Hello all,
I'm trying to extract information from a data signature to copy into another field.
I can access the data signatures in the document through the enumerate method:
var oSigs = xfa.signature.enumerate();
var iNum = oSigs.length;
for (var i=0; i < iNum; i++)
var oChild = oSigs.item(i);
// Display dialog box.
var iVerify = xfa.signature.verify(oChild,"1");
xfa.host.messageBox("Validity of signature integer value: " +
iVerify);
What I'd really like to do is specify an output SignatureInfo object in the "sign" operation so that I can extract the common name of the signer, date, certificate, etc.... through the signatureInfo() method.
Syntax is:
Reference_Syntax.sign( OBJECT param1, STRING param2, STRING param3 [, STRING param4 [, BOOLEAN param5 [, OBJECT param6 [, OBJECT
param7 ] ] ] ] ) where param7 "Represents an output SignatureInfo object containing the writable properties of the signature."
(From http://help.adobe.com/en_US/livecycle/9.0/designerHelp/001413.html#10...)
I have not found an example that includes any of the optional parameters.
Can anyone help with this?
Eanass
Total Likes
Eanass
I have created a simple sample that shows how to get the signatureInfo object (using JavaScript on an XFA based PDF form)
Sample script is as follows...
// Get particular info
var Info = event.target.getField("form1[0].Page1[0].SignatureField1[0]").signatureInfo()
// Some standard signatureInfo properties
app.alert("name = " + Info.name);
app.alert("reason = " + Info.reason);
app.alert("date = " + Info.date);
// Get the certificate; first (and only) one
var certificate = Info.certificates[0];
// Common name of the signer
app.alert("Signer Common Name = " + certificate.subjectCN);
I have also attached the sample file.
Hope this helps.
Steve
Total Likes
Thanks Steve but unfortunately my problem is still unresolved.
I'm trying to extract signature information from a data signature present in the document.
The reason I'm not using a signature field for signing is because the user is then prompted to save the file (locally). I need to replicate the behavior of signing a form in LC ES2 Workspace.
For this reason then, signing is implemented by a regular button, labelled "Sign & Submit", which triggers the click event of a "Submit" button (with sign submission) turned on.
When one opens the signed PDF, the data signatures are visible by opening Reader's Signature Panel, however no signature-like object appears in the body of the document.
xfa.signature.verify has a 4th parameter that, according to the documentation is "an output signatureInfo object containing the writable properties of the signature". http://help.adobe.com/en_US/livecycle/9.0/designerHelp/000976.html#1058250
If I can properly specify param4 thereby creating a corresponding signatureInfo object on the fly, then I can use the signatureInfo methods you referenced in your code sample.
Is this the correct approach? I do not have access to the LC Digital Signatures component.
Thanks.
Eanass
Total Likes
I'm continuing to investigate... hopefully I'll have something soon.
Regards
Steve
Total Likes
Thanks Steve.
Anything yet?
Total Likes
I am waiting on confirmation, but it appears that the ability to create a SignatureInfo object (for an XML data signature) when using the "sign" method with the optional parameter is broken.
Regards
Steve
Total Likes
