Warning. Much of this post is frankly a rant against a poorly written program and the so-called experts who offer up solutions here. If you are one of these experts and you have a thin-skin, don't read this post.
If you just want a solution to the problem skip to the bottom of the post.
INTRODUCTION
Adobe, I want my money back! I rarely buy Adobe products and always wind up regretting it when I do. This product was no exception.
I tried the trial version. Bought the product along with Photoshop Elements as part of a promotion.
Produced a couple of videos with it, no problems. Then, inexplicably, it stopped working for me and I would get the infamous "Sorry, a serious error has occurred..." message while trying to start or open a project. This would happen almost immediately, as it was drawing its intial screen layout.
MY FIRST BIG COMPLAINT... USELESS ERROR MESSAGE
This has to be the most useless error message I've ever read. The few times I've had programs crash on me, the error message that results usually gives me enough clues to find and fix the root problem.
ONWARD...
Uninstalled it with Revo Uninstaller, re-installed it.
Deleted all old project files.
Tried to re-start by clicking 'New Project' button.
Prompts me for a location for the project. I accepted the default.
Immediately gives me the "Sorry, a serious error has occurred..." message and shuts down when I press okay.
MY SECOND BIG COMPLAINT... INCOMPLETE UNINSTALL
I did observe that when I went to use the Organizer after the re-installs, the thumbnails of previous videos were still there. Clearly some cache wasn't removed during the uninstall.
If a cache wasn't removed, perhaps other remnants of the the program were still lying about on my machine. If they were the problem, then no amount of uninstalling/ re-installing would solve the problem.
CONTINUING...
At this point, I came to the forums for help and my worst fears were confirmed. This error message is a common problem. The suggestions to solve it were all over the place. The sheer depth and width of this faultfinding indicated to me that this is a seriously buggy piece of software.
With one or two exceptions it seems that nobody ever resolves this problem.
MY THIRD COMPLAINT... WELL-MEANING BUT UNHELPFUL 'SOLUTIONS'
These are some of the typical solutions I read on these forums:
- Your computer is probably underpowered. Give us a list of all your specs.
- Your computer doesn't have enough hard drive space. Give us a list of all your specs.
- Your computer doesn't have enough RAM. Give us a list of all your specs.
- Something on your computer has 'changed'. Give us a list of all your specs.
- Your hard drive is dying. Back it up quick!
- It's probably your anti-virus software. Turn it off.
- Some of your drivers are probably out of date. Update them all. Give us a list of all your specs.
- That's a different issue... start a new thread. (Lame...)
Most of that advice is... well, lame. It's pretty obvious that these people are just winging it, i.e. throw everything up there and hope something works. Sorta like that tech guy on the support line who always ends up telling you to 're-install the program' because he really has no clue what the problem is and just wants you off the line.
As someone who has used video editing programs for years, I'm here to tell you that the problem is rarely the computer specs. The specs listed by Adobe for this program aren't that onerous and my three-year-old Dell 1525 laptop with less than 20 megs of space on its 136 HD and 2 megs of RAM was able to produce videos with no problem.
Most computers sold within the last three or four years are pretty robust and should have no problem with consumer level video editing.
Sending people off on a quest to 'fix' their computer and research a lot of computer specs is a time-waster. That should be the LAST thing you recommend after first eliminating the program as a problem.
ONLINE SUPPORT
This is worthy of its own post, but I won't bore you here. Suffice it to say that Adobe tech support deserves some sort of industry recognition for its ineptitude.
MY SOLUTION
First, let me reinterate. The problem is probably the buggy program and not your computer, assuming your computer is relatively new and mid-range or better.
In my case, the clue was in the fact that not all of the program is uninstalled when you try to do a uninstall / re-install. The program likely had some sort of corrupted cache that stopped the program and that remained after an uninstall.
I unstalled it again, but after some research I came across this tool:
Adobe Creative Suite Cleaner Tool at http://kb2.adobe.com/cps/829/cpsid_82947.html
and this reference:
http://kb2.adobe.com/cps/859/cpsid_85966.html
The reference above applies to Photoshop, but the Organizer elements applies to Premiere unintalls as well.
After applying these two solutions and then re-installing, my Premiere Elements is working once again.
Had I followed the typical advice I would have spent days updating drivers, installing RAM, de-fragging and cleaning up my hard drive, listing specs to post here, etc. And none of it would have mattered a wit.
The program is still buggy though and my original problem may re-occur, I admit. I will certainly never buy another version of this POS program again, but, in the meantime, I hope I can save someone here some time in looking for a fix for their own message.
If you'd like to contact Adobe, you should click the Contact Adobe button at the bottom of every page on this web site. They often do give refunds
to customers who just can't get the program to work.
This is a user-to-user forum peopled by folks who spend tireless hours every week trying to help people get their computer systems up and running with this program and answers how-to questions for no compensation whatsoever. Posting your rant here does little more than flips them off.
But if you've got a complaint about the software, I do encourage you to contact the people who designed the program.
I re-wrote this post several times to make it more palatable. I deliberately did not mention names or point fingers at specific individuals. Why would any individual feel flipped off?
I appreciate that some people here are well-meaning with their advice but..."roads to hell" and all that.
My bigger point is that the routine advice given here is bad advice and can lead to frustration, anxiety and added expense for newcomers for no reason.
From the point of view of time and effort a better response is:
1. Confirm your computer meets all the specs required by Adobe. (If these specs are 'light', then Adobe should be taken to task.)
2. Eliminate the program as a potential source of problems -- which it likely is. Adobe does have a fault finding guide for this program which I worked my way through to no effect.
A re-install may fix problems with corrupted caches which I suspect is what caused my problem. However, the re-install needs to be COMPLETE (see my original post), not just using the Windows Add/Remove Programs protocol. (Adobe should be taken to task for this.)
3. Only then should hardware issues be considered because it takes a lot of time (and possibly money) to fault find hardware.
Re: contacting Adobe. As I mentioned I could write an essay on my efforts to contact Adobe about this issue. This isn't the place for my comments about it, but, in a nutshell, I would rank their customer service and technical support in a tie with Epson as the worst I have ever endured in my 20+ years of extensive computing.
My pair of pennies...
Your post count is 2 (as I write this) beginning July 17 - which indicates to me that you never asked for help in this forum (or you did so under another name)
As Steve said (and which you may not have known) this is not Adobe support, this is a place provided by Adobe for users to try and help each other
Yes... Adobe has less than good telephone support... a year or so ago that was even admitted to by the Adobe CEO, with discussion of that over in http://forums.adobe.com/community/general/forum_comments or maybe it was http://forums.adobe.com/community/general/forum_comments (been long enough ago that I don't really remember)
If you do have future questions... come back and ask and someone will try to help
Just as advance notice... don't come in saying "my file won't work... why?" without providing details... such as
This is not pointed at you, at least right now... this is just for the future
More information needed for someone to help http://forums.adobe.com/thread/416679
Some specific information that is needed...
Brand/Model Computer (or Brand/Model Motherboard if self-built)
Build a Configuration file http://forums.adobe.com/thread/877653?tstart=0
How much system memory you have installed, such as 2Gig or ???
Operating System version, such as Win7 64bit Pro... or whatevevr
-including your security settings, such as are YOU the Administrator
-and have you tried to RIGHT click the program Icon and then select
-the Run as Administrator option (for Windows, not sure about Mac)
Your Firewall settings and brand of anti-virus are you running
Brand/Model graphics card, sush as ATI "xxxx" or nVidia "xxxx"
-or the brand/model graphics chip if on the motherboard
-and the exact driver version for the above graphics card/chip
-and how much video memory you have on your graphics card
Brand/Model sound card, or sound "chip" name on Motherboard
-and the exact driver version for the above sound card/chip
Size(s) and configuration of your hard drive(s)... example below
-and how much FREE space is available on each drive (in Windows
-you RIGHT click the drive letter while using Windows Explorer
-and then select the Properties option to see used/free space)
Windows Indexing is BAD http://forums.adobe.com/thread/676303
While in Properties, be sure you have drive indexing set OFF
-for the drive, and for all directories, to improve performance
Some/Much of the above are available by going to the Windows
Control Panel and then the Hardware option (Win7 option name)
OR Control Panel--System--Hardware Tab--Device Manager for WinXP
And the EXACT type and size of file that is causing you problems
-for pictures, that includes the camera used and the pixel dimensions
Plus Video-Specific Information http://forums.adobe.com/thread/459220?tstart=0
Read Bill Hunt on a file type as WRAPPER http://forums.adobe.com/thread/440037?tstart=0
What is a CODEC... a Primer http://forums.adobe.com/thread/546811?tstart=0
What CODEC is INSIDE that file? http://forums.adobe.com/thread/440037?tstart=0
Report back with the codec details of your file, use the programs below
For PC http://www.headbands.com/gspot/ or http://mediainfo.sourceforge.net/en
For Mac http://mediainfo.massanti.com/
You are correct in that I didn't ask for help here. I surveyed the threads on this particular issue and quickly realized that the usual fault-finding solutions offered up were time-wasters. I knew that the problem was probably a buggy program, not my computer's specs or performance.
I went back to the problem and solved it myself in less time than it would have taken me to work through the standard solutions offered up time and time again here.
"Some specific information that is needed..."
<snip>
Here is my observation. This long list of information that advisors routinely ask for here before they can provide an answer is a big time waster. A random sampling -- not exhaustive, I'll concede -- of threads here revealed to me that even when people go away and then come back with this exhaustive list of information the solutions offered are usually standard.They usually require the poster to tweak something about their computer -- add RAM, de-frag, turn off virus scanning, turn off unnecessary processes, update drivers, etc. Some of these solutions are likely to cause more problems than they solve.
And these solutions rarely work. The original poster comes back and says that after following the solution offered up, the problem remains. (As is the case for one of the references in your message for example...)
That tells me the problem usually lies with the program itself and has nothing to do with hardware specs or software conflicts.
So my advice to the advisors here would be: Stop sending people away to generate an exhaustive list of their computer's specs and look to the program FIRST as the source of problems.
Once the program has been ruled out as the problem, THEN look to the user's computer specs and practices.
If your car wouldn't start, would you go away and produce an exhaustive description of your cars specs and how you use your car? Would you immediately arrange to take it to a garage and have the electrical system overhauled or the starting motor replaced? No, you would open the hood, check out your battery connections, maybe guess your battery was low if the starting motor didn't turn over.
Whether its cars or computers, the principle of efficient faultfinding is always the same. Start with the simplest/obvious things first, then work backwards to the more complex/less obvious things
This is my final post on the issue... I offer it up to those who would advise others here as a more efficient way to do business. It may not solve more problems but it will result in a lot less frustration for newcomers.
Cheers...
Had you carefully read most of the existing threads, a clear pattern should have been observed:
That is the pattern that I see, and see often. Still, and even when it takes 10 posts to get the basic info, most problems ARE fixed here. Most Bugs do get a workaround, even if it takes a bit more effort from the volunteers here.
If one is serious about getting PrE to work properly, and trust me, it does for the vast majority of users, then the best, first-step would be to post with all of the necessary details, and data, explaining in exact detail, what they are doing, and what is happening. You'd be surprised how many fail to even mention error message, or the exact syntax of error messages. This ARTICLE will be helpful in getting one started in the troubleshooting process. For troubleshooting, this ARTICLE starts with a general checklist of things to do, to get PrE working smoothly, and then works up to some serious troubleshooting, with the "degree of difficulty" advancing, as one works down the links listed.
All of that comes free of charge, and from a bunch of the volunteers here, one of whom, ME, has been using Adobe software to make a good living for almost 20 years. I also have owned nearly every program that Adobe sold, until the last few years, and have had to call for Adobe support once - for a licensing/upgrade issue with Illustrator 3.0, IIRC. Even that problem was solved in less than 5 mins., including hold-time. Not a bad track record for Adobe over almost two decades.
Good luck, and sorry that both Adobe, and the forum has let you down.
Hunt
That, to which you allude, has not been my experience at all, and I have read every thread on this forum, plus the old forum, prior to the Jive Software update - probably 10,000, but who's counting?
Now, in all of my years, I can only recall a few instances, where a solution was not found. A few were actual Bugs in the particular version of the program, and fixing them is way beyond our "pay grade." A few involved the attempt to use PrE in a controlled network environment, for which it is ill-suited. A few more were where a poster was trying to make extremely weak hardware work a version of the program, and material, that was just unsuitable, no matter how many times they were informed that one cannot edit AVCHD on a Pentium 1 machine.
Yes, there have been a few posters, who have found their solutions themselves. They did the physical troubleshooting, while we were hampered by doing virtual troubleshooting. Some have also found answers on other forums, like Elements Village. When this happens, we encourage them to post the details of their solution, so that we can learn to do our work better, can learn from their experiences, and can then help others most effectively.
Sorry that you take offense to our linear methods, but over the long haul, say 9,800 satisfied posters, the outcomes are great - they work. Sorry that we failed you.
Hunt
I also forgot Installation Issues. Those can be highly problematic for us, the mere users, as we seldom encounter them. Our only knowledge is built from reading of others' installation problems, and what worked for them, whether it was info found in an Adobe KB Article (we usually bookmark those), another forum, a suggestion from another user who has found a fix for same, or Adobe T/S (this is an area, where they excel).
Hunt
I think that it was Pinnacle Studio 5, that I started with, and worked up to Studio 11. The only version that was stable for me (stability can be because of the program, or the user's system *) was Studio 9.4.3. Studio 10 was a total disaster, and I never installed Studio 11 (sitting in the box, with all of the extra content). Instead, I went to PrPro Production Studio CS2, upgrading on a "special" from my other CS2 suite products. I never looked back.
I added PrE 4.0, a bit later, as it did some things with "consumer" material, that PrPro did not handle smoothly. I have never had any problem with either program, though have found that on the same system, PrPro handles very large Projects better, than does PrE, but I am talking VERY large Projects.
Hunt
* PrPro CS2 ran pefectly on the same workstation, that Studio 10 would not, so perhaps we could at least slightly discount "system" in that equation?
