I was wondering what all operations defined by CMIS, are supported by CMIS connector that comes with Drive 2.1 esp. from Windows Explorer. When I right click in Windows Explorer, the Drive context menu gives only these options - Check out, Check in, Cancel check out, Show versions and Connect to. But the tech note for CMIS connector says that we can even rename a folder, create a new folder (and a few more operations) by selecting options in context menu. I believe those are not certainly the options provided by Windows but should be somewhere in Drive menu.
Some clarification would help greatly.
Thanks.
Hallo,
ich bin am 25. Juli 2011 wieder im Büro und werde Ihre Mail dann beantworten. In dringenden Fällen wenden Sie sich bitte an unser Büro unter +43 1 9902 804 oder office@metamagix.net.
Mit freundlichen Grüßen,
Martin Gilly.
Hello,
I will be in the office again on July 25th and will then take care of your mail. In urgent cases, please contact our office @ +43 1 9902 804 or office@metamagix.net.
Kind Regards,
Martin Gilly.
Hello,
For the "rename", "new folder" you mentioned, Adobe Drive indeed leverages the context menus provided Explorer in Windows and Finder in Mac OS. Besides those menus, Adobe Drive also supports "copy", "paste", "delete", etc context menus provided by OS.
Zhiqiang
Hallo,
Martin Gilly.
Hello,
Kind Regards,
Martin Gilly.
Hallo,
Martin Gilly.
Hello,
Kind Regards,
Martin Gilly.
Hello,
You want to use Adobe Drive + CMIS Connector to test your CMIS server, right? Because the operations in Adobe Drive, for example, rename operation in the context menu can uses serveral CMIS services, like getObject, moveObject, updateProperties, etc, you have to know exactly the CMIS services used by Adobe Drive for each operation.
Zhiqiang
That's correct. We are using Adobe Drive + CMIS connector to test our CMIS server.
As you said, for CMIS server side develoment wrt Drive, we need to know the the exact list of CMIS services used by Adobe Drive for each operation. I have been trying to figure that out by doing a kind of reverse engineering. I write stubs for a few CMIS services, then initiate an operation from Drive side and then see what methods are invoked. But this does not work all the time.
So if you can provide such mapping which enlists CMIS services needed to be implemented on our side for each operation that can be initiated from Drive, that would be really great.
