Slideshow export problem
Jul 24, 2011 10:21 AM
Hi all,
I created a slideshow with jpeg pics in LR3.  I added a startscreen and logo on each pic.  Slide show worked well in LR3.  I exported it in 1080p and it just showed a black screen in quicktime.  I tried it again in 720p and it worked fine.  Retried it in 1080p and again I just got a blackscreen. I use an intel mac and my software is up to date. Has anyone got any suggestions for a fix? Its making me crazy.  Thanks in advance.
John
    Jul 25, 2011 9:34 AM   in reply to jkg3232
    When you launch the 1080p file can you see the Play Control buttons, or just a black screen? I have a problem with Quicktime using 1080p files on Windows Vista and 7 systems, probably same as a Mac. With 1080p files the viewer window launches in a size bigger than my monitor resolution, so you can't reposition the window to access the Play Controls. Try launching the 1080p file Player Window and select on the menu bar 'View' > 'Half-Size.' You should be able to see the controls and play the 1080p moive. Then you can select 'View'  'Full-Screen,' or whatever size you want.
    You can also try the freeware VLC Media Player..here are the Mac versions:
    http://www.videolan.org/vlc/download-macosx.html
    VLC Media Player also plays H.264 AVCHD files, which Quicktime cannot do! I use PowerDirector 9 Ultra64 with LR Export JPEG slideshow files to create a 1080p H.264 AVC movie that I can burn to standard DVD (NOT Blu-ray) disk with up to 500 1080p images. It will playback on any Blu-ray player and is absolutely the best way to view and enjoy your photos in the comfort of your living room on a 1080p large screen TV.
    Just make sure you uncheck 'Stroke Border' in LR's Slideshow Module, because it causes softness in the images at even a 1px stroke border setting.
    Jul 25, 2011 12:50 PM   in reply to jkg3232
    Then you say:
    I wonder if I did something screwy when I converted the RAW files to JPEG.
    There is no need to create JPEGs if you are using RAW original camera images in Lightroom. You should be using your RAW images in the Slideshow module, which will apply develop settings automatically along with the slideshow elements to your 'Export to video.' If the JPEGs you created are too small, then perhaps LR is unable to create a working 1080p video. I tired creating a 1080p slideshow with small JPEGs (450x300) with no problem. The images were small but their full size (450x300) in the middle of the 1920x1080 slide image, but I'm on Windows. Mac OS may have different issues, which we have already seen with the stroke border in LR 3.4 – Windows is OK, Mac OS slideshow is soft!
    Try creating a 1080p video using the original RAW image files and see what happens.
    Jul 25, 2011 4:07 PM   in reply to jkg3232
    I also noticed you mentioned this:
    I have tried the 1080p conversion 3 times with no success although I could get it to work using just a few slides.
    When exporting a large number of files to a video slideshow and it can take quite a long time. My 2.8GHz i7-860 quad core system with 12GB memory takes about 25 sec. per slide for a 1080p video.Check the progress bar in the upper left-hand corner of Lightroom just under the toolbar. Don't close Lightroom and don't try to play the .mp4 video file until you get the 'Task Completed' confirmation and the progress bar goes away.
    Jul 26, 2011 6:27 AM   in reply to jkg3232
    Yeah, it takes about 7-8 hours to upload 628 pics.I set my computer to never power off for this and left it over night. I am so confused as to why it works on 720p and why it works on 1080p for short shows, but never for the long one.
    That's a lot of pictures for one slideshow! Maybe you are running into a 4GB size limit due to some system limitation. FAT32 has a 4GB file size limit, but Mac OS X file size limits starts at 2TB (2,000GB) for 10.0 up to virtually unlimited with 10.4 and later, so it would seem this is not the problem. The other possibility is that you are running out of memory resources (RAM) at some point during the video rendering process. How much memory do you have on your system and which Mac OS version are you running?
    You can try creating a 1080p video with 300 images and see what happens. That should reduce the file size and required memory resources by half.
    Jul 26, 2011 8:01 AM   in reply to jkg3232
    I purchased Power Director 9 Ultra64 to process 1080p video files from my Canon 5D MKII. I also use LR's export JPEG slideshow files with PD 9 to make Blu-ray player compatible H.264 AVCHD slideshow videos, which I burn to a standard DVD (not Blu-ray disk). I can produce very professional looking 1080p Blu-ray slideshow videos with 500 or more images (~45 min.) on a standard 4.7GB DVD. Unfortunately PD 9 only runs on Windows XP, Vista and 7....no Mac OS X version!
    Not all DVD or Blu-ray players can playback MP4 files, plus you can't add a navigation display with chapters or other indexing. How are you creating the DVD for your customer?
    Jul 26, 2011 12:39 PM   in reply to jkg3232
    As you have discovered Lightroom's slideshow module is limited in output capability. Your best bet is to purchase a good video editing application. This will allow you to edit and create both standard and Blu-ray player compatible videos with navigation, transitions, separate audio and video tracks, splicing and many other effects. Most all DSLR and many point and shoot cameras can also shoot 1080p video, so it's something to consider. Don't hold your breath for Adobe to turn Lightroom into a versatile video editor!
    I'm using Power Director 9 Ultra64 for Windows, which is only $89.99 right now and extremely capable for HD video editing and rendering. There must be something comparable for Mac OS X.
    Jul 28, 2011 8:01 AM   in reply to jkg3232
    Use a free software called DVD Flick to convert the mp4 to a DVD compatable program. Works great.
    Jul 28, 2011 9:15 AM   in reply to trshaner
    1080p video will require a BlueRay disk and player, DVD will just not cope with this.
    There are not hat many computer monitors that will benift from 1080p either and they will require a decent graphics card to really benefit. The monitor need to have a resolution of 1920 x 1080 and not many do. SD 720p at 1280 x 720 resolution is more than good enough for most computer screens and will be far better when converted to a DVD playable format.
    Rendering the amount of video you are talking about is a serious proposition and requires a powerful machine, preferably a Quad core processor and a decent graphics card. LR's export module will work if the machine is good enough, but it isn't the best way to create such a long video. Far better to use decent video software.
    Jul 28, 2011 9:47 AM   in reply to photo printer
    Nice freeware package, but the OP is on a Mac and DVD Flick is Windows only.
    Adobe Premiere Elements 9 ($69.99) is about the least expensive Mac OS X video editing package with true 1080p HD authoring capability, but it does have some issues. You can download the trial copy to see if it fits your HD authoring needs and runs well on your system.
    Some Adobe PE 9 examples here:
    http://www.youtube.com/watch?v=lIsFhn5Xqms
    Final Cut Pro X is probably better, but at 4x the price ($299). Either one will need plenty of processor power for 1080p HD video production!
    Jul 28, 2011 10:08 AM   in reply to Pete Marshall
    This is a totally incorrect statement. Please see my post in this thread, repeated here:
    You can produce 1080p Blu-ray player compatible movies using standard 4.7GB DVDs. It's not practical for actual movie footage due to short run time (<15 min.), but using LR 1080p slideshow export JPEG files you should be able to fit almost 500 pictures onto one standard DVD disk. At 5 seconds each that's about 42 minutes play time.
    The LR exported 1080p images played back on a large screen 1080p TV are stunningly sharp. Just don't use the stroke border (i.e. uncheck it) in LR's Slideshow module! It softens the images when used on Mac OS X platforms: http://forums.adobe.com/message/3092489#3092489
    Jan 9, 2012 5:24 PM   in reply to jkg3232
    Hi all.  I have just spent the better part of a weekend struggling with a 330 image show, both as RAW and JPEG images.  I managed to split it into pieces, but then found that even 1GB would not work.  After many hours, your result is a launched black screen with controls, that then play a long black movie!  I finally imported my images into iMovie and got a decent movie that will play and let one pause etc.
    The terrible thing is that a similar sized movie worked in my Lightroom version in the fall of 2010 (with RAW converted to JPEG images)!
