have you had to configure the Caching Locators? If yes, where did you put them, in only one machine or in all of the nodes?
    On page 29, iten 2.7 (Testing the JBoss Application Server cluster) says that for testing we can run the command specifying the server, in my case is:
    run.bat -c lc_sqlserver_cl -b <ipAddress>
    But in the Appendix C: Configuring JBoss as a Windows Service, it says: call run.bat -c all -b <ipAddress>
    So when should I start JBoss with "lc_sqlserver_cl" or "all" ?
    Jul 27, 2011 7:30 PM   in reply to lionel.whj
    Thanks Lionel!
    How about your setup? Did you manage to get this working?
    Jul 29, 2011 3:28 AM   in reply to lionel.whj
    Hey, just to let you know, I've got some problems with the Locators, and then I followed this article:
    http://blogs.adobe.com/livecycle/2011/07/how-to-ensure-that-tcp-locato rs-are-using-correct-version-of-gemfire-used-by-livecycle-es2-cluster. html
    Let me know if you get succeed.
    Diego
    Jul 29, 2011 6:59 AM   in reply to lionel.whj
    Oh yes, I didn't mention that mine is working fine too. The locators are running and the 2 nodes are seeing each other.
    But how did you get the MS NLB working? I can't get access to LC through NLB IP address. Did you have to include the NLB ip in somewhere in JBoss?
    I suppose that as the MS NLB is already configured, once we follow the configuration (guide below) it's just a matter to turn on both nodes and should work, right? And also since the NLB is set up, we don't need to set up nothing on JBoss - e.g. section 6 of the guide below.
    http://help.adobe.com/en_US/livecycle/9.0/clustering_jboss.pdf
    Is that correct?
    Aug 2, 2011 8:59 PM   in reply to lionel.whj
    Yes, I got mine working after I changed to bind all address no the computer.
    Go to page 30, the note in the top:
    "When you start JBoss Application Server 4.2.0, to bind all addresses on the computer (including the localhost) you can specify -b 0.0.0.0 instead of the IP address of host name".
    So I did this and now it's working.
    I followed this thread: http://community.jboss.org/message/215486
    I hope it helps.
    Diego
    Aug 8, 2011 1:05 AM   in reply to lionel.whj
    Hey!
    I guess I missed this one, what is NICs ?
    I didn't set up the NLB but it's defined as multicast
    Aug 8, 2011 1:19 AM   in reply to lionel.whj
    Oh, nice!
    yeah, it's 1 card per server. Actually it's this 2 servers running with NLB.
    That's good!
    Cheers
