Hello I have a pdf document to be completed.
I put a barcode (PaperFormsBarcode) on the master page
My problem is that if I start to compile module the barcode is becomes invisible
I forced initialization method using the visibility presence but does not work
How can I fix?
In my view paper form barcode should not be placed on master page. Anyways how you are assigning value to paperform barcode ?
Are you making your form reader extended ? You can pass your pdf to me for solution. abhinavhot@gmail.com
We have a barcode in Masterpage of the module.
When we select from combo box in barcode becomes invisible.
Note: After lots of testing we came to know that the function presence used with different fields give this problem,which have no relationship with barcode.At the initialization of the barcode the code is written for it to be visible in all pages.
