I have no idea what I am doing, and trying to find help with an error message is rough. I am using dreamweaver 8 and trying to make a connection to mysql. When I http://www.kytravelers.com/Connections/MyConn.php I get the following error messages...where can I start to find out what I am doing wrong.
Warning: main(..MyConn.php) [function.main]: failed to open stream: No such file or directory in /nfs/c02/h05/mnt/17755/domains/kytravelers.com/html/Connections/MyConn .php on line 2
Fatal error: main() [function.require]: Failed opening required '..MyConn.php' (include_path='.:/usr/local/php-4.4.9-2/share/pear') in /nfs/c02/h05/mnt/17755/domains/kytravelers.com/html/Connections/MyConn .php on line 2
Scott
Im not that familiar with DW 8, I use DW CS4. But when I set up a Database connection there's a "Test" Button so I can check my page will be able to access the db - did you try this?
I've been where you are - totally baffled - and it can be very frustrating but the folks on this forum are really great at hanging in with you until the problem gets solved.
