Useing a database.
Jul 20, 2011 6:36 AM
I have decided to write an examination using a database as the method for storing the questions and answers.
Seeing as I didn’t want to re-invent the wheel I created my database in Access making sure I could read it in Authorware.
I used the show me ODBC.a7p file as the base for my Authorware file and the way I retrieve the data.
All works fantastic and I can retrieve anything I look for however I am having just one small problem I hope someone can help me with.
For example I use    DB_SQLString:= "SELECT [ans4] FROM [Table] WHERE [recordnumber]=" ^ MyRecNum    to retrieve Answer no 4
I would like to use    DB_SQLString:= "SELECT [ans1], [ans2], [ans3], [ans4] FROM [Table] WHERE [recordnumber]=" ^ MyRecNum   to retrieve all answers, but unfortunately I then Can’t separate the resulting string into the separate answer elements..
I also hope this make sense…
    Jul 20, 2011 10:01 PM   in reply to The Pc Doctor
    You can use a loop to run through the resulting string and use GetLine
    and a custom separator to pull each item...thing is, hopefully the
    returned string has something separating each answer.
    Can you post a sample DB_SQLString result?
    Erik
    Jul 21, 2011 9:22 PM   in reply to The Pc Doctor
    Can  you post a sample returned value for the DB_SQLString variable?
    Maybe the separator is there, just not easy to spot...?
    Jul 22, 2011 4:49 AM   in reply to The Pc Doctor
    Use Trace(yourvariablename) to see what your variable looks like in the
    Trace window. You can select the text in the Trace window and right-click it
    to select Copy.
    Steve
    Jul 25, 2011 3:31 AM   in reply to The Pc Doctor
    Your separator must be a RETURN character, which Authorware sees as "\r"
    You can use something like this to divide your data into a list, then
    it is easy to use
    Names:=[]
    repeat with i:= 1 to LineCount(yourdata)
        Names[i]:=GetLine(yourdata, i,i,"\r")
    end repeat
    Then when you need to get the 4th name, you use Names[4]
    Helps?
    Steve
    Jul 25, 2011 8:38 AM   in reply to The Pc Doctor
    Looking at my code .. try changing :=1 to =1 ... Remove the colon. Does it
    work now?
    Jul 25, 2011 9:06 AM   in reply to The Pc Doctor
    Scratch that, my first code was right. Just tested this:
    Jul 25, 2011 9:18 AM   in reply to The Pc Doctor
    Forgive me if I'm missing something but to me it seems the issue is basic. You guys are forgetting the separators. Between records it's a return and between fields it's a tab.
    DB_Data := ODBCExecute(handle, DB_SQLString)
    ResultLine = GetLine(DB_Data, 1) -- get first line (probably not necessary because there's only one
    Ans1 = GetLine(ResultLine, 1, 1, tab) -- get field 1
    Ans2 = GetLine(ResultLine, 2, 2, tab) -- get field 2
    Ans3 = GetLine(ResultLine, 3, 3, tab) -- get field 3
    Ans4 = GetLine(ResultLine, 4, 4, tab) -- get field 4
    This will get the items into the places you want. To take it a bit further you look at the code and notice that they're identical except for the number used for the Ans and the field. A common practice in this case is to set up a loop with a control variable that executes the same code over and over. Our problem is that we have four different variables and we can't cycle through the names to assign values. A "List" type variable is the best idea. We'll create a list type called Ans
    Ans = [] -- empty list
    Repeat with i := 1 to 4
       Ans[i] = GetLine(ResultLine, i, i, tab) -- get a single item into the spot in the list
    End Repeat
    i is the control variable and it increments by one each repeat of the loop. So it's 1 the first time and it does GetLine(ResultLine, 1, 1, tab) and puts that in Ans[1]. On the second loop it does GetLine(ResultLine, 2, 2, tab) and puts it into spot 2. So anywhere in your code where you're using Ans1 you could use Ans[1] instead. If you don't want to keep using ans1, 2, 3, and 4 you can use the first example without the loop and just assign the four items one on each line.
    Let's say just for argument's sake you don't want to use a list and you do want to use the four variables and a loop to load them. You might want to do that because you don't know in advance if you're going to have 4, 2, or 6 answers. I mentioned up above that we can't just cycle through the names. Actually we can, but it involves some tricky code. The EvalAssign function takes a piece of text and executes it as if it were programming code. Here is the example of the loop with i as the control variable again but this time it uses EvalAssign to build the variable name Ans1, Ans2, Ans3, and Ans4 on the fly.
    RepeatWith i := 1 to 4
        EvalAssign("Ans"^i^" = GetLine(ResultLine, "^i^", "^i^", tab)")
    End Repeat
    This is what we used to use before lists were made. This is a rather trivial example. In order to make it mroe real-world we'd also control the limit of 1 to 4 with some other variable to indicate how many distracters are being loaded.
    HTH,
    Mike
    Jul 25, 2011 9:29 AM   in reply to Michael V Baker
    Eek - EvalAssign("Ans"i" = GetLine(ResultLine, "i", "i", tab)")
    What's wrong with a nice List?
    Apparently looking fot Return separator didn;t work for him, though
    that surprises me ...
    Steve
    Jul 25, 2011 9:45 AM   in reply to Steve Howard, ACP
    I don't think it was a return separator the OP needed. It was the tab separator between fields of the return. Between each record will be a return, between the fields like [Ans1] and [Ans2] will be a tab char.
    Only thing wrong with using a list is if there's already 20,000 places where the code has Ans1, Ans2, etc on displays or other code.
    Mike
